0.5mm Pitch, 2.5mm Height, shielded FFC Connectors for High Speed Transmissions
FH41 Series
Supports the next generation chip
V-by-One® HS* by THine
Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
=^\]heZZYhZg^Va^ciZg[VXZ
iZX]cdad\n[dge^XijgZigVchb^hh^dc
■Features
1. Accepts impedance matched shielded FFC
The FH41 Series is equipped with a ground terminal and
can be used with impedance matched shielded FFC.
Dimensions: 68 positions
2.5mm
2. Impedance matched terminal design
38mm
The signal terminal is designed for impedance control
and is capable of handling high speed transmissions.
3. Highly reliable and secure structure
The design of the FH41 series follows in the footsteps
of another popular Hirose connector, the FH28 series.
The FFC positioning mechanism and rugged structure
combine to prevent accidental unlocking and produce
a secure connection.
6.2mm
(Mounting area)
Fig.1
4. Simplified operations with a flip lock system
The flip lock design allows a smoother simpler FFC
operation. It requires less force to rotate the actuator
and delivers a tactile click to reinforce that the lock has
secured the connection.
Sig
0.5 nal co
mm nta
pitc cts
h
5. Suitable for automatic pick-n-place mounting
Offered in tape and reel packaging that is compatible
with automatic machine mounting. (2,500 pcs/reel)
6. Halogen free
All materials and substances used to produce this
product comply with Halogen-free standards.
*Standards by IEC 61249-2-21. Br : 900 ppm or lower,
Cl : 900 ppm or lower, Br+Cl : 1,500 ppm or lower
Gr
2.5 ound
mm co
pitc ntac
h ts
Fig.2
●Uses the same FFC that the FH48 Series (vertical
connection) uses.
●Shielded FFC
Signal connection area
FH41 and FH48 use
the same FFC layout.
FFC
Ground contact connection area
Fig.3
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
2019.4④
1
FH41 Series●0.5mm Pitch, 2.5mm Height, shielded FFC Connectors for High Speed Transmissions
■Product Specifications
Operating temperature range:
−40 to +105ç (Note 2)
Operating humidity range:
Relative humidity of 90% or lower
(no dew condensation)
Rated current 0.5A (Note 1)
Rated voltage AC 50Vrms
Rating
Storage temperature range:
−10 to +50ç (Note 3)
Storage humidity range:
Applicable FPC and FFC
t= 0.3 ±0.05, gold plating (GND plate: t= 0.5 ±0.05, tin plating)
terminal specifications
Items
Specifications
Conditions
1. Insulation resistance Minimum of 500Mø
Measured at DC 100V.
2. Withstanding voltage No flashover or insulation damage
AC 150Vrms for 1 minute
3. Contact
resistance
Measured at 1mA.
Maximum of 100mø
*Incl. FFC conductor resistance
4. Repeated motions Contact resistance : Maximum of 100mø
Durability
No damaged, cracked or loose parts.
20 mating cycles
5. Vibration
resistance
No electrical discontinuity for more than 1µs
Frequency 10 to 55Hz with half amplitude 0.75mm in 3
Contactresistance : Maximum of 100mø
directions, 10 cycles each.
6. Impact
resistance
Acceleration : 981m/s2, duration time : 6ms, with half sine
waves in 3 directions, three times each.
7. Humidity resistance
Insulation resistance : Minimum of 50Mø
in ordinary conditions
Left for 96 hours at temperature 40ç, humidity 90 to 95%
8. Temperature
cycle
Temperature : −40ç → +15ç to +35ç → +105ç → +15ç to +35ç
Time : 30 → 2 to 3 → 30 → 2 to 3 min.
5 cycles in the above conditions
9. Solder heat
resistance
No deformation of components or no
significant looseness of contacts, etc.
Reflow : Recommended temperature profile
Manual soldering : 350 ±5ç for 5 sec.
Note 1 : When energizing rated current to all contacts, use 70% of rated current.
Note 2 : Includes temperature rise caused by current flow.
Note 3 : The term "storage" here refers to products stored for a long period prior to board mounting and use. The operating
temperature and humidity range covers the non-energized condition of connectors after board mounting and the
temporary storage.
■Materials / Finish
Parts
Materials
Insulating parts
Color/Finish
Gray
LCP
Terminal
Black
Phosphor bronze (plating material)
Pure tin reflow plating
■Product number structure
Refer to the chart below when determining the product specifications from the product number.
Please select from the product numbers listed in this catalog when placing orders.
FH 41 − 50S − 0.5 SH (05)
q
w
e
qSeries name : FH
wSeries number : 41
eNumber of contacts : 15 to 68
rContact pitch : 0.5mm
2
r
t
UL94V-0
Gold plating
Phosphor bronze
Metal parts
Remarks
y
tTerminal shape
SH…SMT horizontal implementation type
yPlating specifications :
(05)…Gold plating (Except 50, 68 contacts)
(28)…Gold plating (50, 68 contacts)
■Connector dimension drawing
C
D
(5.05)
(5.45)
(0.12)
0.5
No. of contacts
(0.12)
2.5
Cavity No.
(4.7)
(G-1)×2.5 (=E)
(0.15)
2
2.5
1
0.8
0.25
(F: FFC insert opening dimension)
H
6.2
Note 1 : The coplanarity of the metal fittings and the contacts are a maximum of 0.1mm.
Note 2 : Packaged on tape and reel only. Check packaging specification.
Note 3 : Recesses may be added to the part structure to improve the molding characteristics. Black marks
may appear in the mold resin, but they will not negatively affect the performance of these connectors.
Note 4 : The color of the plating may change after the reflow process, but it will not negatively affect the
■Connector dimension table
Part No.
FH41-15S-0.5SH(05)
FH41-20S-0.5SH(05)
FH41-28S-0.5SH(05)
FH41-30S-0.5SH(05)
FH41-31S-0.5SH(05)
FH41-40S-0.5SH(05)
FH41-50S-0.5SH(28)
FH41-60S-0.5SH(05)
FH41-68S-0.5SH(28)
HRS No.
580-2222-2 05
580-2221-0 05
580-2208-1 05
580-2218-5 05
580-2216-0 05
580-2205-3 05
580-2204-0 28
580-2223-0 05
580-2202-5 28
No. of contacts Number of ground contacts : G
15
3
28
5
30
6
31
6
40
8
50
10
60
12
68
13
Unit : mm
C
11.5
14
18
19
19.5
24
29
34
38
D
7
9.5
13.5
14.5
15
19.5
24.5
29.5
33.5
E
5
7.5
10
12.5
12.5
17.5
22.5
27.5
30
F
8.07
10.57
14.57
15.57
16.07
20.57
25.57
30.57
34.57
H
9.45
11.95
15.95
16.95
17.45
21.95
26.95
31.95
35.95
Note 1 : This embossed packaged product is sold by full reel quantities of 2,500 pcs/reel. Please place orders in full reel quantities.
3
BRecommended PCB layout and metal mask dimension diagram
1.2±0.05(Land pattern)
1±0.05(Metal mask)
1.55±0.05
0.3±0.03(Land pattern)
0.25±0.03(Metal mask)
0.5±0.05
1±0.05
6.35±0.05
0.65±0.05
6.6±0.1
D±0.05
0.2±0.03(Metal mask)
2.5±0.05
0.4±0.03
(G-1)×2.5 (=E)±0.05
J±0.05
Recommended metal mask thickness : t= 0.1
BRecommended FFC dimension drawing
0.5 ±0.1
0.3 ±0.03
5.5 MIN
0.1
0.5 ±0.05(Ground plate thickness)
0.3 ±0.05(End conductor thickness)
0.1 MIN
17.7 MAX
5.5 MIN
2.6 ±0.5
2.1 ±0.5
0.5 ±0.05
1.9 ±0.1
2.6 ±0.1
3.8 ±0.1
0.5 ±0.1
R0
.2
2±0
R0
.1
.2
2-
K ±0.1
L ±0.07
D ±0.05
Ground plate
X
.2 MA
Shielded area
2-R 0
2-R
0. 2
MA
X
1
Note : 1
Please overlap shield plate on ground plate
BRecommended land, metal mask and FFC dimension table
Part No.
FH41-15S-0.5SH(05)
FH41-20S-0.5SH(05)
FH41-28S-0.5SH(05)
FH41-30S-0.5SH(05)
FH41-31S-0.5SH(05)
FH41-40S-0.5SH(05)
FH41-50S-0.5SH(28)
FH41-60S-0.5SH(05)
FH41-68S-0.5SH(28)
4
HRS No.
580-2222-2 05
580-2221-0 05
580-2208-1 05
580-2218-5 05
580-2216-0 05
580-2205-3 05
580-2204-0 28
580-2223-0 05
580-2202-5 28
No. of contacts
15
30
31
40
50
60
68
3
4
5
6
6
8
10
12
13
J
9.5
12
16
17
17.5
22
27
32
36
K
9.2
11.7
15.7
16.7
17.2
21.7
26.7
31.7
35.7
Unit : mm
L
8
10.5
14.5
15.5
16
20.5
25.5
30.5
34.5
BPackaging Specifications
●Embossed carrier tape dimension
CL
P±0.1
M±0.3
0 .1
1.75±0.1
Q±0.1
Ø1
.5 +0
1.75±0.1
(R)
(S)
(T)
(1.64 : Vacuum pick up surface for automatic mounting)
(5.75)
Unreeling direction
(7.35)
CL
Unreeling direction
●Reel dimensions
(Ø80)
(Ø380)
(U : Outer width)
(V : Inner width)
3)
(Ø1
4±0.1 2±0.1 12±0.1
(5.75)
(7.35)
(2.9)
(0.3)
M±0.3
Q±0.1
2±0.1 12±0.1
Ø1
.5 +0
4±0.1
(R)
(S)
(T)
(2.9)
(0.3)
(Tape width: Minimum of 32mm)
0 .1
(Tape width: Maximum of 24mm)
Terminal section
Loaded product section
Empty pockets
(At least 14 empty pockets)
Leader section (Minimum of 400 mm)
Empty pockets Cover tape
(Minimum of 10 empty pockets)
Embossed carrier tape containing product
BPackaging Specification Dimensions
Part No.
FH41-15S-0.5SH(05)
FH41-20S-0.5SH(05)
FH41-28S-0.5SH(05)
FH41-30S-0.5SH(05)
FH41-31S-0.5SH(05)
FH41-40S-0.5SH(05)
FH41-50S-0.5SH(28)
FH41-60S-0.5SH(05)
FH41-68S-0.5SH(28)
HRS No.
580-2222-2 05
580-2221-0 05
580-2208-1 05
580-2218-5 05
580-2216-0 05
580-2205-3 05
580-2204-0 28
580-2223-0 05
580-2202-5 28
15
3
28
5
30
6
31
6
40
8
50
10
60
12
68
13
Unit : mm
M
24
P
Q
11.5
32
28.4
14.2
44
40.4
20.2
56
52.4
26.2
R
11.8
14.3
18.3
19.3
19.8
24.3
29.3
34.3
38.3
S
10.5
13.5
17
18
18.5
23
28
33
37
T
9.2
12.2
15.7
16.7
17.2
21.7
26.7
31.7
35.7
U
V
29.4
25.4
37.4
33.4
49.4
45.4
61.4
57.4
5
BFH41 Series FFC materials configuration
(recommended specifications)
BViZg^VacVbZ
BViZg^Vah
IdiVaI]^X`cZhhVi IdiVaI]^X`cZhhVi
chjaVi^dcAVnZg
EdanZhiZgIneZ
6Y]Zh^kZ
EdanZhiZgIneZ
Hi^[[ZcZg
EdanZhiZgIneZ
IdiVa
8dciVXijhl^i]^cfj^g^Zhdc]dlidX]Vc\Zi]ZheZX^[^XVi^dchVcYi]^X`cZhhXdc[^\jgVi^dch#
BRecommended Soldering Profile
B6M'*%
IZbeZgVijgZ
Hd[i8deeZg;d^aC^X`ZaJcYZg
EaVi^c\
很抱歉,暂时无法提供与“FH41-15S-0.5SH(99)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 500+19.29939500+2.32723
- 1000+16.461251000+1.98499
- 1500+15.893621500+1.91655
- 2500+15.326002500+1.84810
- 5000+14.758365000+1.77965
