HIF3B Series●Ribbon Cable connector Compliant with MIL Standard
HIF3B In-line Type Ribbon Cable Connector
■Features
1. In-line Type
This connector can be used for internal wiring cable to cable within
equipment.
2. Compatibility
This connector is compatible with HIF3A series as well as HIF3B
series socket.
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
3. Applicable Cable
The applicable cable is UL2651 AWG#28 flat cable
(7 pcs./6.127mm, jacket diameter: 0.8 to 1.0mm).
■Product Specifications
Operating Temperature Range : –55 to +85ç (Note 1) Storage Temperature Range : –10 to +60ç (Note 2)
Current rating : 1A
Rating
Storage Humidity Range : 40 to 70% (Note 2)
Voltage rating : 200V AC Operating Moisture Range : 40 to 80%
Item
Specification
Condition
1. Insulation Resistance
1000Mø min.
500V DC
2. Withstanding voltage
No flashover or insulation breakdown.
650V AC/1 minute
3. Contact Resistance
15mø max.
0.1A
4. Vibration
No electrical discontinuity of 1μs or more
Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions.
5. Humidity (Steady state) Insulation resistance: 1000Mø min.
6. Temperature Cycle
96 hours at temperature of 40ç and humidity of 90% to 95%
(-65ç : 30 minutes ➝ 15 to 35ç : 5 minutes max.
No damage, cracks, or parts looseness.
125ç : 30 minutes ➝ 15 to 35ç : 5 minutes max.) 5 cycles
7. Durability (Mating/un-mating) Contact resistance : 15mø max.
500 cycles
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and
Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation.
Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a
specific part number shown.
■Material / Finish
Part
Material
Finish
Remarks
Insulator
PBT
Black
UL94V-0
Plug Contact
Beryllium copper
Gold plated over nickel underplated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
HIF3BA - * P D - 2.54 R - MC
q
q Series Name
w
e
r
y
u
: HIF3BB (50, 60, 64 contacts only) e P : Plug
HIF3BD (10 contacts only)
r D : contact alignment : D : Double
HIF3BAE (60 contacts only)
t Contact Pitch
w Number of Contacts : 10, 16, 20, 26, 30, 34, 40, 50, 60
and 64
B30
t
: 2.54mm
y Connection type
: Ribbon cable
u MC
: Mold clamp
■Plug
Note 1, Note 2 : The number of polarizing slot and key installed positions changes according to products.
The 10 contact connector only has no position for polarizing key insulation.
Note 3 : The number indicated in parentheses are sizes for 60 and 64 contact connectors.
Unit : mm
Part No.
HRS No.
No. of Contacts
A
B
C
HIF3BDE-10PD-2.54R-MC(63) 611-0031-7 63
10
31.98 17.48 10.16
HIF3BAE-16PD-2.54R-MC(63) 611-0032-0 63
16
39.60 25.10 17.78
HIF3BAE-20PD-2.54R-MC(63) 611-0033-2 63
44.68 30.18 22.86
HIF3BAE-26PD-2.54R-MC(63) 611-0034-5 63
26
52.30 37.80 30.48
HIF3BAE-30PD-2.54R-MC(63) 611-0035-8 63
30
57.38 42.88 35.56
HIF3BAE-34PD-2.54R-MC(63) 611-0036-0 63
34
62.46 47.96 40.64
HIF3BAE-40PD-2.54R-MC(63) 611-0037-3 63
40
70.08 55.58 48.26
HIF3BAE-50PD-2.54R-MC(63) 611-0038-6 63
50
HIF3BBE-50PD-2.54R-MC(63) 611-0041-0 63
50
HIF3BAE-60PD-2.54R-MC(63) 611-0039-9 63
60
HIF3BBE-60PD-2.54R-MC(63) 611-0042-3 63
60
HIF3BAE-64PD-2.54R-MC(63) 611-0040-8 63
64
HIF3BBE-64PD-2.54R-MC(63) 611-0045-1 63
64
D
28.14
MAX51.1
35.74
MAX58.7
40.84
MAX63.8
48.44
MAX71.4
53.54
MAX76.5
58.64
MAX81.6
66.24
MAX89.2
E
F
G
H
29.50 37.75
34.58 42.83
42.20 50.45
47.28 55.53
One at center
33.2
52.36 60.61 29.2
59.98 68.23
YES
One on right and left sides, resp.
72.68 80.93
One at center
MAX101.9
91.64
95.48 80.98 73.66
85.38 93.63
35.2
MAX114.6
96.74
90.46 98.71 29.2 35.2
100.56 86.06 78.74
MAX119.7
RoHS
21.88 30.13
78.94
82.78 68.28 60.96
Polarizing slot
One at center
One at center
*D size
locking size
unlocking size
B31
BConnection Procedures
Note1 : Cable length tolerance Less than 500 +10
+00 (mm)
More than 500 +3
+0 (mm)
Type AO
Type BO
Type CO
Type DO
B32
Note2 : When a cable such as a twist cable
or a slit (like a roller screen) cable is
used, the cable pitch will change
according to cable manufacturers.
If connection failure has occurred,
please contact Hirose sales.
HIF3C-50D-2.54C(03) 价格&库存
很抱歉,暂时无法提供与“HIF3C-50D-2.54C(03)”相匹配的价格&库存,您可以联系我们找货
