FH52E-20(10)SB-1SH(99)
    HRS(广濑)
FH52E-20(10)SB-1SH(99) 数据手册
FH52 Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Jun. 2021 ⑥ FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Features Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. Highly reliable connection and robust design Solder tabs prevent actuator disengagement Higher connector body strength and FPC/ FFC connection reliability are required even more than before as connectors continue to be produced with higher pin counts. Compared with existing products ( HRS 0. 5mm pitch standard connector FH12 Series horizontal mounting type) , FH52 Series has higher connection reliability due to the FPC/ FFC positioning mechanism and provides a secure connection that prevents unlocking due to the original, robust design. Each contact prevents actuator disengagement Secure Actuator Retention 2. Product variations that meet a variety of needs ・ FH52E : Long solder tabs type Solder tabs extending from the connector body enable visual inspection of the soldering conditions. ・ FH52K : Long solder tabs and 125℃ ( Note) heat resistance type 125℃ heat resistant connector meets severe automotive requirements. ・ FH52T : Long solder tabs and 2- point contact type The 2 independent spring design connects with the FPC/ FFC at 2 points, preventing contact failure due to dust adhesion. The solder tabs extend out from the connector body, enabling visual inspection of soldering. Long Solder Tabs Type ( FH52E/ FH52K/ FH52T) Note : The heat resistant when using FFC is 105℃. When the heat resistant temperature is less than 125℃ for FPC and 105℃ for FFC, the heat resistant temperature of the FPC/ FFC is applied. 2-point contact design with independent springs enhances reliability. 2- Point Contact ( FH52T) 2 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector 3. Flip lock simplifies operations The flip lock ( one- touch rotation) design enables easier FPC/ FFC connection operation with less force. The clear tactile click upon locking is enhanced compared to existing products ( FH12 horizontal mounting type) for a secure connection. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4. High FPC/ FFC retention force Tabbed FPC/ FFCs enhanced retention force in the horizontal direction. FPC/FFC with tabs increase the retention force in the horizontal direction. Connection Utilizing FPC/ FFC Position Alignment Design 5. Accepts standard 0. 3mm thick FPC/ FFC Compatible 0. 3mm thickness FPC/ FFC, which are easy to manufacture and have superb insertion performance 6. No pattern prohibited area on the bottom of the connector ( Overmolding design) The bottom surface of the connector is fully enclosed to eliminate contact exposure, removing PCB pattern restrictions and enhancing board design flexibility. 7. Halogen- free All materials and substances used to produce this product comply with Halogen- free standards. As defined in IEC 61249- 2- 21. Br : 900ppm or less, Cl : 900ppm or less, Br+ Cl : 1, 500ppm or less 3 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector 8. Supports automatic pick & place mounting Offered in tape and reel packaging that is compatible with automatic machine mounting. ( 3, 000pcs per reel) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 9. 500pcs per reel packing option available The standard packaging is 3, 000pcs per reel, but FH52 is also offered in 500pcs per reel. ( The reel outer diameter is φ180mm for the 500pcs per reel option) 4 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Product Specifications Rated Current (Note 1) 0.5A Operating Temperature (Note 2)(Note 3) -40 to +105℃ Rated Voltage 50V AC Operating Humidity Range RH 90% Max. (No Condensation) Storage Temperature Range (Note 4) -10 to +50℃ Storage Humidity Range (Note 4) RH 90% Max. (No Condensation) Adaptive FPC/FFC Contact Specifications Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Items Thickness : = 0.3 ± 0.05mm Gold Plated Specifications Conditions Insulation Resistance 500M Ω Min. 100V DC Withstanding Voltage No flashover or insulation breakdown 150Vms AC for 1 min. Contact Resistance 50m Ω Max. Includes FPC/FFC conductor resistance 1mA (DC or 1000Hz) Mating Durability (Insertion / Withdrawal) Contact Resistance : 50m Ω Max. No damage, cracks, or parts dislocation 20 cycles Vibration No electrical discontinuity of 1μ s or more Contact Resistance : 50m Ω Max. No damage, cracks, or parts dislocation Frequency : 10 to 55Hz, single amplitude of 0.75mm, 10 cycles in each of the 3 directions Shock No electrical discontinuity of 1μ s or more Contact Resistance : 50m Ω Max. No damage, cracks, or parts dislocation Acceleration of 981m/s2, duration of 6 ms, sine half-wave waveform, 3 cycles in each of the 3 axes Humidity (Steady State) Contact Resistance : 50m Ω Max. Insulation Resistance : 50M Ω Min. No damage, cracks, or parts dislocation 96 hours at temperature of 40℃ and humidity of 90% to 95% Temperature Cycle Contact Resistance : 50m Ω Max. Insulation Resistance : 50M Ω Min. No damage, cracks, or parts dislocation Temperature : -40 → +15 to +35 → +105 (Note 3) → +15 to +35℃ Time : 30 → 2 to 3 → 30 → 2 to 3 (Minutes) 5 cycles Resistance to Soldering Heat No deformation of components affecting performance Reflow : Peak temperature 250℃ Max.,  230℃ or more, 60 seconds or less Manual soldering : 350 ± 10℃ for 5 seconds Note 1 : When passing the current through all of the contacts, use 70% of the current rating. Note 2 : Includes temperature rise caused by current flow. Note 3 : FH52K withstands up to 125℃ . The heat resistant when using FFC is 105℃ . When the heat resistant temperature is less than 125℃ for FPC and 105℃ for FFC, the heat resistant temperature of the FPC/FFC is applied. Note 4 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity Range covers non-conducting condition of installed connectors in storage, shipment or during transportation. Materials / Finish Part Materials Color/Finish Grey Insulator LCP Contacts Copper Alloy Partially Gold Plated Solder Tabs Brass Tin Plated Black 5 Remarks UL94V-0 - FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. FH52 E - 50 (25) S B - 0.5 SH (##) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ❶ ❷ ❸ ❹ ❺ ❻ ❼ ❽ ❾ ❶ Series Name FH52 ❺ Contact Arrangement Single (pole piece array) ❷ Connector Type Blank : Standard Type E : Long Solder Tabs Type K : Long Solder Tabs, 125℃ Heat Resistant Type T : Long Solder Tabs, 2-Point Contact Type ❻ Alternating Direction No Symbol : Standard Type (All Contacts Loaded) A : Alternating Contact Type (Alternating on the Polarity Side) B : Alternating Contact Type (Alternating on Opposite the Polarity Side) ❼ Contact Pitch 0.5mm, 1mm ❸ No. of Pos. Standard Type : No. of Pos. Alternating Contact Type : Mold Size ❽ Termination Type SH : SMT Horizontal Mounting Type ❹ No. of Pos. Standard Type : No Symbol Alternating Contact Type : No. of Pos.     ❾ Specification (00) : Standard, Partially Gold Plated,     3,000pcs per reel (99) : Partially Gold Plated, 500pcs per reel 6 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Connector Dimensional Drawing ■FH52 (Standard Type) 0.5mm Pitch Product A±0.15 B±0.08 (0.12) (5.0) 0.5±0.08 A ## (0.15) (C) D±0.1 No. of Pos. Indicator c b 1.75±0.2 Detailed Drawing a (Note 6) c (3.9) °) 10 (1 2.0±0.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cav No. a 0 (Note 1)(Note 2) 0.15 Max. Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max. Note 2 : The contact lead position indicates the dimension from b, the bottom surface of the insulator body. Note 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details. Note 4 : Sink mark reliefs may be added due to improvements. Note 5 : Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the contact plating may change color, however this does not represent a quality issue. Note 6 : The actuator design of the 60pos. type are shown in the figure. 7 0 (1.3) 1.4±0.1 3.0±0.1 (4.3) 5.7±0.2 0.15 Max. (Note 1)(Note 2) 0.45±0.1 0.7±0.2 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Part No. HRS No. No. of Pos. A B C D FH52-6S-0.5SH(##) CL0580-3304-0-## 6 7.3 2.5 3.57 5.7 FH52-8S-0.5SH(##) CL0580-3305-3-## 8 8.3 3.5 4.57 6.7 FH52-10S-0.5SH(##) CL0580-3306-6-## 10 9.3 4.5 5.57 7.7 FH52-11S-0.5SH(##) CL0580-3320-7-## 11 9.8 5.0 6.07 8.2 FH52-12S-0.5SH(##) CL0580-3307-9-## 12 10.3 5.5 6.57 8.7 FH52-15S-0.5SH(##) CL0580-3302-5-## 15 11.8 7.0 8.07 10.2 FH52-18S-0.5SH(##) CL0580-3321-0-## 18 13.3 8.5 9.57 11.7 FH52-20S-0.5SH(##) CL0580-3309-4-## 20 14.3 9.5 10.57 12.7 FH52-22S-0.5SH(##) CL0580-3317-2-## 22 15.3 10.5 11.57 13.7 FH52-24S-0.5SH(##) CL0580-3318-5-## 24 16.3 11.5 12.57 14.7 FH52-25S-0.5SH(##) CL0580-3316-0-## 25 16.8 12.0 13.07 15.2 FH52-26S-0.5SH(##) CL0580-3319-8-## 26 17.3 12.5 13.57 15.7 FH52-28S-0.5SH(##) CL0580-3324-8-## 28 18.3 13.5 14.57 16.7 FH52-30S-0.5SH(##) CL0580-3310-3-## 30 19.3 14.5 15.57 17.7 FH52-32S-0.5SH(##) CL0580-3325-0-## 32 20.3 15.5 16.57 18.7 FH52-40S-0.5SH(##) CL0580-3300-0-## 40 24.3 19.5 20.57 22.7 FH52-42S-0.5SH(##) CL0580-3329-1-## 42 25.3 20.5 21.57 23.7 FH52-45S-0.5SH(##) CL0580-3311-6-## 45 26.8 22.0 23.07 25.2 FH52-50S-0.5SH(##) CL0580-3303-8-## 50 29.3 24.5 25.57 27.7 FH52-60S-0.5SH(##) CL0580-3301-2-## 60 34.3 29.5 30.57 32.7 8 Purchase Unit Purchase Unit (##) : (00) (##) : (99) 3,000pcs per reel 500pcs per reel FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52 (Standard Type) 1.0mm Pitch Product A±0.15 (Q) (R) B±0.08 (0.12) (5.0) 1±0.08 A ## b (C) D±0.1 2.0±0.2 Detailed Drawing a (Note 6) c 10 (1 ) ° 1.75±0.2 (0.15) a No. of Pos. Indicator c (3.9) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cav No. 0 0 (1.3) 0.15 Max. (Note 1)(Note 2) (Note 1)(Note 2) 0.15 Max. 0.45±0.1 1.4±0.1 3.0±0.1 0.7±0.2 (4.3) 5.7±0.2 Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max. Note 2 : The contact lead position indicates the dimension from b, the bottom surface of the insulator body. Note 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details. Note 4 : Sink mark reliefs may be added due to improvements. Note 5 : Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the contact plating may change color, however this does not represent a quality issue. Note 6 : The actuator design of the 30pos. type are shown in the figure. Unit : mm Part No. HRS No. No. of Pos. A B C D Q R FH52-10(4)SA-1SH(##) CL0580-3330-0-## 4 9.3 3 5.57 7.7 2.9 3.4 FH52-5S-1SH(00) (Note) CL0580-3336-7-00 5 9.8 4.0 6.07 8.2 2.9 2.9 FH52-12S-1SH(##) CL0580-3323-5-## 12 16.8 11 13.07 15.2 2.9 2.9 FH52-32(16)SB-1SH(00) (Note) CL0580-3338-2-00 16 20.3 15 16.57 18.7 2.4 2.9 FH52-60(30)SB-1SH(##) CL0580-3315-7-## 30 34.3 29 30.57 32.7 2.4 2.9 Note : The (99) specification is only available for 4, 12 and 30pos. 9 Purchase Unit (##) : (00) Purchase Unit (##) : (99) 3,000pcs per reel 500pcs per reel FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52E (Long Solder Tabs Type) 0.5mm Pitch Product (0.12) (5.0) 0.5±0.08 A±0.15 B±0.08 A ## Cav No. a No. of Pos. Indicator c b E±0.2 (Note 6) c 1.75±0.2 Detailed Drawing a ) 0° (3.9) 2.0±0.2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (C) D±0.1 ( 11 0 0 (Note 1)(Note 2) 0.15 Max. 1.55±0.2 1.2±0.2 (1.3) (4.3) 5.7±0.2 0.15 Max. (Note 1)(Note 2) 0.45±0.1 0.7±0.2 Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max. Note 2 : The contact lead position indicates the dimension from b, the bottom surface of the insulator body. Note 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details. Note 4 : Sink mark reliefs may be added due to improvements Note 5 : Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the contact plating may change color, however this does not represent a quality issue. Note 6 : The actuator design of the 60pos. type are shown in the figure. Unit : mm Part No. HRS No. No. of Pos. A B C D E FH52E-6S-0.5SH(##) CL0580-3365-0-## 6 7.3 2.5 3.57 5.55 8.1 FH52E-8S-0.5SH(##) CL0580-3349-0-## 8 8.3 3.5 4.57 6.55 9.1 FH52E-10S-0.5SH(##) CL0580-3346-0-## 10 9.3 4.5 5.57 7.55 10.1 FH52E-15S-0.5SH(##) CL0580-3337-0-## 15 11.8 7.0 8.07 10.05 12.6 FH52E-18S-0.5SH(##) CL0580-3331-3-## 18 13.3 8.5 9.57 11.55 14.1 FH52E-20S-0.5SH(##) CL0580-3357-0-## 20 14.3 9.5 10.57 12.55 15.1 FH52E-22S-0.5SH(##) CL0580-3343-2-## 22 15.3 10.5 11.57 13.55 16.1 FH52E-24S-0.5SH(##) CL0580-3340-4-## 24 16.3 11.5 12.57 14.55 17.1 FH52E-26S-0.5SH(00) (Note) CL0580-3366-0-00 26 17.3 12.5 13.57 15.55 18.1 FH52E-30S-0.5SH(##) CL0580-3347-3-## 30 19.3 14.5 15.57 17.55 20.1 FH52E-40S-0.5SH(##) CL0580-3334-1-## 40 24.3 19.5 20.57 22.55 25.1 FH52E-45S-0.5SH(##) CL0580-3368-0-## 45 26.8 22.0 23.07 25.05 27.6 FH52E-50S-0.5SH(##) CL0580-3335-4-## 50 29.3 24.5 25.57 27.55 30.1 FH52E-60S-0.5SH(##) CL0580-3339-5-## 60 34.3 29.5 30.57 32.55 35.1 FH52E-64S-0.5SH(##) CL0580-3333-9-## 64 36.3 31.5 32.57 34.55 37.1 FH52E-68S-0.5SH(##) CL0580-3332-6-## 68 38.3 33.5 34.57 36.55 39.1 Note : The (99) specification is available for all positions except 26pos. 10 Purchase Unit (##) : (00) Purchase Unit (##) : (99) 3,000pcs per reel 500pcs per reel FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52E (Long Solder Tabs Type) 1.0mm Pitch Product A±0.15 (Q) (R) B±0.08 (0.12) (5.0) 1.0±0.08 A ## Cav No. a No. of Pos. Indicator (C) b D±0.1 Detailed Drawing a (Note 6) c 10 (1 ) ° 1.75±0.2 2.0±0.2 E±0.2 (3.9) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. c 0 0 (1.3) 0.15 Max. (Note 1)(Note 2) (Note 1)(Note 2) 0.15 Max. 1.2±0.2 0.45±0.1 1.55±0.2 0.7±0.2 (4.3) 5.7±0.2 Note Note Note Note Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max. 2 : The contact lead position indicates the dimension from b, the bottom surface of the insulator body. 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details. 4 : Sink mark reliefs may be added due to improvements 5 : Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the contact plating may change color, however this does not represent a quality issue. Note 6 : The actuator design of the 30pos. type are shown in the figure. Part No. HRS No. Unit : mm No. of Pos. A B C D E Q R FH52E-8(4)SB-1SH(##) CL0580-3351-0-## 4 8.3 3.0 4.57 6.55 9.1 2.4 2.9 FH52E-20(10)SA-1SH(##) CL0580-3352-0-## 10 14.3 9.0 10.57 12.55 15.1 2.9 2.4 FH52E-20(10)SB-1SH(##) CL0580-3353-0-## 10 14.3 9.0 10.57 12.55 15.1 2.4 2.9 Purchase Purchase Unit Unit (##) : (00) (##) : (99) 3,000pcs per reel FH52E-50(25)SA-1SH(##) CL0580-3354-0-## 25 29.3 24.0 25.57 27.55 30.1 2.9 2.4 FH52E-50(25)SB-1SH(##) CL0580-3355-0-## 25 29.3 24.0 25.57 27.55 30.1 2.4 2.9 FH52E-60(30)SB-1SH(00) (Note) CL0580-3358-0-00 30 34.3 29.0 30.57 32.55 35.1 2.4 2.9 Note : The (99) specification is available for all positions except 30pos. 11 500pcs per reel FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 0.5mm Pitch Product A±0.15 B±0.08 (0.12) (5.0) 0.5±0.08 A ## a c (C) b D±0.1 Detailed Drawing a 2.0±0.2 E±0.2 (Note 6) c 10 (1 ) ° 1.75±0.2 No. of Pos. Indicator (3.9) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Cav No. 0 0 (1.3) 0.15 Max. (Note 1)(Note 2) (Note 1)(Note 2) 0.15 Max. 1.2±0.2 0.45±0.1 0.7±0.2 1.55±0.2 Note Note Note Note Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max. 2 : The contact terminal lead position indicates the dimension from b, the bottom surface of the insulator body. 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details. 4 : Sink mark reliefs may be added due to improvements 5 : Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the contact plating may change color, however this does not represent a quality issue. Note 6 : The actuator design of the 60pos. type are shown in the figure. 12 (4.3) 5.7±0.2 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Unit : mm HRS No. No. of Pos. A B C D E FH52K-6S-0.5SH(##) CL0580-4613-0-## 6 7.3 2.5 3.57 5.55 8.1 FH52K-8S-0.5SH(##) CL0580-4611-0-## 8 8.3 3.5 4.57 6.55 9.1 FH52K-10S-0.5SH(##) CL0580-4606-0-## 10 9.3 4.5 5.57 7.55 10.1 FH52K-12S-0.5SH(##) CL0580-4629-0-## 12 10.3 5.5 6.57 8.55 11.1 FH52K-15S-0.5SH(##) CL0580-4617-0-## 15 11.8 7.0 8.07 10.05 12.6 FH52K-18S-0.5SH(##) CL0580-4636-0-## 18 13.3 8.5 9.57 11.55 14.1 FH52K-20S-0.5SH(##) CL0580-4604-0-## 20 14.3 9.5 10.57 12.55 15.1 FH52K-22S-0.5SH(##) CL0580-4632-0-## 22 15.3 10.5 11.57 13.55 16.1 FH52K-24S-0.5SH(##) CL0580-4633-0-## 24 16.3 11.5 12.57 14.55 17.1 FH52K-25S-0.5SH(##) CL0580-4634-0-## 25 16.8 12.0 13.07 15.05 17.6 FH52K-26S-0.5SH(##) CL0580-4635-0-## 26 17.3 12.5 13.57 15.55 18.1 FH52K-30S-0.5SH(##) CL0580-4631-0-## 30 19.3 14.5 15.57 17.55 20.1 FH52K-32S-0.5SH(##) CL0580-4600-9-## 32 20.3 15.5 16.57 18.55 21.1 FH52K-34S-0.5SH(##) CL0580-4601-0-## 34 21.3 16.5 17.57 19.55 22.1 FH52K-40S-0.5SH(##) CL0580-4620-0-## 40 24.3 19.5 20.57 22.55 25.1 FH52K-45S-0.5SH(##) CL0580-4637-0-## 45 26.8 22.0 23.07 25.05 27.6 FH52K-50S-0.5SH(##) CL0580-4609-0-## 50 29.3 24.5 25.57 27.55 30.1 FH52K-60S-0.5SH(##) 60 34.3 29.5 30.57 32.55 35.1 FH52K-64S-0.5SH(##) Under Planning (Note 2) 64 36.3 31.5 32.57 34.55 37.1 FH52K-68S-0.5SH(##) CL0580-4614-0-## 68 38.3 33.5 34.57 36.55 39.1 FH52K-80S-0.5SH(05) (Note1) CL0580-4641-0-05 80 44.3 39.5 40.57 42.55 45.1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. Purchase Unit (##) : (00) Purchase Unit (##) : (99) 3,000pcs per reel 500pcs per reel - - Note 1 : The (05) specification is available for 80pos. only. The purchase unit is 2,000pcs per reel for specification (05) of FH52K-80S-0.5SH. Note 2 : Products without HRS No. are currently being planned for development. Please contact a Hirose representative regarding questions on pin count variation development. 13 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 1.0mm Pitch Product A±0.15 (Q) (R) B±0.08 1±0.08 Detailed Drawing A A ## (5.0) (0.12) a Cav No. No. of Pos. Indicator b Detailed Drawing a (C) ) 0° ( 1.75±0.2 11 2±0.2 D±0.1 E±0.2 (3.9) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. c 0 0 0.15 Max. (Note 1)(Note 2) (Note 1)(Note 2)0.15 Max. (1.3) 0.45±0.1 1.2±0.2 1.55±0.2 0.7±0.2 (4.3) 5.7±0.2 Note Note Note Note Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max. 2 : The contact lead position indicates the dimension from b, the bottom surface of the insulator body. 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details. 4 : Sink mark reliefs may be added due to improvements 5 : Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the contact plating may change color, however this does not represent a quality issue. Unit : mm Part No. FH52K-12(6)SA-1SH(##) HRS No. No. of Pos. A B C D E Q R CL0580-4638-0-## 6 10.3 5.0 6.57 8.55 11.1 2.9 2.4 Purchase Unit Purchase Unit (##) : (00) (##) : (99) 3,000pcs per reel FH52K-20(10)SB-1SH(##) CL0580-4630-0-## 10 14.3 14 9.0 10.57 12.55 15.1 2.4 2.9 500pcs per reel FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52T (Long Solder Tabs, 2-Point Contact Type) 0.5mm Pitch Product A±0.15 B±0.08 (2.35) (2.45) (0.08) (5.0) 0.5±0.08 A ## Cav No. a c (C) b D±0.1 Detailed Drawing a 10 (1 ) ° 1.75±0.2 2.0±0.2 E±0.2 (3.9) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. No. of Pos. Indicator 0 0 (1.2) 0.15 Max. (Note 1)(Note 2) (1.6) 0.45±0.1 (Note 1)(Note 2) 0.15 Max. 1.2±0.2 1.55±0.2 0.7±0.2 (4.2) 5.7±0.2 Note Note Note Note Note 1 : The coplanarity of the contact and solder tab lead is 0.1 Max. 2 : The contact lead position indicates the dimension from b, the bottom surface of the insulator body. 3 : Packaged in tape and reel only. Check the "Packaging Specification" for details. 4 : Sink mark reliefs may be added due to improvements 5 : Sight variations in color of the plastic compounds do not affect form, fit or function. After reflow, the contact plating may change color, however this does not represent a quality issue. Unit : mm Part No. HRS No. No. of Pos. A B C D E FH52T-10S-0.5SH(##) CL0580-4503-0-## 10 9.3 4.5 5.57 7.55 10.1 FH52T-24S-0.5SH(##) CL0580-4500-0-## 24 16.3 11.5 12.57 14.55 17.1 FH52T-32S-0.5SH(##) CL0580-4502-0-## 32 20.3 15.5 16.57 18.55 21.1 FH52T-50S-0.5SH(##) CL0580-4501-7-## 50 29.3 24.5 25.57 27.55 30.1 15 Purchase Unit (##) : (00) Purchase Unit (##) : (99) 3,000pcs per reel 500pcs per reel FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52 (Standard Type) 0.5mm Pitch Product ● Recommended PCB Mounting Pattern and Metal Mask Dimensions Connector image 0.3±0.03(Land pattern) 0.25±0.03(Metal mask) 2±0.05 0.5±0.05 E±0.05 0.8±0.03 The recommended PCB mounting pattern for the FH12 Series (horizontal mounting type) can be used as well. ● Recommended FPC/FFC Dimensions F±0.1 (Note) G±0.05 B±0.03 0.5±0.03 0.35±0.03 (FPC) 0.3±0.03 (FFC) 0.3±0.05 2-R0.2±0.1 (Note) 2-R0.2±0.1 (Note) (1.0 Min.) 1.35±0.1 (Note) 3.1±0.1 (Note) 2-R0.2±0.05 0.5±0.07 2-R0.2±0.1 (Note) 2-R0.2±0.05 (Note) Note : FPC/FFC without tabs can also be used. When using FPC/FFC without tabs the specified dimensions are not necessary. 16 4.5 Min. 0.5±0.07 3.5 Min. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 4.6±0.05 0.85±0.05 Recommended metal mask thickness : 0.12mm B±0.05 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Pos. B E F G FH52-6S-0.5SH(##) CL0580-3304-0-## 6 2.5 5.1 5.1 3.5 FH52-8S-0.5SH(##) CL0580-3305-3-## 8 3.5 6.1 6.1 4.5 FH52-10S-0.5SH(##) CL0580-3306-6-## 10 4.5 7.1 7.1 5.5 FH52-11S-0.5SH(##) CL0580-3320-7-## 11 5.0 7.6 7.6 6.0 FH52-12S-0.5SH(##) CL0580-3307-9-## 12 5.5 8.1 8.1 6.5 FH52-15S-0.5SH(##) CL0580-3302-5-## 15 7.0 9.6 9.6 8.0 FH52-18S-0.5SH(##) CL0580-3321-0-## 18 8.5 11.1 11.1 9.5 FH52-20S-0.5SH(##) CL0580-3309-4-## 20 9.5 12.1 12.1 10.5 FH52-22S-0.5SH(##) CL0580-3317-2-## 22 10.5 13.1 13.1 11.5 FH52-24S-0.5SH(##) CL0580-3318-5-## 24 11.5 14.1 14.1 12.5 FH52-25S-0.5SH(##) CL0580-3316-0-## 25 12.0 14.6 14.6 13.0 FH52-26S-0.5SH(##) CL0580-3319-8-## 26 12.5 15.1 15.1 13.5 FH52-28S-0.5SH(##) CL0580-3324-8-## 28 13.5 16.1 16.1 14.5 FH52-30S-0.5SH(##) CL0580-3310-3-## 30 14.5 17.1 17.1 15.5 FH52-32S-0.5SH(##) CL0580-3325-0-## 32 15.5 18.1 18.1 16.5 FH52-40S-0.5SH(##) CL0580-3300-0-## 40 19.5 22.1 22.1 20.5 FH52-42S-0.5SH(##) CL0580-3329-1-## 42 20.5 23.1 23.1 21.5 FH52-45S-0.5SH(##) CL0580-3311-6-## 45 22.0 24.6 24.6 23.0 FH52-50S-0.5SH(##) CL0580-3303-8-## 50 24.5 27.1 27.1 25.5 FH52-60S-0.5SH(##) CL0580-3301-2-## 60 29.5 32.1 32.1 30.5 17 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52 (Standard Type) 1.0mm Pitch Product ● Recommended PCB Mounting Pattern and Metal Mask Dimensions B±0.05 0.3±0.03 (Land pattern) 1.0±0.05 4.6±0.05 0.25±0.03 (Metal mask) 2.0±0.05 (Connector image) S±0.05 ● Recommended T±0.05 E±0.05 0.8±0.03 FPC/FFC Dimensions F±0.1 (Note) G±0.07 V±0.1 B±0.05 U±0.1 0.3±0.05 0.6±0.03 1.0±0.05 2-R0.2±0.05 2-R0.2±0.1 (Note) 1.35±0.1 (Note) 3.1±0.1(Note) (1.0 Min.) 4.5 Min. 2-R0.2±0.1 (Note) 3.5 Min. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.85±0.05 Recommended metal mask thickness : 0.12mm 2-R0.2±0.1 (Note) 2-R0.2±0.05 (Note) Note : FPC/FFC without tabs can also be used. When using FPC/FFC without tabs the specified dimensions are not necessary. Unit : mm Part No. HRS No. No. of Pos. B E F G S T U V FH52-10(4)SA-1SH(##) CL0580-3330-0-## 4 3.0 7.1 7.1 5.5 1.8 2.3 1.5 1.0 FH52-5S-1SH(00) CL0580-3336-7-00 5 4.0 7.6 7.6 6.0 1.8 1.8 1.0 1.0 FH52-12S-1SH(##) CL0580-3323-5-## 12 11.0 14.6 14.6 13.0 1.8 1.8 1.0 1.0 FH52-32(16)SB-1SH(00) CL0580-3338-2-00 16 15.0 18.1 18.1 16.5 1.3 1.8 1.0 0.5 FH52-60(30)SB-1SH(##) CL0580-3315-7-## 30 29.0 32.1 32.1 30.5 1.3 1.8 1.0 0.5 18 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52E (Long Solder Tabs Type) 0.5mm Pitch Product ● Recommended PCB Mounting Pattern and Metal Mask Dimensions (0.2) 0.3±0.03(Land pattern) 0.25±0.03(Metal mask) 0.5±0.05 (0.3) (0.3) 1.8±0.05 5.85±0.05 (0.2) Connector image B±0.05 F±0.05 FPC/FFC Dimensions G±0.1 (Note) H±0.05 2-R0.2±0.05 0.5±0.03 B±0.03 0.35±0.03 (FPC) 0.3±0.03 (FFC) 2-R0.2±0.1 (Note) 2-R0.2±0.1 (Note) 2-R0.2±0.1 (Note) 1.35±0.1 (Note) 3.1±0.1 (Note) 0.3±0.05 0.5±0.07 2-R0.2±0.05 (Note) Note : FPC/FFC without tabs can also be used. When using FPC/FFC without tabs the specified dimensions are not necessary. 19 (1.0 Min.) 0.5±0.07 4.5 Min. ● Recommended (0.225) (0.5) 2.0±0.03 3.5 Min. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.85±0.05 Recommended metal mask thickness : 0.12mm FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Pos. B F G H FH52E-6S-0.5SH(##) CL0580-3365-0-## 6 2.5 5.1 5.1 3.5 FH52E-8S-0.5SH(##) CL0580-3349-0-## 8 3.5 6.1 6.1 4.5 FH52E-10S-0.5SH(##) CL0580-3346-0-## 10 4.5 7.1 7.1 5.5 FH52E-15S-0.5SH(##) CL0580-3337-0-## 15 7.0 9.6 9.6 8.0 FH52E-18S-0.5SH(##) CL0580-3331-3-## 18 8.5 11.1 11.1 9.5 FH52E-20S-0.5SH(##) CL0580-3357-0-## 20 9.5 12.1 12.1 10.5 FH52E-22S-0.5SH(##) CL0580-3343-2-## 22 10.5 13.1 13.1 11.5 FH52E-24S-0.5SH(##) CL0580-3340-4-## 24 11.5 14.1 14.1 12.5 FH52E-26S-0.5SH(00) CL0580-3366-0-00 26 12.5 15.1 15.1 13.5 FH52E-30S-0.5SH(##) CL0580-3347-3-## 30 14.5 17.1 17.1 15.5 FH52E-40S-0.5SH(##) CL0580-3334-1-## 40 19.5 22.1 22.1 20.5 FH52E-45S-0.5SH(##) CL0580-3368-0-## 45 22.0 24.6 24.6 23.0 FH52E-50S-0.5SH(##) CL0580-3335-4-## 50 24.5 27.1 27.1 25.5 FH52E-60S-0.5SH(##) CL0580-3339-5-## 60 29.5 32.1 32.1 30.5 FH52E-64S-0.5SH(##) CL0580-3333-9-## 64 31.5 34.1 34.1 32.5 FH52E-68S-0.5SH(##) CL0580-3332-6-## 68 33.5 36.1 36.1 34.5 20 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52E (Long Solder Tabs Type) 1.0mm Pitch Product ● Recommended PCB Mounting Pattern and Metal Mask Dimensions B±0.05 1.0±0.05 0.3±0.03 (Land pattern) 5.85±0.05 0.25±0.03 (Metal mask) (Connector image) 1.8±0.05 S±0.05 T±0.05 F±0.05 ● Recommended 2.0±0.03 FPC/FFC Dimensions G±0.1 (Note) H±0.07 B±0.05 U±0.1 2-R0.2±0.05 V±0.1 0.6±0.03 1.0±0.05 0.3±0.05 4.5 Min. 2-R0.2±0.1 (Note) 1.35±0.1 (Note) 3.1±0.1(Note) (1.0 Min.) 2-R0.2±0.1 (Note) 2-R0.2±0.1 (Note) 3.5 Min. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.85±0.05 Recommended metal mask thickness : 0.12mm 2-R0.2±0.05 (Note) Note : FPC/FFC without tabs can also be used. When using FPC/FFC without tabs the specified dimensions are not necessary. Unit : mm Part No. HRS No. No. of Pos. B F G H S T U V FH52E-8(4)SB-1SH(##) CL0580-3351-0-## 4 3.0 6.1 6.1 4.5 1.3 1.8 1.0 0.5 FH52E-20(10)SA-1SH(##) CL0580-3352-0-## 10 9.0 12.1 12.1 10.5 1.8 1.3 0.5 1.0 FH52E-20(10)SB-1SH(##) CL0580-3353-0-## 10 9.0 12.1 12.1 10.5 1.3 1.8 1.0 0.5 FH52E-50(25)SA-1SH(##) CL0580-3354-0-## 25 24.0 27.1 27.1 25.5 1.8 1.3 0.5 1.0 FH52E-50(25)SB-1SH(##) CL0580-3355-0-## 25 24.0 27.1 27.1 25.5 1.3 1.8 1.0 0.5 FH52E-60(30)SB-1SH(00) CL0580-3358-0-00 30 34.3 32.1 32.1 30.5 1.3 1.8 1.0 0.5 21 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 0.5mm Pitch Product ● Recommended PCB Mounting Pattern and Metal Mask Dimensions (0.2) 0.3±0.03(Land pattern) 0.25±0.03(Metal mask) F±0.05 (0.225) (0.5) 2.0±0.03 FPC/FFC Dimensions G±0.1 (Note) H±0.05 2-R0.2±0.05 0.5±0.03 B±0.03 0.35±0.03 (FPC) 0.3±0.03 (FFC) 2-R0.2±0.1 (Note) 2-R0.2±0.1 (Note) 2-R0.2±0.1 (Note) 1.35±0.1(Note) 3.1±0.1 (Note) 0.3±0.05 0.5±0.07 2-R0.2±0.05 (Note) Note : FPC/FFC without tabs can also be used. When using FPC/FFC without tabs the specified dimensions are not necessary. 22 (1.0 Min.) 0.5±0.07 4.5 Min. ● Recommended (0.3) (0.3) 1.8±0.05 5.85±0.05 0.5±0.05 3.5 Min. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (0.2) 0.85±0.05 Recommended metal mask thickness : 0.12mm Connector image B±0.05 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Pos. B F G H FH52K-6S-0.5SH(##) CL0580-4613-0-## 6 2.5 5.1 5.1 3.5 FH52K-8S-0.5SH(##) CL0580-4611-0-## 8 3.5 6.1 6.1 4.5 FH52K-10S-0.5SH(##) CL0580-4606-0-## 10 4.5 7.1 7.1 5.5 FH52K-12S-0.5SH(##) CL0580-4629-0-## 12 5.5 8.1 8.1 6.5 FH52K-15S-0.5SH(##) CL0580-4617-0-## 15 7.0 9.6 9.6 8.0 FH52K-18S-0.5SH(##) CL0580-4636-0-## 18 8.5 11.1 11.1 9.5 FH52K-20S-0.5SH(##) CL0580-4604-0-## 20 9.5 12.1 12.1 10.5 FH52K-22S-0.5SH(##) CL0580-4632-0-## 22 10.5 13.1 13.1 11.5 FH52K-24S-0.5SH(##) CL0580-4633-0-## 24 11.5 14.1 14.1 12.5 FH52K-25S-0.5SH(##) CL0580-4634-0-## 25 12.0 14.6 14.6 13.0 FH52K-26S-0.5SH(##) CL0580-4635-0-## 26 12.5 15.1 15.1 13.5 FH52K-30S-0.5SH(##) CL0580-4631-0-## 30 14.5 17.1 17.1 15.5 FH52K-32S-0.5SH(##) CL0580-4600-9-## 32 15.5 18.1 18.1 16.5 FH52K-34S-0.5SH(##) CL0580-4601-0-## 34 16.5 19.1 19.1 17.5 FH52K-40S-0.5SH(##) CL0580-4620-0-## 40 19.5 22.1 22.1 20.5 FH52K-45S-0.5SH(##) CL0580-4637-0-## 45 22.0 24.6 24.6 23.0 FH52K-50S-0.5SH(##) CL0580-4609-0-## 50 24.5 27.1 27.1 25.5 60 29.5 32.1 32.1 30.5 64 31.5 34.1 34.1 32.5 FH52K-60S-0.5SH(##) FH52K-64S-0.5SH(##) Under planning (Note) FH52K-68S-0.5SH(##) CL0580-4614-0-## 68 33.5 36.1 36.1 34.5 FH52K-80S-0.5SH(05) CL0580-4641-0-05 80 39.5 42.1 42.1 40.5 Note : Products without HRS No. are currently being planned for development. Please contact a Hirose representative regarding questions on pin count variation development. 23 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 1.0mm Pitch Product ● Recommended PCB Mounting Pattern and Metal Mask Dimensions B±0.05 1.0±0.05 0.3±0.03 (Land pattern) 5.85±0.05 0.25±0.03 (Metal mask) (Connector image) 1.8±0.05 S±0.05 T±0.05 F±0.05 ● Recommended 2.0±0.03 FPC/FFC Dimensions G±0.1 (Note) H±0.07 B±0.05 U±0.1 2-R0.2±0.05 V±0.1 0.6±0.03 1.0±0.05 0.3±0.05 2-R0.2±0.1 (Note) 4.5 Min. 2-R0.2±0.1 (Note) 1.35±0.1 (Note) 3.1±0.1(Note) (1.0 Min.) 2-R0.2±0.1 (Note) 3.5 Min. Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.85±0.05 Recommended metal mask thickness : 0.12mm 2-R0.2±0.05 (Note) Note : FPC/FFC without tabs can also be used. When using FPC/FFC without tabs the specified dimensions are not necessary. Unit : mm HRS No. No. of Pos. B F G H S T U V FH52K-12(6)SA-1SH(##) CL0580-4638-0-## 6 5.0 8.1 8.1 6.5 1.8 1.3 0.5 1.0 FH52K-20(10)SB-1SH(##) CL0580-4630-0-## 10 9.0 12.1 12.1 10.5 1.3 1.8 1.0 0.5 Part No. 24 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ■FH52T (Long Solder Tabs, 2-Point Contact Type) 0.5mm Pitch Product ● Recommended Recommended metal mask thickness : 0.12mm 0.85±0.05 B±0.05 0.3±0.03 (Land pattern) 0.5±0.05 5.85±0.05 0.25±0.03 (Metal mask) 1.8±0.05 (Connector image) ● Recommended F±0.05 2.0±0.03 FPC/FFC Dimensions G±0.1 (Note) H±0.05 2-R0.2±0.05 0.5±0.03 B±0.03 0.35±0.03 (FPC) 0.3±0.03 (FFC) 0.3±0.05 0.5±0.07 2-R0.2±0.1 (Note) 3.5 Min. (1.0 Min.) 2-R0.2±0.1 (Note) 4.5 Min. 0.5±0.07 2-R0.2±0.1 (Note) 1.35±0.1 (Note) 3.1±0.1 (Note) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCB Mounting Pattern and Metal Mask Dimensions 2-R0.2±0.05 (Note) Note : FPC/FFC without tabs can also be used. When using FPC/FFC without tabs the specified dimensions are not necessary. Unit : mm Part No. HRS No. No. of Pos. B F G H FH52T-10S-0.5SH(##) CL0580-4503-0-## 10 4.5 7.1 7.1 5.5 FH52T-24S-0.5SH(##) CL0580-4500-0-## 24 11.5 14.1 14.1 12.5 FH52T-32S-0.5SH(##) CL0580-4502-0-## 32 15.5 18.1 18.1 16.5 FH52T-50S-0.5SH(##) CL0580-4501-7-## 50 24.5 27.1 27.1 25.5 25 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector FPC/FFC Construction (Recommended Specifications) 1. Single-Sided FPC (FPC : Flexible Printed Circuit) Material Name Covering Film Layer Material Polyimide 1mil Copper Foil Base Adhesive Base Film Reinforcement Material Adhesive Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Stiffener (25) (25) Cover Adhesive Surface Treatment Thickness ( µm) 0.2 μm Thick Gold Plated over 1 to 5 μm Thick Nickel Underplating Cu 1oz Thermosetting Adhesive Polyimide 1mil thick Thermosetting Adhesive Polyimide 7mil thick Total 3 35 25 25 30 175 293 2. Double-Sided FPC (FPC : Flexible Printed Circuit) Material Name Covering Film Layer Cover Adhesive Surface Treatment Material Polyimide 1mil 0.2 μm Thick Gold Plated over 1 to 5 μm Thick Nickel Underplating Thickness ( µm) (25) (25) 3 Through-hole Copper Cu Copper Foil Cu Base Adhesive Thermosetting Adhesive 18 Base Film Polyimide 1mil thick 25 Base Adhesive Thermosetting Adhesive 18 Copper Foil Cu Cover Adhesive Thermosetting Adhesive 25 Covering Layer Film Polyimide 1mil thick 25 Reinforcement Material Adhesive Thermosetting Adhesive 50 Stiffener 1/2oz 1/2oz Polyimide 4mil thick Total 15 18 (18) 100 297 Note : Use of double-sided FPC with copper foil is not recommended in order to prevent release of the FPC due to bending. 3. FFC (FFC : Flexible Flat Cable) Material Name Material Polyester Film Adhesive Gold Plated Annealed Copper Foil with Nickel Underplating Adhesive Thermoplastic Polyester Thickness ( µm) (12) (30) 35 Polyester Polyester 30 12 Adhesive Polyester 30 Stiffener Polyester 188 Total 295 Note : Typical thickness tolerance is about ± 20μ m 4. Precautions 1. This is a reference FPC/ FFC construction. Make the thickness of the FPC/ FFC mated portion 0. 30 ± 0. 05mm in reference to the FPC/ FFC construction. 2. Contact an FPC/ FFC maker for details on component construction. 26 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Packaging Specification Carrier Tape Dimensions (Tape Width 24mm Max.) 0 .1 5 +0 (2.4) (0.3) (J) φ 1. 2.0±0.1 12.0±0.1 4.0±0.1 K±0.1 1.75±0.1 L±0.3 ● Embossed 5 +0 (2.4) (0.3) 1.7 +0.15 0 (J) K±0.1 M±0.1 L±0.3 2.0±0.1 4.0±0.1 12.0±0.1 1.75±0.1 Carrier Tape Dimensions (Tape Width 32mm Min.) 0 .1 ● Embossed φ 1. Unreeling Direction ● Reel 1.5+0.1 0 (4.65) (6.4) Dimensions 2±0.5 φ80±1 N±1: Reel Outside Width 0.2 φ13± P±1: Reel Inside Width R1 a End Section Mounting Section Blank Section (15 Pockets Min.) φ 21 ± 0. 8 Detailed Drawing a φ380±2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unreeling Direction (4.65) (6.4) Embossed Carrier Tape Lead Section (400mm Min.) Blank Section (10 Pockets Min.) 27 Top Cover Tape FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector FH52 (Standard Type) 0.5mm Pitch Product Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. Unit : mm No. of Pos. J FH52-6S-0.5SH(##) CL0580-3304-0-## 6 7.6 FH52-8S-0.5SH(##) CL0580-3305-3-## 8 8.6 FH52-10S-0.5SH(##) CL0580-3306-6-## 10 9.6 FH52-11S-0.5SH(##) CL0580-3320-7-## 11 10.1 FH52-12S-0.5SH(##) CL0580-3307-9-## 12 10.6 FH52-15S-0.5SH(##) CL0580-3302-5-## 15 12.1 FH52-18S-0.5SH(##) CL0580-3321-0-## 18 13.6 FH52-20S-0.5SH(##) CL0580-3309-4-## 20 14.6 FH52-22S-0.5SH(##) CL0580-3317-2-## 22 15.6 FH52-24S-0.5SH(##) CL0580-3318-5-## 24 16.6 FH52-25S-0.5SH(##) CL0580-3316-0-## 25 17.1 FH52-26S-0.5SH(##) CL0580-3319-8-## 26 17.6 FH52-28S-0.5SH(##) CL0580-3324-8-## 28 18.6 FH52-30S-0.5SH(##) CL0580-3310-3-## 30 19.6 FH52-32S-0.5SH(##) CL0580-3325-0-## 32 20.6 FH52-40S-0.5SH(##) CL0580-3300-0-## 40 24.6 FH52-42S-0.5SH(##) CL0580-3329-1-## 42 25.6 FH52-45S-0.5SH(##) CL0580-3311-6-## 45 27.1 FH52-50S-0.5SH(##) CL0580-3303-8-## 50 29.6 FH52-60S-0.5SH(##) CL0580-3301-2-## 60 34.6 K L M N P 11.5 24.0 - 29.4 25.4 14.2 32.0 28.4 37.4 33.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 FH52 (Standard Type) 1.0mm Pitch Product Part No. HRS No. Unit : mm No. of Pos. J K L M N P 29.4 25.4 29.4 25.4 FH52-10(4)SA-1SH(##) CL0580-3330-0-## 4 9.6 11.5 24.0 FH52-5S-1SH(00) CL0580-3336-7-00 5 10.1 11.5 24.0 FH52-12S-1SH(##) CL0580-3323-5-## 12 17.1 14.2 32.0 28.4 37.4 33.4 FH52-32(16)SB-1SH(00) CL0580-3338-2-00 16 20.6 20.2 44.0 40.4 49.4 45.4 FH52-60(30)SB-1SH(##) CL0580-3315-7-## 30 34.6 26.2 56.0 52.4 61.4 57.4 28 - FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector FH52E (Long Solder Tabs Type) 0.5mm Pitch Product Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Pos. J FH52E-6S-0.5SH(##) CL0580-3365-0-## 6 7.6 FH52E-8S-0.5SH(##) CL0580-3349-0-## 8 8.6 FH52E-10S-0.5SH(##) CL0580-3346-0-## 10 9.6 FH52E-15S-0.5SH(##) CL0580-3337-0-## 15 12.1 FH52E-18S-0.5SH(##) CL0580-3331-3-## 18 13.6 FH52E-20S-0.5SH(##) CL0580-3357-0-## 20 14.6 FH52E-22S-0.5SH(##) CL0580-3343-2-## 22 15.6 FH52E-24S-0.5SH(##) CL0580-3340-4-## 24 16.6 FH52E-26S-0.5SH(00) CL0580-3366-0-00 26 17.6 FH52E-30S-0.5SH(##) CL0580-3347-3-## 30 19.6 FH52E-40S-0.5SH(##) CL0580-3334-1-## 40 24.6 FH52E-45S-0.5SH(##) CL0580-3368-0-## 45 27.1 FH52E-50S-0.5SH(##) CL0580-3335-4-## 50 29.6 FH52E-60S-0.5SH(##) CL0580-3339-5-## 60 34.6 FH52E-64S-0.5SH(##) CL0580-3333-9-## 64 36.6 FH52E-68S-0.5SH(##) CL0580-3332-6-## 68 38.6 Unit : mm K L M N P 11.5 24.0 - 29.4 25.4 14.2 32.0 28.4 37.4 33.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 FH52E (Long Solder Tabs Type) 1.0mm Pitch Product Part No. HRS No. No. of Pos. J FH52E-8(4)SB-1SH(##) CL0580-3351-0-## 4 8.6 FH52E-20(10)SA-1SH(##) CL0580-3352-0-## 10 14.6 FH52E-20(10)SB-1SH(##) CL0580-3353-0-## 10 14.6 FH52E-50(25)SA-1SH(##) CL0580-3354-0-## 25 29.6 FH52E-50(25)SB-1SH(##) CL0580-3355-0-## 25 29.6 FH52E-60(30)SB-1SH(00) CL0580-3358-0-00 30 34.6 29 Unit : mm K L M N P 11.5 24.0 - 29.4 25.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 0.5mm Pitch Product Unit : mm Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Part No. HRS No. No. of Pos. J FH52K-6S-0.5SH(##) CL0580-4613-0-## 6 7.6 FH52K-8S-0.5SH(##) CL0580-4611-0-## 8 8.6 FH52K-10S-0.5SH(##) CL0580-4606-0-## 10 9.6 FH52K-12S-0.5SH(##) CL0580-4629-0-## 12 10.6 FH52K-15S-0.5SH(##) CL0580-4617-0-## 15 12.1 FH52K-18S-0.5SH(##) CL0580-4636-0-## 18 13.6 FH52K-20S-0.5SH(##) CL0580-4604-0-## 20 14.6 FH52K-22S-0.5SH(##) CL0580-4632-0-## 22 15.6 FH52K-24S-0.5SH(##) CL0580-4633-0-## 24 16.6 FH52K-25S-0.5SH(##) CL0580-4634-0-## 25 17.1 FH52K-26S-0.5SH(##) CL0580-4635-0-## 26 17.6 FH52K-30S-0.5SH(##) CL0580-4631-0-## 30 19.6 FH52K-32S-0.5SH(##) CL0580-4600-9-## 32 20.6 FH52K-34S-0.5SH(##) CL0580-4601-0-## 34 21.6 FH52K-40S-0.5SH(##) CL0580-4620-0-## 40 24.6 FH52K-45S-0.5SH(##) CL0580-4637-0-## 45 27.1 FH52K-50S-0.5SH(##) CL0580-4609-0-## 50 29.6 60 34.6 64 36.6 FH52K-60S-0.5SH(##) FH52K-64S-0.5SH(##) Under planning(Note) FH52K-68S-0.5SH(##) CL0580-4614-0-## 68 38.6 FH52K-80S-0.5SH(05) CL0580-4641-0-05 80 44.6 K L M N P 11.5 24.0 - 29.4 25.4 14.2 32.0 28.4 37.4 33.4 20.2 44.0 40.4 49.4 45.4 26.2 56.0 52.4 61.4 57.4 34.2 ± 0.3 72.0+0.4/-0.3 68.4 77.4 73.4 Note : Products without HRS No. are currently being planned for development. Please contact a Hirose representative regarding questions on pin count variation development. FH52K (Long Solder Tabs, 125℃ Heat Resistant Type) 1.0mm Pitch Product Unit : mm Part No. HRS No. No. of Pos. J FH52K-12(6)SA-1SH(##) CL0580-4638-0-## 6 10.6 FH52K-20(10)SB-1SH(##) CL0580-4630-0-## 10 14.6 K L 11.5 24.0 M - N P 29.4 25.4 FH52T (Long Solder Tabs, 2-Point Contact Type) 0.5mm Pitch Product Part No. HRS No. Unit : mm No. of Pos. J K L M N P FH52T-10S-0.5SH(##) CL0580-4503-0-## 10 9.6 11.5 24.0 - 29.4 25.4 FH52T-24S-0.5SH(##) CL0580-4500-0-## 24 16.6 14.2 32.0 28.4 37.4 33.4 FH52T-32S-0.5SH(##) CL0580-4502-0-## 32 20.6 20.2 44.0 40.4 49.4 45.4 FH52T-50S-0.5SH(##) CL0580-4501-7-## 50 29.6 26.2 56.0 52.4 61.4 57.4 30 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Recommended Temperature Profile Applicable Conditions 250℃ Max. Temperature 250 230℃ 200 200℃ 150 Solder Method : Reflow, IR Environment : Room air Solder Composition : Paste, 96.5%Sn/3.0%Ag/0.5%Cu (Senju Metal Industry's Part Number : M705221CM5-32-10.5) Test Board : Material and Size 150℃ (℃) 100 Glass epoxy 80mm × 100mm × 1.6mm thick 50 0 25℃(60sec.) 90sec. to 120sec. Preheating Time (60sec.) Soldering Time Start 180 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Time (Seconds) Land Dimensions 0.3 × 0.85mm Metal Mask Dimensions : 0.12mm thick Opening dimensions 0.25 × 0.85mm This temperature profile is for the above applicable conditions. The temperature profile may vary depending on the type of cream solder, the manufacturer, the board size, and other conditions such as mounting materials. Please check the mounting status before use. 31 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Operation and Precautions [ Operation] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 1. FPC/ FFC Insertion ① Lift the actuator upward. ( Lock release)   You can easily pop it up with the thumbnail or index- finger nail. ② Insert the FPC or FFC with the exposed conductive traces facing down.   When connecting a tabbed FPC/ FFC, ensure that the FPC/ FFC is inserted at an angle of approximately 10°with respect to the board surface and perpendicular to the connector. FPC/FFC Positioning Guide ③ Rotate down the actuator until firmly closed. 2. FPC/ FFC removal ① Lift the actuator upward. After the lock has been released slightly lift up the FPC/ FFC and pull it out. FPC/FFC Positioning Guide 32 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector [ Precautions] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ① The FH52 Series actuator does not rotate open beyond 110°. Do not apply a force to open it beyond   this point. The actuator may come off or be permanently damaged. ② Insert the FPC or FFC properly to the opening of the connector. Improper insertion may lead to a break or poor continuity of the FPC or FFC. ③ The connector does not have a strong upward tensile strength due to its design. Secure the FPC or FFC when it is subjected to a tensile force. ④ When inserting an FPC or FFC, do not rub it vigorously against the bottom side of the connector opening. Excessive contact between the contacts and the FPC or FFC may result in the deformation of contacts, peeling of conductive traces, or other faults. 33 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector Precautions when Mating/Unmating FPC/FFC with Tabs for Positioning Guidance [ How to insert] Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Insert the cable so that the tabs align in the interspace ( ) between the mold walls on both ends of the cable ) on the insides of both sides of the connector. insertion port and the guide walls ( [ Precautions when mating/ un- mating] ① Avoid insertion in diagonal direction. Do not insert the cable in diagonal direction. The corner of the cable may touch the contact, resulting in contact deformation. Be sure to insert the FPC or FFC straight into the connector opening. Perpendicular to the Connector 34 FH52 Series/0.5mm/1.0mm Pitch, 2.0mm Height, Bottom Contact, Front Flip FPC/FFC Connector ② Avoid Overlap Avoid inserting the cables in way that it overlaps the guides on either side. Do not close the actuator with the cables overlapped on the guides as it may result in conduction failure. Overlap on Both Guides Overlap on Right Guide Correct Insertion Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. FPC/FFC Positioning Tab FPC/FFC Positioning Guide While Taking into Consideration Specifications mentioned in this catalog are reference values. When considering to order or use this product, please confirm the Drawing and Product Specifications sheets. Use an appropriate cable when using the connector in combination with cables. If considering usage of a non- specified cable, please contact your sales representative. If assembly process is done by jigs & tools which are not identified by Hirose, assurance will not be given. If considering usage for below mentioned applications, please contact your sales representative. In cases where the application will demand a high level of reliability, such as automotive, medical instruments, public infrastructure, aerospace/ defense etc. Hirose must review before assurance of reliability can be given. 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN        https://www.hirose.com ※ The contents of this catalog are current as of date of 6/ 2021. Contents are subject to change without notice for the purpose of improvements. 35
FH52E-20(10)SB-1SH(99) 价格&库存
很抱歉,暂时无法提供与“FH52E-20(10)SB-1SH(99)”相匹配的价格&库存,您可以联系我们找货
  • 1+23.024961+2.77648
  • 10+20.0370210+2.41618
  • 25+19.1810325+2.31296
  • 50+18.7564750+2.26176
  • 100+17.90370100+2.15893
  • 250+16.19848250+1.95331
库存:2985
