Power Supply Connectors For Industrial Equipment
PX Series
Structure prevents mis-insertion
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Key
Shape of opening prevents reverse insertion
■Features
1. Power supply connector for high-current
Withstands voltage of 2200V AC max. and 10A/contact
(60A/6 pos.) of rating current.
d
e
b
o
2. Housing design prevents incorrect
insertion
t
d
Opening section is designed to prevent reverse
insertion and mating direction is easily checked.
Additionally, the opening section is keyed to prevent
misalignment of plugs in parallel applications.
d
e
h
c
S
3. Reduced Size
e
l
u
o
c
is
Contact point
(3 points)
Contact spring
guard section
d
e
u
n
i
t
n
Reliable contact structure
retainer
As this window is opened, contact
point can easily be checked.
Wall structure prevents
retainer deformation
16-18
Applicable Wire Size (AWG No.)
Since the retainer portion is lowered
by onestep, the possibility of spring
deformation is minimized even if the
lock is released.
When compared to conventional products, Hirose’s
plug is smaller in size by 65% and the receptacle is
smaller by 55%.
4. Reliable contact structure
➀Three point contact
➁Gold plated contact point (standard) with high-level
Label space
environmental resistance
➂Contact spring guard structure
➃Structure prevents retainer deformation
5. Easy Cable Assembly
➀Use of dedicated crimping tools will make harness
work easier.One tool crimps both AWG#16 and
AWG#18 wire.
➁Positive lock can be felt on contact insertion.
➂Release of contact lock can easily be performed with
dedicated jig, which facilitates the wiring modification
after assembly.
Avoid any short
between
adjacent
contacts
Two layer structure
enables high-density
mounting.
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2014.3 w
1
PX Series●Power Supply Connectors For Industrial Equipment
■Product Specifications
Operating temperature range
-55ç~+105ç
Voltage rating
600V AC
Current rating
10A
Ratings
Description
Specifications
1.Contact resistance
Requirements
10mø max.
100mA
2.Insulation resistance 1000Mø min.
500V DC
3.Withstanding voltage
No flashover or insulation breakdown.
2200V AC / 1 minute.
4.Durability
➀Contact resistance : 20mø max.
1000 cycles
➁No damage, cracks or looseness of parts
5.Vibration
➀No electrical discontinuity of 10μs or
Frequency:10 to 55Hz,single amplitude of 0.75mm,
2 hours,3axis
more.
➁Contact resistance : 20mø max.
Acceleration: 490m/s2 Duration: 11ms
➂No damage, cracks or looseness of parts Test at sine half-wave, 3 axes, bi-directional three times, respectively.
6.Shock
d
e
u
7.Temperature cycle
Temperature : -55/+5~+35/+85/+5~+35ç
10~15Minutes
Time
: -30/+10~+15/+30/+
➁Insulation resistance : 1000Mø min.
➂No damage, cracks or looseness of parts 5 cycles
8.Humidity
96 hours at 40±2ç and humidity of 90~95%
9.Salt spray
➀No corrosions
d
e
h
c
S
Metal fixture
d
e
b
o
t
d
Parts
Insulator
o
c
is
5% salt water for 48 hours
■Materials
Contacts
n
i
t
n
Material
e
l
u
Copper alloy
Finish
Gold plating
PBT (UL94V-0)
Copper alloy
Tin reflow plating
BComparison In Size With Conventional Equivalent
depth
3
4
5
6
depth
2
width
width
12
F
F
A
F
A
height
7
A
height
27.18
1
27.4
A
Depth
1
18.47
7
39.40
14.8
2
28.0
8
Width
Height
PX10
AF6WP
22.80
3
07.15
23.0
9
07.0
4
Height
Depth
10
44.94
5
34.2
Receptacle
11
Width
Plug
6
A company-made
12
Receptacle
PX
PX50-AF6S
Plug
(mm)
R
S
For volume ratio, plug is downsized to : nearly 65%; and
receptacle : nearly 55%.
2
1
6
■Receptacles
●6
pos.×2 row Type
Part No.
PX10-AF6WP(50)
d
e
h
c
S
t
d
e
l
u
BDimensions For Circuit Board
n
i
t
n
o
c
is
d
e
b
o
CL No.
236-0001-0-50
RoHS
YES
d
e
u
BPCB mounting pattern
Installation(For your reference) t=1.6~2.4
*Where t=1.6 (Setting value depends on thickness of boards.)
3
pos.×2 row Type
7
8
3
4
6
2
Part No.
PX10-AD4WP(50)
CL No.
236-0005-0-50
5
1
27.4
PX10
AD4WP
d
e
25.2
21.2
A
e
l
u
7.3
D
ed
terminal No.1
h
c
S
b
o
t
d
D
R
S
1
8
A
4
terminal No.4
4.1
5
terminal No.8
3.4
3.8
10.2
8.4
22.8
8
Installation(For 10.2
your reference)
t=1.6~2.4
terminal No.4
terminal No.1
terminal No.3
P= 3.8
terminal No.7
terminal No.2
11.4
terminal No.8
terminal No.5
5.
09
P=3.4
(6)
09
5.
(8)
3.7 π
6.7
.75
R0
board end
(through-hole)
connector position
22.8
* Where t=1.6 (Setting value depends on thickness of boards.)
4
6.7
11.4
terminal No.6
1.4
8-Ø -hole)
g
u h 1.5
thro
d
e
u
14.8
terminal No.5
n
i
t
n
o
c
is
Label space size 17.2∞10.2
RoHS
YES
4.5
●4
■Plug
CL No.
236-0002-2
RoHS
YES
n
i
t
n
o
c
is
●4-Position Type
terminal No.2
terminal No.1
21.5
23
e
l
u
D
ed
t
d
terminal No.3
terminal No.4
d
e
b
o
(This picture shows the state of cable insertion.)
h
c
S
Part No.
PX50-AD4S
CL No.
236-0006-3
RoHS
YES
d
e
u
A
1
2
3
4
PX50 --- AD4S
Part No.
PX50-AF6S
A
●6-Position Type
7
21.2
27.4
Label space size 11.6∞6.1
5
■Simple-Type Plug Holder Cover
●For
6-Position Type
Part No.
PX-6WS-CV
CL No.
236-0004-8
RoHS
YES
BInstallation status
➀
●6-Position Type
➁
➂
➃
d
e
h
c
S
d
e
u
BInstallation method
e
l
u
t
d
b
o
d
e
o
c
is
n
i
t
n
The holder cover is not a rugged support fixture but only meant for alignment of the plugs. When external force is imposed by
pulling of cables, etc. before mating, please bundle all cables together around the connector with union bands, etc.
6
■Crimp contact
Applicable wire size
Packaging
Part No.
CL No.
Quantity
Reel
PX50-SC-231
236-0003-5
5,000
Bag
PX50-SC-131
236-0008-9
200
16, 18
RoHS
YES
Please order by integral multiple of the packing volume.
■Tools
Type
Description
Automatic
Manual
Part No.
CL No.
Press unit
CM-105
901-0005-4
Applicator
AP105-PX50-3
901-2573-8
Hand tool (*)
HT104/PX50-3
250-0229-4
PX50-SC-TC
250-0233-1
Contact extraction tool
Applicable contacts
PX50-SC-231
PX50-SC-131
PX50-SC-*31
d
e
u
*For our manual crimping tools, we employ the rotate-replace procedure to use the crimper depending on wire size.
o
c
is
n
i
t
n
Applicable AWG size
d
e
h
c
S
t
d
b
o
e
l
u
d
e
Rotate to set the crimper such that applicable
AWG size fits the crimping section.
Note : Since manual crimping tool cannot provide fine adjustment of crimp height, please use the proper crimp height of auto crimper in
crimping of the wires other than specified ones
7
■Crimp Terminal Remoral Jig
Part No.
PX-50-SC-TC
CL No.
250-0233-1
RoHS
YES
When the crimp terminal remoral jig is inserted and pushed from the mating face of a connector as shown below, retainer lock of
the terminal will be released. Then please extract the cable. If the retainer is too lowered after extracting terminal, put it in a former
position and reinsert. Position and direction of the jig top to be inserted are as shown in the Figures below.
Be careful that any mistake will lead to the damage of terminal.
●How To
Extract Crimp Terminal
➀
n
i
t
n
➁
d
e
h
c
S
➂
d
e
b
o
t
d
e
l
u
o
c
is
d
e
u
➃
* Insert the jig top into the peak of convex section on terminal hole.
8
6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 3/2014. Contents are subject to change without notice for the purpose of improvements.
很抱歉,暂时无法提供与“PX50-SC-131(30)”相匹配的价格&库存,您可以联系我们找货
