APPLICABLE STANDARD
OPERATING
TEMPERATURE RANGE
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
In case of consideration for using Automotive equipment / device which demand high reliability, kindly contact our sales window correspondents.
RATING
-55 C
50 V
VOLTAGE
85 C
TO
AC / DC
-10 C TO 50 C (PACKED CONDITION)
RELATIVE HUMIDITY 90 % MAX (NOT DEWED)
t=0.3±0.05mm, GOLD PLATING.(4~30 POS.)
APPLICABLE CABLE
0.5 A
CURRENT
STORAGE
TEMPERATURE RANGE
OPERATING OR STORAGE
HUMIDITY RANGE
t=0.3±0.03mm, GOLD PLATING.(OVER 31 POS.)
SPECIFICATIONS
ITEM
TEST METHOD
REQUIREMENTS
QT
AT
ACCORDING TO DRAWING.
NO FLASHOVER OR BREAKDOWN.
500 M MIN.
50 m MAX.
① NO ELECTRICAL DISCONTINUITY OF
1 s.
② CONTACT RESISTANCE: 50 m MAX.
③ NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
① CONTACT RESISTANCE: 50 m MAX.
② NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
DIRECTION OF INSERTION :
0.3N×n MIN.(4~30 POS.)
0.2N×n MIN.(OVER 31 POS.)
(note 1)
CORROSION SALT MIST EXPOSED AT 35±2 ℃ , 5 % SALT WATER
SPRAY FOR 96 h.
RAPID CHANGE OF
TEMPERATURE
① CONTACT RESISTANCE: 100 m MAX.
OF PARTS.
③ NO EVIDENCE OF CORROSION WHICH
AFFECTS TO OPERATION OF
CONNECTOR.
TEMPERATURE-55→+15TO+35→+85→+15TO+35C ① CONTACT RESISTANCE: 50 m MAX.
TIME
30→ 2 TO 3 → 30→ 2 TO 3
② INSULATION RESISTANCE: 50 M MIN.
min
UNDER
5 CYCLES.
OF PARTS.
EXPOSED AT
40±2 C,
RELATIVE HUMIDITY
90 TO 95 %,
96 h.
EXPOSED AT
-10
TO
+65 C,
RELATIVE HUMIDITY 90 TO 96 %,
② INSULATION RESISTANCE: 1 M MIN.
10 CYCLES,TOTAL
240 h.
(AT HIGH HUMIDITY)
③ INSULATION RESISTANCE: 50 M MIN.
(AT DRY)
④ NO DAMAGE, CRACK AND LOOSENESS
OF PARTS.
CONSTRUCTION
GENERAL EXAMINATION VISUALLY AND BY MEASURING INSTRUMENT.
MARKING
CONFIRMED VISUALLY.
ELECTRICAL CHARACTERISTICS
VOLTAGE PROOF
150 V AC FOR 1 min.
INSULATION
100 V DC.
RESISTANCE
CONTACT RESISTANCE AC 20 mV MAX ( 1 KHz ) ,
1 mA .
INCLUDING FPC,FFC BULK RESISTANCE
(L=8mm)
MECHANICAL CHARACTERISTICS
VIBRATION
FREQUENCY 10 TO 55 Hz, HALF AMPLITUDE
2
0.75 mm, - m/s
FOR
10 CYCLES IN
3 AXIAL DIRECTIONS.
2
981 m/s , DURATION OF PULSE 6 ms
AT 3 TIMES IN 3 BOTH AXIAL DIRECTIONS.
SHOCK
MECHANICAL
OPERATION
20 TIMES INSERTIONS AND EXTRACTIONS.
FPC RETENTION FORCE
MEASURED BY APPLICABLE FPC.
(THICKNESS OF FPC SHALL BE t=0.30mm
AT INITIAL CONDITION.)
ENVIRONMENTAL CHARACTERISTICS
DAMP HEAT
(STEADY STATE)
DAMP HEAT,CYCLIC
COUNT
DESCRIPTION OF REVISIONS
DESIGNED
CHECKED
DATE
REMARK
Unless otherwise specified, refer to IEC 60512.
Note
QT:Qualification Test
FORM HD0011-2-1
NF.MIYAZAKI
16.08.31
CHECKED
YH.MICHIDA
16.08.31
DESIGNED
KN.KOBAYASHI
16.08.31
DRAWN
RK.OGASAWARA
16.08.31
APPROVED
AT:Assurance Test X:Applicable Test
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO.
ELC-156169-99-00
FH33-**S-0.5SH(99)
CL580
SPECIFICATIONS
ITEM
DRY HEAT
EXPOSED AT
TEST METHOD
85±2 C,
96 h.
COLD
EXPOSED AT
-55±3C,
96 h.
SULPHUR DIOXIDE
EXPOSED AT 40±2 C , RELATIVE HUMIDITY
[JIS C 60068-2-42] 80±5%
25±5 ppm FOR
96 h.
HYDROGEN SULPHIDE EXPOSED AT 40±2 C , RELATIVE HUMIDITY 80
[JIS C 60068-2-43] ±5% ,
10 TO 15 ppm FOR 96 h.
SOLDERABILITY
SOLDERED AT SOLDER TEMPERATURE,
235 ±5C FOR IMMERSION DURATION,
2±0.5 sec.
RESISTANCE TO
1) REFLOW SOLDERING :
SOLDERING HEAT
PEAK TMP. 250 C MAX .
REFLOW TMP. OVER 230 C WITHIN 60 sec.
2) SOLDERING IRONS :
TMP. 350 ± 10 C
FOR 5±1 sec .
REQUIREMENTS
QT
OF PARTS.
① CONTACT RESISTANCE: 100 m MAX. ×
OF PARTS.
③ NO EVIDENCE OF CORROSION WHICH ×
CONNECTOR.
AT
A NEW UNIFORM COATING OF SOLDER
SHALL COVER A MINIMUM OF 95 % OF
THE SURFACE BEING IMMERSED.
NO DEFORMATION OF CASE OF
EXCESSIVE LOOSENESS OF THE
TERMINALS.
(note1)
THIS PRODUCT HAS FLIP-LOCK CONSTRUCTION. FASTEN FPC ON PCB OR SOMETHING FIXED IF
FORCE IN VERTICAL DIRECTION SHALL BE PREDICTED.
Note
FORM HD0011-2-2
DRAWING NO.
SPECIFICATION SHEET
PART NO.
CODE NO
ELC-156169-99-00
FH33-**S-0.5SH(99)
CL580
很抱歉,暂时无法提供与“FH33-45S-0.5SH(99)”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+29.077791+3.50637
- 10+26.3870610+3.18190
- 25+24.9944425+3.01397
- 50+24.4128950+2.94385
- 100+23.24988100+2.80361
- 250+20.34361250+2.45315
- 国内价格 香港价格
- 500+14.38732500+1.73491
