Additional Resources:
Product Page
3D Model
PCB Footprint
date
10/27/2022
page 1 of 3
MODEL: PJ-202B | DESCRIPTION: DC POWER JACK
FEATURES
• 2.5 mm center pin
• 2.5 A rating
• right-angle orientation
• through hole
• kinked pins
RoHS
SPECIFICATIONS
parameter
conditions/description
min
rated input voltage
typ
rated input current
contact resistance
between terminal and mating plug
between terminal in a closed circuit
insulation resistance
at 500 Vdc
voltage withstand
at 50/60Hz for 1 minute
1
0.3
-25
life
A
50
30
mΩ
mΩ
500
Vac
3
kg
500
g
85
5,000
flammability rating
UL94V-0
RoHS
yes
Note:
2.5
MΩ
any direction for 10 seconds
operating temperature
units
Vdc
100
insertion/withdrawal force
terminal strength
max
24
°C
cycles
1. When measured at a current of less than 100 mA/1 kHz
SOLDERABILITY
parameter
min
typ
max
units
wave soldering
dipped in solder pot for 5 ±0.5 seconds
255
260
265
°C
cuidevices.com
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: PJ-202B | DESCRIPTION: DC POWER JACK
date 10/27/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
tolerance:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
MATERIAL
PLATING
center pin
copper
nickel
terminal 1
brass
tin
terminal 2
copper alloy
tin
terminal 3
brass
tin
plastic
PBT
14.4 0.57
9.0 0.35
3.50 0.14
11.0 0.43
6.50 0.26
2.50 0.10
6.50 0.26
1.5 0.06
3.5 0.14
2
3.00 0.12
4.7 0.19
3
3.0 0.12
1
2.5 0.10
(2 PLCS)
3.0 0.12
10.7 0.42
10.7 0.42
3.0 0.12
3.0 0.12
4.7 0.19
3
1
2
1.00X3.50
PCB LAYOUT
TOP VIEW
1.00X3.00
(2 PLCS)
1
3
2
SCHEMATIC
MATING PLUG
Jack Insertion Depth: 9.0 mm
Note:
1. All specifications measured at 10~35°C, humidity at 45~85%, under standard atmospheric pressure, unless otherwise noted.
cuidevices.com
Model
PJ-202B
Center Pin
Ø2.5 mm
Product Page
3D Model
PCB Footprint
date 10/27/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
11/17/2005
1.01
applied new spec template
10/25/2013
1.02
increased voltage rating
04/21/2016
logo, datasheet style update
10/27/2022
1.03
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-202B”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+5.92920
- 10+5.79960
- 30+5.71320
