HRFCP-HSCJ-1(60)
HRFCP-HSCJ-1(60)
    HRS(广濑)
HRFCP-HSCJ-1(60) 数据手册
FC Type Fiber Optic Connectors Environment MU Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC SC HRFC Series ■Features Attenuators 1. JIS, IEC standard compliant and intermateability test certified. Comply with IEC 61754-13 and JIS C 5970(type F01). FC intermate test by NTT certified connector. 2.Polishing Available with PC polishing, advanced PC(AdPC) polishiing and Angled PC(APC) polishing. 3.Flame resistant Terminators Satisfies flammability rating UL94V-0. ■Applications POF / PCF Public communications lines, CATV, Test equipment, etc. 30 In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. HRFC Series●FC Type Fiber Optic Connectors ■Product Specifications Operating temperature range Mechanical Characteristics Return Loss Test Method (IEC 61300) -25°C to +70°C Specifications (SM) Wavelength 1310nm (LD) 0.5dB max. (PC, AdPC, APC) (GI) Wavelength 1310nm (LED) 0.3dB max. (PC) (SM) (GI) Wavelength 1310nm (LD) 22dB min. (PC), 40dB min. (AdPC), 60dB min. (APC) 22dB min. (PC) Ferrule withdrawal Extract zirconia gauge 2.499 ±0.0005mm dia from split sleeve. Phosphor bronze split sleeve Zirconia split sleeve Cable retention (Straight pull) 98N tensile load for 1 minute. 1) Insertion loss fluctuation after test: 0.2dB max. 2) No visible damage, dislocation of clamp or cable. Durability (cycles, mating/un-mating) 1000 times Vibration Frequency: 10 to 55 Hz, single amplitude of 0.75mm, 2 hours in each of the 3 axis. Shock Acceleration of 981 m/s2, 6 ms duration, half sine shock pulse, 10 cycles in each of the 3 axis. -10°C to 65°C, humidity: 90% to 96% 10 cycles Change of temperature -40°C to +75°C 42 cycles (Complies with Telcordia standard GR-326-CORE) Dry heat 240 hours at 85°C Cold 240 hours at -25°C Salt mist 48 hours in a 5% concentration of salt mist 1) Insertion loss fluctuation after test: 0.2dB max. 2) No visible damage, cracks or part dislocation. Harsh Environment Humidity (Temperature/ humidity- cycles) 2N to 5.9N 2N to 3.9N MU Environmental Characteristics Insertion Loss Storage temperature range FC No significant corrosion. ■Materials Part Material Plug housing Brass, Zinc alloy Spring Stainless steel Ferrule Zirconia Adapter Brass Split sleeve Zirconia or Phosphor bronze Receptacle Brass Attenuators Terminators Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Optical Characteristics Item -25°C to +70°C SC Ratings POF / PCF 31 HRFC Series●FC Type Fiber Optic Connectors SC ■FC products Plug Housing For 2mm cord, Molded keying ring type For 0.9mm fiber, Molded keying ring type MU Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC For 3mm cord, Molded keying ring type Single mode Multi mode Ferrule HRFC-type Connector Environment Adapter Round type Attenuators Conversion adapter Receptacle POF / PCF Terminators Dust cap 32 Standard type FC to SC Solid Body type Flange type FC to SC HRFC Series●FC Type Fiber Optic Connectors ■Plug Housing Please use it with the SC ferrules. SC *'#- ¢&% B-%#,* ●For 2mm cable FC CL No. Boot color Polishing type HRFC-P8-H2(63) 701-0075-3-63 Blue PC HRFC-P8-L2(61) 701-0077-9-61 Light purple AdPC HRFC-P8-G2(62) 701-2001-8-62 Green APC Boot color Polishing type Note: Guide key width is 2.1mm ●For 3mm cable MU ¢&% B-%#,* *'#- Part Number CL No. HRFC-P8-H3(62) 701-0074-0-62 Blue PC HRFC-P8-L3(61) 701-0078-1-61 Light purple AdPC HRFC-P8-G3(61) 701-2002-0-61 Green APC Harsh Environment Note: Guide key width is 2.1mm ●For 0.9mm fiber B-%#,* ¢&% (%#- Attenuators CL No. Boot color Polishing type HRFC-P15-H(62) Part Number 701-0114-3-62 Blue PC HRFC-P15-L(62) 701-0115-6-62 Light purple AdPC HRFC-P15-G(61) 701-2004-6-61 Green APC Terminators Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part Number Note: Guide key width is 2.1mm POF / PCF 33 HRFC Series●FC Type Fiber Optic Connectors ■Adapters SC ●Solid Body type &* ) &* .#* ■Panel Cutout B-£%#,* B-£%#,* Ø9 FC '£'#' 2∞M2∞0.4 or 2∞Ø2.4 +0.2 0 .#* &* ;8"6 ` h^c iZg #' ¢' djc &#* 8  ¢) Zei] Y 13.4±0.1 Part Number CL No. Split sleeve Remarks HRFC-PA11-G1(40) 701-0071-2-40 Phosphor bronze -------- HRFC-PA11-D1(40) 701-0106-5-40 Zirconia (Note) Note: Please take utmost care when inserting FC plug into a FC adapter. When applying excessive force to the FC plug or inserting in an odd angle, the zirconia sleeve within the adapter might be dameged ●Standard Body type &* &* ) .#* ■Panel Cutout ¢. Environment '£'#' MU 'B-%#,* %#* % 'B'%#) dg'¢'#) %%#' ;8"6 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh +0.5 0 ¢'#' ¢)8djciZgh^c`YZei]&#* &(#)¤%#& Part Number CL No. Mark Split sleeve Remarks HRFC-PA1-G1(41) 701-0014-9-41 FC-AP Phosphor bronze -------- HRFC-PA1-D1(40) 701-0089-8-40 FC-A Zirconia (Note) Note: Please take utmost care when inserting FC plug into a FC adapter. When applying excessive force to the FC plug or inserting in an odd angle, the zirconia slleve within the adapter might be dameged ●Flange type ■Panel Cutout &* ' ¢. %#* % 'B'%#) dg'¢'#) %#' % '£'#' ¢&. &(#)* Attenuators 'B-%#,* '¢'#' '¢)8djciZgh^c`YZei]&#* Terminators Part Number &(#)¤%#& CL No. Split sleeve Remarks HRFC-PA4-G1(40) 701-0068-8-40 Phosphor bronze -------- HRFC-PA4-D1(40) 701-0112-8-40 Zirconia (Note) Note: Please take utmost care when inserting FC plug into a FC adapter. When applying excessive force to the FC plug or inserting in an odd angle, the zirconia sleeve within the adapter might be dameged ●Round type &* Part Number ¢- POF / PCF '£'#' 'B-%#,* CL No. Split sleeve Remarks HRFC-A2-SF(41) 701-0039-0-41 Phosphor bronze -------- HRFC-A2-SF-D1(40) 701-0140-3-40 Zirconia (Note) Note: Please take utmost care when inserting FC plug into a FC adapter. When applying excessive force to the FC plug or inserting in an odd angle, the zirconia sleeve within the adapter might be dameged 34 HRFC Series●FC Type Fiber Optic Connectors ■Conversion adapters ■Panel Cutout '&#' *#* (#* &'#' ¢. %%#* î& * 'B-%#,* &'#¢&. 'B'%#) dg'¢'#) %#' % &(#)¤%#& . &(#) Part Number CL No. Split sleeve HSCJ-HRFCJ-B(43) 704-0021-3-43 Phosphor bronze FC 13.7 (3.9) 9 12.8 32 Part Number CL No. HRFCP-HSCJ-1(61) 7.4 Ø19 9.15 15 ●FC / SC MU Split sleeve Polishing type 701-0065-0-61 HRFCP-HSCJ-1AS(61) 701-0108-0-61 HRFCP-HSCJ-2(61) 701-0085-7-61 PC GI-50/125 AdPC Phosphor bronze PC HRFCP-HSCJ-2AS(61) 701-0109-3-61 Fiber type Harsh Environment SM-9.5/125 AdPC The positions of SC guide slot and FC guide key will not be always aligned. ●FC / SC . &'#- B-%#,* ,#) .#) '& ',#. &#- Part Number CL No. HSCP-HRFCJ-1(61) Split sleeve Polishing type Phosphor bronze AdPC 704-0203-0-61 HSCP-HRFCJ-1AS(61) 704-0288-3-61 HSCP-HRFCJ-2(61) Attenuators 704-0204-3-61 PC PC HSCP-HRFCJ-2AS(61) 704-0289-6-61 AdPC Fiber type GI-50/125 SM-9.5/125 Terminators Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. SC ●FC / SC The positions of SC guide key and FC guide slot will not be always aligned. ■Receptacle ■Panel Cutout . ( î &* *#* ¢. î .#* %#* % )B'%#) dg)¢'#) B-%#,* POF / PCF ;8"G '#' )¢'#' ¢)8djciZgh^c`YZei]&#* Part Number %#' % .#*¤%#& CL No. Remarks HRFC-R1(41) 701-0016-4-41 GI HRFC-R2(41) 701-0023-0-41 SM 35 HRFC Series●FC Type Fiber Optic Connectors ■Ferrule SC Please use the SC connector's ferrule. Part Number HRFC-C1(40) MU Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Harsh FC ■Dust Cap ■Tool ●Crimp tool POF / PCF Terminators Attenuators Environment Please use the SC connector's crimp tool . 36 CL No. 701-0019-2-40
HRFCP-HSCJ-1(60) 价格&库存
很抱歉,暂时无法提供与“HRFCP-HSCJ-1(60)”相匹配的价格&库存,您可以联系我们找货
