FX15SC-41S-0.5SV(30) 数据手册
1mm Pitch Wire-to-Board Connectors supporting LVDS signal
FX15 Series
Space saving, Equal length transmission lines
Termination side: 0.5mm pitch, 1-row construction
Mating side: 1 mm pitch, staggered 2-row construction
Fig.1
■Features
1. Space-saving
Self-alignment of ±1.5mm
Large guide post
1.5mm
Reduction in space is achieved by designing the
contacts in 2-row staggered 1mm pitch on the
mating side and on a single row 0.5mm pitch on
the termination side (Fig.1).
1.5mm
2. Equal length transmission lines
Contact configuration provides equal length
transmission lines, which prevents LVDS signal
loss within the connector.
3. Variations
Fig.2
Side latch -locks
Availability of shielded and non-shielded types
allows for design flexibility and cost reduction.
4. Self alignment and self-guiding
Built-in guide posts allow secure self-alignment
within ±1.5mm (Fig.2).
5. Secure and complete mating / unmating
Side latch locking provides complete and secure
mating, as well as easy unmating (Fig.3).
6. Enhanced shielding performance with
FX15S
Enlarged metal shields prevent intrusion and
emission of electromagnetic interference, which
enhances the integrity of the LVDS signal (Fig.4).
7. RoHS compliant
All materials and substances used to produce this
product comply with RoHS standards.
With metal shields
(FX15 and FX15S Series)
Without metal shields
(FX15M Series)
Fig.3
High Shielding Performance
Without metal
Emitting Noise Level (dBm)
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
Contacts consolidated into 1 row for equal length transmission lines
-10
With metal
-20
-30
-40
-50
0.1 0.2
0.3
0.5
1
1.5
2
Frequency (GHz)
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2015.10e
3
Fig.4
1
FX15 Series●1mm Pitch Wire-to-Board Connectors supporting LVDS signal
■Product Specifications
Current rating
Voltage rating
Ratings
0.5A
100V AC
Operating temperature range
Storage temperature range
-55ç to +80ç (Note 1)
-10ç to +60ç (Note 2)
Item
1. Contact resistance
2. Insulation resistance
3. Withstanding voltage
4. Insertion-Extraction force
Specification
60mø max. (Note 3)
500Mø min.
No flashover or insulation breakdown.
2N min., 30N max.
Conditions
1mA
100V DC
300V AC/one minute
With corresponding connector
5. Mating cycles
Contact resistance : 80mø max.(Note 3)
50 cycles
6. Vibration resistance
7. Shock resistance
No electrical discontinuity of 1µs or more.
Frequency: 10 to 55 Hz, single amplitude of 0.75mm, 2 hours, 3 axis
Acceleration of 490m/s2, 11ms durations, sine half-wave waveform, 3 cycles, 3axis.
8. Humidity resistance
96 hours at 40ç, RH 90% to 95%
No damage, cracks, or parts dislocation.(Note 3)
9. Temperature cycle
Contact resistance : 80mø max. (Note 3)
Insulation resistance : 500Mø min.
Temperature : -55ç → +15ç to +35ç → +85ç → +15ç to +35ç
Time
: 30 → 5 → 30 → 5 (Minutes) 5 cycles
10. Salt spray
No corrosions
5% water solution for 48 hours.
Note 1 : Includes temperature rise caused by current flow.
Note 2 : The term “storage” refers to products stored for long period of time prior to mounting and use. Operating
temperature and humidity range includes non-conducting condition of installed connectors in storage, shipment or
during transportation.
Note 3 : Includes wire conductor resistance (12mm long).
■Materials / Finish
●Receptacle
Insulator
Component
Material
Polyamide
Finish
Color : Black
Remarks
UL94V-0
Contact
Phosphor bronze
Contact area : Gold plated
Termination area : Tin plated
FX15S : Nickel silver
FX15SC : Stainless steel
FX15S : --------------FX15SC : Tin plated
Phosphor bronze
Selective gold flash plated
Insulator
Material
Polyamide
Finish
Color : Black
Remarks
UL94V-0
Contact
Phosphor bronze
Metal shell (shielded version only)
Metal latch locks (shielded version only)
Nickel silver
Stainless steel
Metal shell, metal latch locks
(on micro coax version only)
Stainless steel
Nickel plated
Metal fittings (shielded version only)
●Plug
Component
■Product Number Structure
qSeries Name
wConfiguration
●Receptacle
FX15 S - 31 S - 0.5 SH (**)
q
w
e
r
t
y
●Plug
w
e
r
u
●Crimp contact
FX15 - 3032 PCF B
q
i
o
!0
P
S
: Male contact
: Female contact
tContact pitch
: 0.5 mm
SH
yHousing configuration
SV
: Right angle
: Straight
uTermination
C
: Crimp
0.5SD : Micro-coaxial cable
GND : Separate ground plate
iApplicable conductor
2830
3032
: 28 to 30 AWG
: 30 to 32 AWG
oPackaging
!0Plating (contact area)
PCF
B
Blank
(30)
: Male contact / reel
: Gold plated
: Embossed Packaging (1,000 pcs/reel)
: Embossed Packaging (100 pcs/reel)
!1Packaging
2
15M
: With shields (or crimp contact)
: With shields – enhanced shielding
(PCB mounting pattern : VESA standard)
: Without shields
eNumber of contacts
rConnector type
FX15 S - 31 P - C
q
!1
: FX15
Blank
15S
15SC
■FX15 Series – Functional Diagram
Crimp contact
Plugs
Receptacles
With shields-standard
Vertical, with shields
(FX15-31P-C)
(FX15-31S-0.5SV)
B
Crimp contact
(FX15-3032-PCFB)
(FX15M-P-C)
Right angle, with shields
–enhanced shielding
(FX15S-S-0.5SH)
B
(FX15S-P-C)
Right angle, without shields
(FX15M-S-0.5SH)
B
Without shields
Crimp contact
(FX15-2830-PCFB)
28 to 30 AWG
(FX15SW-31P-C)
PCB mouting pattern : VESA standard
(FX15SC-S-0.5SH)
28
Ground plate
(FX15S-P-GND)
Micro-coaxial cable
(FX15S-P-0.5SD)
(FX15SC-S-0.5SV)
A
3
■Plugs
●With shields (FX15-31P-C)
(27)
24.6±0.3
22.57±0.15
2.7±0.1
18.3±0.3
3.7±0.3
(13.45)
9.4±0.3
Polarizing mark
indicator
No.2
Part No.
HRS No.
No. of contacts
RoHS
FX15-31P-C
575-2101-2
31
Yes
Note 1 : Packaged in trays.
Note 2 : Dimensions in parenthesis ( ) are reference dimensions.
No.1
14±0.15
P=1±0.1
No.30
P=1±0.1
15±0.15
No.31
●With shields, enhanced shielding (FX15S-**P-C)
(A)
B±0.3
C±0.15
4±0.3
2.7±0.1
(13.45)
9.4±0.3
Polarizing mark
indicator
3.7±0.3
D±0.3
No.2
No.1
No.n-1
P=1±0.1
F±0.15
No.n
Part No.
HRS No.
No. of contacts
A
B
C
D
E
F
FX15S-31P-C
575-2106-6
31
27
24.6
22.6
18.3
14
15
FX15S-41P-C
575-2107-9
41
32
29.6
27.6
23.3
19
FX15S-51P-C
575-2103-8
51
37
34.6
32.6
28.3
24
25
4
E±0.15
P=1±0.1
RoHS
Yes
●With shields – enhanced shielding
28 to 30 AWG (FX15SW-31P-C)
(27)
24.6±0.3
22.57±0.15
Polarizing mark
indicator
4±0.3
2.7±0.1
(13.45)
9.4±0.3
B
28
Part No.
HRS No.
No. of contacts
RoHS
FX15SW-31P-C
575-2113-1
31
Yes
No.2
14±0.15
P=1±0.1
3.7±0.3
No.30
A
No.1
P=1±0.1
15±0.15
No.31
●Without shields (FX15M-**P-C)
(A)
B±0.3
Polarizing mark
indicator
(13.6)
(13)
9.55±0.3
18.3±0.3
4.2±0.3
C±0.3
(D)
No.2
No.1
E±0.15
P=1±0.1
No.n-1
P=1±0.1
F±0.15
No.n
Part No.
HRS No.
No. of contacts
A
B
C
D
E
F
FX15M-21P-C
575-2109-4
21
24.8
20.5
13.7
25.8
9
10
FX15M-31P-C
575-2108-1
31
29.8
25.5
18.7
30.8
14
15
RoHS
Yes
Note 1 : Sold in 100 piece packages. Please order in full package quantities.
5
BPlug crimp contacts
Part No.
HRS No.
FX15-2830PCFB
575-2002-0
FX15-3032PCFB
575-2003-3
Packaging
Quantity
Finish
RoHS
Reel
20,000 pcs/reel
Gold plated
Yes
●Applicable cable (Tin plated, annealed copper wire)
30 AWG (7/0.1mm)
32 AWG (7/0.08mm)
Ø0.5 to 0.6mm
1571
UL No.
1516, 1571 (Note)
1571
●Wire strip length: 1.1 to 1.8mm
Note : When using wires other than those noted above, please contact Hirose for asistance.
●Tools
Item
Applicator
Press unit
6
Part No.
AP105-FX15-2830
AP105-FX15-3032
CM-105C
HRS No.
901-4036-0
901-4033-1
901-0001-0
0.35±0.1
Applicable crimp contact
FX15-2830PCFB
FX15-3032PCFB
(7)
Jacket diameter
1517
0.72±0.1
0.9±0.15
FX15-3032PCFB
Applicable wire size
(Stranded wire conductor)
Ø0.56 to 0.72mm
UL No.
2±0.15
28 AWG (7/0.127mm)
30 AWG (7/0.1mm)
Jacket diameter
0.5±0.15
FX15-2830PCFB
t=0.15±0.05
Cd#&
Cd#c
●Plug – Micro-coaxial cable (FX15S-**P-0.5SD)
Cd#'
Cd#c"&
6
7¤%#(
8¤%#&*
EdaVg^o^c\bVg`
^cY^XVidg
6
Part No.
HRS No.
No. of contacts
A
B
C
D
FX15S-41P-0.5SD
575-2110-3
41
31.9
29.6
27.57
FX15S-51P-0.5SD
575-2118-5
51
36.9
34.6
32.57
25
RoHS
Yes
●Ground plate for micro-coaxial cable type
6¤%#'
7¤%#'
Part No.
HRS No.
No. of contacts
A
B
FX15S-41P-GND
575-2111-6
41
29.2
30.06
FX15S-51P-GND
575-2117-2
51
34.2
35.06
RoHS
Yes
●Applicable cable (Micro-coaxial cable)
6¤%#'
7¤%#&*
40 AWG (7/0.03mm)
No. of contacts
41
A
23.1
B
28.1
25
E2%#*¤%#%,
>ccZgXdcYjXidg
>chjaVidg
FX15SC-41S-0.5SV(30) 价格&库存
很抱歉,暂时无法提供与“FX15SC-41S-0.5SV(30)”相匹配的价格&库存,您可以联系我们找货
