Fuseblocks, Holders and Terminal Blocks
CE logo denotes compliance with European
Union Low Voltage Directive (50-1000Vac,
75-1500Vdc). Refer to Data Sheet: 8002 or
contact Bussmann Application Engineering
at 636-527-1270 for more information.
Ratings: 90A, 600V; UL/CSA
Center Spacing: .635∑ (16.13)
Number of Poles: 3
Circuits per Foot: 18
Circuit Jumper: JN1, 2 circuits
Wire Size: AWG #2-18 CU
Screw Size: ⁄Ω¢-28
Mounting Options: 35mm DIN rail,
C-rail, Base Mount. (Dove tail option is
available for mounting side-by-side.
Order part no. NDN111A-WH.)
NDN111-__ __(color)
Rail Mount Terminal Blocks
NDN1-WH
Ratings: 90A, 600V
Number of Poles: 1
Screw Size: ⁄Ω¢-28
C-rail (Dove-tail option is available for
mounting side-by-side. Order part no.
NDN1A-WH.)
Marking Tape: MT12-⁄Ω™
Torque Rating: 32 in/lb max.
NDN1Colors: WH -White
NDNAS
NRA37-1/2
72” long
Stand-Off Channel
for C-rail
SOA72
Bussmann®
See series
specifications
specifications
MARKING JUMPERS
TAPE
See series
NDN111
NDN111A
Colors:
Colors:
YE - Yellow
YE - Yellow
WH - White
WH- White
NFTA
C-rail
Low profile
No flange
Aluminum
37⁄Ω™∑ length
For complete specification data, call Bussmann Information Fax ~ 636.527.1450
C-rail
Aluminum
NFTA36
36” long
NFTA72
72” long
Series NDN Terminal Block Accessories
NDNA
35mm DIN rail
35mm DIN rail
Aluminum
End Stop
NDNA 100 1 meter
NDNA 200 2 meters
90
很抱歉,暂时无法提供与“NDN111-BL”相匹配的价格&库存,您可以联系我们找货
