FX20-40S-0.5SV10
FX20-40S-0.5SV10
    HRS(广濑)
FX20-40S-0.5SV10 数据手册
0.5mm Pitch, Board to Board Connector with Floating Structure FX20 Series X direction Y direction Floating range :0.6mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Floating range :0.6∼0.8mm ■Features Enlarged view of the contact area 1. 0.5mm pitch 2. Connection type: Right angle / Vertical 3. Pin counts : 20, 40, 60, 80, 100, 120 and 140 4. Floating range : ± 0.6 to 0.8mm in the X direction and ± 0.6mm in the Y direction 5. A double beam contact structure produces a highly reliable contact (Refer to the figure on the right) 6. Current capacity : 0.5A per pin 7. Effective mating length of 1.5mm Receptacle-side contact This connector utilizes a 1.5mm effective mating length for signal contacts and provides a sufficient margin for its mating stroke. 8. No conductive trace surface is not specified 9. Contains the vacuum pick up area needed to allow automatic mounting 10. Self-aligning and self-guiding structure Header-side contact Built-in guide posts enable self-alignment and ensure a secure connection ■Stacking height chart Header Receptacle FX20-**S-0.5SV FX20-**P-0.5SV15 FX20-**P-0.5SV20 h=15mm h=20mm h=25mm h=30mm FX20-**S-0.5SV10 FX20-**S-0.5SH Floating range Right angle connection Right angle connection X direction ±0.6mm ±0.8mm Y direction ±0.6mm ±0.6mm FX20-**S-0.5SV10 FX20-**S-0.5SH FX20-**S-0.5SV h=15mm FX20-**P-0.5SV15 FX20-**P-0.5SV20 h=20mm h=25mm h=30mm Right angle connection In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. Right angle connection 2018.7③ 1 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure ■Product Specifications Ratings Rated current 0.5A Rated voltage AC 50V Item Operating temperature range : -55 to 85°C (Note 1) Storage temperature range : -10 to 60°C (Note 2) Standards Condition 1. Contact resistance 70mø max. 100mA(DC or 1000Hz) 2. Insulation resistance 100Mø min. 100V DC. 3. Voltage proof No flashover or breakdown. Contact resistance : Variation from initial 4. Mechanical operation value 20mø or less. No damage, crack and looseness of parts. 5. Vibration Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No electrical discontinuity of 1µs. No damage, crack and looseness of parts. 6. Shock 7. Damp heat (Steady state) 8. Rapid change of temperature Contact resistance : Variation from initial value 20mø or less. Insulation resistance : 100Mø min. No damage, crack and looseness of parts. 150V AC for 1 min. 50 times insertions and extractions. Frequency : 10 to 55 to 10Hz, approx 5 min Single amplitude : 0.75mm, 10 cycles for 3 axial directions. 2 490m/s , duration of pulse 11ms at 3 times for 3 both axial directions. Exposed at 40±2°C, 90~95%, 96h. Temperature : -55 ➝ +85°C Time : 30 ➝ 30 min. Under 5 cycles(relocation time to chamber : within 2~3min) Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" here refers to products stored for a long period prior to board mounting and use. ■Materials / Finish Part Material Header Receptacle Header Receptacle Insulator Contacts Metal Fitting Finish PA Black LCP Black Copper alloy Contact area: Gold plated Phosphor bronze Mounting area: Gold plated Brass Tin plated ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Straight receptacle FX20 − 60 S − 0.5 SV 10 ❶ ❷ ❸ ❹ ❺ ❻ ●Straight header FX20 − 60 P − 0.5 SV 15 ❶ ❷ ❸ ❹ ❺ ❻ ●Right angle receptacle FX20 − 60 S − 0.5 SH ❶ ❷ ❶ Series name ❸ ❹ ❺ : FX20 ❷ Number (contacts) : 2 ❸ Connector type S : Receptacle type P : Header type ❹ Contact pitch : 0.5mm ❺ Housing configuration : SV : Straight type ❻ Stacking height type Mating height [mm] = Height of the receptacle-side + Height of the header-side SH : Right angle type UL standard UL94V-0 UL94V-0 ------------------------------------------- FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure ●Straight receptacle [ FX20-**S-0.5SV ] A±0.3 B±0.3 2.7±0.2 6.8±0.3 Contact No. G Contact No. F C±0.2 P=0.5±0.15 2 1. C 8.3±0.3 D±0.3 (1.1) Polarization mark (1.1) 6.5±0.25 Unit : mm HRS No. No. of contacts A B C D E F G FX20-20S-0.5SV Part No. 570-1114-7 20 17.4 16.4 4.5 12.65 10 11 20 FX20-40S-0.5SV 570-1101-5 40 22.4 21.4 9.5 17.65 20 21 40 FX20-60S-0.5SV 570-1102-8 60 27.4 26.4 14.5 22.65 30 31 60 FX20-80S-0.5SV 570-1103-0 80 32.4 31.4 19.5 27.65 40 41 80 FX20-100S-0.5SV 570-1104-3 100 37.4 36.4 24.5 32.65 50 51 100 FX20-120S-0.5SV 570-1105-6 120 42.4 41.4 29.5 37.65 60 61 120 FX20-140S-0.5SV 570-1106-9 140 47.4 46.4 34.5 42.65 70 71 140 A±0.3 B±0.3 C±0.2 Contact No. G 6.8±0.3 2.7±0.2 [ FX20-**S-0.5SV10 ] Contact No. F P=0.5±0.15 2 1. C Contact No. E Contact No. 1 t=0.3±0.05×w=0.15±0.03 6±0.3 D±0.3 18.3±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Contact No. 1 t=0.2±0.05×w=0.15±0.03 4.5±0.3 Contact No. E (1.1) Polarization mark (1.1) 6.5±0.25 Unit : mm Part No. HRS No. No. of contacts A B C D E F G FX20-20S-0.5SV10 570-1115-0 20 17.4 16.4 4.5 12.65 FX20-40S-0.5SV10 570-1107-1 40 22.4 21.4 9.5 17.65 10 11 20 20 21 40 FX20-60S-0.5SV10 570-1108-4 60 27.4 26.4 14.5 FX20-80S-0.5SV10 570-1109-7 80 32.4 31.4 19.5 22.65 30 31 60 27.65 40 41 80 FX20-100S-0.5SV10 570-1110-6 100 37.4 36.4 FX20-120S-0.5SV10 570-1111-9 120 42.4 41.4 24.5 32.65 50 51 100 29.5 37.65 60 61 120 FX20-140S-0.5SV10 570-1112-1 140 47.4 46.4 34.5 42.65 70 71 140 3 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure Contact No. F A±0.3 B±0.3 Contact No. G C±0.2 P=0.5±0.15 Contact No. E C 1 [ FX20-**P-0.5SV15 ] 8.7±0.2 2.7±0.2 ●Straight header Contact No. 1 t=0.15±0.03×w=0.2±0.05 D±0.15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13.2±0.3 4.8±0.15 Polarization mark (0.85) 6±0.3 (0.85) 9.5±0.25 Unit : mm Part No. HRS No. No. of contacts A B C D E F G FX20-20P-0.5SV15 570-1014-2 20 17.4 16.4 4.5 10.4 10 11 20 FX20-40P-0.5SV15 570-1001-0 40 22.4 21.4 9.5 15.4 20 21 40 FX20-60P-0.5SV15 570-1002-3 60 27.4 26.4 14.5 20.4 30 31 60 570-1003-6 80 32.4 31.4 19.5 25.4 40 41 80 FX20-100P-0.5SV15 570-1004-9 100 37.4 36.4 24.5 30.4 50 51 100 FX20-120P-0.5SV15 570-1005-1 120 42.4 41.4 29.5 35.4 60 61 120 FX20-140P-0.5SV15 570-1006-4 140 47.4 46.4 34.5 40.4 70 71 140 Contact No.F A±0.3 B±0.3 C±0.2 P=0.5±0.15 Contact No.G Contact No.E C 1 [ FX20-**P-0.5SV20 ] 8.7±0.2 2.7±0.2 FX20-80P-0.5SV15 Contact No. 1 t=0.15±0.03×w=0.2±0.05 D±0.15 18.2±0.3 11±0.3 4.8±0.15 (0.85) Polarization mark (0.85) 9.5±0.25 Unit : mm Part No. 4 HRS No. No. of contacts A B C D E F G FX20-20P-0.5SV20 570-1015-5 20 17.4 16.4 4.5 10.4 10 11 20 FX20-40P-0.5SV20 570-1007-7 40 22.4 21.4 9.5 15.4 20 21 40 FX20-60P-0.5SV20 570-1008-0 60 27.4 26.4 14.5 20.4 30 31 60 FX20-80P-0.5SV20 570-1009-2 80 32.4 31.4 19.5 25.4 40 41 80 FX20-100P-0.5SV20 570-1010-1 100 37.4 36.4 24.5 30.4 50 51 100 FX20-120P-0.5SV20 570-1011-4 120 42.4 41.4 29.5 35.4 60 61 120 FX20-140P-0.5SV20 570-1012-7 140 47.4 46.4 34.5 40.4 70 71 140 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure ●Right angle receptacle [ FX20-**S-0.5SH ] A±0.2 P=0.5±0.15 W=0.15±0.03 (5.3) (2) 2.7±0.1 (2) 9.5±0.2 10.4±0.3 Vacuum pick up area Polarization mark (5) 7.15±0.3 6.55±0.3 2.3±0.3 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B±0.2 9.45±0.3 (0.2) C±0.3 D±0.2 P=0.5±0.15 W=0.15±0.03 Contact No. F Contact No. G Contact No. E Contact No. 1 Unit : mm Part No. HRS No. No. of contacts A B C D E F G FX20-20S-0.5SH 570-1611-1 20 4.5 16.4 17.4 4.5 10 11 20 FX20-40S-0.5SH 570-1601-8 40 9.5 21.4 22.4 9.5 20 21 40 FX20-60S-0.5SH 570-1602-0 60 14.5 26.4 27.4 14.5 30 31 60 FX20-80S-0.5SH 570-1603-3 80 19.5 31.4 32.4 19.5 40 41 80 FX20-100S-0.5SH 570-1604-6 100 24.5 36.4 37.4 24.5 50 51 100 FX20-120S-0.5SH 570-1605-9 120 29.5 41.4 42.4 29.5 60 61 120 FX20-140S-0.5SH 570-1606-1 140 34.5 46.4 47.4 34.5 70 71 140 5 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure BRecommended PCB layout (PCB thickness: t= 1.6 mm/Stencil thickness: t= 0.15 mm, t= 0.12 mm) 0 3.2 -0.1 ●Straight receptacle 3.2±0.05 FX20-**S-0.5SV FX20-**S-0.5SV10 7.1 +0.1 0 A±0.03 P=0.5±0.03 Unit: mm SMT pad: 0.3 ±0.03 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Stencil (t= 0.15): 0.25 ±0.03 Stencil (t= 0.12): 0.3 ±0.03 B±0.05 3±0.05 3±0.05 ** A B 20 4.5 13.46 40 9.5 18.46 60 14.5 23.46 80 19.5 28.46 100 24.5 33.46 120 29.5 38.46 140 34.5 43.46 ** A 20 4.5 ●Straight header FX20-**P-0.5SV15 FX20-**P-0.5SV20 3.2±0.05 A±0.03 10.1 +0.1 0 0 6.5 -0.1 P=0.5±0.03 SMT pad: 0.3 ±0.03 Stencil (t= 0.15): 0.25 ±0.03 Stencil (t= 0.12): 0.3 ±0.03 B±0.05 3±0.05 3±0.05 Unit: mm B 13.46 40 9.5 18.46 60 14.5 23.46 80 19.5 28.46 100 24.5 33.46 120 29.5 38.46 140 34.5 43.46 ●Right angle receptacle FX20-**S-0.5SH B±0.05 3±0.05 PCB edge (Mating side) 6 6.85±0.05 Contact No. (n/2+1) Contact No. (n/2) Contact No. n SMT pad: 0.3 ±0.03 Stencil (t= 0.15): 0.25 ±0.03 Stencil (t= 0.12): 0.3 ±0.03 +0.1 Contact No.1 1max 3.2±0.05 P=0.5±0.03 10.05±0.05 1.7  0 +0.1 A±0.03 1.7  0 3±0.05 Unit: mm ** A B 20 4.5 13.46 40 9.5 18.46 60 14.5 23.46 80 19.5 28.46 100 24.5 33.46 120 29.5 38.46 140 34.5 43.46 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure BTray package drawing ●Straight receptacle ((#,* E27 Part No. FX20-20S-0.5SV FX20-20S-0.5SV10 FX20-40S-0.5SV FX20-40S-0.5SV10 FX20-60S-0.5SV FX20-60S-0.5SV10 FX20-80S-0.5SV FX20-80S-0.5SV10 FX20-100S-0.5SV FX20-100S-0.5SV10 FX20-120S-0.5SV FX20-120S-0.5SV10 FX20-140S-0.5SV FX20-140S-0.5SV10 E2&,#* ''* &*,#* 8 6 Quantity A B C 90 42.5 30 240 80 40 35 245 70 50 60 50 45 225 60 47.5 46 230 50 57.5 52.5 210 50 51.5 55.5 222 37.5 225 ('* 8 6 Unit: mm Part No. FX20-20P-0.5SV15 FX20-20P-0.5SV20 FX20-40P-0.5SV15 FX20-40P-0.5SV20 FX20-60P-0.5SV15 FX20-60P-0.5SV20 FX20-80P-0.5SV15 FX20-80P-0.5SV20 FX20-100P-0.5SV15 FX20-100P-0.5SV20 FX20-120P-0.5SV15 FX20-120P-0.5SV20 FX20-140P-0.5SV15 FX20-140P-0.5SV20 E27 E2&,#* ''* &*,#* ((#,* ●Straight header Quantity A B C 90 42.5 30 240 80 40 35 245 70 50 60 50 45 225 60 47.5 46 230 50 57.5 52.5 210 50 51.5 55.5 222 37.5 225 ●Right angle receptacle (325) (C) (A) (P=17.5) (33.8) (P=B) (225) (157.5) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit: mm ('* Unit: mm Part No. FX20- 20S-0.5SH FX20- 40S-0.5SH FX20- 60S-0.5SH FX20- 80S-0.5SH FX20-100S-0.5SH FX20-120S-0.5SH FX20-140S-0.5SH Quantity 90 80 70 60 60 50 50 A B C 42.5 30 240 40 35 245 50 37.5 225 50 45 225 47.5 46 230 57.5 52.5 210 51.5 55.5 222 7 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure BRecommended Solder ●This temperature profile is based on the setting conditions shown below and is for reference only. For individual applications, the temperature profile may vary in accordance with the conditions. Please confirm the profile before mounting. (Peak temperature : MAX250℃) 260 240 220℃ 220 200℃ Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature (℃) 200 180 160 150℃ 140 0 (90 to 120 seconds) Preheating time(150 to 200℃) Test PCB dimensions : 110 × 50 × 1.6mm Material : Glass epoxy Solder composition : Sn- 3 Ag- 0.5 Cu Flux content : 11 wt% Stencil thickness : 0.12mm, 0.15mm Reflow count : 2 times Reflow area : 220°C or more, 60 sec max. Preheating unit : 150 to 200°C, 90 to 120 sec * The temperature profile may vary due to external conditions such as the type of cream solder, manufacturer, and board size. Please contact the solder manufacturer for their specifications. (within 60 seconds) Soldering time (220℃ or more) BCleaning condition ●Organic solvent-based cleaning Solvent type IPA (Isopropyl alcohol) Room temperature cleaning Heated cleaning ○ ○ ●Water based cleaning When using water based cleaning agents (including terpene, and alkali saponifiers), pay special attention to how the cleaning agent will react to specific metals and plastics before selecting one of them. Various cleaning agent manufacturers publish reaction tables for their cleaning agents. Do not leave connectors with moisture remaining on them. ●Caution when washing The electrical performance may deteriorate if the flux or cleaning detergent is left on the connector after the cleaning. Check thoroughly to ensure that there is no residue left on any of the surfaces. BPrecautions ●Tolerance clearance on mating The effective contact length of each product is 1.5mm. In the mated condition, the header and receptacle shall have a clearance or gap between them of no more than 1mm. Receptacle-side connector Header-side connector 8 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure ●Using excessive force when mating these connectors may result in damage and alter their performance. Although they are designed with a prevention mechanism to resist incorrect insertion, do not forcibly mate them. Before mating the connector, confirm the connector polarity as shown below. C surface Δ Mark (polarization mark) C surface Receptacle-side connector * Mate them so that both C surfaces or both Δ marks on the connector outer surface are aligned. Header-side connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C surface Δ Mark (polarization mark) C surface ●Provide another form of support to the PCB. This connector was not designed to be the main form of support. ●Mating and un-mating with excessive prying force or rotating force may result in damage to the connector or contact failure. If you have no choice but to mate and un-mate with prying force based on your usage environment, use a point as a pivot shown by Δ mark in the figure below when you apply those forces. The point shall be a certain distance away from the connector end and has equal or higher height of the mating height. (Please refer to the guideline for details including the relationship between the pivot position and the connector position, and usage examples.) Minimum of 25 mm Minimum of 30 mm Stacking height or higher Stacking height or higher ●This connector has a floating structure, but the floating range may vary depending on the height of connector on the header side (which has a floating mechanism). Y direction (transverse direction) Y direction (transverse direction) X direction (longitudinal direction) X direction (longitudinal direction) Y direction (transverse direction) X direction (longitudinal direction) h=15mm Header-side FX20-**P-0.5SV15 FX20-**P-0.5SV20 FX20-**P-0.5SV15 FX20-**P-0.5SV20 FX20-**P-0.5SV15 FX20-**P-0.5SV20 h=30mm Receptacle-side FX20-**S-0.5SV FX20-**S-0.5SV10 FX20-**S-0.5SH Stack height 15mm 20mm 25mm 30mm ----------------------------- Right angle connection Floating range X direction (longitudinal direction) Y direction (transverse direction) 0.6mm 0.8mm 0.6mm 0.8mm 0.6mm 0.8mm 0.6mm 0.6mm 0.6mm 0.6mm 0.6mm 0.6mm 9 FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure ●If the right angle type connector is positioned too far back from the recommended connector mounting position, the 1. 0m m Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. M AX straight type connector will make contact with the PCB, and these may lead to damaged product or abnormal connections. The location of right angle type SMT pad should be set to within 1mm from the edge of the PCB, and the mounting position should be set so that the clearance from the head of the connector to the edge of the PCB is 1.3mm or less. 10 1.3mm MAX FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. MEMO : 11 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FX20 Series●0.5mm Pitch, Board to Board Connector with Floating Structure USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 12 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 07/2018. Contents are subject to change without notice for the purpose of improvements.
FX20-40S-0.5SV10 价格&库存
很抱歉,暂时无法提供与“FX20-40S-0.5SV10”相匹配的价格&库存,您可以联系我们找货
