DESCRIPTION: POWER / SIGNAL - VERTICAL BOARD - MALE
SPECIFICATIONS:
ELECTRICAL:
INSULATION RESISTANCE:
DIELECTRIC WITHSTANDING VOLTAGE:
WORKING VOLTAGE:
OPERATING TEMPERATURE:
POWER CONTACT RESISTANCE:
SIGNAL CONTACT RESISTANCE:
POWER PINS:
SIGNAL PINS:
2.088 [53.05]
±0.010 [±0.25]
1.852 [47.05]
±0.010 [±0.25]
Ø 0.120 [Ø 3.05]
2-PLACES
1.533 [38.95]
±0.010 [±0.25]
1 2 3
4 5
11 12 13 14 15
0.112 [2.84]
A1
6 7
8 9 10
250V
-55°C TO +125°C
1.0 mΩ MAX.
10 mΩ MAX.
40 AMPS
5 AMPS
MECHANICAL:
CONTACT INSERTION FORCE:
CONTACT SEPARATION FORCE:
4.5 Kg MAX.
0.3 Kg MIN.
MATERIALS:
CONTACTS:
INSULATOR:
COPPER ALLOY, GOLD FLASH
PBT UL94V-0 RATED
SEAL:
SHELL:
HARDWARE:
F08 FLEXIBLE ADHESIVE
NICKEL PLATED STEEL
NICKEL PLATED BRASS
230°C PROCESS TEMP.
16 17 18 19 20
10°
5 GΩ MIN.
1000 VAC FOR 1 MIN
0.327 [8.30]
681S21W1103LYYY
0.492 [12.50]
0 = 40 AMP
2
3
4
5
0.240 [6.10]
0.031 [0.80]
±0.008 [±0.20]
0.433 [11.00]
1 = GOLD FLASH
MEETS IP67 STANDARDS
SEE SHEET 2
FOR DETAILS
RoHS COMPLIANT
N
C
THESE DRAWINGS AND SPECIFICATIONS ARE
THE PROPERTY OF NorComp AND SHALL NOT
BE REPRODUCED, COPIED OR USED AS THE
BASIS FOR THE MANUFACTURE OR SALE OF
APPARATUS WITHOUT WRITTEN PERMISSION.
= NO HARDWARE
= 0.098" CN PCB SIDE
= 0.236" CN PCB SIDE
= 0.236" CN MATING SIDE
= 0.237" BOARDLOCK PCB SIDE
= 0.224" BOARDLOCK PCB SIDE
(SEE PAGE 2 FOR SEALING DETAILS)
UNITS = INCHES [MM]
DRAWN:
M. SIGMON
DATE:
06/11/2013
DO NOT SCALE FROM DRAWING
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
1
4
681S21W1103LYYY
2
DESCRIPTION: 681 SERIES CONTACTS
NOTE:
SIGNAL AND POWER CONTACTS
COME PRE-LOADED INTO INSULATORS
Ø 0.026
[0.65]
0.112
[2.84]
A
0.22 ± .012
[5.60 ± 0.30]
SIGNAL CONTACTS
A
0.209 ± 0.012
[5.30 ± 0.30]
FRONT SEAL APPLIED OVER INSULATOR
AND BETWEEN FRONT & REAR SHELLS
0.031 ± 0.012
[0.80 ± 0.30]
DETAIL A-A
Ø 0.148
[3.75]
0.059 ± 0.012
[1.50 ± 0.30]
SHOWN FOR REFERENCE ONLY
POWER CONTACTS
RoHS COMPLIANT
N
C
UNITS = INCHES [MM]
DRAWN:
M. SIGMON
DATE:
06/11/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
2
4
681S21W1103LYYY
2
DESCRIPTION: PCB LAYOUT
1.852
0.654
Ø 0.130
2-PLACES
0.654
0.545
0.545
0.436
0.436
0.327
0.327
0.218
0.218
Ø 0.165
1-PLACE
0.112
0.164
0.164
0.273
0.273
0.382
0.382
0.491
0.491
0.600
0.600
Ø 0.043
20-PLACES
RECOMMENDED PCB LAYOUT
RoHS COMPLIANT
N
C
UNITS = INCHES
DRAWN:
M. SIGMON
DATE:
06/11/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
3
4
681S21W1103LYYY
2
DESCRIPTION: CLINCH NUT HARDWARE
TOLERANCE:
ALL CLINCH-NUTS ARE 4-40 INTERNAL THREADS
0 ..... NO HARDWARE
2 ..... 0.236" PCB SIDE
4 ..... 0.237" PCB SIDE
1 ..... 0.098" PCB SIDE
3 ..... 0.236" MATING SIDE
5 ..... 0.224" PCB SIDE
RoHS COMPLIANT
N
C
ALL DIMENSIONS ARE ±0.010
UNITS = INCHES [MM]
DRAWN:
M. SIGMON
DATE:
06/11/2013
NorComp
SCALE:
SHEET
NTS
DWG NO.
REV
OF
4
4
681S21W1103LYYY
2
很抱歉,暂时无法提供与“681S21W1103L001”相匹配的价格&库存,您可以联系我们找货
