TM21R-5B-3232D
TM21R-5B-3232D
    HRS(广濑)
    CONNMODJACK8P8CR/ASHLD
TM21R-5B-3232D 数据手册
Modular Jack Connectors for High Speed LAN Transmission TM21R Series Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Built-in Light Indicators LED Light Indicator Light Pipe ■Features Housing 1. Supports High Speed LAN Transmission Complies with TIA/EIA-568-B data wiring requirements, guaranteeing Cat.5e transmission for the single port configuration and Cat.5 transmission performance for the multi-port configuration. As such, these products fully support Gigabit Ethernet (1000BASE-T) and Fast Ethernet (100BASE-TX) high speed LAN transmission. Light Indicator Area Space saving Light Indicator 2. Built-in Light Indicators There is no need to design a separate space for the light indicators as they are built-in the connector, enabling space-saving. (Fig.1) Compared with LED type indicators, they do not emit any electrical noise. (Fig.2) One additional TM21 multi-port jack can be mounted in the space previously occupied by LEDs. 3. EMI protection Fig.1 Metal shield covers the outer surfaces of the connectors assuring complete protection against electromagnetic interference. 4. FCC Standards Meets requirements of FCC Title 47, Part 68, Subpart F. 5. THR (Through-Hole Mounting) Type THR (Through-Hole Mounting) compatible type is available. ■Applications LAN Equipment, Office Equipment and Measuring Devices. Built-in LED Type (Easily affected by noise.) Built-in Light Pipe Type (Not affected by noise.) Fig.2 2021.9③ 1 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission ■Product Specifications Rated Current 1A Operating Temperature : -55 to +85ç (Note) Rated Voltage 125V AC Storage Temperature Range : -25 to +60ç Ratings Item Specification Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 01.Insulation Resistance Conditions 100V DC 100MΩ min 02.Withstanding Voltage No flashover or insulation breakdown (Between Adjacent Contacts) 500V AC for 1min. 03.Withstanding Voltage No flashover or insulation breakdown (Between Contact and Shield) 1500V AC for 1min. 04.Contact Resistance 230mΩ max. 100mA DC 05.Vibration No electrical discontinuity of 5μs or more Contact resistance : 250mΩ max. Frequency : 10 to 55 Hz, single amplitude of 0.75mm, 2 hours / 3 axis 06.Shock No electrical discontinuity of 5μs or more Contact resistance : 250mΩ max. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 07.Mating Durability Contact resistance : 250mΩ max. 200 cycles 08.Temperature Cycle Contact resistance : 250mΩ max. Insulation resistance : 100MΩ min. (Temperature : -55ç/+5ç to +35ç/+85ç/+5ç to +35ç Duration : 30 / 5 / 30 / 5 (Minutes) 5 cycles 09.Humidity Contact resistance : 250mΩ max. Insulation resistance : 1MΩ min. (High humidity) Insulation resistance : 10MΩ min. (Dry state) 500 hours at temperature of 40ç and humidity of 90% to 95% 10.Salt Spray Contact resistance : 250mΩ max. Exposed to density 5% salt water for 48 hours Note : Includes temperature rise caused by current flow. ■Materials / Finish Part Material Finish Remarks Insulator Synthetic Resin Color : Black UL94V-0 Contact Copper Alloy Contact Area : Gold Plating 1.27μ Termination Area : Gold Plating ------- Color : Clear ------- Tin Plating ------- Polycarbonate Copper Alloy Light Pipe Shield ■Product Number Structure Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Jacks q Series Name w Connector Type e Jack Type Number r Jack Performance Level Code t Jack Mating Port Size TM21 R - 5 A - 32 32 D - LP (50) 1 2 3 4 5 6 7 8 9 y Number of Contacts u Number of Rows i Option o RoHS Compliant 2 TM21 R : Jack 5 : Right Angle PCB Through-Hole Type A : Cat.5 (Single row, multi-port) B : Cat.5 (Double row, multi port) C : Supports Cat.5e (Single port) 8 : 8 contacts 32 : 8 contacts /4 ports 48 : 8 contact/6 ports 8 : 8 contacts 32 : 8 contacts inserted in 4 ports=32 contacts 48 : 8 contacts inserted in 6 ports=48 contacts Blank : Single row D : Double row LP : With light pipe inserted Blank : Without light pipe DIR : THR (Through-Hole Mounting) (50) TM21R Series●Modular Jack Connectors for High Speed LAN Transmission ■Modular Jack Connectors Supporting Cat.5e ●Single Port With Built-in Light Pipe 21 16 0.25 0.45 1.7 13.4 13.75 (2.8) 0.8 3.6 3 Contact No.1 0.8 (5.5) Contact No.8 0.35 1 11.43 3.05 15.75 6.35 13.05 10.25 0.8 2.54 0.8 (5.5) (5.5) Part No. HRS No. RoHS Contact No.7 TM21R-5C-88-LP(50) 222-2892-0 50 YES Contact No.8 TM21R-5C 1 PC Contact No.1 Contact No.2 11.9 21 ●Single Port Without Light Pipe 16 0.25 0.45 1.7 13.4 (2.8) 0.8 13.75 3.6 3 Contact No.1 0.8 (5.5) Contact No.8 3.05 15.75 0.8 0.35 1 11.43 6.35 2.54 13.05 10.25 0.8 (5.5) (5.5) 24 Part No. HRS No. RoHS TM21R-5C-88(50) 222-2893-2 50 YES Contact No.7 TM21R-5C 1 PC Contact No.8 Contact No.1 Contact No.2 11.9 Contact No.1 13.75 21 5.5 0.8 16 Contact No.8 13.4 ●Single Port (Through-Hole Mounting Type) 3.6 0.8 0.8 5.5 15.75 Contact No.7 Contact No.8 Part No. HRS No. RoHS TM21R-5C-88-DIR 222-2091-0 00 YES 0.8 2.8 0.25 0.45 5.5 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 24 1 7.2 9.4 0.35 2.54 Contact No.1 Contact No.2 3 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission BRecommended PCB Mounting Patterns ●With Built-in Light Pipe 11.9 8.89 2 1 3MIN 3 4 6.75 5 6 3MIN 2.54 6.35 3MIN 6.75 PCB Edge Connector Front Edge 11.43MIN No Conductive Traces 7 1 No Ground Traces 2 11.43 PCB Edge Connector Front Edge 11.43MIN 15.75 No Conductive Traces *Recommendations for PCB Design 1 1 Note that the contact arrangement for contact No.1 and No.2 and No.7 and No.8 are switched. 2 Areas indicated should be free of conductive traces. 3 Area indicated should be free of ground traces. 4 Recommended board thickness: 1.6mm. 5 The LED for the jack connector with built-in light pipe is mounted on the PCB. Please use an LED within the specified dimensions. For LED specifications, contact the LED manufacturer. 6 Mount so that the center of the light emitting part of the LED is at the center of the dimensions indicated in the diagram. 7 Please check the latest dimension of LED pad with the corresponding LED manufacturer before designing. Contact Arrangement Other Series TM21R Series 7 5 3 1 8 5 3 2 8 6 4 2 5 7 6 4 1 Applicable LEDs LED Light Emitting Center 2.7MAX BRecommended Panel Cutout Diagram ●Same Recommended Cutout for Built-in Light Indicator Type, Type Without Light Indicator and Through-Hole Mounting Type 4.5 +1 -2 3 Lock Lever TM21P--88P TM21R--5C--88--LP 14.1 1 4.5MIN 0.6MIN (33) 1 0.15 Panel Side 2 PCB Mounting Surface 16.4 3 Connector Front Surface 3 0 2.8 -0.8 6.75 10.25 *Recommendations for Panel Design 1 When making the panel, make a notch according to the dimensions shown as a relief for the plug lock lever. 2 Set the panel mounting position so that the bottom surface of the panel is 0.15mm below the PCB mounting surface. 0 3 The contact position of the contact spring is 4.5 +1 --2 (top and sides) and 2.8 --0.8 (back side) from the front surface of the connector. Please be careful when setting the panel position. ●Usage Precautions for Built-in Light Pipe Type IPA cleaning at room temperature is recommended for cleaning. When using a liquid-based cleaning agent, the color of the light pipe (made of polycarbonate resin) may change. Please select a cleaning agent after reviewing the table of cleaning agent effects on resin issued by cleaning agent manufacturers. 4 3 2 3.2MAX 15.75 8 3.05 2Ø1 .6 11.43 3MIN Ø3 2- 6.75 2 1 Contact No. 2Ø1 7 7 2.54 6 3 4 6.35 13.05 5 6 3 3.2 8 7 .2 1 Ø1 No Ground Traces Contact No. 6.35 3.81 1.27 6 Ø 2- 3.05 8.89 6 8- Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. LED Mounting Area LED Light Emission Area 1 8-Ø 6.35 3.81 1.27 6.75 7 .6 6 ●Without Light Pipe ●Through-Hole Mounting Type 1.5MAX TM21R Series●Modular Jack Connectors for High Speed LAN Transmission ■Modular Receptacles Supporting Cat.5 ●1 Row×4 Ports 59.18 25.9 41.91 HRS No. RoHS TM21R-5A-3232-LP(50) 222-2873-50 YES 1.7 (3.5) 0.35 Contact No.7 53.81 1.4 2.5 Contact No.8 58.93 12.7 15.525 5.8 8.34 1 8.34 10.25 1 (6) 15.4 15.3 0.75 1 15.4 3.6 3 0.45 Contact No.2 0.25 Contact No.1 (6) Part No. (6) Contact No.8 Contact No.1 1 11.9 BRecommended PCB Mounting Patterns LED Mount Area Dimensions 58.93 41.91 CL-220 Series 13.97 12.7 5 8.34 1.45 1.5 6 6 12.7 1.4 1.6 1.3 32-Ø1 8.34 1 4 6 7 2 3 5 8 10.9 6 4 11.9 5.8 LED Light Emission Area SML-010 Series 1.2 12.7 8.89 6.35 3.81 1.27 4 6 LED Mounting Area 15.525 4-Ø2 SML-020 Series 2.5 No conductive traces 2 0.6 53.81 6 12.7 2-Ø3.2 PCB Edge Connector Front Edge 1 1 2.7 6 6 Contact No. 4-Ø2 6 4.4 3MIN 10.4 6MAX Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13.97 *Recommendations for PCB Design 1 Note that the contact arrangement for contact No.1 and No.2 and No.7 and No.8 are switched. For LED specifications, contact the LED manufacturer. 2 Areas indicated should be free of conductive traces. 3 Recommended board thickness: 1.6mm. 4 The LED for the jack connector with built-in light pipe is mounted on the PCB. Please use the compatible LEDs shown on the table. For LED specifications, contact the LED manufacturer. 5 Mount so that the center of the light emitting part of the LED is at the center of the dimensions indicated in the diagram. 6 Please check the latest dimension of LED pad with the corresponding LED manufacturer before designing. 4 Applicable LEDs Series Name CL-220 CL-221 SML-010 SML-020 Manufacturer Citizen Electronics Co., Ltd. Citizen Electronics Co., Ltd. Rohm Co., LTD Rohm Co., LTD 1 Contact Arrangement TM21R Series 1 4 6 7 Other Series 2 4 6 8 1 3 5 7 2 3 5 8 5 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission BRecommended Panel Cutout Diagram 4.5MIN 1 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 2 1 0.4MIN 0.15 15.8 PCB Mounting Surface 13.97 3 41.91 Panel Side 59.6 +1 (34) TM21P-- 88P Contact Spring 3 5 - 2.5 3 Connector Front Surface Lock Lever 6 MAX 3 3.5 0 -1 10.25 *Recommendations for Panel Design 1 When making the panel, make a notch according to the dimensions shown as a relief for the plug lock lever. 2 Set the panel mounting position so that the bottom surface of the panel is 0.15mm below the PCB mounting surface. 0 3 The contact position of the contact spring is 5 +1 --2.5 (top and sides) and 3.5 --1 (back side) from the front surface of the connector. Please be careful when setting the panel position. ●Usage Precautions for Built-in Light Pipe Type IPA cleaning at room temperature is recommended for cleaning. When using a liquid-based cleaning agent, the color of the light pipe (made of polycarbonate resin) may change. Please select a cleaning agent after reviewing the table of cleaning agent effects on resin issued by cleaning agent manufacturers. 6 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission ●2 Row×4 Ports A B 32.5 1 (6) 1.7 27.9 0.75 Contact No.8 Lower Row 28 0.45 Contact No.1 0.25 C D 3.6 Contact No.1 22.125 7 6 4 1 8 5 3 2 19.3 2 3 5 8 1 4 6 7 14.94 12.4 1 PBT 14.94 10.25 5.8 Lower Row Contacts 1.4 2.5 8.34 1 (6) 1 0.35 (3.5) Upper Row Contacts 7.7 TM21R-5B-4848D-LP(50) 11.9 Part No. HRS No. A B C D TM21R-5B-3232D-LP(50) 222-2879-1 50 59.18 41.91 53.81 58.93 TM21R-5B-4848D-LP(50) 222-2885-4 50 87.12 69.85 81.75 86.87 BRecommended PCB Mounting Pattern 7.7 A B 13.97 7 8.89 7 6.35 LED Light Emission Area E- Ø2 3.81 1.27 1.2 Upper Row Contact Hole 2 Lower Row Contact Hole 2 5.8 8.34 1 4 6 7 2 3 5 8 2.5 3 MIN D- Ø1 4- Ø2 1 Contact No. No Conductive Traces PCB Edge 3 Connector Front Edge C 2- Ø3.2 12.4 7 8 5 3 2 7 6 4 1 14.94 19.3 YES 22.125 8 11.9 RoHS 14.94 8 Lower Row LED Mount Position 8 6 1.3 Upper Row LED Mount Position 1.4 6 6 MAX Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (6) ●2 Row×6 Ports 3 TM21R-5B-3232D-LP(50) 28 Upper Row 13.97 Contact No.8 Part No. HRS No. A B C D E TM21R-5B-3232D-LP(50) 222-2879-1 50 58.93 41.91 53.81 64 4 TM21R-5B-4848D-LP(50) 222-2885-4 50 86.87 69.85 81.75 96 *Recommendations for PCB Design 1 Note that the contact arrangement for contact No.1 and No.2 and No.7 and No.8 are switched. 2 The positions of the upper and lower contacts are as shown in the drawing. 3 Areas indicated should be free of conductive traces. 4 Recommended board thickness : 1.6mm. 5 The LED for the jack connector with built-in light pipe is mounted on the PCB. Please use the compatible LEDs shown on the table. For LED specifications, contact the LED manufacturer. 6 The mounting positions of the upper and lower LED are as shown in the drawing. 7 Mount so that the center of the light emitting part of the LED is at the center of the dimensions indicated in the diagram. 8 Please check the latest dimension of LED pad with the corresponding LED manufacturer before designing. 6 p 1 Contact Arrangement Other Series 7 8 5 6 2 1 3 4 4 3 1 8 2 6 5 TM21R Series 7 8 5 6 1 7 2 3 4 4 3 2 1 6 5 7 8 5 Applicable LEDs Series Name CL-220 CL-221 Manufacturer Citizen Electronics Co., Ltd. Citizen Electronics Co., Ltd. 7 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission BPanel Cutout Contact Spring 28.4 3 0.4 MIN 4.5MIN 1 1 2 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.15 PCB Mounting Surface 13.97 A Panel Side B Part No. HRS No. A B TM21R-5B-3232D-LP(50) 222-2879-1 50 41.91 59.60 TM21R-5B-4848D-LP(50) 222-2885-4 50 69.85 87.54 (34) 5 Lock lever TM21P -- 88P 3 +1 -2.5 RoHS YES 3 TM21R -- 5B -- * * * * D -- LP Connector Front Surface 6 MAX 3 3.5 -10 10.25 *Recommendations for Panel Design 1 When making the panel, make a notch according to the dimensions shown as a relief for the plug lock lever. 2 Set the panel mounting position so that the bottom surface of the panel is 0.15mm below the PCB mounting surface. 0 3 The contact position of the contact spring is 5 +1 --2.5 (upper and side) and 3.5 --1 (lower) from the front surface of the connector. Please be careful when setting the panel position. ●Usage Precautions for Built-in Light Pipe Type IPA cleaning at room temperature is recommended for cleaning. When using a liquid-based cleaning agent, the color of the light pipe (made of polycarbonate resin) may change. Please select a cleaning agent after reviewing the table of cleaning agent effects on resin issued by cleaning agent manufacturers. 8 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission BTechnical Documentation Cat.5e Transmission Characteristics Data The below graph is of representative values for the various transmission characteristics for the receptacle (TM21R-5C88P) mated with plug (TM21P-88P). The TM21R-5C series meets the requirements for Cat.5e single transmission when used with plugs manufactured on the De-embedded method of the TIA/EIA-568-B.2 standard. Note : This data is for the listed mated connector pair. For other combinations, please contact a Hirose Electric representative. ●Signal Attenuation Attenuation(dB) 0.4 0.3 0.2 0.1 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2 3,6 4,5 7,8 Cat.5e Spec ●Near-End Crosstalk (NEXT) Data 120 NEXT(dB) 100 80 60 40 20 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2-3,6 1,2-4,5 1,2-7,8 3,6-4,5 3,6-7,8 4,5-7,8 Cat.5e Spec ●Return Loss 80 Return Loss(dB) Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5 60 40 20 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2 3,6 4,5 7,8 Cat.5e Spec 9 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission ●Far-End Crosstalk (FEXT) 120 FEXT(dB) 100 80 60 40 20 0 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0 10 20 30 40 50 60 70 80 90 100 90 100 90 100 Frequency(MHz) 1,2-3,6 3,6-1,2 4,5-1,2 7,8-1,2 Cat.5e Spec 1,2-4,5 3,6-4,5 4,5-3,6 7,8-3,6 1,2-7,8 3,6-7,8 4,5-7,8 7,8-4,5 ●Propagation Delay 3 Delay(ns) 2.5 2 1.5 1 0.5 0 0 10 20 30 40 50 60 70 80 Frequency(MHz) 1,2 3,6 4,5 7,8 Cat.5e Spec ●Propagation Delay (Delay Skew) 1.4 Delay Skew(ns) 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 40 50 60 70 Frequency(MHz) Measurement Value 10 Cat.5e Spec 80 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission BReference Documentation ●CAT6 Certification Received Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM21R-5C Series meets the requirements for Cat.6 single transmission when used with plugs manufactured on the de-embedded method of the TIA/EIA-568-B.2 standard under certain conditions. A certificate was issued by GHMT, an independent European testing company. Certificate of Acceptance Return Loss NEXT 11 TM21R Series●Modular Jack Connectors for High Speed LAN Transmission Modular Connector Guide ■Modular Connector Contact Numbers (8pos.) The numbers below comply with FCC standards. Please be aware of how contact numbers are decided during design. Plug Jack (Mating Face) Contact No.1 Contact No.8 Contact No.8 ■Plug Mating Cautions Contact No.1 FCC Plug Dimensions 5.89 - 6.15 Nov.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Use only plugs that conform to FCC standards. Pay particular attention to the contact height shown to the right. ■Mating Port Size and Number of Contacts (6pos.) The relationship between the mating port size of the jack connector and number of contacts is shown below. Model 66 Model 64 Model 62 Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66. For details, please contact us for drawings because only standard models are shown in the catalogs. ■Recommended Soldering for Modular Through-Hole Connectors ●Same for Types With/Without Built-in Light Pipe ●Flow solder (automatic soldering machine) ●Hand soldering Pre-heat : 90 - 130ç Soldering iron tip temperature Pre-heat time : 120 seconds maximum Soldering temperature Solder temperature : 240 - 260ç Soldering iron output Soldering time : 10 seconds maximum Note : When soldering, do not apply excessive force to the connector terminals. ●Recommended Solder composition: Paste, 96.5%Sn/3.0%Ag/0.5%Cu : 350ç : 5seconds maximum : 30 - 40W ●Through-Hole Mounting Type 260 Connector surface temperature Number of Reflow cycles : 2 times Max 10 seconds 250℃ max 240 Heating Temperature (℃) 220 220℃ The temperature profile may vary due to external conditions such as the type of cream solder, manufacturer, and board size. Please contact the solder manufacturer for their specifications. 200 60±10 seconds 180 160 150∼180℃ 140 90±30 seconds pre-heating 0 Time 12 The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 09/2021. Contents are subject to change without notice for the purpose of improvements.
TM21R-5B-3232D 价格&库存
很抱歉,暂时无法提供与“TM21R-5B-3232D”相匹配的价格&库存,您可以联系我们找货
