GT13
GT5
For Antenna
Features
Space-saving design
Compact and light comparing to HRS GT5 series.
Excellent high frequency performance
Refer to V.S.W.R. data on the following pages.
Applications
In-car communication, car sensors(temperature, pressure), automotive audio systems, GPS antenna
systems, RACS antenna audio/video antenna systems, CRT displays, medical and measuring
instrumentation LAN systems.
GT9
GT8E
GT25
GT18W
GT10
GT7
GT3
GT32
GT17
GT11
GT36
GT26
GT21
GT19
PO5G
— Subminiature Connectors for coaxial cables —
GT15
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
For Antenna
GT16
GT16 Series
48
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
GT16 Series ● For Antenna
GT5
GT16 Series
F Connectors (Common Use)
0.8
7.6
4
GT13
Center terminal
0.2
Material/Plating
Phosphor bronze/
Tin plating
Conductor Size
24 to 28 AWG
30 AWG
Packaging
RoHS
10,000 pcs/reel
YES
GT21
GT26
Insulator (Common Use)
φ3.4
φ3.2
φ3.8
GT11
φ4.4
GT36
GT17
HRS No.
766-0002-5
Material
PBT
Color
White
Packaging
1
RoHS
YES
GT3
Part No.
GT16-SC
GT32
GT7
M Connectors (Common Use)
0.8
9.25
Center Terminals
GT10
4
GT18W
0.2
φ0.72
GT25
φ1.28
GT19
HRS No.
766-0001-2
766-0055-1
GT8E
Material/Plating
Brass/Tin plating
Conductor Size
24 to 28 AWG
30 AWG
Packaging
RoHS
10,000 pcs/reel
YES
GT15
HRS No.
766-0006-6
766-0015-7
GT9
Part No.
GT16-2428PCF
GT16-30PCF
49
For Antenna
PO5G
φ1.28
GT16
Part No.
GT16-2428SCF
GT16-30SCF
GT13
GT5
φ2.8
φ3.8
PO5G
GT19
GT21
GT26
HRS No.
766-0007-9
Material
PBT
Color
White
Packaging
1
RoHS
YES
Without retainer type (F Connector)
Housing
GT11
GT36
Part No.
GT16-PC
Part No.
GT16F-1S-HU(A)
GT16F-1S-HU(B)
HRS No.
766-0082-4
766-0083-7
Material
PBT
Color
Brown
Green
Packaging
RoHS
1
YES
GT10
GT7
GT3
GT32
GT17
PBT *
Outer terminal
GT18W
15.7
GT25
φ5
7.2
GT8E
GT9
GT15
For Antenna
GT16
6.3
4.1
50
Part No.
GT16-/1.6-2.9SC
GT16-/0.7-1.5SC
HRS No.
766-0003-8
766-0056-4
Material/Plating
Phosphor bronze/
Tin plating
Insulator Diameter Outer Diameter
Ø1.5 to 2.0
Ø2.6 to 3.4
Ø0.6 to 0.9
Ø1.4 to 1.8
Packaging
RoHS
1
YES
GT5
Without retainer type (M Connector)
GT13
Housing
BMated condition
GT16F-1S-HU(A)
4.05
PBT
A
A
GT16F−1P−HU(A)
Material
Color
Brown
Green
PBT
Packaging
RoHS
1
YES
GT21
HRS No.
766-0086-5
766-0087-8
GT26
Outer terminals
GT36
GT11
Circuit Board Type(SMT Type)
RoHS
1
YES
BRecommended PCB pattern
9.8
Vacuum pick up area
1.2
3.95
7
9.3
GT3
2.8
13.1
4.1
10
BMated condition
(23)
3.8
GT16F−1P−H(A)
GT18W
(6.3)
HRS No.
GT16F-1P-H(B) 766-0079-0
Color
Packaging RoHS
Brown
1
YES
Green
GT9
Housing:PPS
Inner Terminal:Phosphor bronze/Tin plating
Outer Terminal:Phosphor bronze/Tin plating
Insulator:PPS/Natural
Shield plate:Phosphor bronze/Tin plating
Metal reinforcement:Brass/Tin plating
GT8E
GT16F-1P-H(A) 766-0078-7
Material/Plating
GT25
GT16F-1S-HU(A)
Part No.
GT10
5
GT7
16
16.7
3
Ø8
0.7
Packaging
1.2
Tin plating
Ø1.5 to 2.0
Ø2.6 to 3.4
Ø0.6 to 0.9
Ø1.4 to 1.8
6.3
Plating
14.5
Material
Phosphor
bronze
GT32
● Printed
HRS No.
766-0019-8
766-0018-5
GT17
Part No.
GT16C-/1.6-2.9PC
GT16C-/0.7-1.5PC
GT16F−1P−H(A)
GT19
Part No.
GT16F-1P-HU(A)
GT16F-1P-HU(B)
GT15
51
For Antenna
(6.3)
PO5G
9.1
GT16F−1P−HU(A)
(31.4)
PBT
GT16
10
25.1
Genuine Market Parts F Connectors
Housing (Retainer Stopper Specification)
7.5
10.1
GT26
GT21
GT16C−1S−HU
GT19
11.6
PO5G
17.5
Part No.
GT16C-1S-HU
GT16C-1S-HU(A)
GT16C-1S-HU(B)
HRS No.
766-0010-3
766-0060-1
766-0061-4
Material
PBT
Color
Light Gray
Brown
Green
Packaging
RoHS
1
YES
Outer terminal (Retainer Stopper Specification)
GT17
GT11
GT36
Note : This product is used in conjunction with retainer GT16C-1P/S-R (CL766-0011-6) which is a separate item.
15.7
Part No.
GT16C-/1.6-2.9SC
GT16C-/0.7-1.5SC
HRS No.
766-0012-9
766-0057-7
Material/Plating
Phosphor bronze/
Tin plating
Ø1.5 to 2.0
Ø2.6 to 3.4
Ø0.6 to 0.9
Ø1.4 to 1.8
Packaging
RoHS
1
YES
Retainer
2.15
11.2
1.25
GT25
R2.6
GT18W
GT10
GT7
GT3
φ5
GT32
7.2
GT9
5.6
GT8E
GT15
For Antenna
GT16
GT13
GT5
52
Part No.
GT16C-1P/S-R
HRS No.
766-0011-6
Material
PBT
Color
Dark Gray
Packaging
1
RoHS
YES
GT5
Genuine Market Parts M Connectors
GT13
GT16
7.5
11.1
12.2
10.15
0.8
(1.5)
HRS No.
766-0029-1
766-0064-2
766-0065-5
(1.5)
Material
Color
Light Gray
Brown
Green
PBT
Packaging
RoHS
1
YES
GT36
Part No.
GT16C-1PP-HU
GT16C-1PP-HU(A)
GT16C-1PP-HU(B)
(31.4)
GT26
GT11
Note: Use this product with separate retainer part GT16C-1P/S-R(CL766-0011-6).
2.5
9.6
10
0.2
0.7
GT32
15.1
BRecommended panel
cutout dimension
12.6
φ
13.2
5
18.2
Printed Circuit Board Type
(Reinforced Lock and Screw Fastening Type)
GT3
11.1
Board
4
BMated condition
7.475
4.1
6.575
( 23 )
6.575
7.5
7.475
1
GT18W
Panel
HRS No.
13.2
3 --φ
GT16C-1P/S-R
Part No.
4.1
T= 1.6
3.5
GT10
2 -φ
GT16C-1S-HU
( 1.5 )
BRecommended PCB
pattern
GT7
3 8.65
12.2
GT17
GT16C-1P/S-R
GT16C-1P/S-R
Board
Material/Plating
Packaging RoHS
Light Gray
Brown
Green
1
YES
GT8E
Note : Use mounting screws of M3 with nominal diameter 3L-6.
Color
GT25
Housing:PBT
GT16C-1P-DS
766-0013-1
GT16C-1P-DS(A) 766-0062-7 Insulator:Phosphor bronze/Tin plating
GT16C-1P-DS(B) 766-0063-0 Shield plate:Phosphor bronze/Tin plating
GT9
GT15
53
For Antenna
GT16C-1S-HU
GT21
GT16C-1PP-HU
GT19
4.8
BMated condition
PO5G
12
9.6
23.5
9.6
Panel Mounting Type
GT16
22.6
23.5
7.5
4
GT36
GT11
GT17
GT32
GT3
GT7
GT10
GT18W
GT25
GT8E
.5
2-
(1.5)
Part No.
GT16CB-1PP-HU
GT9
φ3
10
GT16C-1S-HU
12.6
(31.4)
HRS No.
766-0017-2
7.8
GT21
GT26
16.2
4-
GT15
8.95
7.6
PO5G
GT19
2.
BRecommended panel cutout dimension
Panel
GT16C-1P/S-R
54
2.1
φ
BMated condition
10.8
2-
For Antenna
16.2
12.2
GT13
GT5
.2
R1
Material/Plating or Color
Housing:PBT/Light Gray
Ground terminal:Copper alloy/Tin plating
Packaging
RoHS
1
YES
GT5
BGT16C Wiring Method
GT13
GT21
GT26
4. Insert the crimped
terminal into the
Insulator.
GT17
GT32
6. Crimp the outside
tube.
GT11
5. Insert the insulator
into the outside
tube.
GT36
GT3
7. Insert outer
terminal block into
the housing.
GT7
GT10
GT19
3. Crimp the center
terminal.
GT18W
8. Insert the retainer
into the housing.
GT25
GT8E
GT9
GT15
55
For Antenna
PO5G
2. Strip the cable.
GT16
1. Pass the cable
through the
outside tube.
Inner Terminal
Insulator
GT16-2428SCF
GT16-30SCF
GT16-SC
PO5G
GT19
GT21
GT26
GT36
GT11
Retainer
Housing
Outer Terminal
GT16-/1.6-2.9SC GT16F-1S-HU(A)
Not Used
GT16-/0.7-1.5SC GT16F-1S-HU(B)
GT16C-1S-HU
GT16C-/1.6-2.9SC
GT16C-1S-HU(A) GT16C-1P/S-R
GT16C-/0.7-1.5SC
GT16C-1S-HU(B)
F Connectors
GT16C-1S-HU
B M Connector Components Table
Inner Terminal
GT16-2428PCF
GT16-30PCF
Insulator
Outer Terminal
Housing
Retainer
GT16CB-1PP-HU
GT16F-1P-HU(A)
Not Used
GT16C-/1.6-2.9PC GT16F-1P-HU(B)
GT16C-/0.7-1.5PC GT16C-1PP-HU
GT16C-1PP-HU(A) GT16C-1P/S-R
GT16C-1PP-HU(B)
GT16-PC
M Connectors
GT16CB-1PP-HU
GT16C -1PP- HU
GT16C-1P-DS
B Key Variation
F Connectors
GT16F-1S-HU(A)
GT16F-1S-HU(B)
GT16C-1S-HU(A)
GT16C-1S-HU(B)
GT16F-1P-H(A)
GT16F-1P-H(B)
GT16C-1P-DS
GT16C-1P-DS(A)
GT16C-1P-DS(B)
M Connectors
GT16F-1P-HU(A)
GT16F-1P-H(A)
GT16F-1P-HU(B)
GT16F-1P-H(B)
GT16C-1P-HU(A)
GT16C-1P-DS(A)
GT16C-1P-HU(B)
GT16C-1P-DS(B)
B Crimping tools
User's manuals are available. Please ask your Hirose Electric account representative.
Automatic Crimping Machine
Picture reference only
Specifications
GT17
Item
GT32
Part No. CM-105C
GT3
* See the table below for
the product number of
the applicator.
Specification
Press capacity
1.5ton
Stroke Length
30mm
Number of strokes
200spm(50Hz)
Weight
75kg
Motor
0.2kW
Crimping speed
Remarks
240spm(60Hz)
AC100V
2,000∼4,000/H
GT9
GT8E
GT25
GT18W
GT10
GT7
Hand Press
GT15
For Antenna
B Mating Table
B F Connector Components Table
GT16
GT13
GT5
56
Harness Tool
Terminal Product No.
GT16 -2428SCF
GT16 -2428PCF
GT16 - 30SCF
GT16 - 30PCF
GT16 - /1.6 -2.9SC
GT16C - /1.6 -2.9SC
GT16C - /1.6 -2.9PC
GT16 - /0.7-1.5SC
GT16C - /0.7-1.5SC
GT16C - /0.7-1.5PC
Terminal HRS No.
766-0001-2
766-0006-6
766-0055-1
766-0015-7
766-0003-8
766-0012-9
766-0019-8
766-0056-4
766-0057-7
766-0018-5
Tool No.
Tool HRS No.
AP105-GT16-2428
901-5108-4
AP105-GT16-30
901-5124-0
GT16-1.6-2.9/CK-MP
902-5058-4
GT16-0.7-1.5/CK-MP
902-5064-7
* Crimp height setting tables are available for each cable type. Please contact your nearest Hirose Electric account representative.
* Different cables will require different crimp height settings.
GT5
GT16G Series
GT13
F and M Common Parts
Terminal Ferrule
GT16
0.6
GT19
HRS No.
Material
766-0028-9 Phosphor bronze
Plating
Packaging
RoHS
Tin plating
1
YES
GT26
GT36
Outer Ferrule
2.7
GT17
2.3
GT11
GT32
7.6
GT3
Part No.
GT16G-1.5DHQS
HRS No.
Material
766-0027-6 Phosphor bronze
Plating
Packaging
RoHS
Tin plating
1
YES
8.3
0.8
GT10
F Common Parts
GT7
4
Center Terminal
GT18W
GT25
0.2
GT8E
φ1.28
GT21
Part No.
GT16G-FR
GT9
Part No.
HRS No.
Material
766-0022-2 Phosphor bronze
Plating
Conductor Size
Packaging
RoHS
Tin plating
24 to 28 AWG
10,000 pcs/reel
YES
GT15
GT16G-2428SCF
57
For Antenna
PO5G
1.25
4.6
Insulator
GT16
GT13
GT5
10.1
6
R2
.2
1.
1.05
PO5G
3.8
GT19
Color
Packaging
RoHS
PBT
Natural
1
YES
M Common Parts
8.8
0.8
4
Center Terminal
GT32
φ1.28
φ0.72
GT17
GT11
GT36
GT21
Material
GT26
HRS No.
766-0023-5
Note : Two of these products are used per connection.
GT3
Insulator
HRS No.
Material
Plating
Conductor Size(AWG)
766-0046-0
Brass
Tin plating
24 to 28 AWG
Packaging
RoHS
10,000 pcs/reel YES
GT18W
GT10
GT7
Part No.
GT16G-2428PCF
GT25
7.4
GT8E
0.6
R1.
GT9
Part No.
GT15
Part No.
GT16G-SC
0.2
For Antenna
R
58
GT16G-PC
HRS No.
Material
Color
Packaging
RoHS
766-0047-3
PBT
Natural
1
YES
9
GT5
Outer Terminal
GT13
φ4.4
0.6
Material
Plating
Applicabie cable
Packaging
RoHS
Tin plating
1.5D-2W or equivalent
1
YES
GT21
GT26
F Connector (No retainer required type)
GT36
Housing
GT11
8.3
GT17
7.1
19.1
GT32
GT3
Part No.
GT16GM-1S-HU
HRS No.
Material
Color
Packaging
RoHS
766-0033-9
PBT
Black
1
YES
GT7
Outer Terminal
GT10
GT18W
17.2
8
GT25
φ5
5.7
GT19
HRS No.
GT8E
GT9
HRS No.
Material
Plating
Applicabie cable
Packaging
RoHS
Tin plating
1
YES
GT15
Part No.
GT16GM-/1.6-2.9SC 766-0025-0 Phosphor bronze
59
For Antenna
PO5G
Part No.
GT16G-/1.6-2.9PC 766-0048-6 Phosphor bronze
GT16
17.4
8
M Connector (No retainer required type)
Housing
25.6
9.8
PO5G
BMated condition
GT21
GT19
(33.7)
(8.1)
GT16GM-1P-HU
Part No.
HRS No.
Material
Color
Packaging
RoHS
766-0050-8
PBT
Black
1
YES
GT16GM-1S-HU
Housing (Bracket mounting type)
GT11
GT36
GT26
Cable
Cable
GT16GM-1P-HU
GT32
GT17
17
4.5
(8.1)
GT7
9.8
Cable
Cable
GT16GM-1S-HU
GT9
GT8E
GT25
GT18W
GT10
GT16GMN-1PP-HU
60
Part No.
HRS No.
Material
Color
Packaging
RoHS
GT16GMN-1PP-HU
766-0051-0
PBT
Black
1
YES
9
GT3
(33.7)
11.4
25.6
BMated condition
GT15
For Antenna
GT16
9
GT13
GT5
GT5
Board Type (Lock Pin Type)
1.2
13.5
MA
10.2
X
AX
.5M
R2
Board
5
GT16
7.4
9.4
4
16.2
3-R
GT13
BRecommended panel
cutout dimension
9.8
14.3
12.3
BMated condition
4.2
3.95
T=1.6
9
7 (
(7.3)
5.8
GT16GM-1P-H
Panel
2.4
11.6
4.3
(3)
R0.95
2-φ0.5 Through Hole
4.4
0.5
1.1
YES
R
Throu 0.55
gh Ho
le
Panel
1
R0. 1.9
7M
AX
766-0032-6
Housing:PBT/Black
Insulator:PBT/Natural
Lock pin:Phosphor bronze/Tin plating
RoHS
0.4
Packaging
7.3
(1.5)
Double sided PCB board
* Use micro strip line and set so that dimension
A has a characteristic impedance of 50ø.
R1.2
Board
0.3
T=1
13.1
16
Board
Panel
GT16GM-1S-HU
9.1
GT7
9.8
16.6
13
GT10
5
9.5
0.8
3.95
5.6 6
5.5
17.45
8.1
7
(3)
0.7
200 pcs/reel
YES
0.55
0.4
5.5
0.5
2-φ0.5 Through Hole
Board
8.2
17.6
0.95
A
7
5.55
4.4
RoHS
2.5
3.6
6
Panel
(1.5)
18.05
dimension A has a characteristic
impedance of 50 ø.
GT15
766-0052-3
Housing:PPS/Black
Insulator L,R:PPS/Natural
Metal fittings:Brass/Tin plating
Packaging
GT9
GT8E
GT16GMP-1P-H
HRS No.
GT25
1.1
2-φ
0.3
GT18W
Part No.
GT3
5
10.2
9.4
16.6
6.6
R1.2
GT32
(24.7)
(8.1)
17.6
GT17
BMated condition BRecommended panel
cutout dimension
Board Type (SMT Type)
GT11
GT36
GT16GM-1P-H
HRS No.
13.5
5.2
1.8
Part No.
4.15
10.2
A
2.3
1.3
GT26
5.8
0.25MAX
GT21
GT16GM-1S-HU
GT19
Cable
Borad
61
For Antenna
2.2
PO5G
(22.4)
(8.1)
F Connector (Retainer required type)
Housings
GT16
GT13
GT5
Part No.
HRS No.
GT16G-1S-HU
766-0026-3
GT16G-1S-HU(24) 766-0026-3 24
Material
PBT
Color
Light Gray
Black
Packaging
RoHS
1
YES
Note : Use this product with separate retainer part GT16C-1P/S-R (CL766-0011-6).
GT36
GT26
GT21
GT19
11.6
10.1
PO5G
19.1
GT11
Outer Terminal
17.2
6.3
0.6
GT32
φ5
GT17
8
GT3
GT7
GT10
GT18W
GT25
GT8E
GT9
GT15
For Antenna
7.5
62
Part No.
HRS No.
Material
GT16G-/1.6-2.9SC 766-0024-8 Phosphor bronze
Plating
Applicable cable
Packaging
RoHS
Tin plating
1
YES
2.
5
(22.4)
(8.1)
T=1.6
5
21
16
Cable
GT16G-1P-H
GT16G-1S-HU
Panel
4-R
MA
10
X
4.9
12.4
Board
7 (7.3)
2.2
2.4
11.6
2-φ
(3)
4.3
A
GT26
5.8
3.5
GT21
10
16
5.2
1.8
2-φ0.5 Through Hole
0.4
GT36
X
MA
Packaging RoHS
1
2-
Panel
0.5
(1.6)
(24.7)
(8.1)
13.4
T=1.6
GT16C-1P/S-R
10
2-R1.2MAX
GT16GD-1P-H
GT16GD-1S-HU
Panel
Board
GT7
17.6
15.8
13
16.6
13
5.4
7
(1.5)
Panel
.2
φ1
0.4
A
GT8E
1
1.
φ
7
4.4
18.8
1.1
5
HRS No.
Housing:PPS/Black
InsulatorL,R:PPS/Natural
Packaging RoHS
200 pcs/reel
YES
7
11.5
17.45
18.05
(3)
Note : Use micro strip line and set so that
impedance of 50ø.
GT15
GT16GD-1P-H 766-0044-5
2.5
3.6
GT9
Part No.
GT25
0.5
2-φ0.5
Through Hole
2-
10
6
Board
3
GT18W
8
5
BRecommended PCB
pattern
5
1.1
7
11
20.8
1.4
5
10
GT10
6
GT3
5.55
BRecommended panel
cutout dimension
GT32
BMated condition
GT17
Note 1: Suitable mounting screws are JIS B 1122 pan
head tapping screws class 2, nominal diameter
3, length 6.
Note 2: Use micro strip line and set so that dimension A
YES
(1.5)
7.3
GT11
GT16G-1P-H 766-0021-0
10.4
HRS No.
.7
R0
0.2
Part No.
GT19
4.7 4.1
12
1.2
63
For Antenna
BRecommended panel
cutout dimension
9.6
PO5G
14.3
12.3
GT16
GT16C-1P/S-R
1.6
Board
GT13
Board Type (Screw Fastening Type)
GT5
BMated condition
φ
Board Type (Lead Reflow Type)
16.2
GT13
0.1
12
1.4
(8.1)
GT16C-1P/S-R
1.6
Board
GT16GL-1P-H(70)
2.4 11.6 (3)
6.9(4.7)
0.5
GT16G-1S-HU
10
.7M
2
Housing:PPS
Inner Terminal:
Light Gray
GT16GL-1P-H(70) 766-0043-2 70
Outer Terminal:
GT16GL-1P-H(71) 766-0043-2 71
Black
Brass/Tin plating
2-φ0.5 Through Hole
200 pcs/reel
YES
dimension
4-R
X
5.3
15.7
6.25
18.4
GT3
12.4
MA
Board
BMated condition
2.2
GT16C-1P/S-R
9.6
3.5
GT10
14.3
12.3
(22.4)
(8.1)(1.6)
T=1.6
12
4.4
4.5
GT7
7.4
GT18W
(1.5)
impedance of 50ø.
Cable
GT16G-1S-HU(24)
Board
7 (7.3)
Panel
GT16GR-1P-H
YES
1.8
0.5
4.4
Hole
1
0.4
Packaging RoHS
R0.
Thro 55
ugh
766-0059-2
Housing:PBT/Black
AX
2-φ0.5 Through Hole
R0
.7M
GT16GR-1P-H
HRS No.
1.9
Part No.
15.7
5.2
A
6.25
11.6 (3) R0.95
4.3
2.3
1.3
7.3
4.6
2.4
0.25MAX
5.8
GT25
GT8E
GT9
GT15
4.3
7.4
6 φ1.2 Through Hole
1.2
64
Panel
0.4
Packaging RoHS
AX
Color
R0
Material/Plating
13.4
5.2
1.8
HRS No.
12.4
GT32
GT17
GT11
GT36
A
Panel
Part No.
4.7
Cable
10
GT26
4.9
Board
(22.4)
T=1.6
X
10
12.4
MA
5.8
BMated condition
BRecommended panel
cutout dimension
1.2
GT21
9.6
6.6(7.7)
2.2
4-R
(3.1)
14.3
12.3
PO5G
GT19
For Antenna
GT16
9.2
1.1
GT5
Panel
(1.5)
impedance of 50ø.
GT5
F Connector (Waterproof type)
GT13
Housing
17
GT16
GT21
(52.1)
(32.2)
GT26
GT5W-1P/S-R
GT36
GT5W-1P/S-R
GT16GW-1P-HU
Part No.
GT16GW-1S-HU
HRS No.
Material
Color
Packaging
RoHS
766-0076-1
PBT
Silicon rubber
Black
White
1
YES
GT11
Note: Assemble main parts with separated retainer part GT5W-1P/S-R (CL755-0028-5).
GT17
M Connector (Waterproof type)
GT32
Housing
14.5
GT3
GT7
18.5
36
GT10
20.6
GT19
BMated condition
GT18W
GT25
GT8E
HRS No.
Material
Color
Packaging
RoHS
766-0077-4
PBT
Black
1
YES
GT15
Note: Assemble main parts with separate retainer part GT5W-1P/S-R (CL755-0028-5).
GT9
Part No.
GT16GW-1P-HU
65
For Antenna
PO5G
30.7
PO5G
GT19
GT21
햲Strip the cable.
Note 1. See "Crimping Quality Standards Manual" for
information about the end processing dimensions.
Note 2. Before performing end processing, arrange cable
ends to be perpendicular. (There shall be no cable
crushing.)
Note 3. Care must be taken so as not to damage the various
cut portions of the center conductor, dielectric, and
outer conductor.
Note 1. Orient the terminal ferrule as illustrated in the
diagram, align the slit portion of the terminal ferrule
with the protruding portion of the crimp terminal,
and then insert.
Terminal ferrule
Slit
Protruding
Dielectric
Conductor
Dielectric
햳Crimp the center terminal with the special jig.
Note 1. See "Crimping Conditions Table" for information
about the crimp height.
Note 2. See "Crimping Quality Standards Manual" for
information about crimping standards.
햷Set the aforementioned terminal block onto the insulator
and enclose it from the top with one more insulator.
Note 1. Set the protruding portion of the crimp terminal in
the groove hole of the insulator.
Note 2. Pull the cable with a force on the order of 4.9 N and
check that the terminal block does note come out.
Crimped
p terminal
Groove hole
햴Place the outside tube over the cable.
Protruding portion
Insulator
Note 1. Pay attention to the placement direction of the
outside tube.
Outside tube
GT17
GT11
햶Using the special jig, insert the terminal ferrule from the
coupling side of the crimp terminal until it reaches the end.
Outside conductor Coaxial cable
GT36
GT26
B GT16G Wiring Method
햸Use the special tool to cover the insulator with
GT32
the outside tube, which was previously inserted.
햵Widen the external conductor with the special tool, place the outer
GT9
GT8E
GT25
GT18W
GT10
GT7
GT3
ferrule, and return the external conductor over the outer ferrule.
GT15
For Antenna
GT16
GT13
GT5
66
Note 1. Spread only the outer conductor without unravelling.
Copper foil or aluminum foil shall not be spread, but
shall be on the inside of the outer ferrule.
Note 2. The orientation of the outer ferrule shall be as
indicated in the diagram. Align the slit of the outer
ferrule with the protruding portion of the crimp
terminal and insert.
Note 3. The outer ferrule shall be placed so that the portion
of different level is inserted as far as the sheath end.
Note 4. Pay attention to pinching of the external conductor
(i.e., biting into the sheath) during the placement.
Outside conductor
Outer ferrule
Note 1. Orient the outside tube as illustrated in the diagram,
align the punched-in portion of the outside tube with
the groove portion of the insulator (so that at both
left and right, the split of the outer ferrule is aligned
with the barrel bottom portion of the outside tube),
and then insert.
Note 2. Insert until the insulator stops at the lance of the
outside tube.
Groove portion Punched-in portion
Slit
90
Lance
Portion of
different level
Slit
0.2±0.2
Copper foil, aluminum foil
Portion of different level
Protruding
Outside conductor
Barrel bottomportion
GT13
GT19
GT21
Groove
Homologous
GT36
Housing
GT26
Protruding
GT11
햻Insert the retainer into the housing.
Note 1. Insert until the retainer stops at the housing.
GT17
Retainer
GT32
GT3
햽Inspect and complete the wiring.
GT7
GT25
L2
GT18W
L1
GT10
Note : The length (L) dimension after wiring and the cut cable length are
described below.
Cut cable length: L1 - 8.1
L2 + 11.0
GT8E
GT9
GT15
67
For Antenna
PO5G
햺Insert the aforementioned outside tube block into the housing.
Note 1. Align the protruding portion of the outside tube with
the groove portion of the housing, and then insert.
Note 2. Insert until the outside tube stops at the lance of the
housing.
GT16
Clearance between insulator and outer ferrule 0.4MAX
GT5
햹Use the special jig to crimp the crimp terminal.
about the crimping height.
Conversion Adapter
SMA Conversion Adapter (Coupling portion: GT16G side jack - SMA side jack)
PO5G
φ1
Note : The adapter does not have a lock portion and thus can only
be used for performance measurements.
Packaging RoHS
1
23
HRS No.
766-0031-3
YES
(4)
Part No.
GT16GS-HRMJ
6
GT11
GT36
GT26
13
GT21
GT19
φ6
SMA Conversion Adapter (Coupling portion: GT16G side plug - SMA side jack)
GT7
8
GT3
GT32
GT17
1/4-36UNS-2A
GT10
φ1
Packaging RoHS
1
18.25
HRS No.
766-0030-0
YES
6
GT8E
GT9
Part No.
GT16GP-HRMJ
(4)
8.25
GT25
GT18W
φ7.4
1/4-36UNS-2A
GT15
For Antenna
8
GT16
GT13
GT5
68
GT5
B F Connector Composition Table
GT16G-FR
Outer Ferrule
Inner Terminal
GT16G-1.5DHQS GT16G-2428SCF
Insulator
GT16G-SC
Outer Terminal
Housing
Retainer
GT16GM-/1.6-2.9SC GT16GM-1S-HU
GT16G-1S-HU
GT16G-1S-HU(24) GT16C-1P/S-R
GT16G-/1.6-2.9SC
GT16GD-1S-HU
GT16GW-1S-HU
GT5W-1P/S-R
GT13
Terminal Ferrule
GT16
GT16G-1.5DHQS
Inner Terminal
Insulator
GT16G-2428PCF GT16G-PC
Outer Terminal
Housing
GT16GM-1P-HU
GT16G-/1.6-2.9PC
GT16GMN-1PP-HU
Retainer
GT5W-1P/S-R
B Wiring Tools
Applicable Connectors
Process 1 Cable strip processing
Process 2 Center terminal crimping
B Mating Table
Process 5 Terminal ferrule insertion
Schleuniger MP257, etc. (Commercial product)
Crimping machine body type 105
쎵
AP105-GT16G-2428P
Shield forming tool
GT16G-1.5DHQS/CF-MD
Outside ferrule insertion tool
GT16G-1.5DHQS/PR-MD
Terminal ferrule insertion tool
GT16G-FR/PR-MD
쎵
AP105-GT16G-2428P
Shield forming tool
GT16G-1.5DHQS/CF-MD
GT16G-1.5DHQS/PR-MD
GT16G-FR/PR-MD
Manual task
Manual task
Process 6 Insulated washer assembly
Insulated washer press tool
GT16G-SC/PR-MD
Process 7 Outside tube insertion
Manual task
Manual task
High frequency characteristics test (Complete)
Continuity / Withstand voltage test
Inspection of external appearance
Process 9 Housing, (retainer) installation
GT32
Hand press MOS-7
쎵
GT16G-1.6-2.9P/CK-MP
Process 8 Outside tube tightening
Process 10 Inspection
Hand press MOS-7
쎵
GT16G-1.6-2.9S/CK-MP
GT17
M Connectors
GT16GM-1P-H
GT16GMP-1P-H
GT16GM-1S-HU
GT16GM-1P-HU
GT16GMN-1PP-HU
GT16G-1P-H
GT16GL-1P-H(70)
GT16G-1S-HU
GT16GB-1PP-HU
GT16GL-1P-H(71)
GT16G-1S-HU(24)
GT16GR-1P-H
GT16GD-1S-HU GT16GD-1P-H
GT11
F Connectors
Process 4 Outside ferrule insertion
GT16GM-1P-HU
GT16GMN-1PP-HU
GT36
Process 3 Cable forming
GT16GM-1S-HU
GT16G-1S-HU
GT16G-1S-HU(24)
GT16GD-1S-HU
GT26
GT16GM-1P-H
GT16GMP-1P-H
GT16G-1P-H
GT16GL-1P-H(70)
GT16GL-1P-H(71)
GT16GR-1P-H
GT16GD-1P-H
GT21
GT3
B Test Data (Using 1.5D-2W Type cable)
High Frequency Characteristics (V.S.W.R.)
GT7
3.0
2.0
2.8
1.9
2.6
GT10
GT16GW-1P-HU
GT19
GT16G-FR
Outer Ferrule
1.8
2.4
1.7
1.6
2.0
1.5
GT18W
2.2
1.4
1.8
1.3
1.6
1.2
GT25
1.4
1.1
1.2
1.0
1.0
1.0
2.0
2
3
4
5
6GHZ
3.0GHZ
Note: The measurement data shown above were obtained using the GT16G-1P-H and GT16G-1S-HU.
GT8E
Note: Typical data using fully assemblied and connected GT16-1P-H and the GT16-1S-HU.
GT9
GT15
69
For Antenna
Terminal Ferrule
PO5G
B M Connector Composition Table
