P006-006-13LA
P006-006-13LA
    TRIPPLITE
    CABLEIECTONEMA6'
P006-006-13LA 数据手册
1000 Eaton Boulevard Cleveland, OH 44122 United States Computer Power Cord, NEMA 5-15P to LeftAngle C13 - 10A, 125V, 18 AWG, 6 ft. (1.83 m), Black Highlights ● Left-angle C13 plug allows easier connection in confined or hard-to-reach spaces ● Recommended for powering computers, printers and other compatible peripherals ● Adds 6-ft. (1.83 m) to your existing power connection to provide flexibility in placing devices ● Ideal replacement for worn-out or missing computer power cord ● NEMA 5-15P plug connects to AC power; C13 plug connects to device's C14 inlet MODEL NUMBER: P006-006-13LA Applications ● Connect devices like computers, monitors, scanners and printers to a power outlet up to 6-ft. (1.83 m) away in your home office, work space or dorm room ● Extend an existing power connection up to 6-ft. (1.83 m) to more easily place a device or reach a power source away from your workstation ● Provide a high-quality replacement for a worn-out or missing power cord ● Power a device located in a hard-to-access area behind a desk or flush against a wall Computer power cord with left-angled C13 plug allows connection of a PC, monitor or printer in a tight space or at an awkward angle. Features Desktop Computer Power Cord Connects PCs, Printers, Monitors and Other EquipmentThis desktop computer power cord is designed for computers, monitors, scanners, printers and other compatible peripherals. It features a left-angled C13 end for connecting to a device and a 5-15P plug for connecting to an AC power source. The 6-ft. (1.83 m) length allows you some flexibility in placing equipment with respect to the power outlet. Left-Angle C13 Plug Makes Connecting in Tight Spaces EasierThe angled C13 connector makes installations easier in confined spaces, such as the back of a rack enclosure cabinet. When plugged in, the left-angled plug guides the computer power supply cable parallel to your peripheral, allowing you to push the device up against a wall or hide it behind a desk to maximize space. Specifications OVERVIEW UPC Code 037332156464 Device Compatibility Computer; Monitor/HDTV; Printer; Server; UPS; PDU Country/Region North America INPUT Maximum Input Amps 10 Voltage Compatibility (VAC) 125 1/3 Package Includes ● P006-006-13LA NEMA 5-15P to Left-Angle C13 Power Extension Cable, 6-ft. (1.83 m), Black 1000 Eaton Boulevard Cleveland, OH 44122 United States PHYSICAL Plug Color Black Cable Jacket Color Black Cable Jacket Material PVC Cable Jacket Rating VW-1 Power Cord Jacket Type SJT Cable Outer Diameter (OD) 7.8mm Number of Conductors 3 Wire Gauge (AWG) 18 Wire Gauge (OD - mm²) 0.82 Cable Length (ft.) 6 Cable Length (m) 1.83 Shipping Dimensions (hwd / in.) 10.00 x 7.10 x 0.50 Shipping Dimensions (hwd / cm) 25.40 x 18.03 x 1.27 Shipping Weight (lbs.) 0.51 Shipping Weight (kg) 0.23 ENVIRONMENTAL Operating Temperature Range -4 F TO 140 F (-20 C TO 60 C) Storage Temperature Range -4 F TO 140 F (-20 C TO 60 C) Operating Humidity Range 10 TO 65% RH Storage Humidity Range 10 TO 65% RH CONNECTIONS Side A - Connector 1 NEMA 5-15P Side B - Connector 1 IEC-320-C13 - LEFT ANGLE FEATURES & SPECIFICATIONS High Voltage No Locking Plug No Antibacterial No Angled Plug Yes Coiled Power Cord No STANDARDS & COMPLIANCE Product Certifications cUL Listed; UL Listed 2/3 1000 Eaton Boulevard Cleveland, OH 44122 United States Product Compliance RoHS WARRANTY & SUPPORT Product Warranty Period (Worldwide) Lifetime limited warranty © 2022 Eaton. All Rights Reserved. Eaton is a registered trademark. All other trademarks are the property of their respective owners. 3/3
P006-006-13LA 价格&库存
很抱歉,暂时无法提供与“P006-006-13LA”相匹配的价格&库存,您可以联系我们找货
