HIF3C-50D-2.54C(03)
HIF3C-50D-2.54C(03)
    HRS(广濑)
    CONN HOUSING 50POS 2.54MM DUAL
HIF3C-50D-2.54C(03) 数据手册
HIF3B Series●Ribbon Cable connector Compliant with MIL Standard HIF3B In-line Type Ribbon Cable Connector ■Features 1. In-line Type This connector can be used for internal wiring cable to cable within equipment. 2. Compatibility This connector is compatible with HIF3A series as well as HIF3B series socket. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3. Applicable Cable The applicable cable is UL2651 AWG#28 flat cable (7 pcs./6.127mm, jacket diameter: 0.8 to 1.0mm). ■Product Specifications Operating Temperature Range : –55 to +85ç (Note 1) Storage Temperature Range : –10 to +60ç (Note 2) Current rating : 1A Rating Storage Humidity Range : 40 to 70% (Note 2) Voltage rating : 200V AC Operating Moisture Range : 40 to 80% Item Specification Condition 1. Insulation Resistance 1000Mø min. 500V DC 2. Withstanding voltage No flashover or insulation breakdown. 650V AC/1 minute 3. Contact Resistance 15mø max. 0.1A 4. Vibration No electrical discontinuity of 1μs or more Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 directions. 5. Humidity (Steady state) Insulation resistance: 1000Mø min. 6. Temperature Cycle 96 hours at temperature of 40ç and humidity of 90% to 95% (-65ç : 30 minutes ➝ 15 to 35ç : 5 minutes max. No damage, cracks, or parts looseness. 125ç : 30 minutes ➝ 15 to 35ç : 5 minutes max.) 5 cycles 7. Durability (Mating/un-mating) Contact resistance : 15mø max. 500 cycles Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Information contained in this catalog represents general requirements for this Series. Contact us for the drawings and specifications for a specific part number shown. ■Material / Finish Part Material Finish Remarks Insulator PBT Black UL94V-0 Plug Contact Beryllium copper Gold plated over nickel underplated –––––– ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. HIF3BA - * P D - 2.54 R - MC q q Series Name w e r y u : HIF3BB (50, 60, 64 contacts only) e P : Plug HIF3BD (10 contacts only) r D : contact alignment : D : Double HIF3BAE (60 contacts only) t Contact Pitch w Number of Contacts : 10, 16, 20, 26, 30, 34, 40, 50, 60 and 64 B30 t : 2.54mm y Connection type : Ribbon cable u MC : Mold clamp HIF3B Series●Ribbon Cable connector Compliant with MIL Standard Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ■Plug Note 1, Note 2 : The number of polarizing slot and key installed positions changes according to products. The 10 contact connector only has no position for polarizing key insulation. Note 3 : The number indicated in parentheses are sizes for 60 and 64 contact connectors. Unit : mm Part No. HRS No. No. of Contacts A B C HIF3BDE-10PD-2.54R-MC(63) 611-0031-7 63 10 31.98 17.48 10.16 HIF3BAE-16PD-2.54R-MC(63) 611-0032-0 63 16 39.60 25.10 17.78 HIF3BAE-20PD-2.54R-MC(63) 611-0033-2 63 20 44.68 30.18 22.86 HIF3BAE-26PD-2.54R-MC(63) 611-0034-5 63 26 52.30 37.80 30.48 HIF3BAE-30PD-2.54R-MC(63) 611-0035-8 63 30 57.38 42.88 35.56 HIF3BAE-34PD-2.54R-MC(63) 611-0036-0 63 34 62.46 47.96 40.64 HIF3BAE-40PD-2.54R-MC(63) 611-0037-3 63 40 70.08 55.58 48.26 HIF3BAE-50PD-2.54R-MC(63) 611-0038-6 63 50 HIF3BBE-50PD-2.54R-MC(63) 611-0041-0 63 50 HIF3BAE-60PD-2.54R-MC(63) 611-0039-9 63 60 HIF3BBE-60PD-2.54R-MC(63) 611-0042-3 63 60 HIF3BAE-64PD-2.54R-MC(63) 611-0040-8 63 64 HIF3BBE-64PD-2.54R-MC(63) 611-0045-1 63 64 D 28.14 MAX51.1 35.74 MAX58.7 40.84 MAX63.8 48.44 MAX71.4 53.54 MAX76.5 58.64 MAX81.6 66.24 MAX89.2 E F G H 29.50 37.75 34.58 42.83 42.20 50.45 47.28 55.53 One at center 33.2 52.36 60.61 29.2 59.98 68.23 YES One on right and left sides, resp. 72.68 80.93 One at center MAX101.9 91.64 95.48 80.98 73.66 85.38 93.63 35.2 MAX114.6 96.74 90.46 98.71 29.2 35.2 100.56 86.06 78.74 MAX119.7 RoHS 21.88 30.13 78.94 82.78 68.28 60.96 Polarizing slot One on right and left sides, resp. One at center One on right and left sides, resp. One at center *D size locking size unlocking size B31 HIF3B Series●Ribbon Cable connector Compliant with MIL Standard BConnection Procedures Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Note1 : Cable length tolerance Less than 500 +10 +00 (mm) More than 500 +3 +0 (mm) Type AO Type BO Type CO Type DO B32 Note2 : When a cable such as a twist cable or a slit (like a roller screen) cable is used, the cable pitch will change according to cable manufacturers. If connection failure has occurred, please contact Hirose sales.
HIF3C-50D-2.54C(03) 价格&库存
很抱歉,暂时无法提供与“HIF3C-50D-2.54C(03)”相匹配的价格&库存,您可以联系我们找货
