电子发烧友
开通电子发烧友VIP会员 尊享10大特权
海量资料免费下载
精品直播免费看
优质内容免费畅学
课程9折专享价
430101-01-0
    CURTISINDUSTRIES
    1 电路 阻隔块 连接器, 螺钉
430101-01-0 数据手册
Series 43000 .4375" (11.11mm) Center-to-Center Spacing Single Row Features: ‡ Cost-competitiYe line of .4375" (11.11mm) centerline terminal blocks provides design engineers with multitude of selection choices: base mount and feed thru styles with P.C. pin, turret, quick connect, wire wrap and right angle. Available in up to 28 positions. ‡ 5ated up to 30A, 009 ‡ Accepts very broad wire range from 22A:* to 12 A:*. Variety to top terminations including 6-32 and 8-32 screws, quick connects, wire clamps, Mumpers, and covers. ‡ 8nique Curtis contact design helps eliminate fracturing of solder Moint due to pin twist. ‡ Plated brass inserts are standard on all Series 43000 terminal blocks. Standoffs molded into the blocks inhibit the trapping of solder flux – makes it easier to clean boards. ‡ All terminal blocks for electronic use are made from highly durable, self-extinguishing polypropylene material rated 94 V-0 by Underwriters Laboratories, Inc. ‡ Custom built terminal blocks for special applications are available. Contact any authorized Curtis distributor or representative, or call the factory direct. Recognized under the Components Program of Underwriters Laboratories, Inc. Standard 1059, Guide No. XCFR2, File No. E62557. Guide No. 22.2 No. 158, Report No. LR39186-1. Series 43000 Variations BARRIER STYLE 0 – Flush Mount 3 – Quick Connect .110” 2 – Turret Type Solder Terminal 1 – Printed Circuit Pin .23 (5,84) .75 Typ. .15 (3,81) .75 Typ. 4 – Quick Connect .187” .44 (11,18) .06 x .031 (1,57 x 0,78) PC Terminal 5 – Quick Connect .250” .100 x .031 (2,54 x 0,78) PC Terminal .110 x .031 (2,79 x 0,78) QC Terminal 6 – Wire Wrap Pin 7 – Right Angle Printed Circuit Pin .38 (9,65) .46 (11,68) .187 x .031 (4,75 x 0,78) QC Terminal 1 – Printed Circuit Pin .55 (13,97) .21 (5,34) 20 .062 x .031 (1,57 x 0.78) PC Terminal www.curtisind.com .250 x .031 (6,35 x 0.78) QC Terminal .34 (8,64) .72 (18,29) .062 x .031 (1,57 x 0,78) Wire Wrap Terminal 2 – Turret Type Solder Terminal .85 (21,59) .51 (12,95) 3 – Quick Connect .110” .65 (16,51) .100 x .031 (2,54 x 0.78) T Turret Terminal .062 x .031 Right Angle .062 .09 Terminal (1,57)(2,28) .31 .110 x .031 (7,87) (2,79 x 0.78) Quick Connect Curtis Industries A Division of Powers Holdings, Inc. 6 – Wire Wrap Pin (extended pc pin) .75 (19,05) .41 (10,41) .062 x .031 (1,57 x 0.78) Wire Wrap Terminal 6SHci¿cDtionssuEMHcttocKDnJH. Dimensions are shown for reference purposes only. SSeFi¿Fations: Series 43000 With Mounting Ends Center-to-Center Spacing: .4375" (11.11mm) Wire Range: No. 22AWG to 12AWG No. of Terminals: 1 thru 26 (28 without mounting holes) Voltage Rating: 600V Tightening Torque: 9 in. lb. Current Rating: 20 amps UL (30 Amps with 10AWG & Lugs) Housing: Material Polypropylene Continuous Use Temp. (UL Index) 105°C (221°F) Flammability Rating 94V-0 Water Absorption (24 hrs. % wt. gain) .03% Breakdown Voltage: Terminal - Terminal 3000V Terminal - Ground 3000V Terminals: Brass - Tin Plated Dimensions Number of Terminals A ± .031 Overall Dimensions (O.D.) Inches Metric (mm) B ± .031 Mounting Dimensions (M.D.) Inches Metric (mm) C ± .031 Less Mounting Positions Inches Metric (mm) 1.375 34.93 .875 22.23 .500 12.70 2 1.813 46.05 1.313 33.35 .938 23.83 3 2.250 57.15 1.750 44.45 1.375 34.93 4 2.688 68.28 2.188 55.58 1.813 46.05 5 3.125 79.38 2.625 66.68 2.250 57.15 6 3.563 90.50 3.063 77.80 2.688 68.28 7 4.000 101.60 3.500 88.90 3.125 79.38 8 4.438 3.938 100.03 3.563 90.50 112.73 4.875 123.83 4.375 111.13 4.000 101.60 5.313 134.95 4.813 122.25 4.438 112.73 11 5.750 146.05 5.250 133.35 4.875 123.83 12 6.188 157.18 5.688 144.48 5.313 134.95 13 6.625 168.28 6.125 155.58 5.750 146.05 14 7.063 179.40 6.563 166.70 6.188 157.18 “B” Mounting Dimension 15 7.500 190.50 7.000 177.80 6.625 168.28 “C” Less Mounting Ends 16 7.938 201.63 7.438 188.93 7.063 179.40 17 8.375 212.73 7.875 200.03 7.500 190.50 18 8.813 223.85 8.313 211.15 7.938 201.63 19 9.250 235.00 8.750 222.25 8.375 212.73 20 9.688 246.08 9.188 233.38 8.813 223.85 21 10.125 257.18 9.625 244.48 9.250 234.95 22 10.563 268.30 10.063 255.60 9.688 246.08 “A” Overall Dimension .438 (11,12) .190 (4,82) Dia. Mounting Holes (2) .75 (19,05) 6-32 x 5/16 Lg. Sems Wire Clamp 6-32 x 5/16 Lg. Co Bh Hd Mach. Screw .388 (9,85) .75 (19,05) .52 (13,20) .036 (0,91) .48 (12,19) 23 11.000 279.4 10.500 266.70 10.125 257.18 24 11.438 290.53 10.938 277.83 10.563 268.30 25 11.875 301.63 11.375 288.93 11.000 279.40 26 12.313 312.75 11.813 300.05 11.438 290.53 27 11.875 301.63 28 12.313 312.75 BARRIER STYLE 9 Single Row 1 10 Series 43000 Surface Mount With Mounting Ends .438 (11,12) Without Mounting Ends Dimensions shown are ± 0.030" 43000 Feed-Thru Series .388 (9,85) .75 (19,05) .48 (12,19) .45 (11,43) .34 (8,63) .250 (6,35) Dia. Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 21 Series 43000 How to Order 43 X X X X XX X BARRIER STYLE Single Row MOLDING DESIGN ] 0 = Surface Mount w/ Mounting Ends 1 = Surface Mount w/o Mounting Ends 2 = Insulated Feed Thru w/ Mounting Ends 3 = Insulated Feed Thru w/o Mounting Ends [ SPECIALS OR OPTIONAL DESIGNS 0 = None A-= = Custom Con¿guration [ NUMBER OF POSITIONS Available 1 thru 26 W/Mounting End 1 thru 28 w/o Mounting Ends INSERT OR BOTTOM TERMINATION DESIGN ] 0 = Surface Mount, No Bottom Termination 1 = Printed Circuit Pin 2 = Turret Type Solder Terminal 3 = Quick Connect .110" 4 = Quick Connect .187" 5 = Quick Connect .250" 6 = Extended Printed Circuit Pin or Wire Wrap 7 = Right Angle Printed Circuit Pin [ HARDWARE OR TOP TERMINATION DESIGN 0 = Standard Zinc Plated Steel Screw, Combo Head 1 = Wire Clamp Screw 2 = Nickel Plated Brass Screw 3 = Stainless Steel Screw 5 = Without Screws 6 = Quick Connects, Screw Type* 8 = Captivated Screw Note: Option 4 & 5 Only Available on Surface Mount Style Molding INSERT/SCREW DIMENSION ] 0 = 6-32 Insert and Screw 1 = 8-32 Insert and Screw, available on PC Pin, Turret Type Solder Pins, Wire Wrap and Right Angle Versions only *See accessories Series 43000 Accessories TERMINAL BLOCK JUMPERS WIRE CLAMP 4300 – Wire clamp captivated to No. 6-32 or 8-32 screw eliminates need for lugs. Accepts up to No. 12AWG wire. May be ordered factory installed or loose. 4300 – Plated brass “Rooster comb” design Type 267A42 permits connections of two to 18 poles. To order, specify; Part No. 267A42-_ _ . MARKING STRIPS 4300 – Pre-punched black ¿ber . . . mounts under block. May be imprinted to customer speci¿cations. To order, specify: Part No. 267A19-1 thru 26 (with mounting hole); Part No. 267A218-1 thru 28 (less mounting hole). COVERS 43000 – Rigid .030” thick self-extinguishing vinyl. Black matte-¿nished on both sides. May double as marking strip when imprinted with white ink. Complete with spring clips for attaching to mounting positions. Part No. 0196_ _ 000, 1 thru 26 poles. Example: 019605000 would be a 5 pole cover .605 to .645 (15,36) to (16,38) TINNERMAN NUT 4300 – for special mounting of terminal blocks less mounting position. Part No. TN-375. 22 www.curtisind.com .448 (11,37) .428 (10,85) Curtis Industries A Division of Powers Holdings, Inc. Part No. TN-375 For Long Feed Through .065 (1,65) .035 (0,88) Speci¿cations subMect to change. Dimensions are shown for reference purposes only. QUICK-CONNECT TERMINALS QUICK-CONNECT TERMINALS 43000 – Available with .250" x .032" quick-connect tabs of tin-plated brass, held in place by terminal screws. Six styles . . . one to six terminations per pole. Factory-assembled or supplied bulk. 1.50 (38,1) .070 (1,78) Dia. Holes (2) .125 (3,175) .186 (4,72) .035 (,889) .250 .750 (19,05) .175 (6,35) (4,45) .201 (5,11) Dia. Hole .350 (8,89) Part No. TB21 TB21 .500 (12,70) .480 (12,19) Single Row 90° 90° TB22 TB25 1.25 (31,75) .839 (21,31) 45° 45° BARRIER STYLE TB26 TB23 .986 (25,04) .231 (5,87) TB24 PC BOARD DRILLING DIMENSIONS .437 Typ. 2-11 Terminals Ø.079 (No. 47 Drill) 12 T Terminals and Over Ø.093 (No. 42 Drill) Dimensions are in inches and millimeters unless otherwise speci¿ed. Values in parentheses are metric equivalents. RECOMMENDED PANEL CUTOUT DIMENSIONS Mounting Holes .437 (11,11) Feed-Thru – Panel Hole Dia. = .281 (7,13) Curtis Industries A Division of Powers Holdings, Inc. 1-800-657-0853 23
430101-01-0 价格&库存
很抱歉,暂时无法提供与“430101-01-0”相匹配的价格&库存,您可以联系我们找货
