1000 Eaton Boulevard
Cleveland, OH 44122
United States
Free NetCommander-AXS Management Software is available for access and control of all of your Tripp
Lite NetCommander IP KVM switches (B070 and B072 series). From a single interface, you can access
Highlights
32 ports provide control of
computers/servers locally or via
your network or the Internet
KVM settings. This software can be found on the model support page of the B072-032-IP2-K, or via
Occupies just 1U of rack space
searching NetCommander-AXS on www. Tripplite.com
Low-cost Cat5 cabling allows
longer distances, reduces cable
clutter
Simultaneous support for 3
users – 1 local, 2 remote
Includes 16 USB Server
Interface dongles for connecting
computers or servers
Compliant with the Federal
Trade Agreements Act (TAA) for
GSA Schedule purchases
server ports on any of your KVM switches, power cycle or power on/off outlets of IP PDU's, and manage
NetCommander 32-Port Cat5 KVM over IP Switch
- 2 Remote + 1 Local User, 16 USB Dongles, 1U
Rack-Mount
MODEL NUMBER: B072-032-IP2-K
System Requirements
Computer with HD15 (VGA)
port, and USB port or PS/2
keyboard/mouse ports
User-supplied Cat 5e/6/6a
cabling
B078-101-USB-1 or B078-101USB2 (USB) or B078-101-PS2
(PS/2) Server Interface Unit is
required for each connected
computer/server; 16 B078-101USB-1 units are included
For computers with Displayport
or HDMI, change to VGA using
Tripp Lite adapters P134-06NVGA-V2 or P131-06N.
Maximum video resolutions
using adapters may vary.
Compatible with Windows and
Linux operating systems
Remote access supported using
Windows computers
Remote console computers
require minimum Pentium 4 with
2 GB memory
Control up to 32 computers from virtually anywhere with one Cat5 KVM switch. This KVM switch with IP
remote access is a smart solution for efficient server control. Low-cost Cat5 cables let you locate servers
up to 100 ft. away.
Description
Tripp Lite’s B072-032-IP2-K KVM Switch is the optimal solution for controlling up to 32 computers/servers
locally, from across the room, down the street or around the globe on a network or the Internet.
This KVM switch can be accessed and controlled remotely, so there’s no need to travel to the server room
or network closet. A Java-based application allows access via web browser from any secure IP
connection; a non-browser client that can bypass browser-related Java Security prompts is available.
The B072-032-IP2-K uses inexpensive, user-supplied Cat5e/6/6a cabling with Server Interface Units (16
included) so you can connect computers/servers located up to 100 ft. away from the switch. This switch
features dual Ethernet ports and dual power supplies; if one fails, the other takes over, keeping access
uninterrupted. Switch easily between the 32 ports using an on-screen display (OSD), hotkey commands or
a remote toolbar. Multi-level password protection prohibits unauthorized users from accessing connected
computers, and a local user and up to two remote users can each log on and access different ports
simultaneously.
Two serial ports allow control of serial-manageable devices such as IP PDUs, firewalls and routers;
individual ports can be assigned to an IP PDU port to power on/off the server connected to that port. This
KVM switch is compatible with Windows and Linux operating systems, and provides remote access using
a Windows computer. It supports VGA video resolutions up to 1920 x 1080 @ 60 Hz. Heavy-duty steel
housing stands up to frequent use.
Virtual Media allows an .iso file to be mounted to a target server and accessed as if it were stored directly
on it. Virtual Media data transfer rates up to 12Mbps are supported when using a B078-101-USB2 Server
Interface Unit. Other features include RADIUS and LDAP/S authentication, system-sent SNMP messaging
and an event log that tracks logins, reboots and network setting changes.
Free NetCommander-AXS Management Software is available to access and control all of your Tripp Lite
NetCommander IP KVM switches (B070 and B072 series). From a single interface, you can access server
ports on any of your KVM switches, power cycle or power on/off outlets of IP PDUs and manage KVM
settings. This software can be downloaded free of charge from the model support page for the B072-0321/5
Package Includes
B072-032-IP2-K 32-Port Cat5
2+1 User 1U Rack-Mount KVM
Switch with IP Remote Access
16 USB Server Interface
Dongles (B078-101-USB-1)
C13 to 5-15P Power Cords (x2)
Rack-Mount Hardware
CD with Owner's Manual
Quick Start Guide
Cleveland, OH 44122
United States
IP2-K.
Features
Saves Space and Money
● Mounts in a standard 19 in. rack
Inexpensive Cat5e/6/6a cabling lets you locate servers up to 100 ft. from the switch
Use a Server Interface Unit, B078-101-USB-1 or B078-101-USB2 (for USB) or B078-101-PS2 (for PS/2)
with each server that will be connected with Cat5 cable; 16 B078-101-USB-1 units are included
To convert DisplayPort or HDMI computers to VGA, use Tripp Lite adapters P134-06N-VGA-V2 or
P131-06N. Maximum video resolutions using adapters may vary.
IP Remote Access for Fewer Trips to the Server Room
● Remote access means there’s no need to travel to the server room or network closet
Java-based application allows Windows computers to control a target server via web browser from any
location over a secured IP connection
A non-browser client is available that allows Windows computers to remotely access the KVM without
the need for a browser and without the need to install Java
1 local + 2 remote users can access different ports concurrently; up to 5 users can share a single
remote session
Supports both IPv4 and IPv6
Simplifies IT Tasks
● On-screen display, hot keys and remote toolbar for easy use
Free NetCommander-AXS Management Software gives you remote access and control over all your
Tripp Lite NetCommander IP KVM switches (B070 and B072 series)
Video resolutions up to 1920 x 1080 @ 60 Hz are supported
2 serial ports allow control of serial-manageable devices such as IP PDUs, firewalls and routers; assign
individual ports to an IP PDU port to power on/off the server connected to that port
BIOS-level control of any brand and model server, regardless of the server’s condition and network
connectivity
Virtual Media allows an .iso file to be mounted to a target server and accessed as if it were directly
stored on it
Interface Unit; the included B078-101-USB-1 Server Interface Units can be used for Virtual Media
support, but only at speeds up to 1Mbps
Fast Virtual Media KVM System patented under Pat. No. US 9,417,720
System-sent messages to SNMP server notify you of network failures
Supports RADIUS and LDAP/S authentication
Log tracks events such as logins, reboots and network setting changes on your installation
Advanced Security Features
● Multi-level password protection: create administrator accounts with full access and user accounts with
limited access
Supports TLS 1.2 security protocol
You can install SSL certificates to ensure secure transactions between web servers and browsers
Built to Last
● Flash-upgradable firmware over the network
Heavy-duty steel housing stands up to frequent use
Compliant with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
2/5
Cleveland, OH 44122
United States
OVERVIEW
UPC Code
037332181442
Technology
Cat5/5e; PS/2; VGA/SVGA
VIDEO
Max Supported Video Resolution
Local : 1920 x 1200 @ 60 Hz ; Remote : 1920 x 1080 @ 60 Hz
INPUT
Voltage Compatibility (VAC)
100; 110; 120; 127; 200; 208; 220; 230; 240
Input Frequency
50/60Hz
Input Current
120V (0.7A) / 230V (0.3A)
Power Input Receptacle
IEC-320-C14
Redundancy - Dual Power Inputs
Yes
POWER
Power Consumption (Watts)
50
USER INTERFACE, ALERTS & CONTROLS
LED Indicators
Blue (Power)
PHYSICAL
Color
Black
Material of Construction
Steel (Steel, Electrogalvanized, Cold Rolled, Coil)
Rackmountable
Yes
Shipping Dimensions (hwd / in.)
5.70 x 14.40 x 23.00
Shipping Dimensions (hwd / cm)
14.48 x 36.58 x 58.42
Shipping Weight (lbs.)
14.20
Shipping Weight (kg)
6.44
Unit Dimensions (hwd / in.)
1.710 x 17.280 x 10.990
Unit Packaging Type
Box
Unit Weight (lbs.)
7.70
Unit Weight (kg)
3.49
ENVIRONMENTAL
Operating Temperature Range
32 to 104 F (0 to 40 C)
Storage Temperature Range
-40 to 158 F (-40 to 70 C)
Relative Humidity
0% to 80% RH, Non-Condensing
3/5
Cleveland, OH 44122
United States
BTUs
171 BTU/Hr
COMMUNICATIONS
IP Remote Access
Yes
Network Compatibility
100 Mbps (Fast Ethernet)
CONNECTIONS
Number of Ports
32
PC/Server Connections
PS/2; USB; VGA
Side A - Connector 1
(3) USB A (FEMALE)
Side A - Connector 2
HD15 (FEMALE)
Side A - Connector 3
(4) RJ45 (FEMALE)
Side B - Connector 1
(32) RJ45 (FEMALE)
Computer Keyboard and Mouse
Interface
PS/2; USB
Computer Monitor Interface
VGA
Console Keyboard and Mouse
Interface
USB
Console Monitor Interface
VGA
FEATURES & SPECIFICATIONS
Number of Users
3
NIAP-Certified Secure
No
On-Screen Display (OSD)
Yes
Port Selection
Hotkey; OSD
USB Specification
USB 2.0 (up to 480 Mbps)
Driver Required
No
Authentication Supported
RADIUS; LDAPS
Cat5 KVM Switch
Yes
Recommended Category Cable
Cat5e/6/6a Cables
REMOTE ACCESS
Virtual Media Speed
Up to 12 Mbps (using B078-101-USB2)
STANDARDS & COMPLIANCE
Product Certifications
CAN/CSA C22.2; CAN/CSA-C22.2 No. 60950-1 (Canada); UL 60950-1
Product Compliance
RoHS; CE (Europe); REACH; FCC Part 15 Class A (USA); Trade Agreements Act (TAA)
WARRANTY & SUPPORT
4/5
Cleveland, OH 44122
United States
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
5/5
很抱歉,暂时无法提供与“B072-032-IP2-K”相匹配的价格&库存,您可以联系我们找货
