TM21R-5B-3232D-LP
TM21R-5B-3232D-LP
    HRS(广濑)
    CONN MOD JACK 8P8C R/A SHIELDED
TM21R-5B-3232D-LP 数据手册
Modular Jack Connectors for High-Speed LAN Transmission TM21R Series Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Built-in Optical Indicators LED Optical indicator Optical pipe ■Features Housing 1. Supports High-Speed LAN Transmission Meets requirements of TIA/EIA-568-B data wiring standard. Single port configuration meeting CAT5e and multiple port configuration meeting CAT5 transmission performance. As such, these products fully support Gigabit Ethernet (1000BASE-T) and Fast Ethernet (100BASE-TX) highspeed LAN transmission. Optical indicator area Space saving Optical indicator 2. Built-in Optical Indicators Optical indicators are integral part of the connectors saving space on customer’s board. Compared with LED type indicators, they do not emit any electrical noise. 3. EMI protection One additional TM21 multi-port jack can be mounted in the space previously occupied by LEDs. Metal shield covers the outer surfaces of the connectors assuring complete protection against electromagnetic interference. Built-in multiple shield and ground contacts assure reliable connection with the mounting panel as well as with the mating connector. 4. FCC Standards Meets requirements of FCC Title 47, Part 68, Subpart F. ■Applications Telecom Hubs, Routers, Bridges and ATM Transmission Equipment, Ethernet Switches and Networking Equipment, Test and Measurement Equipment, Medical Diagnostic Equipment. Built-in LED type (Possibility of electromagnetic noise emission and interference.) Built-in Optical pipe type (No electromagnetic noise emission.) 2012.6 1 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission ■Product Specifications Current rating 1A Voltage rating 125 V AC Operating temperature range-25ç to +80ç (Note) Ratings Item Specification Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 01.Insulation resistance Conditions 100 V DC 100 M ohms min 02.Dielectric Withstanding Voltage No flashover or insulation breakdown (between adjacent contacts) 500 V AC / one minute 03.Withstanding voltage No flashover or insulation breakdown (between contact and shield) 1500 V AC / one minute 04.Contact resistance 230 m ohms max. 100mA DC 05.Vibration No electrical discontinuity of 5 ms or more Contact resistance: 250m ohms max. Frequency: 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours / 3 axis 06.Shock No electrical discontinuity of 5ms or more Contact resistance: 250m ohms max. Acceleration of 490 m/s2, 11 ms duration, sine half-wave waveform, 3 cycles in each of the 3 axis 07.Durability (mating/unmating) Contact resistance: 250m ohms max. 200 cycles 08.Temperature cycle Contact resistance: 250 m ohms max. Insulation resistance: 100 M ohms min. (Temperature: -55ç/+5ç to +35ç/+85ç/+5ç to +35ç Duration: 30 / 5 / 30 / 5 (Minutes) 5 cycles Contact resistance: 250 m ohms max. Insulation resistance: 1 M ohms min. (High humidity) Insulation resistance: 10 M ohms min. (Dry state) 500 hours at temperature of 40ç and humidity of 90% to 95% Contact resistance: 250 m ohms max. Exposed to density 5% salt water for 48 hours 09.Humidity 10.Salt Spray Note :Includes temperature rise caused by current flow. ■Materials Part Material Finish Remarks PBT Color: Black UL94V-0 Copper alloy Contact area: Gold plating Termination area: Gold plating flash ------- Color: Clear ------- Tin plating ------- Insulator Contact Poly carbonate Copper alloy Optical pipe Shield ■Ordering information ●Jacks TM21 R - 5 A - 32 32 D - LP (50) 1 2 2 3 4 5 6 7 8 9 q Series Name w Connector type e Jack type number r Jack performance level code TM21 R : Jack 5 : PCB Right-angle through hole type A : CAT5 (Single row, multi-port) B : CAT5 (Double row, multi port) C : Supports CAT5e (Single port) t Jack opening code 8 : 8 contacts 32 : 8 contacts /4 ports 48 : 8 contact/6 ports y Number of inserted contacts 8 : 8 contact 32 : 8 contact inserted in 4 ports=32 contacts 48 : 8 contact inserted in 6 ports=48 contacts u Number of rows Blank: Single row D: Double row i Optical pipe LP: With optical pipe inserted Blank: Without optical pipe (50) o RoHS compliant TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission ■Modular Jack Connectors Supporting CAT5e ●Single Port With Built-in Optical Pipe 21 16 1.7 13.75 13.4 0.8 (2.8) 3.05 15.75 0.8 0.35 1 11.43 6.35 2.54 13.05 10.25 0.8 (5.5) (5.5) 24 Contact No.7 TM21R-5C 1 PC Contact No.8 Contact No.1 Contact No.2 11.9 Part Number CL No. RoHS TM21R-5C-88-LP(50) 222-2892-0-50 YES ●Single Port Without Optical Pipe 21 16 11.43 (2.8) 0.35 1 3.05 15.75 0.8 1.7 13.4 0.8 13.75 3.6 0.25 0.45 0.8 (5.5) Contact No.1 3 Contact No.8 6.35 2.54 13.05 10.25 0.8 (5.5) (5.5) 24 Contact No.7 TM21R-5C 1 PC Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 3.6 0.25 0.45 0.8 (5.5) Contact No.1 3 Contact No.8 Contact No.8 Contact No.1 Contact No.2 11.9 Part Number CL No. RoHS TM21R-5C-88(50) 222-2893-2-50 YES 3 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission BRecommended PCB mounting patterns ●With Built-in Optical Pipe ●Without Optical Pipe 11.9 8.89 No ground traces 3 .6 3MIN 2 1 6.75 3 4 3MIN 5 6 6.75 2.54 3MIN 6.75 6.35 3MIN Printed board edge Connector front edge 11.43MIN No conductive traces 7 1 2 11.43 Printed board edge Connector front edge 11.43MIN 15.75 No conductive traces *Recommendations for PCB Design 1 1 The contact arrangement differs between the contact area side and Printed board side. (1,2,3,4,5,6,7,8 on the contact are side / 2,1,3,4,5,6,8,7 on the printed board side) 2 Areas indicated should be free of conductive traces. 3 Area indicated should be free of ground traces. 4 Recommended board thickness: 1.6mm. 5 To assure that the indicator light pipes operates correctly the LED's must be installed directly on the PCB, within recommended dimensions and with light emitting center in upward direction. Contact applicable manufacturer for LED specification. 2 PCB mounting pattern Other Series TM21R Series 7 5 3 1 8 5 3 2 8 6 4 2 5 7 6 4 1 Suggested LEDs LED light emitting center 2.7MAX 3.2MAX 15.75 8 3.05 2Ø1 .6 11.43 6.75 Ø3 2- 2Ø1 2.54 2 1 6.35 13.05 3.05 3 4 Contact No. 3.2 5 6 Ø 2- 8 .2 3 1 Ø1 No ground traces Contact No. 7 6.35 3.81 1.27 8- Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.89 LED location area LED light emission area 1 8-Ø 6.35 3.81 1.27 1.5MAX BPanel Cutout ●For Both Types, With and Without Built-in Optical Pipe 4.5 0.6MIN (33) PCB mounting surface 0.15 Lock lever TM21P--88P TM21R--5C--88--LP 14.1 4.5MIN +1 -2 1 Panel side 1 Connector front surface 16.4 1 0 2.8 -0.8 6.75 10.25 *Recommendations for Panel Design 1 The shield contacts should connect with the panel cut-out on all sides. Note: IPA cleaning at room temperature is recommended for the cleaning of this product. When an aqueous cleaning agent is to be used, there is a concern that the light pipe (made of polycarbonate resin) may change color; therefore, please make a selection based on a table showing the effects on the resin. These tables are issued by the various manufacturers of cleaning agents. 4 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission ■Modular Receptacles Supporting CAT5 ●Single row/ multiple ports, with Built-in Optical Pipe 59.18 25.9 41.91 CL No. RoHS TM21R-5A-3232-LP(50) 222-2873-50 YES 1.7 (3.5) 0.35 Contact No.7 53.81 1.4 2.5 Contact No.8 58.93 8.34 10.25 15.525 5.8 8.34 1 12.7 1 (6) 15.4 15.3 0.75 1 15.4 3.6 3 0.45 Contact No.2 0.25 Contact No.1 (6) Part Number (6) Contact No.8 Contact No.1 1 11.9 BRecommended PCB mounting patterns LED Mount Area Dimensions 58.93 41.91 CL-220 Series 13.97 12.7 8.34 1.45 1.5 1.6 12.7 1.4 32-Ø1 8.34 1 4 6 7 2 3 5 8 10.9 1.3 4 11.9 1.2 5.8 LED light emission area 8.89 6.35 3.81 1.27 4 12.7 LED location area SML-010 Series 15.525 4-Ø2 SML-020 Series 2.5 Contact No. 1 No conductive traces 2 4-Ø2 0.6 Printed board edge Connector front edge 53.81 4.4 12.7 2-Ø3.2 2.7 1 3MIN 10.4 6MAX Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 13.97 *Recommendations for PCB Design 1 The contact arrangement differs between the contact area side and Printed board side. (1,2,3,4,5,6,7,8 on the contact are side / 2,1,3,4,5,6,8,7 on the printed board side) 2 Areas indicated should be free of conductive traces. 3 Recommended board thickness: 1.6mm. 4 To assure that the indicator light pipes operates correctly the LED’s must be installed directly on the PCB, within recommended dimensions and with light emitting center in upward direction. Contact applicable manufacturer for LED specification. 4 Suggested LEDs Series Name Manufacturer CL-220 Citizen Electronics Co., Ltd. SML-010 Rohm Co., LTD SML-020 Rohm Co., LTD 1 PCB mounting pattern 2 1 4 3 6 5 8 7 1 2 4 3 6 5 7 8 5 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission BRecommended Panel Cutout 15.8 0.4MIN 0.15 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCB mounting surface 4.5MIN 13.97 1 41.91 Panels Side 59.6 +1 (34) TM21P-- 88P Shield spring contact 5 - 2.5 1 Connector front surface Lock lever 3.5 6 MAX 0 -1 10.25 *Recommendations for Panel Design 1 The shield contacts should connect with the panel cut-out on all sides. Note: IPA cleaning at room temperature is recommended for the cleaning of this product. When an aqueous cleaning agent is to be used, there is a concern that the light pipe (made of polycarbonate resin) may change color; therefore, please make a selection based on a table showing the effects on the resin. These tables are issued by the various manufacturers of cleaning agents. 6 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission ●Double row / multiple port, with Built-in Optical Pipe A B 32.5 1 (6) 1.7 27.9 0.75 Contact No.8 Lower row 28 0.45 Contact No.1 0.25 C D 3.6 Contact No.1 14.94 22.125 7 6 4 1 8 5 3 2 19.3 2 3 5 8 1 4 6 7 14.94 12.4 1 PBT 1.4 2.5 10.25 5.8 1 0.35 (3.5) 8.34 3 Lower row connectors contacts (6) (6) 1 Upper row connectors contacts 7.7 TM21R-5B-4848D-LP(50) 11.9 Part Number CL No. A B C D TM21R-5B-3232D-LP(50) 222-2879-1-50 59.18 41.91 53.81 58.93 TM21R-5B-4848D-LP(50) 222-2885-4-50 87.12 69.85 81.75 86.87 RoHS YES BRecommended PCB mounting pattern A B 4 4 Upper row LED mount position 11.9 13.97 8.89 7.7 Lower row LED mount position 6.35 LED light emission area E- Ø2 3.81 1.27 Upper row contact hole 1.3 1.4 1.2 4- Ø2 1 Contact No. No conductive traces 22.125 14.94 Printed board edge 2 Connector front edge C 2- Ø3.2 5.8 8.34 1 4 6 7 2 3 5 8 2.5 3 MIN D- Ø1 12.4 8 5 3 2 7 6 4 1 14.94 19.3 Lower row contact hole 6 MAX Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. TM21R-5B-3232D-LP(50) 28 Upper row 13.97 Contact No.8 Part Number CL No. A B C D E TM21R-5B-3232D-LP(50) 222-2879-1-50 58.93 41.91 53.81 64 4 TM21R-5B-4848D-LP(50) 222-2885-4-50 86.87 69.85 81.75 96 6 *Recommendations for PCB Design 1 The contact arrangement differs between the contact area side and Printed board side. (1,2,3,4,5,6,7,8 on the contact are side / 2,1,3,4,5,6,8,7 on the printed board side) 2 Areas indicated should be free of conductive traces. 3 Recommended board thickness: 1.6mm. 4 To assure that the indicator light pipes operates correctly the LED's must be installed directly on the PCB, within recommended dimensions and with light emitting center in upward direction. Contact applicable manufacturer for LED specification. 1 PCB mounting pattern Other Series 7 8 5 6 2 1 3 4 4 3 1 2 6 5 TM21R Series 8 7 8 7 5 6 1 2 3 4 4 3 2 1 6 5 7 8 4 Suggested LEDs Series Name Manufacturer CL-220 Citizen Electronics Co., Ltd. 7 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission BPanels Cutout Shield spring contact spring 28.4 1 0.4 MIN 0.15 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. PCB mounting surface 4.5MIN 13.97 A Panel Side B Part Number CL No. A B TM21R-5B-3232D-LP(50) 222-2879-1-50 41.91 59.60 TM21R-5B-4848D-LP(50) 222-2885-4-50 69.85 87.54 (34) 5 Lock lever TM21P -- 88P 1 YES 1 TM21R -- 5B -- * * * * D -- LP Connector front surface 1 +1 -2.5 RoHS 6 MAX 3.5 -10 10.25 *Recommendations for Panel Design 1 The shield contacts should connect with the panel cut-out on all sides. Note: IPA cleaning at room temperature is recommended for the cleaning of this product. When an aqueous cleaning agent is to be used, there is a concern that the light pipe (made of polycarbonate resin) may change color; therefore, please make a selection based on a table showing the effects on the resin. These tables are issued by the various manufacturers of cleaning agents. 8 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission BTechnical Documentation CAT5e Transmission Characteristics Data Representative values of the various transmission characteristics data for fully mated receptacle (TM21R-5C-88-LP) and plug (TM21P-88P). All plugs in the TM21R-5C Series that were manufactured based on the De-embedded method of the TIA/EIA-568-B.2 standard and meet performance requirements of CAT5e single transmission. Note:These data are for the listed connector combination. Inquire with your Hirose Electric account representative about other combinations. ●Signal Attenuation Attenuation(dB) 0.4 0.3 0.2 0.1 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2 3,6 4,5 7,8 CAT5e Spec ●Near-End Crosstalk (NEXT) Data 120 NEXT(dB) 100 80 60 40 20 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2-3,6 1,2-4,5 1,2-7,8 3,6-4,5 3,6-7,8 4,5-7,8 CAT5e Spec ●Return Loss 80 Return Loss(dB) Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5 60 40 20 0 0 10 20 30 40 50 60 70 80 90 100 Frequency(MHz) 1,2 3,6 4,5 7,8 CAT5e Spec 9 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission ●Far-End Crosstalk (FEXT) 120 FEXT(dB) 100 80 60 40 Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 20 0 0 10 20 30 40 50 60 70 80 90 100 90 100 90 100 Frequency(MHz) 1,2-3,6 3,6-1,2 4,5-1,2 7,8-1,2 CAT5e Spec 1,2-4,5 3,6-4,5 4,5-3,6 7,8-3,6 1,2-7,8 3,6-7,8 4,5-7,8 7,8-4,5 ●Propagation Delay 3 Delay(ns) 2.5 2 1.5 1 0.5 0 0 10 20 30 40 50 60 70 80 Frequency(MHz) 1,2 3,6 4,5 7,8 CAT5e Spec ●Propagation Delay (Delay Skew) 1.4 Delay Skew(ns) 1.2 1 0.8 0.6 0.4 0.2 0 0 10 20 30 40 50 60 70 Frequency(MHz) Measurement Value 10 CAT5e Spec 80 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission BReference Documentation ●CAT6 Certification Received Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Only the high quality plugs in the TM21R-5C Series (based on the De-embedded method of the TIA/EIA-568-B.2 standard) clear CAT6 single transmission performance. A certificate was issued by the GHMT, independent European testing company. Certificate of Acceptance Return Loss NEXT 11 TM21R Series●Modular Jack Connectors for High-Speed LAN Transmission GUIDANCE FOR MODULAR CONNECTORS ■Modular Connector Terminal Numbers Unless otherwise specified, see the figures below for the terminal numbers of the product. Plug Jack Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (mating face) Powered by TCPDF (www.tcpdf.org) Contact No.1 Contact No.8 Contact No.8 Contact No.1 ■Attention to Plug Mating FCC PLUG DIMENSIONS 5.89 - 6.15 Use only plugs conforming to FCC standards. Please pay particular attention to dimensions shown right. ■Opening Size and Number of Conductors(6-Conductor) See the figures below for the relationship between the opening size and the number of conductors of the jack connectors. Model 66 Model 64 Model 62 Models 64 and 62 are obtained by removing 1 pin and 2 pins, respectively, from both sides of model 66.For details, please contact us for drawings because only standard models are shown in the catalogs. ■Recommended Soldering for Modular Dip Connectors ●Flow solder (automatic soldering machine) Pre-heat : 90 - 130ç Pre-heat time : 120 seconds maximum Solder temperature : 240 - 260ç Soldering time : 10 seconds maximum ●Hand soldering Soldering iron tip temperature : 350ç Soldering temperature : 5seconds maximum Soldering iron output : 30 - 40W Note: When soldering, use care not to apply excessive force to the connector terminals. ●Recommended Solder composition: Paste, 96.5%Sn/3.0%Ag/0.5%Cu ® 12 6-3,Nakagawa Chuoh-2-Chome,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 06/2012. Contents are subject to change without notice for the purpose of improvements.
TM21R-5B-3232D-LP 价格&库存
很抱歉,暂时无法提供与“TM21R-5B-3232D-LP”相匹配的价格&库存,您可以联系我们找货
