FH36-19S-0.3SHW(10)
FH36-19S-0.3SHW(10)
    HRS(广濑)
FH36-19S-0.3SHW(10) 数据手册
0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors FH36 Series 1.0mm MAX ●Space saving (51 positions shown) 2.7mm [51 Positions] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 16.9mm ■Features Metal fittings do not protrude outside of the connector body 1. Low-profile and light weight Weight: Reduced approximately 30% Board footprint: Reduced approximately 15% (As compared with Hirose Electric's FH26 Series connectors (51 positions) ●Can be mounted over conductive traces 2. Easy solderability on the PC board The soldering leads are on 0.6 mm pitch, exiting on front and back of the connector. 3. Conducive traces on the PCB can run under the connector No exposed contacts on the bottom of the connector. 4. Easy FPC insertion and reliable electrical connection Proven Flip Lock actuator allows easy insertion of FPC and provides a tactile sensation when fully closed, confirming complete electrical and mechanical connection. No exposed contacts on the bottom of the connector ●Operation (1) Actuator open (2) Insert FPC Actuator FPC 5. FPC position hold Tabs on each side of the FPC assure correct placement and hold in the connector prior to closing of the actuator. (3) Close the actuator (4) FPC connected 6. Accepts standard FPC thickness 0.2mm thick standard Flexible Printed Circuit (FPC) can be used. This is the only ultra-low profile ZIF connector using standard FPC. 7. Board placement with automatic equipment Flat upper surface and tape and reel packaging facilitate vacuum pick-up and placement. Standard reel packaging contains 5,000 connectors. ●FPC temporary hold 8. Halogen-free * (FH36W Series) *As defined by IEC61249-2-21 Br-900ppm maximum, Cl-900ppm maximum, Cl + Br combined-1,500ppm maximum 2013.11② 1 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors ■Specifications Operating Current rating 0.2 A DC (Note 1) -55 to +85°C (Note 2) temperature range Operating Relative humidity 90% Voltage rating 30 Vrms AC humidity range max. (No condensation) Rating Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Recommended FPC Storage -10 to +50°C (Note 3) temperature range Storage Relative humidity 90% humidity range max. (No condensation) Thickness: 0.2±0.03mm Gold plated Item Specification 1.Insulation resistance 50 Mø min 2.Withstanding voltage No flashover or insulation breakdown 100 mø max. 3.Contact resistance * Including FPC conductor resistance Contact resistance: 100 mø max. 4.Durability No damage, cracks, or parts dislocation No electrical discontinuity of 1 μs or longer 5.Vibration Contact resistance: 100 mø max. No damage, cracks, or parts dislocation No electrical discontinuity of 1 μs or longer 6.Shock Contact resistance: 100 mø max. No damage, cracks, or parts dislocation Contact resistance: 100 mø max. 7.Humidity Insulation resistance: 50 Mø min. (Steady state) No damage, cracks, or parts dislocation Contact resistance: 100 mø max. 8.Temperature cycle Insulation resistance: 50 Mø min. No damage, cracks, or parts dislocation Conditions 100 V DC 90 Vrms AC / one minute 9.Resistance to soldering heat 1) Reflow: At the recommended temperature profile. 2) Manual soldering: 350ç ± 10ç for 5 seconds 1 mA 10 cycles Frequency: 10 to 55 Hz, single amplitude of 0.75 mm 10 cycles in each of the 3 directions Acceleration of 981m/s2, 6 ms duration, sine half-wave, 3 cycles in each of the 3 axis 96 hours at a temperature of 40°C and humidity of 90 to 95% Temperature:-55ç➝+15ç to +35ç➝+85ç➝+15ç to +35ç Time: 30➝ 2 to 3 ➝ 30➝ 2 to 3 minutes 5 cycles No deformation of components affection performance. Note 1: When passing the current through all of the contacts, use 70% of the rated current. Note 2: Includes temperature rise caused by current flow. Note 3: The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage, shipment or during transportation. ■Materials Part Material Insulator LCP Actuator Finish Color: Beige FH36 series: Dark brown PA Contacts UL94V-0 FH36W series: Light brown UL94HB Gold plating ----------------- Pure tin reflow plating ----------------- Phosphor bronze Metal fittings Remarks ■Ordering information FH 36 W - 51S - 0.3 SHW (50) 1 2 3 4 5 6 7 1 Series name : FH 4 Number of positions : 11 to 61 2 Series No. : 36 5 Contact pitch : 0.3mm 3 Blank :Standard W :Halogen-free (Flame retardance UL94HB). 6 Termination type: SMT horizontal staggered mounting type 7 specifications (50)…Gold plating with nickel barrier 5,000 pieces/reel (99)…Gold plating with nickel barrier 500 pieces/reel 2 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors ■Connector Dimensions A±0.15 B±0.1 0.3±0.1 0.6±0.1 (0.12) (2.75) (1) Lot No. indicator A** HRS mark 0.6±0.1 Cav No. Number of contacts indicator (0.12) (1.0 MAX) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. C±0.1 (0.47) (D: FPC insertion slot dimension) E±0.1 1 (0.25) 1 0.1 0.1 (2.7) Note 1 : The coplanarity of each terminal lead is within 0.1. Note 2 : Packaged on tape and reel only. Check packaging specification. Note 3 : Slight discoloration in color of the plastic compounds does not affect form, fit or function of the connector. Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue. All dimensions: mm Part Number FH36-15S-0.3SHW(50) FH36-17S-0.3SHW(50) FH36-19S-0.3SHW(50) FH36-25S-0.3SHW(50) FH36-29S-0.3SHW(50) FH36-33S-0.3SHW(50) FH36-35S-0.3SHW(50) FH36-45S-0.3SHW(50) FH36-51S-0.3SHW(50) FH36-61S-0.3SHW(50) FH36W-11S-0.3SHW(50) FH36W-15S-0.3SHW(50) FH36W-17S-0.3SHW(50) FH36W-19S-0.3SHW(50) FH36W-23S-0.3SHW(50) FH36W-27S-0.3SHW(50) FH36W-31S-0.3SHW(50) FH36W-33S-0.3SHW(50) FH36W-39S-0.3SHW(50) FH36W-51S-0.3SHW(50) FH36W-61S-0.3SHW(50) CL No. 580-1618-8-50 580-1606-9-50 580-1607-1-50 580-1619-0-50 580-1613-4-50 580-1615-0-50 580-1604-3-50 580-1617-5-50 580-1601-5-50 580-1600-2-50 580-1625-3-50 580-1623-8-50 580-1616-2-50 580-1612-1-50 580-1614-7-50 580-1608-4-50 580-1609-7-50 580-1622-5-50 580-1620-0-50 580-1605-6-50 580-1611-9-50 Number of contacts 15 17 19 25 29 33 35 45 51 61 11 15 17 19 23 27 31 33 39 51 61 A 6.1 6.7 7.3 9.1 10.3 11.5 12.1 15.1 16.9 19.9 4.9 6.1 6.7 7.3 8.5 9.7 10.9 11.5 13.3 16.9 19.9 B 3.6 4.2 4.8 6.6 7.8 9 9.6 12.6 14.4 17.4 2.4 3.6 4.2 4.8 6 7.2 8.4 9 10.8 14.4 17.4 C 4.2 4.8 5.4 7.2 8.4 9.6 10.2 13.2 15 18 3 4.2 4.8 5.4 6.6 7.8 9 9.6 11.4 15 18 D 4.83 5.43 6.03 7.83 9.03 10.23 10.83 13.83 15.63 18.63 3.63 4.83 5.43 6.03 7.23 8.43 9.63 10.23 12.03 15.63 18.63 E 5.59 6.19 6.79 8.59 9.79 10.99 11.59 14.59 16.39 19.39 4.39 5.59 6.19 6.79 7.99 9.19 10.39 10.99 12.79 16.39 19.39 Tape and reel packaging (5,000 pieces/reel, 500 pieces/reel). Order by number of reels. 3 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors (Recommended metal mask thickness: t=0.1) B±0.05 (0.2) (0.3) 0.3±0.05 (0.3:Metal mask) 0.6±0.05 0.3±0.03 (0.23:Metal mask) 0.4±0.05 0.535±0.05 C±0.05 ■Recommended FPC Dimensions 2.2±0.3 S 0.1±0.02 (0.2) 0.3 0.9±0.2 0.2±0.03 B±0.03 J±0.05 A +0.04 – 0.03 0.9±0.2 B Detail S MAX R0.2 2.4±0.1 1.65±0.05 1.15±0.05 0.3 R 0±0.03 *RELATIVE POSITIONS OF POINT A and B 0.3±0.07 +0.04 – 0.03 3.3±0.3 (Stiffener) disengagement shift (0.07) 0.1±0.15 0.75±0.1 0.85±0.1 1.45±0.1 0.6±0.02 0.3±0.02 Detail R (Lead plated 0.1 MAX) F±0.1 G±0.1 H±0.05 C±0.03 0.3±0.07 (0.7:Metal mask) 0.95±0.05 0.03±0.05 1.67±0.05 0.3±0.05 (0.5) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.6±0.05 0.3±0.03 (0.23:Metal mask) 0.8±0.05 (0.65:Metal mask) (3.07) 0.6±0.05 (0.5:Metal mask) ■Recommended PCB mounting pattern and metal mask dimensions R0.2±0.05 R0.2±0.1 (0.15) R0.2±0.05 (R0.2) (R0.2) R0.2±0.05 All dimensions: mm Part Number FH36-15S-0.3SHW(50) FH36-17S-0.3SHW(50) FH36-19S-0.3SHW(50) FH36-25S-0.3SHW(50) FH36-29S-0.3SHW(50) FH36-33S-0.3SHW(50) FH36-35S-0.3SHW(50) FH36-45S-0.3SHW(50) FH36-51S-0.3SHW(50) FH36-61S-0.3SHW(50) FH36W-11S-0.3SHW(50) FH36W-15S-0.3SHW(50) FH36W-17S-0.3SHW(50) FH36W-19S-0.3SHW(50) FH36W-23S-0.3SHW(50) FH36W-27S-0.3SHW(50) FH36W-31S-0.3SHW(50) FH36W-33S-0.3SHW(50) FH36W-39S-0.3SHW(50) FH36W-51S-0.3SHW(50) FH36W-61S-0.3SHW(50) 4 CL No. 580-1618-8-50 580-1606-9-50 580-1607-1-50 580-1619-0-50 580-1613-4-50 580-1615-0-50 580-1604-3-50 580-1617-5-50 580-1601-5-50 580-1600-2-50 580-1625-3-50 580-1623-8-50 580-1616-2-50 580-1612-1-50 580-1614-7-50 580-1608-4-50 580-1609-7-50 580-1622-5-50 580-1620-0-50 580-1605-6-50 580-1611-9-50 Number of contacts 15 17 19 25 29 33 35 45 51 61 11 15 17 19 23 27 31 33 39 51 61 B 3.6 4.2 4.8 6.6 7.8 9 9.6 12.6 14.4 17.4 2.4 3.6 4.2 4.8 6 7.2 8.4 9 10.8 14.4 17.4 C 4.2 4.8 5.4 7.2 8.4 9.6 10.2 13.2 15 18 3 4.2 4.8 5.4 6.6 7.8 9 9.6 11.4 15 18 F 6.04 6.64 7.24 9.04 10.24 11.44 12.04 15.04 16.84 19.84 4.84 6.04 6.64 7.24 8.44 9.64 10.84 11.44 13.24 16.84 19.84 G 5.6 6.2 6.8 8.6 9.8 11 11.6 14.6 16.4 19.4 4.4 5.6 6.2 6.8 8 9.2 10.4 11 12.8 16.4 19.4 H 4.8 5.4 6 7.8 9 10.2 10.8 13.8 15.6 18.6 3.6 4.8 5.4 6 7.2 8.4 9.6 10.2 12 15.6 18.6 J 4.6 5.2 5.8 7.6 8.8 10 10.6 13.6 15.4 18.4 3.4 4.6 5.2 5.8 7 8.2 9.4 10 11.8 15.4 18.4 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors ■Recommended FPC construction ●Contact FPC manufacturer for specific details. 1. Using Single-sided FPC Connecting side Material Material Name Covering film layer Polyimide 1 mil thick. (25) (25) Cover adhesive Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Material Thickness (μm) Surface treatment 0.2μm thick gold plated over 1 to 5μm thick nickel underplating Copper foil Cu Base adhesive Thermosetting adhesive 25 Base film Polyimide 25 1oz 1 mil thick 3 35 Reinforcement material adhesive Thermosetting adhesive 40 Stiffener Polyimide 3 mil thick 75 Total 203 Back side 2. Using Double-sided FPC Connecting side Material Name Covering layer film Material Polyimide 1 mil thick (25) (25) Cover adhesive Back side Material Thickness (μm) Surface treatment 0.2μm thick gold plated over 1 to 5μm thick nickel underplating Through-hole copper Cu Copper foil Cu Base adhesive Thermosetting adhesive 18 Base film Polyimide 25 3 15 1/2oz 1 mil thick 18 Base adhesive Thermosetting adhesive Copper foil Cu Cover adhesive Thermosetting adhesive 25 Covering film layer Polyimide 25 1/2oz 1 mil thick 18 (18) Reinforcement material adhesive Thermosetting adhesive 25 Stiffener 25 Polyimide 1 mil thick Total 197 * To prevent release of the FPC due to its bending, use of the double sided FPC with copper foil on the back side is NOT RECOMMENDED. 3.Precautions 1. This specification is a recommendation for the construction of the FH36 Series FPC (t=0.2 ± 0.03) 2. For details about the construction, please contact the FPC manufacturers. 5 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors ■Packaging Specification Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (3.85) (1) 1.75±0.1 1.5 +0.1 0 Flat surface, for placement with automatic equipment. Unreeling direction (Ø1 3) ●Reel Dimensions K±0.3 M±0.1 (N) (2.95) L±0.1 8±0.1 4±0.1 2±0.15 1.7 +0.15 0 (1.5) (0.3) Ø1 .5 Ø (N) M±0.1 (1.5) (0.3) .1 +0 0 5 1. 1.75±0.1 8±0.1 K±0.3 4±0.1 2±0.15 ●Embossed Carrier Tape Dimensions Flat surface, for placement (Tape width of 32mm min.) with automatic equipment. +0 0 .1 ●Embossed Carrier Tape Dimensions (Tape width of 24mm max.) (Ø80) (Ø380) (P:INSIDE) (Q:OUTSIDE) End section No connector inserted (25 pockets min.) Lead section (400mm min.) Mounting section Embossed carrier tape No connector inserted (25 pockets min.) Top cover tape All dimensions: mm Part Number FH36-15S-0.3SHW(50) FH36-17S-0.3SHW(50) FH36-19S-0.3SHW(50) FH36-25S-0.3SHW(50) FH36-29S-0.3SHW(50) FH36-33S-0.3SHW(50) FH36-35S-0.3SHW(50) FH36-45S-0.3SHW(50) FH36-51S-0.3SHW(50) FH36-61S-0.3SHW(50) FH36W-11S-0.3SHW(50) FH36W-15S-0.3SHW(50) FH36W-17S-0.3SHW(50) FH36W-19S-0.3SHW(50) FH36W-23S-0.3SHW(50) FH36W-27S-0.3SHW(50) FH36W-31S-0.3SHW(50) FH36W-33S-0.3SHW(50) FH36W-39S-0.3SHW(50) FH36W-51S-0.3SHW(50) FH36W-61S-0.3SHW(50) 6 CL No. 580-1618-8-50 580-1606-9-50 580-1607-1-50 580-1619-0-50 580-1613-4-50 580-1615-0-50 580-1604-3-50 580-1617-5-50 580-1601-5-50 580-1600-2-50 580-1625-3-50 580-1623-8-50 580-1616-2-50 580-1612-1-50 580-1614-7-50 580-1608-4-50 580-1609-7-50 580-1622-5-50 580-1620-0-50 580-1605-6-50 580-1611-9-50 Number of contacts 15 17 19 25 29 33 35 45 51 61 11 15 17 19 23 27 31 33 39 51 61 K 16 16 16 24 24 24 24 24 32 32 16 16 16 16 24 24 24 24 24 32 32 L ------------------------28.4 28.4 ---------------------------28.4 28.4 M 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 7.5 7.5 7.5 7.5 11.5 11.5 11.5 11.5 11.5 14.2 14.2 N 6.3 6.9 7.5 9.3 10.5 11.7 12.3 15.3 17.1 20.1 5.1 6.3 6.9 7.5 8.7 9.9 11.1 11.7 13.5 17.1 20.1 P 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 17.4 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 33.4 33.4 Q 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 21.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 37.4 37.4 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors ■Temperature Profile ●Using Lead-free Solder Paste MAX 250ç 250 230ç Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Temperature (ç) 200 200ç 150 150ç 100 50 25ç (60sec.) 90 sec. to 120 sec. Preheating 0 (60sec.) Soldering HRS test condition Solder method :Reflow, IR/hot air Environment :Room air Solder composition :Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry, Co., Ltd.'s Part Number:M705-221CM532-10.5) Test board :Glass epoxy 25mm∞50mm∞0.8mm thick Land dimensions :0.3mm∞0.6mm, 0.3mm∞0.8mm Metal mask :0.23∞0.5, 0.23∞0.65∞0.1mm thick Start Time (Seconds) The temperature profiles shown are based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume / thickness and board size / thickness. Consult your solder paste and equipment manufacturer for specific recommendations. 7 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors ■Operation and Precautions Operation 1. FPC insertion procedure. Connector installed on the board. 1 Lift up the actuator. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Use thumb or index finger. 2 Insert the FPC (contact surfaces facing down) at angle of approximately 10° to the board surface ①, making sure that the FPC positioning tabs clear the protrusions on both sides of the connector. Lower the FPC down ②, parallel to the board surface. FPC contact surface faces downward ① 10° ② Protrusions for the FPC positioning. 3 Rotate down the actuator until firmly closed. 2. FPC removal 1 Lift up the actuator Pull up the FPC at an angle of approximately 10° ① and than withdrew it from the connector ②. 125 ° ② 10° ① Protrusions for FPC positioning 8 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors Precautions Exercise care when handling connectors. Follow recommendations given below. [ Precautions when mounting connectors on the PCB ] ◆Handling before mounting on PCB Insertion of the FPC or operation of the actuator prior to mounting on the PCB is NOT RECOMMENDED. ◆When braking the large PC board into individual boards exercise care NOT to damage the installed connectors. ◆When attaching the boards or other components with the screws make sure that any stresses will NOT cause board deflections affecting the mounting areas of the connector. 0.5MAX ◆Bending of the board For a board width of 100 mm, bending of the board must be 0.5 mm max. (Ref to Fig. 1) 0.6 100 Connector F Board F Board 0.6 Connector 0.5MAX Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ◆PC board warpage Minimize the warpage as much as possible. The connector is straight within 0.1 mm max. Make sure that the mounting area flatness can accept the connector terminals without causing any failure of the solder joints. 100 Fig. 1 [ Precautions during FPC insertion and mating ] Pay attention to the following points when inserting FPC. ◆Actuator operation 1 Do not apply excessive force when opening the actuator prior to FPC insertion. When opening make sure that the force is applied only to the actuator itself, avoiding touching of the contacts. Actuator Damage to the actuator Damage to the actuator 2 Axis of rotation Assure free rotation of the actuator. 9 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors Precautions 3 The actuator will rotate 125ç. Do not apply force to rotate 12 further. 5° 4 When opening or closing the actuator, do so at Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. the center section. 5 Do not grasp or and lift the actuator (Fig. 2) nor insert the nail from the back of it (Fig. 3). Fig. 2 ◆FPC insertion Do not insert the FPC at any high angle from above. 10° Protrusions for FPC positioning 10 Fig. 3 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors Precautions As illustrated (Fig. 4) angle insertion may cause electrical discontinuity when the FPC is deflected in use. Opening of the FPC pattern Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Fig. 4 • To avert insertion of the FPC at an angle, consideration should be given to securing enough insertion space when designing the board lay-out. Insertion will be difficult when the FPC is too short. • Contact FPC manufacturer for information about the bending specifications. ◆Verification of the fully closed actuator The FPC should be fully inserted, with its positioning tabs fully behind the protrusions on both sides of the connector’s insertion slot (Fig. 5). FPC positioning tab Protrusions FPC positioning Fig. 5 [ Routing of the FPC (FPC fully inserted / actuator closed) ] ◆Do not apply any pull or upward-directed force to the FPC. Do not make any sharp bends of FPC close to the immediate exit from the connector (Fig. 6) Fig. 6 11 FH36 Series●0.3 mm Pitch, 1.0 mm above the board Flexible Printed Circuit ZIF Connectors Precautions [ Removing of the FPC ] ◆Rotate the actuator to the fully open position (max. angle of 125ç) Lift the FPC approximately 10ç (making sure that the positioning tabs clear the protrusions on both sides) and carefully withdraw it from the connector. 125 ° Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 10° Protrusions for FPC positioning [ Other Precautions ] ◆Hand Soldering Precautions When hand soldering: 1 Do not perform reflow or hand soldering with the FPC inserted in the connector. 2 Do not apply excessive heat or touch the soldering iron anywhere other than the connector leads. 3 Do not use excessive amount of solder or flux compounds. Operation of the actuator or contacts may be affected by excessive amounts of solder or flux com- ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The contents of this catalog are current as of date of 11/2013. Contents are subject to change without notice for the purpose of improvements.
FH36-19S-0.3SHW(10) 价格&库存
很抱歉,暂时无法提供与“FH36-19S-0.3SHW(10)”相匹配的价格&库存,您可以联系我们找货
