1000 Eaton Boulevard
Cleveland, OH 44122
United States
Tripp Lite's B055-001-UDP is currently not compatible with Intel HD630 graphic cards.
NetDirector DisplayPort USB Server Interface
Unit with Virtual Media and CAC Support (B064IPG Series)
Highlights
Provides connected DisplayPort
server with Virtual Media access
Supports Common Access Card
(CAC)
Eliminates thick, heavy KVM
cable kits
Ideal for running cable through
conduit and other tight spaces
Plug-and-play—no software or
power supply required
MODEL NUMBER: B055-001-UDP
System Requirements
Server, CPU or CAC reader with
DisplayPort and USB ports
B064-IPG Series HWv1 KVM
switch with v1.0.071 or later
firmware installed, or any B064IPG Series HWv2 KVM switch
Cat5e/6 cable
Package Includes
Connects a DisplayPort USB server to a compatible Tripp Lite B064-Series NetDirector KVM switch up to
164 ft. (50 m) away using Cat5e/6 cabling. Requires B064-IPG Series KVM switch with v1.0.071 or later
firmware installed.
Description
The B055-001-UDP NetDirector® DisplayPort USB Server Interface Unit connects a server, computer or
CAC reader with DisplayPort™ and/or USB ports to a Tripp Lite B064-IPG Series KVM switch with
v1.0.071 or later firmware installed. Using Cat5e/6 cabling, you can locate the KVM switch up to 164 feet
(50 meters) from the server.
Allowing the DisplayPort server to access the KVM switch’s Virtual Media functionality via low-cost
Cat5e/6 cable eliminates the need for bulky KVM cables. This frees up precious space in your server
cabinet, and allows for better ventilation and longer cable runs. Running cable through conduit and other
tight spaces takes advantage of the increased flexibility when setting up your network application.
No software or external power supply is needed. The unit’s compact, lightweight design is plug-and-play
for immediate installation and deployment. It complies with the Federal Trade Agreements Act (TAA) for
GSA Schedule purchases.
Note: SIU's that were purchased prior to that of your KVM switch may require a firmware upgrade in order
for them to work properly (see Maintenance under OSD Operation section of your B064-Series KVM
Owner's Manual for details)
Features
Convenient, Cost-Effective KVM Connection
● Connects DisplayPort USB server to Tripp Lite B064-IPG Series KVM switch with v1.0.071 or later
firmware via Cat5e/6 cable
Allows server to access Virtual Media functionality
Supports Common Access Card (CAC)
Maximum distance between server and KVM switch of 164 ft. (50 m)
Eliminates Bulky KVM Cables
● Frees precious space in server cabinet
Provides better ventilation and longer cable runs
1/2
Interface Unit
Cleveland, OH 44122
United States
More flexibility for running cable through conduit and other tight spaces
Plug-and-Play Convenience
● No software or external power supply required
Ready for immediate installation and deployment
TAA-Compliant
● Complies with the Federal Trade Agreements Act (TAA) for GSA Schedule purchases
Specifications
OVERVIEW
UPC Code
037332198099
Accessory Type
Technology
Cat5/5e; DisplayPort
Accessory Class
KVM Switch Accessories
PHYSICAL
Shipping Dimensions (hwd / in.)
1.70 x 4.80 x 4.90
Shipping Dimensions (hwd / cm)
4.32 x 12.19 x 12.45
Shipping Weight (lbs.)
0.40
Shipping Weight (kg)
0.18
STANDARDS & COMPLIANCE
Product Compliance
WARRANTY & SUPPORT
Product Warranty Period
(Worldwide)
3-year limited warranty
© 2022 Eaton. All Rights Reserved.
Eaton is a registered trademark. All other trademarks
are the property of their respective owners.
2/2
很抱歉,暂时无法提供与“B055-001-UDP”相匹配的价格&库存,您可以联系我们找货
