FH40-80S-0.5SV(99)
FH40-80S-0.5SV(99)
    HRS(广濑)
FH40-80S-0.5SV(99) 数据手册
0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC FH40 Series Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Strong actuator construction Fig.1 ■Features ●Simple FPC insertion 1. Reduction in connection man-hours (30% reduction compared to our conventional item) Our unique actuator form enables the completion of both FPC insertion ~ joint in the same motion. 2. Prevention of half and diagonal joints The side catcher for FPC positioning ensures accurate FPC insertion. 3. Durable structure and no lost actuator The unique terminal form means the actuator is retained, even under rough operation conditions. 4. One-finger operation of the actuator Proven (in several other Hirose's connectors!) FlipLock rotating actuator assures reliable mechanical and electrical connection with FPC, confirming it with a definite tactile feel. Fig.2 ●Lock 5. Accepts standard FPC thickness 0.3mm thick standard Flexible Printed Circuit (FPC) can be used. 6. Board placement with automatic equipment Flat upper surface and tape and reel packaging facilitate vacuum pick-up and placement. Standard reel packaging contains 1,000 connectors. 7. Halogen-free * *As defined by IEC61249-2-21 Br-900ppm maximum, Cl-900ppm maximum, Cl + Br combined-1,500ppm maximum In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. Fig.3 2016.3③ 1 FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC ■Product Specifications Ratings Current rating : 0.5A DC(Note 1) Operating Temperature Range : −40 to +105ç (Note 2) Storage Temperature Range : −10 to +50ç (Note 2) Voltage rating : 50Vrms AC Operating Humidity Range : Relative humidity 90% max. Storage Humidity Range : Relative humidity 90% max. (No condensation) (No condensation) Recommended FPC Thickness 0.3±0.05mm, Gold plated contact pads Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Item Specification Conditions 1. Insulation resistance 500Mø min. 100V DC 2. Withstanding voltage No flashover or insulation breakdown 150Vrms AC / 1 minute 3. Contact resistance 50mø max. Including FPC and FFC conductor resistance 1mA, (DC or 1000Hz) 4. Durability Contact resistance : 50mø max. No damage, cracks, or parts dislocation 20 cycles 5. Vibration No electrical discontinuity of 1µs or longer Contact resistance: 50mø max. No damage, cracks, or parts dislocation Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 axis. 6. Shock No electrical discontinuity of 1µs or longer No damage, cracks, or parts dislocation Contact resistance : 50mø max. Acceleration of 981m/s2, 6ms duaration, sine half-wave wavefrom 3 cycles in each of the 3 axis Contact resistance : 50mø max. 7. Humidity(Steady state) Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation 96 hours at 40ç and humidity of 90 to 95% 8. Temperature Cycle Contact resistance : 50mø max. Insulation resistance : 50Mø min. No damage, cracks, or parts dislocation Temperature : −40ç → +15ç to +35ç → +105ç → +15ç to +35ç Time : 30 → 2 to 3 → 30 → 2 to 3(minutes) 5 cycles 9. Resistance to Soldering heat No deformation of components affecting performance Reflow : At the recommended temperature profile Manual soldering : 350ç±5ç for 5 seconds Note 1 : When passing the current through all of the contacts, use 70% of the rated current. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term "storage" refers to products stored for a long period prior to mounting and use. The operating temperature and humidity range covers the non-conducting condition of installed connectors in storage, shipment or during transportation after board mounting. ■Materials / Finish Part Material Finish Insulator LCP Contact Phosphor bronze Color : Beige Color : Black Gold plated ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 40 - 50S - 0.5 SV (99) q w e r q Series Name : FH w Series No. : 40 t y e Number of positions : 10 to 80 r Contact pitch : 0.5mm t SV : SMT vertical mounting type y Specifications standard...Partial gold plating 1,000pcs/reel (99)...Partial gold plating 500pcs/reel 2 Remarks UL94V-0 ––––––– FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC ■Connector Dimensions A (FPC insertion slot dimension) Pin No.1 (0.12) 1 (0.12) 1 B (5.65) 4.65 (1.45) (4.35) 5.8 5.8 (2.3) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Number of contacts indicator 1 0.5 3.55 C Note 1 Note 2 Note 3 Note 4 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max. : Packaged on tape and reel only. Check packaging specification. : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. : After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm Part No. FH40-10S-0.5SV FH40-20S-0.5SV FH40-24S-0.5SV FH40-30S-0.5SV FH40-40S-0.5SV FH40-45S-0.5SV FH40-50S-0.5SV FH40-60S-0.5SV FH40-64S-0.5SV FH40-80S-0.5SV HRS No. 580-2104-6 580-2105-9 580-2106-1 580-2108-7 580-2107-4 580-2101-8 580-2100-5 580-2109-0 580-2102-0 580-2103-3 No. of Contacts 10 20 24 30 40 45 50 60 64 80 A 5.57 10.57 12.57 15.57 20.57 23.07 25.57 30.57 32.57 40.57 B 8.2 13.2 15.2 18.2 23.2 25.7 28.2 33.2 35.2 43.2 C 4.5 9.5 11.5 14.5 19.5 22 24.5 29.5 31.5 39.5 Note 1 : Tape and reel packaging (1,000 pcs/reel, 500 pcs/reel). Order by number of reels. 3 FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC 1.2±0.1 Pin No.1 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5±0.05 1±0.05 4.25±0.1 1.2±0.1 (Land pattern) 1±0.05 (Metal mask) BRecommended PCB mounting pattern and metal mask dimensions 0.35±0.1 (Land pattern) 0.25±0.05 (Metal mask) C±0.05 Recommended metal mask thickness : t=0.15 BRecommended FPC Dimensions A .2M X 0.5±0.1 C0 0.5±0.05 R 0. 2 R0 4.5MIN (stiffener) 3.5MIN AX X MA .2 .2M 1.4±0.1 R0 R0 2.8±0.1 (X) It is not recommended to mate FPC without tabs to this connector. .5M 0.35±0.03 AX 0.3±0.05 0.5±0.1 C±0.05 D±0.07 E±0.1 Note 1 : Stiffener dimension should be 3.5mm min., and X dimension should be 0.5mm for improved flexibility of FPC. Unit : mm Part No. FH40-10S-0.5SV FH40-20S-0.5SV FH40-24S-0.5SV FH40-30S-0.5SV FH40-40S-0.5SV FH40-45S-0.5SV FH40-50S-0.5SV FH40-60S-0.5SV FH40-64S-0.5SV FH40-80S-0.5SV 4 HRS No. 580-2104-6 580-2105-9 580-2106-1 580-2108-7 580-2107-4 580-2101-8 580-2100-5 580-2109-0 580-2102-0 580-2103-3 No. of Contacts 10 20 24 30 40 45 50 60 64 80 C 4.5 9.5 11.5 14.5 19.5 22 24.5 29.5 31.5 39.5 D 5.5 10.5 12.5 15.5 20.5 23 25.5 30.5 32.5 40.5 E 7.1 12.1 14.1 17.1 22.1 24.6 27.1 32.1 34.1 42.1 FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC BRecommended FPC construction 1. Using Single-sided FPC FPC : Flexible Printed Circuit Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Material Name 2. Using Double-sided FPC Material Covering film layer Cover adhesive Polyimide 1 mil thick. Surface treatment 0.2µm thick gold plated over 1 to 5µm nickel underplating Copper foil Cu 1oz Material Thickness (µm) (25) (25) 3 35 Base adhesive Thermosetting adhesive 25 Base film Polyimide 1 mil thick 25 Reinforcement material adhesive Thermosetting adhesive 40 Stiffene Polyimide 7 mil thick 175 Total 303 FPC : Flexible Printed Circuit Material Name Covering film layer Material Material Thickness (µm) Polyimide 1 mil thick. (25) Cover adhesive Surface treatment 0.2µm thick gold plated over 1 to 5µm nickel underplating Through-hole copper Cu 15 Copper foil Cu 1/2oz 18 Base adhesive Thermosetting adhesive 18 Base film Polyimide 1 mil thick 25 3 Base adhesive Thermosetting adhesive Copper foil Cu 1/2oz Cover adhesive Thermosetting adhesive 25 Covering film layer Polyimide 1 mil thick. 25 18 (18) Reinforcement material adhesive Thermosetting adhesive 50 Stiffener Polyimide 4 mil thick 100 Total 297 * To prevent release of the FPC due to its bending, use of the double sided FPC with copper foil on the back side is NOT RECOMMENDED. 3. Using FFC (25) FFC : Flexible Flat Cable Material Name Material Thickness (µm) Polyester thermoplastic type 30 Polyester film Adhesive 12 Annealed copper foil (Gold plating over nickel under plating) Adhesive 35 Polyester Polyester 30 12 Adhesive Polyester 30 Stiffener Polyester 188 Total 295 * Actual tolerance of the thickness is approximately ±20µm. 1. This specification is a recommendation for the material configuration of the FPC/FFC (t=0.3 ±0.05mm) for the FH40 series connectors. 2. Please contact the FPC/FFC manufacturer for the material configurations of their FPC/FFC. 5 FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC BPackaging Specification Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (6.25) (6) 1.75±0.1 0 0.1 .5 + Ø1 1.75±0.1 2±0.15 12±0.1 (6) (0.5) G±0.1 F±0.3 H±0.1 (0.5) +0.15 1.7 0 (0.45) 4±0.1 (J) (J) (3.25) ●Embossed Carrier Tape Dimensions (Tape width 32mm min.) H±0.1 F±0.3 2±0.15 12±0.1 Ø1 .5 4±0.1 + 0 0 .1 ●Embossed Carrier Tape Dimensions (Tape width to 24mm max.) (2.05) Flat surface, for placement with automatic equipment. 1.5+0.1 0 (2.05) Flat surface, for placement with automatic equipment. (0.45) (3.25) Unreeling direction (6.25) Unreeling direction (Ø1 3) ●Reel Dimensions (Ø380) (Ø80) (K: INSIDE) (L: OUTSIDE) End portion Lead portion (400mm min.) Mounting portion No connector inserted connector Embossed carrier tape Noinserted (10 pockets min.) Top cover tape (10 pockets min.) BPackaging Specification Dimensions Part No. FH40-10S-0.5SV FH40-20S-0.5SV FH40-24S-0.5SV FH40-30S-0.5SV FH40-40S-0.5SV FH40-45S-0.5SV FH40-50S-0.5SV FH40-60S-0.5SV FH40-64S-0.5SV FH40-80S-0.5SV HRS No. 580-2104-6 580-2105-9 580-2106-1 580-2108-7 580-2107-4 580-2101-8 580-2100-5 580-2109-0 580-2102-0 580-2103-3 No. of Contacts 10 20 24 30 40 45 50 60 64 80 Note 1 : Tape and reel packaging (1,000 pcs/reel). 6 F 16 Unit : mm 32 G ------28.4 44 40.4 20.2 56 52.4 26.2 24 H 7.5 11.5 14.2 J 8.4 13.4 15.4 18.4 23.4 25.9 28.4 33.4 35.4 43.4 K 17.4 L 21.4 25.4 29.4 33.4 37.4 45.4 49.4 57.4 61.4 FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC BTemperature Profile MAX 250ç 250 Temperature 230ç 200 200ç 150 150ç (ç) Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 100 50 25ç (60 seconds) 0 90 to 120 seconds Preheating 60 seconds Soldering HRS test conditions Solder method : Reflow, IR/hot air Environment: : Room air Solder composition : Paste, 96.5%Sn/3%Ag/0.5%Cu (Senju Metal Industry, Co., Ltd.’s Part Number : M705-GRN360-K2-V) Test board : Glass epoxy 30mm∞66mm∞0.8mm thick Land dimensions : 0.35mm∞1.2mm Metal mask : 0.25∞1.0∞0.15mm thick The temperature profiles shown are based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume / thickness and board size / thickness. Consult your solder paste and equipment manufacturer for specific recommendations. Start Time (Seconds) 7 FH40 Series●0.5mm Pitch, 5.8mm above the board, vertical connectors for FPC BConnector Operation and Precautions Operation Precautions 1. FPC Termination procedure. q Verify that the actuator is positioned upright. If the actuator has rotated to the side, carefully rotate it upright. Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. w Insert the FPC vertically in the connector slot assuring that the conductive traces of the FPC are facing away from the actuator. q Avoid forcing the actuator up or down without the FPC inserted. w Application of excessive force to the inserted FPC may cause damage to connector and may affect the reliability of electrical connection. FPC conductive traces e Press down the actuator in the direction shown. Do not insert the FPC diagonally. Doing so will result in the corners of the FPC catching on the contacts and will cause deformation of the contacts. e Disengage the actuator to release the lock and extract the FPC/FFC (refer to the picture below). By utilizing your thumb and index finger, you can easily manipulate the actuator to disengage the lock. 2. FPC Removal q Rotate the actuator upward and withdraw the FPC. During the design phase of the PCB layout, make sure to incorporate enough space to engage/ disengage the actuator on this connector when inserting or removing the FPC. ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 03/2016. Contents are subject to change without notice for the purpose of improvements.
FH40-80S-0.5SV(99) 价格&库存
很抱歉,暂时无法提供与“FH40-80S-0.5SV(99)”相匹配的价格&库存,您可以联系我们找货
FH40-80S-0.5SV(99)
  • 500+48.23092500+5.81596
  • 1000+42.629951000+5.14056
  • 1500+41.385251500+4.99047
库存:1944
