0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC
FH40 Series
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
●Strong actuator construction
Fig.1
■Features
●Simple FPC insertion
1. Reduction in connection man-hours (30%
reduction compared to our conventional
item)
Our unique actuator form enables the completion of
both FPC insertion ~ joint in the same motion.
2. Prevention of half and diagonal joints
The side catcher for FPC positioning ensures accurate
FPC insertion.
3. Durable structure and no lost actuator
The unique terminal form means the actuator is
retained, even under rough operation conditions.
4. One-finger operation of the actuator
Proven (in several other Hirose's connectors!) FlipLock rotating actuator assures reliable mechanical and
electrical connection with FPC, confirming it with a
definite tactile feel.
Fig.2
●Lock
5. Accepts standard FPC thickness
0.3mm thick standard Flexible Printed Circuit (FPC)
can be used.
6. Board placement with automatic equipment
Flat upper surface and tape and reel packaging
facilitate vacuum pick-up and placement.
Standard reel packaging contains 1,000 connectors.
7. Halogen-free *
*As defined by IEC61249-2-21
Br-900ppm maximum, Cl-900ppm maximum,
Cl + Br combined-1,500ppm maximum
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
Fig.3
2016.3③
1
FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC
■Product Specifications
Ratings
Current rating : 0.5A DC(Note 1) Operating Temperature Range : −40 to +105ç (Note 2) Storage Temperature Range : −10 to +50ç (Note 2)
Voltage rating : 50Vrms AC Operating Humidity Range : Relative humidity 90% max. Storage Humidity Range : Relative humidity 90% max.
(No condensation)
(No condensation)
Recommended FPC Thickness 0.3±0.05mm, Gold plated contact pads
Item
Specification
Conditions
1. Insulation resistance 500Mø min.
100V DC
2. Withstanding voltage No flashover or insulation breakdown
150Vrms AC / 1 minute
3. Contact resistance
50mø max.
Including FPC and FFC conductor resistance
1mA, (DC or 1000Hz)
4. Durability
Contact resistance : 50mø max.
No damage, cracks, or parts dislocation
20 cycles
5. Vibration
No electrical discontinuity of 1µs or longer
Contact resistance: 50mø max.
Frequency : 10 to 55Hz, single amplitude of 0.75mm,
10 cycles in each of the 3 axis.
6. Shock
Acceleration of 981m/s2, 6ms duaration, sine
half-wave wavefrom 3 cycles in each of the 3
axis
7. Humidity(Steady state) Insulation resistance : 50Mø min.
96 hours at 40ç and humidity of 90 to 95%
8. Temperature Cycle
Temperature : −40ç → +15ç to +35ç → +105ç → +15ç to +35ç
Time : 30 → 2 to 3 → 30 → 2 to 3(minutes)
5 cycles
9. Resistance to Soldering heat
No deformation of
components affecting performance
Reflow : At the recommended temperature profile
Manual soldering : 350ç±5ç for 5 seconds
Note 1 : When passing the current through all of the contacts, use 70% of the rated current.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term "storage" refers to products stored for a long period prior to mounting and use.
The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage,
shipment or during transportation after board mounting.
■Materials / Finish
Part
Material
Finish
Insulator
LCP
Contact
Phosphor bronze
Color : Beige
Color : Black
Gold plated
■Product Number Structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 40 - 50S - 0.5 SV (99)
q
w
e
r
q Series Name
: FH
w Series No.
: 40
t
y
e Number of positions : 10 to 80
r Contact pitch
: 0.5mm
t SV
: SMT vertical mounting type
y Specifications
standard...Partial gold plating 1,000pcs/reel
(99)...Partial gold plating 500pcs/reel
2
Remarks
UL94V-0
■Connector Dimensions
A (FPC insertion slot dimension)
Pin No.1
(0.12)
1
(0.12)
1
B
(5.65)
4.65
(1.45)
(4.35)
5.8
5.8
(2.3)
Number of contacts indicator
1
0.5
3.55
C
Note 1
Note 2
Note 3
Note 4
: The coplanarity of each terminal lead within specified dimension is 0.1mm Max.
: Packaged on tape and reel only. Check packaging specification.
: Slight variations in color of the plastic compounds do not affect form, fit or function of the connector.
: After reflow, the terminal plating may change color, however this does not represent a quality issue.
Unit : mm
Part No.
FH40-10S-0.5SV
FH40-20S-0.5SV
FH40-24S-0.5SV
FH40-30S-0.5SV
FH40-40S-0.5SV
FH40-45S-0.5SV
FH40-50S-0.5SV
FH40-60S-0.5SV
FH40-64S-0.5SV
FH40-80S-0.5SV
HRS No.
580-2104-6
580-2105-9
580-2106-1
580-2108-7
580-2107-4
580-2101-8
580-2100-5
580-2109-0
580-2102-0
580-2103-3
No. of Contacts
10
30
40
45
50
60
64
80
A
5.57
10.57
12.57
15.57
20.57
23.07
25.57
30.57
32.57
40.57
B
8.2
13.2
15.2
18.2
23.2
25.7
28.2
33.2
35.2
43.2
C
4.5
9.5
11.5
14.5
19.5
22
24.5
29.5
31.5
39.5
Note 1 : Tape and reel packaging (1,000 pcs/reel, 500 pcs/reel).
Order by number of reels.
3
1.2±0.1
Pin No.1
0.5±0.05
1±0.05
4.25±0.1
1.2±0.1 (Land pattern)
1±0.05 (Metal mask)
BRecommended PCB mounting pattern and metal mask dimensions
0.35±0.1 (Land pattern)
0.25±0.05 (Metal mask)
C±0.05
Recommended metal mask thickness : t=0.15
BRecommended FPC Dimensions
A
.2M
X
0.5±0.1
C0
0.5±0.05
R
0.
2
R0
4.5MIN
(stiffener)
3.5MIN
AX
X
MA
.2
.2M
1.4±0.1
R0
R0
2.8±0.1
(X)
It is not recommended to mate FPC without tabs to this connector.
.5M
0.35±0.03
AX
0.3±0.05
0.5±0.1
C±0.05
D±0.07
E±0.1
Note 1 : Stiffener dimension should be 3.5mm min., and X dimension should be 0.5mm for improved
flexibility of FPC.
Unit : mm
Part No.
FH40-10S-0.5SV
FH40-20S-0.5SV
FH40-24S-0.5SV
FH40-30S-0.5SV
FH40-40S-0.5SV
FH40-45S-0.5SV
FH40-50S-0.5SV
FH40-60S-0.5SV
FH40-64S-0.5SV
FH40-80S-0.5SV
4
HRS No.
580-2104-6
580-2105-9
580-2106-1
580-2108-7
580-2107-4
580-2101-8
580-2100-5
580-2109-0
580-2102-0
580-2103-3
No. of Contacts
10
30
40
45
50
60
64
80
C
4.5
9.5
11.5
14.5
19.5
22
24.5
29.5
31.5
39.5
D
5.5
10.5
12.5
15.5
20.5
23
25.5
30.5
32.5
40.5
E
7.1
12.1
14.1
17.1
22.1
24.6
27.1
32.1
34.1
42.1
BRecommended FPC construction
1. Using Single-sided FPC
FPC : Flexible Printed Circuit
Material Name
2. Using Double-sided FPC
Material
Covering film layer
Cover adhesive
Polyimide 1 mil thick.
Surface treatment
0.2µm thick gold plated over 1 to
5µm nickel underplating
Copper foil
Cu 1oz
Material Thickness
(µm)
(25)
(25)
3
35
Base adhesive
Thermosetting adhesive
25
Base film
25
Reinforcement material adhesive Thermosetting adhesive
40
Stiffene
Polyimide 7 mil thick
175
Total
303
Material Name
Covering film layer
Material
Material Thickness
(µm)
(25)
Cover adhesive
Surface treatment
Through-hole copper
Cu
15
Copper foil
Cu 1/2oz
18
Base adhesive
18
Base film
25
3
Base adhesive
Copper foil
Cu 1/2oz
Cover adhesive
25
Covering film layer
25
18
(18)
50
Stiffener
Polyimide 4 mil thick
100
Total
297
* To prevent release of the FPC due to its bending, use of the double sided FPC
with copper foil on the back side is NOT RECOMMENDED.
3. Using FFC
(25)
FFC : Flexible Flat Cable
Material Name
Material
Thickness (µm)
Polyester thermoplastic type
30
Polyester film
Adhesive
12
Annealed copper foil
(Gold plating over nickel under plating)
Adhesive
35
Polyester
Polyester
30
12
Adhesive
Polyester
30
Stiffener
Polyester
188
Total
295
* Actual tolerance of the thickness is approximately ±20µm.
1. This specification is a recommendation for the material configuration of the FPC/FFC (t=0.3 ±0.05mm) for the FH40 series
connectors.
2. Please contact the FPC/FFC manufacturer for the material configurations of their FPC/FFC.
5
BPackaging Specification
(6.25)
(6)
1.75±0.1
0 0.1
.5 +
Ø1
1.75±0.1
2±0.15
12±0.1
(6)
(0.5)
G±0.1
F±0.3
H±0.1
(0.5)
+0.15
1.7 0
(0.45)
4±0.1
(J)
(J)
(3.25)
●Embossed Carrier Tape Dimensions
(Tape width 32mm min.)
H±0.1
F±0.3
2±0.15
12±0.1
Ø1
.5
4±0.1
(Tape width to 24mm max.)
(2.05) Flat surface,
for placement with
automatic equipment.
1.5+0.1
for placement with
(0.45)
(3.25)
Unreeling direction
(6.25)
Unreeling direction
(Ø1
3)
●Reel Dimensions
(Ø380)
(Ø80)
(K: INSIDE)
(L: OUTSIDE)
End portion
Lead portion (400mm min.)
Mounting portion
No connector
inserted
connector
Embossed carrier tape Noinserted
(10 pockets min.)
Top cover tape
(10 pockets min.)
BPackaging Specification Dimensions
Part No.
FH40-10S-0.5SV
FH40-20S-0.5SV
FH40-24S-0.5SV
FH40-30S-0.5SV
FH40-40S-0.5SV
FH40-45S-0.5SV
FH40-50S-0.5SV
FH40-60S-0.5SV
FH40-64S-0.5SV
FH40-80S-0.5SV
HRS No.
580-2104-6
580-2105-9
580-2106-1
580-2108-7
580-2107-4
580-2101-8
580-2100-5
580-2109-0
580-2102-0
580-2103-3
No. of Contacts
10
30
40
45
50
60
64
80
Note 1 : Tape and reel packaging (1,000 pcs/reel).
6
F
16
Unit : mm
32
G
------28.4
44
40.4
20.2
56
52.4
26.2
24
H
7.5
11.5
14.2
J
8.4
13.4
15.4
18.4
23.4
25.9
28.4
33.4
35.4
43.4
K
17.4
L
21.4
25.4
29.4
33.4
37.4
45.4
49.4
57.4
61.4
BTemperature Profile
MAX 250ç
250
Temperature
230ç
200
200ç
150
150ç
(ç)
100
50
25ç
(60 seconds)
90 to 120 seconds
Preheating
60 seconds
Soldering
HRS test conditions
Solder method
: Reflow, IR/hot air
Environment:
: Room air
Solder composition : Paste, 96.5%Sn/3%Ag/0.5%Cu
(Senju Metal Industry, Co., Ltd.’s
Part Number : M705-GRN360-K2-V)
Test board
: Glass epoxy 30mm∞66mm∞0.8mm thick
Land dimensions : 0.35mm∞1.2mm
Metal mask
: 0.25∞1.0∞0.15mm thick
The temperature profiles shown are based on the above
conditions.
In individual applications the actual temperature may vary,
depending on solder paste type, volume / thickness and
board size / thickness. Consult your solder paste and
equipment manufacturer for specific recommendations.
Start
Time (Seconds)
7
BConnector Operation and Precautions
Operation
Precautions
1. FPC Termination procedure.
q Verify that the actuator is positioned upright. If
the actuator has rotated to the side, carefully
rotate it upright.
w Insert the FPC vertically in the connector slot
assuring that the conductive traces of the FPC
are facing away from the actuator.
q Avoid forcing the actuator up or down without
the FPC inserted.
w Application of excessive force to the inserted
FPC may cause damage to connector and may
affect the reliability of electrical connection.
FPC conductive traces
e Press down the actuator in the direction shown.
Do not insert the FPC diagonally.
Doing so will result in the corners of the FPC
catching on the contacts and will cause
deformation of the contacts.
e Disengage the actuator to release the lock and
extract the FPC/FFC (refer to the picture
below). By utilizing your thumb and index
finger, you can easily manipulate the actuator
to disengage the lock.
2. FPC Removal
q Rotate the actuator upward and withdraw the
FPC.
During the design phase of the PCB layout, make
sure to incorporate enough space to engage/
disengage the actuator on this connector when
inserting or removing the FPC.
8
2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN
TEL: +81-45-620-3526 Fax: +81-45-591-3726
http://www.hirose.com
http://www.hirose-connectors.com
The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use.
The contents of this catalog are current as of date of 03/2016. Contents are subject to change without notice for the purpose of improvements.
