FH12-33S-0.5SH(57)
FH12-33S-0.5SH(57)
    HRS(广濑)
FH12-33S-0.5SH(57) 数据手册
0.5mm and 1mm Pitch FPC/FFC Connectors Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH12 Series ■Features 1. Rotating one-touch ZIF mechanism The one-touch rotating ZIF mechanism is easier to operate and works with a light force. Rotating one-touch ZIF mechanism q 2. Clear tactile click A clear tactile click is delivered upon the successful completion of the mating process 3. Supports high density mounting The FH12’s one-touch ZIF system requires less space than a slide locking connector and can be mounted in the center of the PCB. 4. Top & Bottom Contact and Vertical Mount type w There are three connection types available : top contact, bottom contact and a Vertical mount. 5. 1mm pitch product Contact surface of the FPC+FFC In addition to the 0.5mm pitch connector, we also offer a 1mm pitch connector. 6. Reinforced actuator The FH12S version in 30, 40, 45, 50, and 53 pin counts are offered with a reinforced actuator that provides an extra measure of security against actuator breakage. e 2017.1③ 1 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■Product Specifications Current rating : 0.5A DC(Note 1) Operating Temperature Range : _40 to +85ç (Note 2) Storage Temperature Range : _10 to +50ç (Note 3) Voltage rating : 50V AC Operating Humidity Range : Relative humidity, 90% max. Storage Humidity Range : Relative humidity, 90% max. Rating (Not dewed) t=0.3±0.05 Gold plated Adaptive FPC/FFC contact specifications Item 1. Insulation resistance 2. Withstanding voltage 3. Contact resistance Specification 500Mø minimum No flashover or insulation breakdown. 50mø maximum Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. Durability (Insertion/withdrawal) Contact resistance : 50mø maximum No damage, cracks, or parts dislocation. No electrical discontinuity of 1μs or more 5. Vibration Contact resistance : 50mø maximum. No damage, cracks, or parts dislocation. No electrical discontinuity of 1μs or more Contact resistance : 50mø maximum. No damage, cracks, or parts dislocation. 6. Shock Contact resistance : 50mø maximum. 7. Humidity(Steady state) Insulation resistance : 50Mø minimum. No damage, cracks, or parts dislocation. Contact resistance : 50mø maximum. Insulation resistance : 50Mø minimum. No damage, cracks, or parts dislocation. 8. Temperature Cycle (Not dewed) Conditions 100V DC 150V AC/1 minute 1mA 20 cycles Frequency : 10 to 55Hz, single amplitude of 0.75mm, for 10 cycles in 3 axial directions Acceleration of 981m/s2, 6ms duaration, sine half-wave waveform, 3 cycles in each of the 3 axis 96 hours at 40ç and humidity of 90% to 95% Temperature : -40ç / 15 to 35ç / 85ç / 15 to 35ç, Time: 30 / 2 to 3 / 30 / 2 to 3(minutes) 5 cycles No deformation of Reflow : At the recommended temperature profile Manual soldering : 350±10ç for 5 seconds components affecting performance. Note 1 : When passing the current through all of the contacts,use 70% of the current rating. Note 2 : Includes temperature rise caused by current flow. Note 3 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers nonconducting condition of installed connectors in storage, shipment or during transportation. 9.Resistance to Soldering heat ■Materials / Finish Part Material Finish Polyamide, LCP(60 pos.) Insulator Remarks Color : Beige PPS UL94V-0 Color : Dark brown Contact Phosphor bronze Metal Fittings Brass Gold plated ––––––– Tin plated ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH 12 A - 10 (4) q w e r t q Series Name : FH w Series No. : 12 e Blank : standard type A : Top contact type S : Type with strengthed flip-lock actuator r Standard type : Number of contacts Eccentric type : Number of contacts in 0.5mm housing t Standard type : Blank Eccentric type : Number of contacts 2 **) S A - 0.5 SH (* y u i o !0 y Contact alignment : Single u Eccentric direction : Blank : standard type A : Eccentric type i Contacts Pitch : 0.5mm, 1mm o Contact type SH : SMT horizontal mounting type SVA : SMT vertical mounting type !0 Plating specification (54) : Selective gold plated (55) : Gold plated (1)(98) : Gold plated 500 pieces/reel FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■Series Configuration Pitch Bottom Contact Type Top Contact Type Vertical mounting Type FPC/FFC conductive surface(bottom side) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC/FFC conductive surface 0.5mm FH12- ** S-0.5SH P.4 Number of contacts 6, 8, 10, 11, 12, 13, 14, 15, 16, 17, 18, 19, 20, 22, 24, 25, 26, 28, 30, 32, 33, 34, 35, 36, 40, 45, 50, 53 Type with Strengthened Lock Lever FH12S- ** S-0.5SH P.5 Number of contacts 30, 40, 45, 50, 53 FH12A- ** S-0.5SH P.6 Number of contacts 10, 12 ,15, 16, 18, 20, 22, 24, 26, 28, 29, 30, 32, 33, 34, 36, 40, 42, 45, 50 FH12- ** S-0.5SVA P.7 Number of contacts 6, 10, 12, 13, 15, 16, 17, 18, 20, 22, 24, 26, 30, 32, 33, 34, 36, 40, 45, 49, 50, 60 FPC/FFC conductive surface(bottom side) 1mm FH12- ** S-1SH P.8 Eccentric FH12- ** (**) SA-1SH Standard Standard Number of contacts 5, 6, 7, 8, 9, 11, 12,16,17,22,26 Eccentric FH12- ** S-1SVA P.9 Number of contacts 6, 7, 8, 16, 20, 22, Number of contacts 4, 6, 8, 10, 11, 14, 19, 24 24 3 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■0.5mm Pitch Bottom Contact Type A 1.2 2 0.8 0.5 ( 0.2) polarizing mark indicator Number of Contacts indicator 5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 1.85 B C D Note 1 Note 2 Note 3 Note 4 Note 5 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max. : Packaged on tape and reel only. Check packaging specification. : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. : After reflow, the terminal plating may change color, however this does not represent a quality issue. : If there is no problem with the connector height, we recommend the type with the strengthened Fliplock actuator (FH12S-*S-0.5SH). Standard type connector height : 2mm Connector height of type with strengthened Flip-lock actuator : 2.4mm Unit : mm Part No. HRS No. No. of Contacts A B C D FH12-6S-0.5SH(**) 586-0582-5 ** 6 2.5 06.1 7.1 3.57 FH12-8S-0.5SH(**) 586-0744-5 ** 8 3.5 07.1 8.1 4.57 FH12-10S-0.5SH(**) 586-0522-3 ** 10 4.5 08.1 9.1 5.57 FH12-11S-0.5SH(**) 586-0600-5 ** 11 5.0 08.6 9.6 6.07 FH12-12S-0.5SH(**) 586-0704-0 ** 12 5.5 09.1 10.1 6.57 FH12-13S-0.5SH(**) 586-0549-0 ** 13 6.0 09.6 10.6 7.07 FH12-14S-0.5SH(**) 586-0533-0 ** 14 6.5 10.1 11.1 7.57 FH12-15S-0.5SH(**) 586-0523-6 ** 15 7.0 10.6 11.6 8.07 FH12-16S-0.5SH(**) 586-0531-4 ** 16 7.5 11.1 12.1 8.57 FH12-17S-0.5SH(**) 586-0606-1 ** 17 8.0 11.6 12.6 9.07 FH12-18S-0.5SH(**) 586-0530-1 ** 18 8.5 12.1 13.1 9.57 FH12-19S-0.5SH(**) 586-0534-2 ** 19 9.0 12.6 13.6 10.07 FH12-20S-0.5SH(**) 586-0524-9 ** 20 9.5 13.1 14.1 10.57 FH12-22S-0.5SH(**) 586-0532-7 ** 22 10.5 14.1 15.1 11.57 FH12-24S-0.5SH(**) 586-0521-0 ** 24 11.5 15.1 16.1 12.57 FH12-25S-0.5SH(**) 586-0692-3 ** 25 12.0 15.6 16.6 13.07 FH12-26S-0.5SH(**) 586-0576-2 ** 26 12.5 16.1 17.1 13.57 FH12-28S-0.5SH(**) 586-0612-4 ** 28 13.5 17.1 18.1 14.57 FH12-30S-0.5SH(**) 586-0525-1 ** 30 14.5 18.1 19.1 15.57 FH12-32S-0.5SH(**) 586-0681-7 ** 32 15.5 19.1 20.1 16.57 FH12-33S-0.5SH(**) 586-0520-8 ** 33 16.0 19.6 20.6 17.07 FH12-34S-0.5SH(**) 586-0617-8 ** 34 16.5 20.1 21.1 17.57 FH12-35S-0.5SH(**) 586-0740-4 ** 35 17.0 20.6 21.6 18.07 FH12-36S-0.5SH(**) 586-0526-4 ** 36 17.5 21.1 22.1 18.57 Note 5 FH12-40S-0.5SH(**) 586-0527-7 ** 40 19.5 23.1 24.1 20.57 Note 5 FH12-45S-0.5SH(**) 586-0528-0 ** 45 22.0 25.6 26.6 23.07 Note 5 FH12-50S-0.5SH(**) 586-0529-2 ** 50 24.5 28.1 29.1 25.57 Note 5 Note 5 4 4.6 5.6 53 26.0 30.6 29.6 27.07 FH12-53S-0.5SH(**) 586-0595-7 ** Note 1 : Embossed tape reel packaging (2,000 pcs/reel, 500 pcs/reel). Order by number of reels. FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■0.5mm Pitch Bottom Contact Type with Strengthened Flip-lock Actuator 1.2 2 0.8 A 0.5 (0.2) polarizing mark indicator Number of Contacts indicator 2 2.4 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2.25 B C D 4.6 5.6 Note 1 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max. Note 2 : Packaged on tape and reel only. Check packaging specification. Note 3 : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm Part No. HRS No. No. of Contacts A B C D FH12S-30S-0.5SH(**) 586-0667-6 ** 30 14.5 18.1 19.1 15.57 FH12S-40S-0.5SH(**) 586-0640-0 ** 40 19.5 23.1 24.1 20.57 FH12S-45S-0.5SH(**) 586-0665-0 ** 45 22.0 25.6 26.6 23.07 FH12S-50S-0.5SH(**) 586-0642-5 ** 50 24.5 28.1 29.1 25.57 FH12S-53S-0.5SH(**) 586-0691-0 ** 53 26.0 29.6 30.6 27.07 Note 1 : Embossed tape reel packaging (2,000 pcs/reel, 500 pcs/reel). Order by number of reels. 5 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■0.5mm Pitch Top Contact Type A B C (1.85 ) 0.5 ( 0.2) 6.2 2 (3.6) polarizing mark indicator D ( 0.45 ) 0.8 E 2.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.85 1.45 Note 1 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max. Note 2 : Packaged on tape and reel only. Check packaging specification. Note 3 : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm Part No. HRS No. No. of Contacts A B C D E FH12A-10S-0.5SH(**) 586-0550-9 ** 10 9.1 8.35 4.5 9.5 5.57 FH12A-12S-0.5SH(**) 586-0696-4 ** 12 10.1 9.35 5.5 10.5 6.57 FH12A-15S-0.5SH(**) 586-0551-1 ** 15 11.6 10.85 7.0 12.0 8.07 FH12A-16S-0.5SH(**) 586-0552-4 ** 16 12.1 11.35 7.5 12.5 8.57 FH12A-18S-0.5SH(**) 586-0553-7 ** 18 13.1 12.35 8.5 13.5 9.57 FH12A-20S-0.5SH(**) 586-0554-0 ** 20 14.1 13.35 9.5 14.5 10.57 FH12A-22S-0.5SH(**) 586-0686-0 ** 22 15.1 14.35 10.5 15.5 11.57 FH12A-24S-0.5SH(**) 586-0555-2 ** 24 16.1 15.35 11.5 16.5 12.57 FH12A-26S-0.5SH(**) 586-0663-5 ** 26 17.1 16.35 12.5 17.5 13.57 FH12A-28S-0.5SH(**) 586-0725-0 ** 28 18.1 17.35 13.5 18.5 14.57 FH12A-29S-0.5SH(**) 586-0585-3 ** 29 18.6 17.85 14.0 19.0 15.07 FH12A-30S-0.5SH(**) 586-0556-5 ** 30 19.1 18.35 14.5 19.5 15.57 FH12A-32S-0.5SH(**) 586-0687-3 ** 32 20.1 19.35 15.5 20.5 16.57 FH12A-33S-0.5SH(**) 586-0570-6 ** 33 20.6 19.85 16.0 21.0 17.07 FH12A-34S-0.5SH(**) 586-0670-0 ** 34 21.1 20.35 16.5 21.5 17.57 FH12A-36S-0.5SH(**) 586-0662-2 ** 36 22.1 21.35 17.5 22.5 18.57 FH12A-40S-0.5SH(**) 586-0557-8 ** 40 24.1 23.35 19.5 24.5 20.57 FH12A-42S-0.5SH(**) 586-0698-0 ** 42 25.1 24.35 20.5 25.5 21.57 FH12A-45S-0.5SH(**) 586-0558-0 ** 45 26.6 25.85 22.0 27.0 23.07 FH12A-50S-0.5SH(**) 586-0559-3 ** 50 29.1 28.35 24.5 29.5 25.57 Note 1 : Embossed tape reel packaging (2,000 pcs/reel). Order by number of reels. 6 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■0.5mm Pitch Vertical mounting Type ( 0.2 ) Mated Cross-sectional Diagram ( 0.15) FPC/FFC Contact Surface (1.4 ) ( 2.15 ) 1 1 0.5 F 2.5 ( 4.25 ) (1.75 ) 3.6 5.5 ( 4.85 ) A B Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5 0.5 C D E Note 1 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max. Note 2 : Packaged on tape and reel only. Check packaging specification. Note 3 : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm Part No. HRS No. No. of Contacts A B C D E F FH12-6S-0.5SVA(54) FH12-10S-0.5SVA(54) 586-0756-4 54 6 6.4 4.9 2.5 4.5 6.2 4 586-0806-0 54 10 8.4 6.9 4.5 6.5 8.2 4 FH12-12S-0.5SVA(54) 586-0757-7 54 12 9.4 7.9 5.5 7.5 9.2 4 FH12-13S-0.5SVA(54) 586-0807-3 54 13 9.9 8.4 6.0 8.0 9.7 4 FH12-15S-0.5SVA(54) 586-0808-6 54 15 10.9 9.4 7.0 9.0 10.7 4 FH12-16S-0.5SVA(54) 586-0809-9 54 16 11.4 9.9 7.5 9.5 11.2 4 FH12-17S-0.5SVA(54) 586-0810-8 54 17 11.9 10.4 8.0 10.0 11.7 4 FH12-18S-0.5SVA(54) 586-0811-0 54 18 12.4 10.9 8.5 10.5 12.2 4 FH12-20S-0.5SVA(54) 586-0812-3 54 20 13.4 11.9 9.5 11.5 13.2 4 FH12-22S-0.5SVA(54) 586-0813-6 54 22 14.4 12.9 10.5 12.5 14.2 8 FH12-24S-0.5SVA(54) 586-0814-9 54 24 15.4 13.9 11.5 13.5 15.2 8 FH12-26S-0.5SVA(54) 586-0815-1 54 26 16.4 14.9 12.5 14.5 16.2 8 FH12-30S-0.5SVA(54) 586-0750-8 54 30 18.4 16.9 14.5 16.5 18.2 8 FH12-32S-0.5SVA(54) 586-0816-4 54 32 19.4 17.9 15.5 17.5 19.2 8 FH12-33S-0.5SVA(54) 586-0818-0 54 33 19.9 18.4 16.0 18.0 19.7 8 FH12-34S-0.5SVA(54) 586-0817-7 54 34 20.4 18.9 16.5 18.5 20.2 8 FH12-36S-0.5SVA(54) 586-0819-2 54 36 21.4 19.9 17.5 19.5 21.2 8 FH12-40S-0.5SVA(54) 586-0804-5 54 40 23.4 21.9 19.5 21.5 23.2 8 FH12-45S-0.5SVA(54) 586-0820-1 54 45 25.9 24.4 22.0 24.0 25.7 8 FH12-49S-0.5SVA(54) 586-0821-4 54 49 27.9 26.4 24.0 26.0 27.7 8 FH12-50S-0.5SVA(54) 586-0805-8 54 50 28.4 26.9 24.5 26.5 28.2 8 FH12-60S-0.5SVA(54) 586-0749-9 54 60 33.4 31.9 29.5 31.5 33.2 8 Note 1 : Embossed tape reel packaging (1,000 pcs/reel, 500 pcs/reel). Order by number of reels. 7 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■1mm Pitch Type Bottom Contact Type 2.3 E A 1.0 (0.2) 1.2 2 0.8 Mated Cross-sectional Diagram FPC/FFC Contact Surface polarizing mark indicator (2.1) (3.1) Number of Contacts indicator Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 (4.8) 1.85 B C D 4.6 5.6 Note 1 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max. Note 2 : Packaged on tape and reel only. Check packaging specification. Note 3 : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm Standard type Part No. Eccentric type HRS No. No. of Contacts A B C D E FH12-5S-1SH(**) 586-0591-6 ** 5 4 8.6 9.6 6.07 2.3 FH12-6S-1SH(**) 586-0607-4 ** 6 5 9.6 10.6 7.07 2.3 FH12-7S-1SH(**) 586-0535-5 ** 7 6 10.6 11.6 8.07 2.3 FH12-8S-1SH(**) 586-0579-0 ** 8 7 11.6 12.6 9.07 2.3 FH12-9S-1SH(**) 586-0540-5 ** 9 8 12.6 13.6 10.07 2.3 FH12-11S-1SH(**) 586-0668-9 ** 11 10 14.6 15.6 12.07 2.3 FH12-12S-1SH(**) 586-0741-7 ** 12 11 15.6 16.6 13.07 2.3 FH12-16S-1SH(**) 586-0536-8 ** 16 15 19.6 20.6 17.07 2.3 FH12-17S-1SH(**) 586-0739-5 ** 17 16 20.6 21.6 18.07 2.3 FH12-22S-1SH(**) 586-0547-4 ** 22 21 25.6 26.6 23.07 2.3 FH12-26S-1SH(**) 586-0592-9 ** 26 25 29.6 30.6 27.07 2.3 FH12-10(4)SA-1SH(**) 586-0537-0 ** 4 3 8.1 9.1 5.57 2.8 FH12-14(6)SA-1SH(**) 586-0538-3 ** 6 5 10.1 11.1 7.57 2.8 FH12-18(8)SA-1SH(**) 586-0539-6 ** 8 7 12.1 13.1 9.57 2.8 FH12-22(10)SA-1SH(**) 586-0541-8 ** 10 9 14.1 15.1 11.57 2.8 FH12-24(11)SA-1SH(**) 586-0542-0 ** 11 10 15.1 16.1 12.57 2.8 FH12-30(14)SA-1SH(**) 586-0543-3 ** 14 13 18.1 19.1 15.57 2.8 FH12-40(19)SA-1SH(**) 586-0546-1 ** 19 18 23.1 24.1 20.57 2.8 FH12-50(24)SA-1SH(**) 586-0548-7 ** 24 23 28.1 29.1 25.57 2.8 Note 1 : Embossed tape reel packaging (2,000 pcs/reel, 500 pcs/reel). Order by number of reels. 8 (1.3) FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ■1mm Pitch Vertical Mounting Type Mated Cross-sectional Diagram 2 FPC/FFC Contact Surface (0.15) (1.4) (2.15) (0.2) 2 0.5 F 2.5 (4.25) (1.75) 3.6 5.5 (4.85) A B Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5 1.0 3.8(Metal fitting dimension) C D E Note 1 : The coplanarity of each terminal lead within specified dimension is 0.1mm Max. Note 2 : Packaged on tape and reel only. Check packaging specification. Note 3 : Slight variations in color of the plastic compounds do not affect form, fit or function of the connector. Note 4 : After reflow, the terminal plating may change color, however this does not represent a quality issue. Unit : mm HRS No. No. of Contacts A B C D E F FH12-06S-1SVA(54) Part No. 586-0822-0 54 6 9.9 8.4 5 8 9.7 4 FH12-07S-1SVA(54) 586-0823-0 54 7 10.9 9.4 6 9 10.7 4 FH12-08S-1SVA(54) 586-0824-0 54 8 11.9 10.4 7 10 11.7 4 FH12-16S-1SVA(54) 586-0825-0 54 16 19.9 18.4 15 18 19.7 8 FH12-20S-1SVA(54) 586-0826-0 54 20 23.9 22.4 19 22 23.7 8 FH12-22S-1SVA(54) 586-0827-0 54 22 25.9 24.4 21 24 25.7 8 FH12-24S-1SVA(54) 586-0828-0 54 24 27.9 26.4 23 26 27.7 8 Note 1 : Embossed tape reel packaging (1,000 pcs/reel, 500 pcs/reel). Order by number of reels. 9 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC BRecommended FPC/FFC dimensions and Land/Metal Mask dimensions ●0.5mm Pitch Product 0.5±0.1 0.3±0.03(Land) 0.5±0.05 0.25±0.03(Metal mask) A±0.05 *Set the stiffener thickness to 0.188 (7.5mil) min. Number of Contacts 6 8 10 11 12 13 14 15 16 17 18 19 20 22 24 Dimension A B 2.5 3.5 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.5 11.5 3.5 4.5 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 11.5 12.5 Number of Contacts 25 26 28 29 30 32 33 34 35 36 40 42 45 50 53 A B 12.0 12.5 13.5 14.0 14.5 15.5 16.0 16.5 17.0 17.5 19.5 20.5 22.0 24.5 26.0 13.0 13.5 14.5 15.0 15.5 16.5 17.0 17.5 18.0 18.5 20.5 21.5 23.0 25.5 27.0 6 8 10 11 12 13 14 15 16 17 18 19 20 22 24 A B 2.5 3.5 4.5 5.0 5.5 6.0 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.5 11.5 8.1 9.1 10.1 10.6 11.1 11.6 12.1 12.6 13.1 13.6 14.1 14.6 15.1 16.1 17.1 C Dimension Number of Contacts A B C 4.5 5.5 6.5 7.0 7.5 8.0 8.5 9.0 9.5 10.0 10.5 11.0 11.5 12.5 13.5 25 26 28 29 30 32 33 34 35 36 40 42 45 50 53 12.0 12.5 13.5 14.0 14.5 15.5 16.0 16.5 17.0 17.5 19.5 20.5 22.0 24.5 26.0 17.6 18.1 19.1 19.6 20.1 21.1 21.6 22.1 22.6 23.1 25.1 26.1 27.6 30.1 31.6 14.0 14.5 15.5 16.0 16.5 17.5 18.0 18.5 19.0 19.5 21.5 22.5 24.0 26.5 28.0 0.5±0.05 0.35±0.03(FPC) 0.3±0.05 1±0.05 1±0.05 0.5±0.1 10 0.6±0.1(Land) B±0.05 Number of Contacts 6 10 12 13 15 16 17 18 20 22 24 A B 02.5 04.5 05.5 06.0 07.0 07.5 08.0 08.5 09.5 10.5 11.5 03.5 05.5 06.5 07.0 08.0 08.5 09.0 09.5 10.5 11.5 12.5 Dimension Number of Contacts 26 30 32 33 34 36 40 45 49 50 60 0.5±0.05(Metal mask) 1±0.05 1.8±0.1 1.8±0.1 Recommended metal mask thickness : 0.15mm Unit : mm Dimension No.1 contact A±0.1 0.8±0.1(Land) 0.65±0.05(Metal mask) 0.6±0.1(Land) 0.5±0.05 0.5±0.05(Metal mask) 1±0.05 1±0.05 1±0.05 B±0.05 *Set the stiffener thickness to 0.188 (7.5mil) min. 0.5mm Pitch Vertical Mountin g Type 1.5±0.1 1.5±0.1 4.5±0.1 0.5±0.05 0.3±0.03(FFC) A±0.05 B±0.07 Odd contact number No.1 contact A±0.1 0.8±0.1(Land) 0.65±0.05(Metal mask) 1.8±0.1 1.8±0.1 2MIN 3MIN Even contact number 0.5±0.1 Unit : mm Recommended metal mask thickness : 0.15mm Dimension Number of Contacts 1.5±0.1 Unit : mm Dimension 1.5±0.1 4.5±0.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5mm Pitch Top Contact Type 0.3±0.05 1.3±0.1 A±0.05 B±0.07 B±0.1 C±0.1 1.5±0.1 4.5MIN 3.5MIN 0.35±0.03(FPC) 0.3±0.03(FFC) 0.5±0.05 0.5±0.1 0.5mm Pitch Bottom Contact Type Land / Metal Mask dimensions 2.2±0.1 FPC/FFC dimensions A B 12.5 14.5 15.5 16.0 16.5 17.5 19.5 22.0 24.0 24.5 29.5 13.5 15.5 16.5 17.0 17.5 18.5 20.5 23.0 25.0 25.5 30.5 Unit : mm Dimension Number of Contacts 10 12 13 15 16 17 18 20 22 24 A B 06.5 07.5 08.0 09.0 09.5 10.0 10.5 11.5 12.5 13.5 04.5 05.5 06.0 07.0 07.5 08.0 08.5 09.5 10.5 11.5 Dimension Number of Contacts 26 30 32 33 34 36 40 45 49 50 60 A B 14.5 16.5 17.5 18.0 18.5 19.5 21.5 24.0 26.0 26.5 31.5 12.5 14.5 15.5 16.0 16.5 17.5 19.5 22.0 24.0 24.5 29.5 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC BRecommended FPC/FFC dimensions and Land/Metal Mask dimensions ●1mm Pitch Product 1mm Pitch Vertical Mounting Type Land / Metal Mask dimensions Recommended metal mask thickness : 0.15mm πSet the stiffener thickness to 0.188 (7.5mil) min. 1mm Pitch Bottom Contact Type Unit : mm B C 5 6 7 8 9 11 12 16 17 22 26 04 05 06 07 08 10 11 15 16 21 25 06 07 08 09 10 12 13 17 18 23 27 1 1 1 1 1 1 1 1 1 1 1 A B C 4 6 8 10 11 14 19 24 03 05 07 09 10 13 18 23 05.5 07.5 09.5 11.5 12.5 15.5 20.5 25.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 *Set the stiffener thickness to 0.188 (7.5mil) min. Unit : mm Dimension A Number of Contacts 5 6 7 8 9 11 12 16 17 22 26 04 05 06 07 08 10 11 15 16 21 25 B C D 10.6 11.6 12.6 13.6 14.6 16.6 17.6 21.6 22.6 27.6 31.6 07 08 09 10 11 13 14 18 19 24 28 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 1.5 Number of Contacts A B 6 7 8 16 20 22 24 05 06 07 15 19 21 23 07 08 09 17 21 23 25 03 05 07 09 10 13 18 23 4 6 8 10 11 14 19 24 B C 10.1 06.5 12.1 08.5 14.1 10.5 16.1 12.5 17.1 13.5 20.1 16.5 25.1 21.5 30.1 26.5 D 2 2 2 2 2 2 2 2 Recommended metal mask thickness : 0.15mm Unit : mm Dimension Dimension A Number of Contacts Eccentric Type A Dimension Number of Contacts Standard Type Dimension Number of Contacts Eccentric Type Standard Type Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC/FFC dimensions Unit : mm Dimension Number of Contacts A B 6 7 8 16 20 22 24 08 09 10 18 22 24 26 05 06 07 15 19 21 23 11 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC BPackaging Specification Embossed Carrier Tape Dimensions Horizontal Type (Common to Bottom/Top Contact, 0.5mm/1mm Pitch) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (2.0) Flat surface for placement with Automatic equipment 3) Reel Dimensions (Common to All Types) (ø1 (D : INSIDE) Mounting portion Lead portion (400mm min.) ( ( ) ) End portion Embossed carrier tape Blank portion ( E : OUTSIDE) (10 pockets min.) ●0.5mm Pitch Bottom/Top Contact Type Dimension Number of Contacts A B C D 6 8 10 11 12 13 14 15 16 17 18 19 20 22 24 16 16 16 16 24 24 24 24 24 24 24 24 24 24 24 ---------------------------------------------------------------------------------------------------------------------------------------- 07.5 07.5 07.5 07.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 11.5 17.4 17.4 17.4 17.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 25.4 Top cover tape Blank portion (10 pockets min.) Unit : mm E Dimension Number of Contacts A B C D E 21.4 21.4 21.4 21.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 29.4 25 26 28 29 30 32 33 34 35 36 40 42 45 50 53 24 24 32 32 32 32 32 32 44 44 44 44 44 44 44 ------------------28.4 28.4 28.4 28.4 28.4 28.4 40.4 40.4 40.4 40.4 40.4 40.4 40.4 11.5 11.5 14.2 14.2 14.2 14.2 14.2 14.2 20.2 20.2 20.2 20.2 20.2 20.2 20.2 25.4 25.4 33.4 33.4 33.4 33.4 33.4 33.4 45.4 45.4 45.4 45.4 45.4 45.4 45.4 29.4 29.4 37.4 37.4 37.4 37.4 37.4 37.4 49.4 49.4 49.4 49.4 49.4 49.4 49.4 12 Unit : mm Dimension Number of Contacts A B C D E 5 6 7 8 9 11 12 16 17 22 26 16 24 24 24 24 24 24 32 44 44 44 ---------------------------------------------------------------28.4 40.4 40.4 40.4 07.5 11.5 11.5 11.5 11.5 11.5 11.5 14.2 20.2 20.2 20.2 17.4 25.4 25.4 25.4 25.4 25.4 25.4 33.4 45.4 45.4 45.4 21.4 29.4 29.4 29.4 29.4 29.4 29.4 37.4 49.4 49.4 49.4 Eccentric Type Standard Type ● 1mm Pitch Bottom Contact Type Dimension Number of Contacts A B C D E 4 6 8 10 11 14 19 24 16 24 24 24 24 32 44 44 ---------------------------------------------28.4 40.4 40.4 07.5 11.5 11.5 11.5 11.5 14.2 20.2 20.2 17.4 25.4 25.4 25.4 25.4 33.4 45.4 45.4 21.4 29.4 29.4 29.4 29.4 37.4 49.4 49.4 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC Flat surface for placement with Automatic equipment (1.75) 3) Reel Dimensions (Common to All Types) (D : INSIDE) (ø1 Mounting portion Lead portion (400mm min.) ( ) ) End portion ( Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Vertical Mounting Type (Common to 0.5mm/1mm Pitch) ( E : OUTSIDE) Embossed carrier tape Blank portion (10 pockets min.) ●0.5mm Pitch Vertical mounting Type Dimension Number of Contacts A B C D Top cover tape Blank portion (10 pockets min.) Unit : mm E Dimension Number of Contacts A B C D E 6 16 ---------- 07.5 17.4 21.4 26 24 ---------- 11.5 25.4 29.4 10 16 ---------- 07.5 17.4 21.4 30 32 28.4 14.2 33.4 37.4 12 16 ---------- 07.5 17.4 21.4 32 32 28.4 14.2 33.4 37.4 13 24 ---------- 11.5 25.4 29.4 33 32 28.4 14.2 33.4 37.4 15 24 ---------- 11.5 25.4 29.4 34 44 40.4 20.2 45.4 49.4 16 24 ---------- 11.5 25.4 29.4 36 44 40.4 20.2 45.4 49.4 17 24 ---------- 11.5 25.4 29.4 40 44 40.4 20.2 45.4 49.4 18 24 ---------- 11.5 25.4 29.4 45 44 40.4 20.2 45.4 49.4 20 24 ---------- 11.5 25.4 29.4 49 44 40.4 20.2 45.4 49.4 22 24 ---------- 11.5 25.4 29.4 50 44 40.4 20.2 45.4 49.4 24 24 ---------- 11.5 25.4 29.4 60 56 52.4 26.2 57.4 61.4 ●1mm Pitch Vertical mounting Type Unit : mm Dimension Number of Contacts A B C D E 6 24 ---------- 11.5 25.4 29.4 7 24 ---------- 11.5 25.4 29.4 8 24 ---------- 11.5 25.4 29.4 16 32 28.4 14.2 33.4 37.4 20 44 40.4 20.2 45.4 49.4 22 44 40.4 20.2 45.4 49.4 24 44 40.4 20.2 45.4 49.4 13 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC BFH12 Series FPC/FFC Construction (Recommended Specifications) 1. FFC FFC : Flexible Flat Cable Material Name Material Thickness (μm) (12) Polyester film Adhesive Thermoplastic polyester (Nickel under plated / Gold plated), soft copper film 35 Polyester type Adhesive (30) 30 12 Polyester Adhesive Polyester type 30 Stiffener Polyester type 188 Total 295 (Note) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. *Real tolerance of thickness dimension is on the order of ±20μm (275 to 315μm) Note : Use of a thicker FFC results in a stiffer lock action and the lock is more easily released. A factor that contributes to thicker FFC is the use of 250μm stiffener which is thicker than the standard (188μm) product. This results in a total thickness of 357μm. When using FFC, control of FFC thickness becomes easy if you indicate to us the thickness of the stiffener. FPC : Flexible Printed Circuit 2. FPC Material Name Covering layer film Material Polyimide 1 mil Thickness (μm) (25) (25) Cover adhesive Surface treatmenta Nickel under plated 1to 5μm / Gold plated 0.2μm Copper foil Cu Base adhesive Heat-hardened adhesive 25 Base film Polyimide 1 mil 25 1oz Reinforcement material adhesive Heat-hardened adhesive Stiffener 3 35 30 Polyimide 7 mil 175 Total 293 3. Precautions 1. This specification is a recommendation for the construction of the FH12 Series FPC and FFC (t=0.3±0.05). 2. For details about the construction, please contact the FPC/FFC manufacturers. ■Recommended Temperature Profile MAX 250ç 250 Temperature 230ç 200 200ç 150 150ç (ç) 100 50 0 25ç (60 seconds) 90 to 120 seconds Preheating Start Time 14 30 seconds Soldering HRS test conditions Solder method : Reflow, IR/hot air Environment : Room air Solder composition : Paste, 96.5%Sn/3%Ag/0.5%Cu (Senju Metal Industry, Co., Ltd.’s Part Number: M705-221CM5-3210.5) Test board : Glass epoxy 40mm∞80mm∞1.6mm thick Land dimensions : Top and bottom contact type 0.3mm∞1.3mm Vertical mounting type 0.6mm∞1.5mm Metal mask : Top and bottom contact type 0.25mm∞1.3mm∞0.15mm thick Vertical mounting type 0.5mm∞1.5mm∞0.15mm thick This temperature profile is based on the above conditions. In individual applications the actual temperature may vary, depending on solder paste type, volume/thickness and board size/thickness. Consult your solder paste and equipment manufacturer for specific recommendations. FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC BConnector Operating Instructions, precautions and recommendations ●Bottom Contact Type (common for 0.5mm/1mm Pitch) Operation Precautions 1. FPC/FFC Termination procedure. Connector installed on the board. 1) Avoid grasping the actuator with two fingers or lifting the actuator with fingernail. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) Lift up the actuator. Use thumb or index finger. 2) Do not use a thin tool such as the tip of a screwdriver to release the lock lever. Doing so will cause deformation of the contacts. 3) Do not apply force in the direction of arrows A, B, or C while the lock lever is open. Doing so will cause the lock lever to become disen gaged, or will damage the hook portion of the connector body. 2) Fully insert the FPC/FFC parallel to mounting surface, with the exposed conductive traces facing down. 4) When inserting the FPC/FFC, do not forcefully rub against the surface beneath the connector insertion slot. Doing so will result in the FPC/FFC forcefully striking the contacts and this will cause contact deformation, peeling of the FPC/FFC conductors, and other irregularities. FPC/FFC conductive traces 5) Insert the FPC/FFC at the proper position of the connector insertion slot, and insert perpendicularly with respect to the connector. Improper insertion will cause continuity problems, disengagement of the lock lever, and damage to the hook portion. 15 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Bottom Contact Type (common for 0.5mm/1mm Pitch) Operation Precautions 3) Rotate down the actuator until firmly closed. It is critical that the inserted FPC/FFC is not moved and remains fully inserted. Should the FPC/FFC be moved, open the actuator and repeat the process, starting with Step 1. 6) Partial insertion of the FPC/FFC, offset insertion, and diagonal insertion will result in an unfavorable engagement of the lock lever in which the lock lever is raised. To correct this, first remove the FPC/FFC and then reinsert it. Forcing the lock will damage the connector. Stiffener 7) When locking, handle the FPC/FFC so that a load is not applied to the FPC/FFC as would occur by pulling the FPC/FFC, or lifting it, etc. When a load is applied in the opposite direction to the rotational movement of the lock, an excessive load will be applied and this will cause connector damage. 2. FPC/FFC Removal 1) Lift up the actuator. 2) Carefully remove the FPC/FFC. 8) At the time of lock operation, application of force such as that indicated by the arrows in the diagrams below will cause the lock lever to disengage. When the lock lever has become disengaged, please exchange the entire connector. 16 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ●Top Contact Type Operation Precautions 1. FPC/FFC Termination procedure. Connector installed on the board. 1) Lift up the actuator. Use thumb or index finger. 1) Avoid further lifting of the actuator once the lock has been released. Doing so will cause the lock lever to separate from the rotational shaft, and the lock lever will become disengaged or the hook portion of the connector body will be damaged. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. actuator Rotational shaft 2) Fully insert the FPC/FFC parallel to mounting surface, with the exposed conductive traces facing UP. C FP a are tion r e ins FPC/FFC conductive traces 2) Avoid further pressing of the lock portion from the locked condition when the FPC/FFC has not yet been inserted. Doing so will cause the lock lever to become disengaged from the rotational shaft, and the hook portion of the connector body will be damaged. Stiffener 3) Rotate down the actuator until firmly closed. It is critical that the inserted FPC/FFC is not moved and remains fully inserted. Should the FPC/FFC be moved, open the actuator and repeat the process, starting with Step 1 above. 3) Do not insert the FPC/FFC diagonally. D o i n g so will result in the corners of the FPC/FFC catching on the contacts and will cause deformation of the contacts. 2. FPC/FFC Removal 1) Lift up the actuator. 2) Carefully remove the FPC/FFC. 4) When closing down the actuator apply equal pressure to both sides of the actuator. 17 FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC ●Vertical Mounting type (common for 0.5mm/1mm pitch) Operation Precautions 1. FPC/FFC Termination procedure. Connector installed on the board. 1) Avoid forcing the actuator up or down without the FPC/FFC inserted. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1) Verify that the actuator is positioned upright. If the actuator has rotated to the side, carefully rotate it upright. Actuator upright 2) Insert the FPC/FFC vertically in the connector slot assuring that the conductive traces of the FPC/FFC are facing away from the actuator. Stiffener 2) Do not attempt to open or over rotate an already released actuator (refer to the diagram below). These actions may damage the actuator. FPC/FFC conductive traces Sl ot 3) Press down the actuator in the direction shown. 3) Do not insert the FPC/FFC diagonally. Doing so will result in the corners of the FPC/FFC catching on the contacts and will cause deformation of the contacts. 2. FPC/FFC Removal Rotate the actuator upward and withdraw the FPC/FFC. 4) Do not press down vertically on the actuator when the FPC/FFC already inserted, it needs to be rotated to engage the lock. Refer to the diagram below. Doing so may cause actuator failure. 18 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC MEMO: 19 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FH12 Series●0.5mm and 1mm Pitch Connectors For FPC/FFC 20 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 01/2017. Contents are subject to change without notice for the purpose of improvements.
FH12-33S-0.5SH(57)
物料型号:HIROSE ELECTRIC CO., LTD. 的FH12系列,提供0.5mm和1mm间距的FPC/FFC连接器。
器件简介: - 该系列连接器具有一键旋转ZIF机制,操作简便,只需轻力即可完成接合。 - 提供清晰的触感反馈,接合成功后会有明确的触觉点击感。 - 支持高密度安装,与其他滑锁连接器相比,所需的空间更小,可安装在PCB中心。 - 提供顶部接触、底部接触和垂直安装三种连接类型。 - 除了0.5mm间距连接器外,还提供1mm间距的产品。 - 某些型号(如FH12S系列)具有加固的驱动器,增加了对驱动器断裂的防护。
引脚分配:根据接触类型(顶部、底部或垂直安装)和间距(0.5mm或1mm),FH12系列提供多种引脚分配选项。
参数特性: - 工作温度范围:-40至+85°C。 - 电压等级:50V AC。 - 存储温度范围:-10至+50°C。 - 存储湿度范围:相对湿度最大90%(无结露)。 - 接触电阻:最小500MΩ。 - 耐电压:150V AC/1分钟,无闪络或绝缘击穿。 - 耐久性:插拔20次,接触电阻最大50mΩ,无损坏、裂纹或零件移位。
功能详解: - 连接器设计用于在需要高可靠性的应用中使用,例如汽车行业。 - 提供不同数量的接触点,以适应不同的FPC/FFC配置。
应用信息: - 适用于FPC(Flexible Printed Circuit)和FFC(Flexible Flat Cable)的连接。 - 推荐使用特定厚度的FPC/FFC,以确保连接器的正确操作和接合。
封装信息: - 提供详细的封装尺寸和材料信息,包括绝缘体、接触件和金属配件的材料和表面处理。 - 提供产品编号结构,以便于从产品编号确定产品规格。
FH12-33S-0.5SH(57) 价格&库存
很抱歉,暂时无法提供与“FH12-33S-0.5SH(57)”相匹配的价格&库存,您可以联系我们找货
