PHD CONNECTOR
2.0 mm pitch/Disconnectable Crimp style connectors
Specifications
PHD CONNECTOR
• Current rating: 3 A AC/DC (AWG #22)
• Voltage rating: 250 V AC/DC
• Temperature range: -25℃ to +85℃
(including temperature rise in applying
electrical current)
• Contact resistance: Initial value/ 10 mΩ max.
After environmental tests/ 20 mΩ max.
• Insulation resistance: 1,000 MΩ min.
• Withstanding voltage: 800 VAC/minute
• Applicable wire: AWG #28 to #22
• Applicable PC board thickness: 1.6 mm
* In using the products,refer to "Handling Precautions for Terminals
and Connectors" described on our website (Technical documents
of Product information page).
* RoHS2 compliance
* Dimensional unit: mm
* Contact JST for details.
This is a 2.0 mm pitch, crimp style, dual-row,
wire-to-board connector. It is designed to
meet the demand for high-density and
low-profile connection.
● Compact
● Reliable contacts
● Fully shrouded header
Standards
PC board layout and Assembly layout
Top entry type
1.95 min.
Side entry type
2±0.05
1.95 min.
(11.8)
+0.1
φ0.7 0
Even number
circuits
5
7 min.
(8.8)
(3)
(3)
2 ±0.05
Odd number
circuits
Circuit No.1
2 ±0.05
+0.1
φ0.7 0
5
1.5 min.
2
±0.05
Recognized E60389
Note: 1
. The above figure is the figure viewed from soldering side.
2. Tolerances are non-cumulative: ± 0.05 mm for all centers.
3. Hole dimensions differ according to the type of PC board and piercing method. If PC boards made of hard material are used, the hole dimensions
should be larger. The dimensions above should serve as a guideline. Contact JST for details.
Contact
Applicable wire
mm2
AWG #
Model No.
1.5
SPHD-002T-P0.5
SPHD-001T-P0.5
Insulation O.D.
(mm)
0.08~0.21
28~24
0.9~1.5
0.13~0.33
26~22
1.0~1.5
Q'ty/
reel
8,000
Material and Finish
6.5
Phosphor bronze, tin-plated (reflow treatment)
2.85
1.3
RoHS2 compliance
Contact
SPHD-002T-P0.5
SPHD-001T-P0.5
Crimping
machine Crimp applicator
AP-K2N
MKS-L-10
Applicator
Dies
APLMK SPHD002-05
MK/SPHD-001-05
APLMK SPHD001-05
Note: Contact JST for fully automatic crimping applicator.
1
Crimp applicator with dies
MK/SPHD-002-05
PHD CONNECTOR
Housing
No. of
circuits
8
10
12
14
16
Circuit No.1
Circuit No.1
Circuit No.2
18
H JST
24
7.3
26
28
30
32
2
34
2
1.95
A
4.2
B
5
Model No.
PHDR-08VS
PHDR-10VS
PHDR-12VS
PHDR-14VS
PHDR-16VS
PHDR-18VS
PHDR-20VS
PHDR-22VS
PHDR-24VS
PHDR-26VS
PHDR-28VS
PHDR-30VS
PHDR-32VS
PHDR-34VS
A
Dimensions (mm)
B
Q'ty/
bag
6.0
9.9
1,000
8.0
11.9
1,000
10.0
13.9
1,000
12.0
15.9
1,000
14.0
17.9
1,000
16.0
19.9
1,000
18.0
21.9
1,000
20.0
23.9
1,000
22.0
25.9
1,000
24.0
27.9
1,000
26.0
29.9
1,000
28.0
31.9
1,000
30.0
33.9
1,000
32.0
35.9
1,000
PHD CONNECTOR
Material and Finish
PA 66, UL94V-0, natural (white)
RoHS2 compliance
As the color identification,
the following alphabet shall be put in the underlined part.
For availability, delivery and minimum order quantity, contact JST.
ex.
PHDR-10VSS...natural (white)
K...black Y...yellow E...blue R...red
Shrouded header
Top entry type
No. of
circuits
Circuit No.1
8
10
12
6.5
JST
H
14
16
(3)
18
Circuit No.1
□0.5
2
1.95
Circuit No.2
A
1.5 2
B
5
22
24
26
28
30
32
34
Side entry type
1.95
□0.5
A
B
Q'ty/box
Top entry Side entry
type
type
A
B
6.0
9.9
500
500
8.0
11.9
500
500
10.0
13.9
500
500
12.0
15.9
500
250
14.0
17.9
500
250
16.0
19.9
500
250
18.0
21.9
250
250
20.0
23.9
250
250
22.0
25.9
250
200
24.0
27.9
250
200
26.0
29.9
250
200
28.0
31.9
250
200
30.0
33.9
250
200
32.0
35.9
250
200
(3)
7
Circuit No.2
5
Post: Copper alloy, copper-undercoated, tin-plated (reflow treatment)
Wafer: Glass-filled PA 66, UL94V-0, natural (ivory)
RoHS2 compliance This product displays (LF)(SN) on a label.
2
9.5
6.5
JST
2
Dimensions
(mm)
Material and Finish
Circuit No.1
H
Model No.
Glass-filled nylon
Nylon
Top entry
Side entry
Top entry
Side entry
type
type
type
type
S8B-PHDSS
B8B-PHDSS
S10B-PHDSS B10B-PHDSS-B S10B-PHDSS-B
B10B-PHDSS
S12B-PHDSS B12B-PHDSS-B S12B-PHDSS-B
B12B-PHDSS
S14B-PHDSS B14B-PHDSS-B S14B-PHDSS-B
B14B-PHDSS
S16B-PHDSS B16B-PHDSS-B S16B-PHDSS-B
B16B-PHDSS
S18B-PHDSS B18B-PHDSS-B S18B-PHDSS-B
B18B-PHDSS
S20B-PHDSS B20B-PHDSS-B S20B-PHDSS-B
B20B-PHDSS
S22B-PHDSS B22B-PHDSS-B S22B-PHDSS-B
B22B-PHDSS
S24B-PHDSS B24B-PHDSS-B S24B-PHDSS-B
B24B-PHDSS
S26B-PHDSS B26B-PHDSS-B S26B-PHDSS-B
B26B-PHDSS
S28B-PHDSS B28B-PHDSS-B S28B-PHDSS-B
B28B-PHDSS
S30B-PHDSS B30B-PHDSS-B S30B-PHDSS-B
B30B-PHDSS
S32B-PHDSS B32B-PHDSS-B S32B-PHDSS-B
B32B-PHDSS
S34B-PHDSS B34B-PHDSS-B S34B-PHDSS-B
B34B-PHDSS
Circuit
No.1
ex.
B10B-PHDSS-
S...natural (ivory)
ex.
B10B-PHDSS-B-
S...natural (white)
2
很抱歉,暂时无法提供与“PHDR-20VS”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 5+0.91143
- 50+0.74244
- 150+0.65795
- 1000+0.53837
- 2000+0.48768
- 5000+0.46233
