GT16C-2P/S-R
GT16C-2P/S-R
    HRS(广濑)
GT16C-2P/S-R 数据手册
GT13 GT5 For Antenna Features Space-saving design Compact and light comparing to HRS GT5 series. Excellent high frequency performance Refer to V.S.W.R. data on the following pages. Applications In-car communication, car sensors(temperature, pressure), automotive audio systems, GPS antenna systems, RACS antenna audio/video antenna systems, CRT displays, medical and measuring instrumentation LAN systems. GT9 GT8E GT25 GT18W GT10 GT7 GT3 GT32 GT17 GT11 GT36 GT26 GT21 GT19 PO5G — Subminiature Connectors for coaxial cables — GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For Antenna GT16 GT16 Series 48 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. GT16 Series ● For Antenna GT5 GT16 Series F Connectors (Common Use) 0.8 7.6 4 GT13 Center terminal 0.2 Material/Plating Phosphor bronze/ Tin plating Conductor Size 24 to 28 AWG 30 AWG Packaging RoHS 10,000 pcs/reel YES GT21 GT26 Insulator (Common Use) φ3.4 φ3.2 φ3.8 GT11 φ4.4 GT36 GT17 * HRS No. 766-0002-5 Material PBT Color White Packaging 1 RoHS YES GT3 Part No. GT16-SC GT32 GT7 M Connectors (Common Use) 0.8 9.25 Center Terminals GT10 4 GT18W 0.2 φ0.72 GT25 φ1.28 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 HRS No. 766-0001-2 766-0055-1 GT8E Material/Plating Brass/Tin plating Conductor Size 24 to 28 AWG 30 AWG Packaging RoHS 10,000 pcs/reel YES GT15 HRS No. 766-0006-6 766-0015-7 GT9 Part No. GT16-2428PCF GT16-30PCF 49 For Antenna PO5G φ1.28 GT16 Part No. GT16-2428SCF GT16-30SCF Insulator (Common Use) GT13 GT5 GT16 Series ● For Antenna φ2.8 φ3.8 PO5G GT19 GT21 GT26 HRS No. 766-0007-9 Material PBT Color White Packaging 1 RoHS YES Without retainer type (F Connector) Housing GT11 ,#& GT36 Part No. GT16-PC &,#* Part No. GT16F-1S-HU(A) GT16F-1S-HU(B) HRS No. 766-0082-4 766-0083-7 Material PBT Color Brown Green &&#( -#( Packaging RoHS 1 YES GT10 GT7 GT3 GT32 (#&* GT17 )#&* )#' PBT * Outer terminal GT18W 15.7 GT25 φ5 7.2 GT8E GT9 GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. * For Antenna GT16 6.3 4.1 50 Part No. GT16-/1.6-2.9SC GT16-/0.7-1.5SC HRS No. 766-0003-8 766-0056-4 Material/Plating Phosphor bronze/ Tin plating Insulator Diameter Outer Diameter Ø1.5 to 2.0 Ø2.6 to 3.4 Ø0.6 to 0.9 Ø1.4 to 1.8 Packaging RoHS 1 YES GT16 Series ● For Antenna GT5 Without retainer type (M Connector) GT13 Housing BMated condition GT16F-1S-HU(A) 4.05 PBT A A GT16F−1P−HU(A) Material Color Brown Green PBT Packaging RoHS 1 YES GT21 HRS No. 766-0086-5 766-0087-8 GT26 Outer terminals GT36 &+#+ ¢)#) -#& GT11 Circuit Board Type(SMT Type) RoHS 1 YES BRecommended PCB pattern 9.8 Vacuum pick up area 1.2 3.95 7 9.3 GT3 2.8 13.1 4.1 10 BMated condition (23) 3.8 GT16F−1P−H(A) GT18W (6.3) HRS No. GT16F-1P-H(B) 766-0079-0 Color Packaging RoHS Brown 1 YES Green GT9 Housing:PPS Inner Terminal:Phosphor bronze/Tin plating Outer Terminal:Phosphor bronze/Tin plating Insulator:PPS/Natural Shield plate:Phosphor bronze/Tin plating Metal reinforcement:Brass/Tin plating GT8E GT16F-1P-H(A) 766-0078-7 Material/Plating GT25 GT16F-1S-HU(A) Part No. GT10 5 GT7 16 16.7 3 Ø8 0.7 Packaging 1.2 Tin plating Insulator Diameter Outer Diameter Ø1.5 to 2.0 Ø2.6 to 3.4 Ø0.6 to 0.9 Ø1.4 to 1.8 6.3 Plating 14.5 Material Phosphor bronze GT32 ● Printed HRS No. 766-0019-8 766-0018-5 GT17 Part No. GT16C-/1.6-2.9PC GT16C-/0.7-1.5PC GT16F−1P−H(A) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 Part No. GT16F-1P-HU(A) GT16F-1P-HU(B) GT15 51 For Antenna (6.3) PO5G 9.1 GT16F−1P−HU(A) (31.4) PBT GT16 10 25.1 Genuine Market Parts F Connectors Housing (Retainer Stopper Specification) 7.5 10.1 GT26 GT21 GT16C−1S−HU GT19 11.6 PO5G 17.5 Part No. GT16C-1S-HU GT16C-1S-HU(A) GT16C-1S-HU(B) HRS No. 766-0010-3 766-0060-1 766-0061-4 Material PBT Color Light Gray Brown Green Packaging RoHS 1 YES Outer terminal (Retainer Stopper Specification) GT17 GT11 GT36 Note : This product is used in conjunction with retainer GT16C-1P/S-R (CL766-0011-6) which is a separate item. 15.7 Part No. GT16C-/1.6-2.9SC GT16C-/0.7-1.5SC HRS No. 766-0012-9 766-0057-7 Material/Plating Phosphor bronze/ Tin plating Insulator Diameter Outer Diameter Ø1.5 to 2.0 Ø2.6 to 3.4 Ø0.6 to 0.9 Ø1.4 to 1.8 Packaging RoHS 1 YES Retainer 2.15 11.2 1.25 GT25 R2.6 GT18W GT10 GT7 GT3 φ5 GT32 7.2 GT9 5.6 GT8E * GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For Antenna GT16 GT13 GT5 GT16 Series ● For Antenna 52 Part No. GT16C-1P/S-R HRS No. 766-0011-6 Material PBT Color Dark Gray Packaging 1 RoHS YES GT16 Series ● For Antenna GT5 Genuine Market Parts M Connectors GT13 Housing (Retainer Stopper Specification) GT16 7.5 11.1 12.2 10.15 0.8 (1.5) HRS No. 766-0029-1 766-0064-2 766-0065-5 (1.5) Material Color Light Gray Brown Green PBT Packaging RoHS 1 YES GT36 Part No. GT16C-1PP-HU GT16C-1PP-HU(A) GT16C-1PP-HU(B) (31.4) GT26 GT11 Note: Use this product with separate retainer part GT16C-1P/S-R(CL766-0011-6). 2.5 9.6 10 0.2 0.7 GT32 15.1 BRecommended panel cutout dimension 12.6 φ 13.2 5 18.2 Printed Circuit Board Type (Reinforced Lock and Screw Fastening Type) GT3 11.1 Board 4 BMated condition 7.475 4.1 6.575 ( 23 ) 6.575 7.5 7.475 1 GT18W Panel HRS No. 13.2 3 --φ GT16C-1P/S-R Part No. 4.1 T= 1.6 3.5 GT10 2 -φ GT16C-1S-HU ( 1.5 ) BRecommended PCB pattern GT7 3 8.65 12.2 * GT17 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16C-1P/S-R GT16C-1P/S-R Board Material/Plating Packaging RoHS Light Gray Brown Green 1 YES GT8E Note : Use mounting screws of M3 with nominal diameter 3L-6. Color GT25 Housing:PBT GT16C-1P-DS 766-0013-1 Inner Terminal:Phosphor bronze/Tin plating GT16C-1P-DS(A) 766-0062-7 Insulator:Phosphor bronze/Tin plating Insulator:PPS/Natural GT16C-1P-DS(B) 766-0063-0 Shield plate:Phosphor bronze/Tin plating GT9 GT15 53 For Antenna GT16C-1S-HU GT21 GT16C-1PP-HU GT19 4.8 20 BMated condition PO5G 12 9.6 23.5 9.6 Panel Mounting Type GT16 22.6 23.5 7.5 4 GT36 GT11 GT17 GT32 GT3 GT7 GT10 GT18W GT25 GT8E .5 2- (1.5) Part No. GT16CB-1PP-HU GT9 φ3 10 GT16C-1S-HU 12.6 (31.4) HRS No. 766-0017-2 7.8 GT21 GT26 16.2 4- GT15 8.95 7.6 PO5G GT19 2. BRecommended panel cutout dimension Panel GT16C-1P/S-R 54 2.1 φ BMated condition Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10.8 2- For Antenna 16.2 12.2 GT13 GT5 GT16 Series ● For Antenna .2 R1 Material/Plating or Color Housing:PBT/Light Gray Ground terminal:Copper alloy/Tin plating Note : Use mounting screws of M3 with nominal diameter 3L-6. Packaging RoHS 1 YES GT16 Series ● For Antenna GT5 BGT16C Wiring Method GT13 GT21 GT26 4. Insert the crimped terminal into the Insulator. GT17 GT32 6. Crimp the outside tube. GT11 5. Insert the insulator into the outside tube. GT36 GT3 7. Insert outer terminal block into the housing. GT7 GT10 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT19 3. Crimp the center terminal. GT18W 8. Insert the retainer into the housing. GT25 GT8E GT9 GT15 55 For Antenna PO5G 2. Strip the cable. GT16 1. Pass the cable through the outside tube. Inner Terminal Insulator   GT16-2428SCF  GT16-30SCF GT16-SC PO5G GT19 GT21 GT26 GT36 GT11 Retainer Housing Outer Terminal GT16-/1.6-2.9SC  GT16F-1S-HU(A) Not Used GT16-/0.7-1.5SC  GT16F-1S-HU(B)  GT16C-1S-HU GT16C-/1.6-2.9SC  GT16C-1S-HU(A) GT16C-1P/S-R GT16C-/0.7-1.5SC  GT16C-1S-HU(B) F Connectors        GT16C-1S-HU B M Connector Components Table Inner Terminal GT16-2428PCF GT16-30PCF Insulator Outer Terminal Housing Retainer GT16CB-1PP-HU GT16F-1P-HU(A) Not Used GT16C-/1.6-2.9PC GT16F-1P-HU(B) GT16C-/0.7-1.5PC GT16C-1PP-HU GT16C-1PP-HU(A) GT16C-1P/S-R GT16C-1PP-HU(B) GT16-PC M Connectors GT16CB-1PP-HU GT16C -1PP- HU GT16C-1P-DS B Key Variation F Connectors GT16F-1S-HU(A) GT16F-1S-HU(B) GT16C-1S-HU(A) GT16C-1S-HU(B) Printed Circuit Board Type GT16F-1P-H(A) GT16F-1P-H(B) GT16C-1P-DS GT16C-1P-DS(A) GT16C-1P-DS(B) M Connectors GT16F-1P-HU(A) GT16F-1P-H(A) GT16F-1P-HU(B) GT16F-1P-H(B) GT16C-1P-HU(A) GT16C-1P-DS(A) GT16C-1P-HU(B) GT16C-1P-DS(B) B Crimping tools User's manuals are available. Please ask your Hirose Electric account representative. Automatic Crimping Machine Picture reference only Specifications GT17 Item GT32 Part No. CM-105C GT3 * See the table below for the product number of the applicator. Specification Press capacity 1.5ton Stroke Length 30mm Number of strokes 200spm(50Hz) Weight 75kg Motor 0.2kW Crimping speed Remarks 240spm(60Hz) AC100V 2,000∼4,000/H GT9 GT8E GT25 GT18W GT10 GT7 Hand Press GT15 For Antenna Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. B Mating Table B F Connector Components Table GT16 GT13 GT5 GT16 Series ● For Antenna 56 Harness Tool Terminal Product No. GT16 -2428SCF GT16 -2428PCF GT16 - 30SCF GT16 - 30PCF GT16 - /1.6 -2.9SC GT16C - /1.6 -2.9SC GT16C - /1.6 -2.9PC GT16 - /0.7-1.5SC GT16C - /0.7-1.5SC GT16C - /0.7-1.5PC Terminal HRS No. 766-0001-2 766-0006-6 766-0055-1 766-0015-7 766-0003-8 766-0012-9 766-0019-8 766-0056-4 766-0057-7 766-0018-5 Tool No. Tool HRS No. AP105-GT16-2428 901-5108-4 AP105-GT16-30 901-5124-0 GT16-1.6-2.9/CK-MP 902-5058-4 GT16-0.7-1.5/CK-MP 902-5064-7 * Crimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account representative. * Different cables will require different crimp height settings. GT16 Series ● For Antenna GT5 GT16G Series GT13 F and M Common Parts Terminal Ferrule GT16 0.6 GT19 HRS No. Material 766-0028-9 Phosphor bronze Plating Packaging RoHS Tin plating 1 YES GT26 F and M Common Parts GT36 Outer Ferrule 2.7 GT17 2.3 GT11 GT32 7.6 GT3 Part No. GT16G-1.5DHQS HRS No. Material 766-0027-6 Phosphor bronze Plating Packaging RoHS Tin plating 1 YES 8.3 0.8 GT10 F Common Parts GT7 4 Center Terminal GT18W GT25 0.2 GT8E φ1.28 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT21 Part No. GT16G-FR GT9 Part No. HRS No. Material 766-0022-2 Phosphor bronze Plating Conductor Size Packaging RoHS Tin plating 24 to 28 AWG 10,000 pcs/reel YES GT15 GT16G-2428SCF 57 For Antenna PO5G 1.25 4.6 Insulator GT16 GT13 GT5 GT16 Series ● For Antenna 10.1 6 R2 .2 1. 1.05 PO5G 3.8 GT19 Color Packaging RoHS PBT Natural 1 YES M Common Parts 8.8 0.8 4 Center Terminal GT32 φ1.28 φ0.72 GT17 GT11 GT36 GT21 Material GT26 HRS No. 766-0023-5 Note : Two of these products are used per connection. GT3 Insulator HRS No. Material Plating Conductor Size(AWG) 766-0046-0 Brass Tin plating 24 to 28 AWG Packaging RoHS 10,000 pcs/reel YES GT18W GT10 GT7 Part No. GT16G-2428PCF GT25 7.4 GT8E 0.6 R1. GT9 Part No. GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. GT16G-SC 0.2 For Antenna R 58 GT16G-PC HRS No. Material Color Packaging RoHS 766-0047-3 PBT Natural 1 YES Note : Two of these products are used per connection. 9 GT16 Series ● For Antenna GT5 Outer Terminal GT13 φ4.4 0.6 Material Plating Applicabie cable Packaging RoHS Tin plating 1.5D-2W or equivalent 1 YES GT21 GT26 F Connector (No retainer required type) GT36 Housing GT11 8.3 GT17 7.1 19.1 GT32 GT3 Part No. GT16GM-1S-HU HRS No. Material Color Packaging RoHS 766-0033-9 PBT Black 1 YES GT7 Outer Terminal GT10 GT18W 17.2 8 GT25 φ5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 5.7 GT19 HRS No. GT8E GT9 HRS No. Material Plating Applicabie cable Packaging RoHS Tin plating 1.5D-2W or equivalent 1 YES GT15 Part No. GT16GM-/1.6-2.9SC 766-0025-0 Phosphor bronze 59 For Antenna PO5G Part No. GT16G-/1.6-2.9PC 766-0048-6 Phosphor bronze GT16 17.4 8 M Connector (No retainer required type) Housing 25.6 9.8 PO5G BMated condition GT21 GT19 (33.7) (8.1) GT16GM-1P-HU Part No. HRS No. Material Color Packaging RoHS 766-0050-8 PBT Black 1 YES GT16GM-1S-HU Housing (Bracket mounting type) GT11 GT36 GT26 Cable Cable GT16GM-1P-HU 20 GT32 GT17 17 4.5 (8.1) GT7 9.8 Cable Cable GT16GM-1S-HU GT9 GT8E GT25 GT18W GT10 GT16GMN-1PP-HU 60 Part No. HRS No. Material Color Packaging RoHS GT16GMN-1PP-HU 766-0051-0 PBT Black 1 YES 9 GT3 (33.7) 11.4 25.6 BMated condition GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For Antenna GT16 9 GT13 GT5 GT16 Series ● For Antenna GT16 Series ● For Antenna GT5 Board Type (Lock Pin Type) 1.2 13.5 MA 10.2 X AX .5M R2 Board 5 GT16 7.4 9.4 4 16.2 3-R GT13 BRecommended panel cutout dimension 9.8 14.3 12.3 BMated condition 4.2 3.95 . T=1.6 9 7 ( (7.3) ) 5.8 GT16GM-1P-H Panel BRecommended PCB pattern 2.4 11.6 4.3 (3) R0.95 2-φ0.5 Through Hole 4.4 0.5 1.1 YES R Throu 0.55 gh Ho le Panel 1 R0. 1.9 7M AX 766-0032-6 Housing:PBT/Black Inner Terminal:Phosphor bronze/Tin plating Outer Terminal:Phosphor bronze/Tin plating Insulator:PBT/Natural Lock pin:Phosphor bronze/Tin plating RoHS 0.4 Packaging 7.3 (1.5) Double sided PCB board * Use micro strip line and set so that dimension A has a characteristic impedance of 50ø. R1.2 Board 0.3 T=1 13.1 16 Board Panel GT16GM-1S-HU 9.1 GT7 9.8 16.6 13 GT10 5 9.5 0.8 3.95 5.6 6 5.5 17.45 8.1 7 (3) 0.7 200 pcs/reel YES 0.55 0.4 5.5 0.5 2-φ0.5 Through Hole Board 8.2 17.6 0.95 A 7 5.55 4.4 RoHS 2.5 3.6 6 Panel (1.5) 18.05 * Use micro strip line and set so that dimension A has a characteristic impedance of 50 ø. GT15 766-0052-3 Housing:PPS/Black Inner Terminal:Phosphor bronze/Tin plating Outer Terminal:Phosphor bronze/Tin plating Insulator L,R:PPS/Natural Shield plate:Phosphor bronze/Tin plating Metal fittings:Brass/Tin plating Packaging GT9 Material/Plating or Color GT8E GT16GMP-1P-H HRS No. GT25 1.1 2-φ 0.3 GT18W BRecommended PCB pattern Part No. GT3 5 10.2 9.4 16.6 6.6 R1.2 GT32 (24.7) (8.1) 17.6 GT17 BMated condition BRecommended panel cutout dimension Board Type (SMT Type) GT11 Material/Plating or Color GT36 GT16GM-1P-H HRS No. 13.5 5.2 1.8 Part No. 4.15 10.2 A 2.3 1.3 GT26 5.8 0.25MAX GT21 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16GM-1S-HU GT19 Cable Borad 61 For Antenna 2.2 PO5G (22.4) (8.1) F Connector (Retainer required type) Housings GT16 GT13 GT5 GT16 Series ● For Antenna Part No. HRS No. GT16G-1S-HU 766-0026-3 GT16G-1S-HU(24) 766-0026-3 24 Material PBT Color Light Gray Black Packaging RoHS 1 YES Note : Use this product with separate retainer part GT16C-1P/S-R (CL766-0011-6). GT36 GT26 GT21 GT19 11.6 10.1 PO5G 19.1 GT11 Outer Terminal 17.2 6.3 0.6 GT32 φ5 GT17 8 GT3 GT7 GT10 GT18W GT25 GT8E GT9 GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For Antenna 7.5 62 Part No. HRS No. Material GT16G-/1.6-2.9SC 766-0024-8 Phosphor bronze Plating Applicable cable Packaging RoHS Tin plating 1.5D-2W or equivalent 1 YES GT16 Series ● For Antenna 2. 5 (22.4) (8.1) T=1.6 5 21 16 Cable GT16G-1P-H GT16G-1S-HU Panel 4-R MA 10 X 4.9 12.4 Board 7 (7.3) 2.2 2.4 11.6 2-φ (3) 4.3 A GT26 5.8 3.5 GT21 BRecommended PCB pattern 10 16 5.2 1.8 2-φ0.5 Through Hole 0.4 GT36 X MA Packaging RoHS Housing:PBT/Light Gray Inner Terminal:Phosphor bronze/Tin plating Outer Terminal:Phosphor bronze/Tin plating Insulator:PBT/Natural 1 2- Panel 0.5 (1.6) (24.7) (8.1) 13.4 T=1.6 GT16C-1P/S-R 10 2-R1.2MAX GT16GD-1P-H GT16GD-1S-HU Panel Board GT7 17.6 15.8 13 16.6 13 5.4 7 (1.5) Panel .2 φ1 0.4 A GT8E 1 1. φ 7 4.4 18.8 1.1 5 HRS No. Housing:PPS/Black Inner Terminal:Phosphor bronze/Tin plating Outer Terminal:Phosphor bronze/Tin plating InsulatorL,R:PPS/Natural Shield plate:Phosphor bronze/Tin plating Metal reinforcement:Brass/Tin plating Packaging RoHS 200 pcs/reel YES 7 11.5 17.45 18.05 (3) Note : Use micro strip line and set so that dimension A has a characteristic impedance of 50ø. GT15 GT16GD-1P-H 766-0044-5 Material/Plating or Color 2.5 3.6 GT9 Part No. GT25 0.5 2-φ0.5 Through Hole 2- 10 6 Board 3 GT18W 8 5 BRecommended PCB pattern 5 1.1 7 11 20.8 1.4 5 10 GT10 6 GT3 5.55 BRecommended panel cutout dimension GT32 BMated condition GT17 Note 1: Suitable mounting screws are JIS B 1122 pan head tapping screws class 2, nominal diameter 3, length 6. Note 2: Use micro strip line and set so that dimension A has a characteristic impedance of 50ø. YES Board Type (SMT Type) (1.5) 7.3 GT11 GT16G-1P-H 766-0021-0 Material/Plating or Color 10.4 HRS No. .7 R0 0.2 Part No. GT19 4.7 4.1 12 1.2 63 For Antenna BRecommended panel cutout dimension 9.6 PO5G 14.3 12.3 GT16 GT16C-1P/S-R 1.6 Board Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT13 Board Type (Screw Fastening Type) GT5 BMated condition Genuine Market Parts M Connectors φ Board Type (Lead Reflow Type) 16.2 GT13 0.1 12 1.4 (8.1) BRecommended PCB pattern GT16C-1P/S-R 1.6 Board GT16GL-1P-H(70) 2.4 11.6 (3) 6.9(4.7) 0.5 GT16G-1S-HU 10 .7M 2 Housing:PPS Inner Terminal: Light Gray GT16GL-1P-H(70) 766-0043-2 70 Phosphor bronze/Tin plating Outer Terminal: Phosphor bronze/Tin plating Insulator:PBT/Natural GT16GL-1P-H(71) 766-0043-2 71 Black Metal reinforcement: Brass/Tin plating 2-φ0.5 Through Hole 200 pcs/reel YES BRecommended panel cutout dimension 4-R X 5.3 15.7 6.25 18.4 GT3 12.4 MA Board BMated condition 2.2 GT16C-1P/S-R 9.6 3.5 GT10 14.3 12.3 (22.4) (8.1)(1.6) T=1.6 12 4.4 4.5 GT7 7.4 GT18W (1.5) Note : Use micro strip line and set so that dimension A has a characteristic impedance of 50ø. Board Type (Lock Pin Type) Cable GT16G-1S-HU(24) Board 7 (7.3) Panel GT16GR-1P-H BRecommended PCB pattern YES 1.8 0.5 4.4 Hole 1 0.4 Packaging RoHS R0. Thro 55 ugh 766-0059-2 Housing:PBT/Black Inner Terminal:Phosphor bronze/Tin plating Outer Terminal:Phosphor bronze/Tin plating Insulator:PBT/Natural Lock pin:Phosphor bronze/Tin plating AX Material/Plating or Color 2-φ0.5 Through Hole R0 .7M GT16GR-1P-H HRS No. 1.9 Part No. 15.7 5.2 A 6.25 11.6 (3) R0.95 4.3 2.3 1.3 7.3 4.6 2.4 0.25MAX 5.8 GT25 GT8E GT9 GT15 4.3 7.4 6 φ1.2 Through Hole 1.2 64 Panel 0.4 Packaging RoHS AX Color R0 Material/Plating 13.4 5.2 1.8 HRS No. 12.4 GT32 GT17 GT11 GT36 A Panel Part No. 4.7 Cable 10 GT26 4.9 Board (22.4) T=1.6 X 10 12.4 MA 5.8 BMated condition BRecommended panel cutout dimension 1.2 GT21 9.6 6.6(7.7) 2.2 4-R Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (3.1) 14.3 12.3 PO5G GT19 For Antenna GT16 9.2 1.1 GT5 GT16 Series ● For Antenna Panel (1.5) Double sided PCB board Note : Use micro strip line and set so that dimension A has a characteristic impedance of 50ø. GT16 Series ● For Antenna GT5 F Connector (Waterproof type) GT13 Housing 17 GT16 GT21 (52.1) (32.2) GT26 GT5W-1P/S-R GT36 GT5W-1P/S-R GT16GW-1P-HU Part No. GT16GW-1S-HU HRS No. Material Color Packaging RoHS 766-0076-1 PBT Silicon rubber Black White 1 YES GT11 Note: Assemble main parts with separated retainer part GT5W-1P/S-R (CL755-0028-5). GT17 M Connector (Waterproof type) GT32 Housing 14.5 GT3 GT7 18.5 36 GT10 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 20.6 GT19 BMated condition GT18W GT25 GT8E HRS No. Material Color Packaging RoHS 766-0077-4 PBT Black 1 YES GT15 Note: Assemble main parts with separate retainer part GT5W-1P/S-R (CL755-0028-5). GT9 Part No. GT16GW-1P-HU 65 For Antenna PO5G 30.7 PO5G GT19 GT21 햲Strip the cable. Note 1. See "Crimping Quality Standards Manual" for information about the end processing dimensions. Note 2. Before performing end processing, arrange cable ends to be perpendicular. (There shall be no cable crushing.) Note 3. Care must be taken so as not to damage the various cut portions of the center conductor, dielectric, and outer conductor. Note 1. Orient the terminal ferrule as illustrated in the diagram, align the slit portion of the terminal ferrule with the protruding portion of the crimp terminal, and then insert. Terminal ferrule Slit Protruding Dielectric Conductor Dielectric 햳Crimp the center terminal with the special jig. Note 1. See "Crimping Conditions Table" for information about the crimp height. Note 2. See "Crimping Quality Standards Manual" for information about crimping standards. 햷Set the aforementioned terminal block onto the insulator and enclose it from the top with one more insulator. Note 1. Set the protruding portion of the crimp terminal in the groove hole of the insulator. Note 2. Pull the cable with a force on the order of 4.9 N and check that the terminal block does note come out. Crimped p terminal Groove hole 햴Place the outside tube over the cable. Protruding portion Insulator Note 1. Pay attention to the placement direction of the outside tube. Outside tube GT17 GT11 햶Using the special jig, insert the terminal ferrule from the coupling side of the crimp terminal until it reaches the end. Outside conductor Coaxial cable GT36 GT26 B GT16G Wiring Method 햸Use the special tool to cover the insulator with GT32 the outside tube, which was previously inserted. 햵Widen the external conductor with the special tool, place the outer GT9 GT8E GT25 GT18W GT10 GT7 GT3 ferrule, and return the external conductor over the outer ferrule. GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For Antenna GT16 GT13 GT5 GT16 Series ● For Antenna 66 Note 1. Spread only the outer conductor without unravelling. Copper foil or aluminum foil shall not be spread, but shall be on the inside of the outer ferrule. Note 2. The orientation of the outer ferrule shall be as indicated in the diagram. Align the slit of the outer ferrule with the protruding portion of the crimp terminal and insert. Note 3. The outer ferrule shall be placed so that the portion of different level is inserted as far as the sheath end. Note 4. Pay attention to pinching of the external conductor (i.e., biting into the sheath) during the placement. Outside conductor Outer ferrule Note 1. Orient the outside tube as illustrated in the diagram, align the punched-in portion of the outside tube with the groove portion of the insulator (so that at both left and right, the split of the outer ferrule is aligned with the barrel bottom portion of the outside tube), and then insert. Note 2. Insert until the insulator stops at the lance of the outside tube. Groove portion Punched-in portion Slit (   90 ° ) Lance Portion of different level Slit 0.2±0.2 Copper foil, aluminum foil Portion of different level Protruding Copper foil, aluminum foil Outside conductor Barrel bottomportion GT16 Series ● For Antenna GT13 GT19 GT21 Groove Homologous GT36 Housing GT26 Protruding GT11 햻Insert the retainer into the housing. Note 1. Insert until the retainer stops at the housing. GT17 Retainer GT32 GT3 햽Inspect and complete the wiring. GT7 GT25 L2 GT18W L1 GT10 Note : The length (L) dimension after wiring and the cut cable length are described below. Cut cable length: L1 - 8.1 L2 + 11.0 GT8E GT9 GT15 67 For Antenna PO5G 햺Insert the aforementioned outside tube block into the housing. Note 1. Align the protruding portion of the outside tube with the groove portion of the housing, and then insert. Note 2. Insert until the outside tube stops at the lance of the housing. GT16 Clearance between insulator and outer ferrule 0.4MAX Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT5 햹Use the special jig to crimp the crimp terminal. Note 1. See "Crimping Conditions Table" for information about the crimping height. Note 2. See "Crimping Quality Standards Manual" for information about crimping standards. Conversion Adapter SMA Conversion Adapter (Coupling portion: GT16G side jack - SMA side jack) PO5G φ1 0 Note : The adapter does not have a lock portion and thus can only be used for performance measurements. Packaging RoHS 1 23 HRS No. 766-0031-3 YES (4) Part No. GT16GS-HRMJ 6 GT11 GT36 GT26 13 GT21 GT19 φ6 SMA Conversion Adapter (Coupling portion: GT16G side plug - SMA side jack) GT7 8 GT3 GT32 GT17 1/4-36UNS-2A GT10 φ1 0 Packaging RoHS 1 18.25 HRS No. 766-0030-0 YES 6 GT8E GT9 Part No. GT16GP-HRMJ (4) 8.25 Note : The adapter does not have a lock portion and thus can only be used for performance measurements. GT25 GT18W φ7.4 1/4-36UNS-2A GT15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. For Antenna 8 GT16 GT13 GT5 GT16 Series ● For Antenna 68 GT16 Series ● For Antenna GT5 B F Connector Composition Table GT16G-FR Outer Ferrule Inner Terminal GT16G-1.5DHQS GT16G-2428SCF Insulator GT16G-SC Outer Terminal Housing Retainer – GT16GM-/1.6-2.9SC GT16GM-1S-HU GT16G-1S-HU GT16G-1S-HU(24) GT16C-1P/S-R GT16G-/1.6-2.9SC GT16GD-1S-HU GT16GW-1S-HU GT5W-1P/S-R GT13 Terminal Ferrule GT16 GT16G-1.5DHQS Inner Terminal Insulator GT16G-2428PCF GT16G-PC Outer Terminal Housing GT16GM-1P-HU GT16G-/1.6-2.9PC GT16GMN-1PP-HU Retainer – GT5W-1P/S-R B Wiring Tools Printed Circuit Board Type Applicable Connectors Process 1 Cable strip processing Process 2 Center terminal crimping B Mating Table Process 5 Terminal ferrule insertion Schleuniger MP257, etc. (Commercial product) Crimping machine body type 105 쎵 AP105-GT16G-2428P Shield forming tool GT16G-1.5DHQS/CF-MD Outside ferrule insertion tool GT16G-1.5DHQS/PR-MD Terminal ferrule insertion tool GT16G-FR/PR-MD Crimping machine body type 105 쎵 AP105-GT16G-2428P Shield forming tool GT16G-1.5DHQS/CF-MD Outside ferrule insertion tool GT16G-1.5DHQS/PR-MD Terminal ferrule insertion tool GT16G-FR/PR-MD Manual task Manual task Process 6 Insulated washer assembly Insulated washer press tool GT16G-SC/PR-MD Process 7 Outside tube insertion Manual task Manual task High frequency characteristics test (Complete) Continuity / Withstand voltage test Inspection of external appearance High frequency characteristics test (Complete) Continuity / Withstand voltage test Inspection of external appearance Process 9 Housing, (retainer) installation GT32 Hand press MOS-7 쎵 GT16G-1.6-2.9P/CK-MP Process 8 Outside tube tightening Process 10 Inspection ‒ Hand press MOS-7 쎵 GT16G-1.6-2.9S/CK-MP GT17 M Connectors GT16GM-1P-H GT16GMP-1P-H GT16GM-1S-HU       GT16GM-1P-HU GT16GMN-1PP-HU GT16G-1P-H GT16GL-1P-H(70) GT16G-1S-HU GT16GB-1PP-HU GT16GL-1P-H(71) GT16G-1S-HU(24) GT16GR-1P-H GT16GD-1S-HU GT16GD-1P-H Schleuniger MP257, etc. (Commercial product) GT11 F Connectors       Process 4 Outside ferrule insertion GT16GM-1P-HU GT16GMN-1PP-HU GT36 Process 3 Cable forming GT16GM-1S-HU GT16G-1S-HU GT16G-1S-HU(24) GT16GD-1S-HU GT26 GT16GM-1P-H GT16GMP-1P-H GT16G-1P-H GT16GL-1P-H(70) GT16GL-1P-H(71) GT16GR-1P-H GT16GD-1P-H GT21 GT3 B Test Data (Using 1.5D-2W Type cable) High Frequency Characteristics (V.S.W.R.) GT7 High Frequency Characteristics (V.S.W.R.) 3.0 2.0 2.8 1.9 2.6 GT10 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. GT16GW-1P-HU GT19 GT16G-FR Outer Ferrule 1.8 2.4 1.7 1.6 2.0 1.5 GT18W 2.2 1.4 1.8 1.3 1.6 1.2 GT25 1.4 1.1 1.2 1.0 1.0 1.0 2.0 0 1 2 3 4 5 6GHZ 3.0GHZ Note: The measurement data shown above were obtained using the GT16G-1P-H and GT16G-1S-HU. GT8E Note: Typical data using fully assemblied and connected GT16-1P-H and the GT16-1S-HU. GT9 GT15 69 For Antenna Terminal Ferrule PO5G B M Connector Composition Table
GT16C-2P/S-R 价格&库存
很抱歉,暂时无法提供与“GT16C-2P/S-R”相匹配的价格&库存,您可以联系我们找货
