HIF6-50D-1.27R(02)
HIF6-50D-1.27R(02)
    HRS(广濑)
    RECEPTACLE 50 POS IDC TYPE
HIF6-50D-1.27R(02) 数据手册
1.27mm Pitch Two-Piece Connectors HIF6 Series Connector in combination with the HIF6 series connection type ●HIF3B Series Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. (MIL-C-83503) ●HIF2 Series (Board direct mount type) 1 ●HIF5 Series (Card edge type) 2 ●FD Series (D sub-ribbon connector) ■Features 1. Product Variation The connection method is available with the board to board type and insulation displacement type. Fig.1 (For further information, refer to catalog page B86.) 2. Broad applications HIF2E, HIF3B and HIF5 can be combined one other, because the 1.27mm pitch flat cable is used. (Fig.1) 3. Applicable Cables The applicable cable is a (UL2651) 28 AWG flat cable (7cores: 0.127mm, outer jacket diameter: 0.8 to1.0mm) 4. Mis-insertion Preventive Structure The mis-insertion preventive guide prevents misinsertion. ■Product Specifications Rating Current rating : 0.5A Operating Temperature Range : -55 to +85 ç (Note 1) Storage Temperature Range : -10 to +60ç (Note 2) Voltage rating : 125V AC Operating Humidity Range : 40 to 80% Item Operating Humidity Range : 40 to 70% Specification (Note 2) Condition 1.Insulation Resistance 1000MΩ min. 250V DC 2.Withstanding Voltage No flashover or insulation breakdown. 300V AC/1 minute. 3.Contact Resistance 30mΩ max. 0.1A 4.Vibration No electrical discontinuity of 1μs or more Frequency : 10 to 55 Hz, single amplitude of 0.75 mm, 2 hours in each of the 3 directions. 5.Humidity (Steady state) Insulation resistance : 1000MΩ min. 96 hours at temperature of 40ç and humidity of 90% to 95% 6.Temperature Cycle (-65ç : 30 minutes→15 to 35ç : 5 minutes max.→ 125ç : 30 minutes→15 to 35ç : 5 minutes max.) 5 cycles No damage, cracks, or parts looseness. 7.Durability (Mating/un-mating) Contact resistance : 30mΩ max. 8.Resistance to Soldering heat No deformation of components affecting performance. 500 cycles Solder bath : 260ç for 10 seconds Manual soldering : 360ç for 5 seconds Note 1 : Includes temperature rise caused by current flow. Note 2 : The term "storage" refers to products stored for long period of time prior to mounting and use. Operating Temperature Range and Humidity range covers non conducting condition of installed connectors in storage, shipment or during transportation. Note 3 : Please note that there is a risk of deforming the lock when an excessive load is applied to the inside. B69 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Materials / Finish Parts Material Finish Remarks Insulator PBT Black UL94V-0 Socket Contact Copper alloy Pin header Contact Brass Selective gold plating ———— ■Product Number Structure Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Refer to the chart below when determining the product specifications from the product number. Please select from the product numbers listed in this catalog when placing orders. ●Socket and Receptacle HIF6 A – * D A – 1.27 DSA L q w e r t y u i q Series Name : HIF6 w Blank : Ribbon cable insulation displacement type A : Without board mounting hole B : With board mounting hole e Number of contacts : 20, 26, 32, 34, 40, 50, 52, 60, 68, 80, 100 r D : Socket or receptacle t A : Selective gold plated y Contact pitch : 1.27mm u Contact type : DS : Right angle type DSA : Straight type R : Ribbon cable ID type i L : Board pre-fixed lock pin ●Pin Header HIF6 A – * P A – 1.27 DSA L q w r e t y u i q Series Name : HIF6 w Blank : With lock A : Without board mounting hole B : With board mounting hole e Number of contacts : 20, 26, 32, 34, 40, 50, 52, 60, 68, 80, 100 r P : Pin header t A : Selective gold plated y Contact pitch : 1.27mm u Contact style : DS DSA : Right angle type : Straight type i L : Board pre-fixed lock pin B70 HIF6 Series●1.27mm Pitch Two-Piece Connectors BFunction Chart Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Pin Header Socket or Receptacle Side Right Angle Type with lock Two pieces of 1.27mm pitch cable used a2.54 pitch connector (MIL-C-83503) Straight Type with lock HIF2B series HIF3B series HIF5 series Ribbon cable FD (D sub) connector Right Angle Type with Right Angle mounting hole Type with mounting hole Straight Type with mounting hole Straight Type with mounting hole Right Angle Type without mounting hole Right Angle Type without mounting hole Straight Type without mounting hole Straight Type without mounting hole B71 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Cable ID Connector Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Unit : mm Unit : mm B72 Part No. HRS No. No. of Contacts A B C D HIF6-020D-1.27R(20) 630-0001-4 20 20 18.55 11.43 13.95 16.35 HIF6-026D-1.27R(20) 630-0002-7 20 26 22.36 15.24 17.76 20.16 HIF6-032D-1.27R(20) 630-0003-0 20 32 26.17 19.05 21.57 23.97 HIF6-034D-1.27R(20) 630-0004-2 20 34 27.44 20.32 22.84 25.24 HIF6-040D-1.27R(20) 630-0005-5 20 40 31.25 24.13 26.65 29.05 HIF6-050D-1.27R(20) 630-0006-8 20 50 37.60 30.48 33.00 35.40 HIF6-052D-1.27R(20) 630-0007-0 20 52 38.87 31.75 34.27 36.67 HIF6-060D-1.27R(20) 630-0008-3 20 60 43.95 36.83 39.35 41.75 HIF6-068D-1.27R(20) 630-0009-6 20 68 49.03 41.91 44.43 46.83 HIF6-080D-1.27R(20) 630-0010-5 20 80 56.65 49.53 52.05 54.45 HIF6-100D-1.27R(20) 630-0011-8 20 100 69.35 62.23 64.75 67.15 RoHS YES HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Pin Header Right Angle Type with lock Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= Number of Contacts 2 Note : Size F indicates the state where the lock is open. BPCB mounting pattern ● Indicate Mating Side mark position. Mating Side Unit : mm Part No. HRS No. No. of Contacts A B C D E F HIF6-020PA-1.27DS(71) 630-0051-2 71 20 30.95 11.43 24.55 18.75 21.59 43.55 HIF6-026PA-1.27DS(71) 630-0052-5 71 26 34.76 15.24 28.36 22.56 25.40 47.36 HIF6-032PA-1.27DS(71) 630-0053-8 71 32 38.57 19.05 32.17 26.37 29.21 51.17 HIF6-034PA-1.27DS(71) 630-0054-0 71 34 39.84 20.32 33.44 27.64 30.48 52.44 HIF6-040PA-1.27DS(71) 630-0055-3 71 40 43.65 24.13 37.25 31.45 34.29 56.25 HIF6-050PA-1.27DS(71) 630-0056-6 71 50 50.00 30.48 43.60 37.80 40.64 62.60 HIF6-052PA-1.27DS(71) 630-0057-9 71 52 51.27 31.75 44.87 39.07 41.91 63.87 HIF6-060PA-1.27DS(71) 630-0058-1 71 60 56.35 36.83 49.95 44.15 46.99 68.95 HIF6-068PA-1.27DS(71) 630-0059-4 71 68 61.43 41.91 55.03 49.23 52.07 74.03 HIF6-080PA-1.27DS(71) 630-0060-3 71 80 69.05 49.53 62.65 56.85 59.69 81.65 HIF6-100PA-1.27DS(71) 630-0061-6 71 100 81.75 62.23 75.35 69.55 72.39 94.35 RoHS YES B73 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Pin Header Straight Type with lock Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= Number of Contacts 2 BPCB mounting pattern Guide Key Side (20, 32, 40, 52, 60, 68, 80, 100 contacts) (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side ● Indicate mark position. (26, 34, 50 contacts) Note : Size G indicates a state where the lock is open. (26, 34, 50 contacts) Unit : mm B74 Part No. HRS No. No. of Contacts A B C D E F G HIF6-020PA-1.27DSA(71) 630-0101-9 71 20 30.95 11.43 24.55 18.75 14.95 21.59 43.55 HIF6-026PA-1.27DSA(71) 630-0102-1 71 26 34.76 15.24 28.36 22.56 18.76 25.40 47.36 HIF6-032PA-1.27DSA(71) 630-0103-4 71 32 38.57 19.05 32.17 26.37 22.57 29.21 51.17 HIF6-034PA-1.27DSA(71) 630-0104-7 71 34 39.84 20.32 33.44 27.64 23.84 30.48 52.44 HIF6-040PA-1.27DSA(71) 630-0105-0 71 40 43.65 24.13 37.25 31.45 27.65 34.29 56.25 HIF6-050PA-1.27DSA(71) 630-0106-2 71 50 50.00 30.48 43.60 37.80 34.00 40.64 62.60 HIF6-052PA-1.27DSA(71) 630-0107-5 71 52 51.27 31.75 44.87 39.07 35.27 41.91 63.87 HIF6-060PA-1.27DSA(71) 630-0108-8 71 60 56.35 36.83 49.95 44.15 40.35 46.99 68.95 HIF6-068PA-1.27DSA(71) 630-0109-0 71 68 61.43 41.91 55.03 49.23 45.43 52.07 74.03 HIF6-080PA-1.27DSA(71) 630-0110-0 71 80 69.05 49.53 62.65 56.85 53.05 59.69 81.65 HIF6-100PA-1.27DSA(71) 630-0111-2 71 100 81.75 62.23 75.35 69.55 65.75 72.39 94.35 RoHS YES HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Receptacle Right Angle Type with Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= Number of Contacts 2 BPCB mounting pattern Mating Side BApplication Pattern (20, 32, 40, 52, 60, 68, 80 contacts) Mating Side Mounting hole center line (26, 34, 50 contacts) Unit : mm No. of Contacts A B C D E HIF6B-20DA-1.27DS(71) 631-0051-9 71 20 30.95 20.95 11.43 26.67 18.55 HIF6B-26DA-1.27DS(71) 631-0052-1 71 26 34.76 24.76 15.24 30.48 22.36 HIF6B-32DA-1.27DS(71) 631-0053-4 71 32 38.57 28.57 19.05 34.29 26.17 HIF6B-34DA-1.27DS(71) 631-0054-7 71 34 39.84 29.84 20.32 35.56 27.44 HIF6B-40DA-1.27DS(71) 631-0055-0 71 40 43.65 33.65 24.13 39.37 31.25 HIF6B-50DA-1.27DS(71) 631-0056-2 71 50 50.00 40.00 30.48 45.72 37.60 HIF6B-52DA-1.27DS(71) 631-0057-5 71 52 51.27 41.27 31.75 46.99 38.87 HIF6B-60DA-1.27DS(71) 631-0058-8 71 60 56.35 46.35 36.83 52.07 43.95 HIF6B-68DA-1.27DS(71) 631-0059-0 71 68 61.43 51.43 41.91 57.15 49.03 HIF6B-80DA-1.27DS(71) 631-0060-0 71 80 69.05 59.05 49.53 64.77 56.65 Part No. *Lock pin type is also available. HRS No. RoHS YES B75 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Receptacle Right Angle Type Without Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= BPCB mounting pattern Mating Side BApplication Pattern (20, 32, 40, 52, 60, 68, 80 contacts) Mating Side (26, 34, 50 contacts) Unit : mm B76 Part No. HRS No. No. of Contacts A B C HIF6A-20DA-1.27DS(71) 631-0001-0 71 20 20.95 11.43 18.55 HIF6A-26DA-1.27DS(71) 631-0002-3 71 26 24.76 15.24 22.36 HIF6A-32DA-1.27DS(71) 631-0003-6 71 32 28.57 19.05 26.17 HIF6A-34DA-1.27DS(71) 631-0004-9 71 34 29.84 20.32 27.44 HIF6A-40DA-1.27DS(71) 631-0005-1 71 40 33.65 24.13 31.25 HIF6A-50DA-1.27DS(71) 631-0006-4 71 50 40.00 30.48 37.60 HIF6A-52DA-1.27DS(71) 631-0007-7 71 52 41.27 31.75 38.87 HIF6A-60DA-1.27DS(71) 631-0008-0 71 60 46.35 36.83 43.95 HIF6A-68DA-1.27DS(71) 631-0009-2 71 68 51.43 41.91 49.03 HIF6A-80DA-1.27DS(71) 631-0010-1 71 80 59.05 49.53 56.65 RoHS YES Number of Contacts 2 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Receptacle Straight Type with Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= BPCB mounting pattern Number of Contacts 2 (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side (26, 34, 50 contacts) BApplication Pattern (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side (26, 34, 50 contacts) Mounting hole center line Unit : mm No. of Contacts A B C D HIF6B-020DA-1.27DSA(71) 631-0151-3 71 20 30.95 26.67 11.43 18.55 HIF6B-026DA-1.27DSA(71) 631-0152-6 71 26 34.76 30.48 15.24 22.36 HIF6B-032DA-1.27DSA(71) 631-0153-9 71 32 38.57 34.29 19.05 26.17 HIF6B-034DA-1.27DSA(71) 631-0154-1 71 34 39.84 35.56 20.32 27.44 HIF6B-040DA-1.27DSA(71) 631-0155-4 71 40 43.65 39.37 24.13 31.25 HIF6B-050DA-1.27DSA(71) 631-0156-7 71 50 50.00 45.72 30.48 37.60 HIF6B-052DA-1.27DSA(71) 631-0157-0 71 52 51.27 46.99 31.75 38.87 HIF6B-060DA-1.27DSA(71) 631-0158-2 71 60 56.35 52.07 36.83 43.95 HIF6B-068DA-1.27DSA(71) 631-0159-5 71 68 61.43 57.15 41.91 49.03 HIF6B-080DA-1.27DSA(71) 631-0160-4 71 80 69.05 64.77 49.53 56.65 HIF6B-100DA-1.27DSA(71) 631-0161-7 71 100 81.75 77.47 62.23 69.35 Part No. *Lock pin type is also available. HRS No. RoHS YES B77 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Receptacle Straight Type without Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= (20, 32, 40, 52, 60, 68, 80, 100 contacts) BPCB mounting pattern Guide Key Side (26, 34, 50 contacts) BApplication Pattern (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side (26, 34, 50 contacts) Unit : mm Part No. B78 No. of Contacts A B C HIF6A-020DA-1.27DSA(71) 631-0101-5 71 HRS No. 20 20.95 11.43 18.55 HIF6A-026DA-1.27DSA(71) 631-0102-8 71 26 24.76 15.24 22.36 HIF6A-032DA-1.27DSA(71) 631-0103-0 71 32 28.57 19.05 26.17 HIF6A-034DA-1.27DSA(71) 631-0104-3 71 34 29.84 20.32 27.44 HIF6A-040DA-1.27DSA(71) 631-0105-6 71 40 33.65 24.13 31.25 HIF6A-050DA-1.27DSA(71) 631-0106-9 71 50 40.00 30.48 37.60 HIF6A-052DA-1.27DSA(71) 631-0107-1 71 52 41.27 31.75 38.87 HIF6A-060DA-1.27DSA(71) 631-0108-4 71 60 46.35 36.83 43.95 HIF6A-068DA-1.27DSA(71) 631-0109-7 71 68 51.43 41.91 49.03 HIF6A-080DA-1.27DSA(71) 631-0110-6 71 80 59.05 49.53 56.65 HIF6A-100DA-1.27DSA(71) 631-0111-9 71 100 71.75 62.23 69.35 RoHS YES Number of Contacts 2 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Pin Header Right Angle Type with Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= Number of Contacts 2 BPCB mounting pattern Mating Side BApplication Pattern (20, 32, 40, 52, 60, 68, 80, 100 contacts) Mating Side Mounting hole center line (26, 34, 50 contacts) Unit : mm No. of Contacts A B C D E HIF6B-020PA-1.27DS(71) 631-0251-8 71 20 30.95 20.95 18.75 11.43 26.67 HIF6B-026PA-1.27DS(71) 631-0252-0 71 26 34.76 24.76 22.56 15.24 30.48 HIF6B-032PA-1.27DS(71) 631-0253-3 71 32 38.57 28.57 26.37 19.05 34.29 HIF6B-034PA-1.27DS(71) 631-0254-6 71 34 39.84 29.84 27.64 20.32 35.56 HIF6B-040PA-1.27DS(71) 631-0255-9 71 40 43.65 33.65 31.45 24.13 39.37 HIF6B-050PA-1.27DS(71) 631-0256-1 71 50 50.00 40.00 37.80 30.48 45.72 HIF6B-052PA-1.27DS(71) 631-0257-4 71 52 51.27 41.27 39.07 31.75 46.99 HIF6B-060PA-1.27DS(71) 631-0258-7 71 60 56.35 46.35 44.15 36.83 52.07 HIF6B-068PA-1.27DS(71) 631-0259-0 71 68 61.43 51.43 49.23 41.91 57.15 HIF6B-080PA-1.27DS(71) 631-0260-9 71 80 69.05 59.05 56.85 49.53 64.77 HIF6B-100PA-1.27DS(71) 631-0261-1 71 100 81.75 71.75 69.55 62.23 77.47 Part No. πLock pin type is also available. HRS No. RoHS YES B79 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Pin Header Right Angle Type Without Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= BPCB mounting pattern Mating Side BApplication Pattern (20, 32, 40, 52, 60, 68, 80, 100 contacts) Mating Side (26, 34, 50 contacts) Unit : mm Part No. B80 No. of Contacts A B C HIF6A-020PA-1.27DS(71) 631-0201-0 71 HRS No. 20 20.95 18.75 11.43 HIF6A-026PA-1.27DS(71) 631-0202-2 71 26 24.76 22.56 15.24 HIF6A-032PA-1.27DS(71) 631-0203-5 71 32 28.57 26.37 19.05 HIF6A-034PA-1.27DS(71) 631-0204-8 71 34 29.84 27.64 20.32 HIF6A-040PA-1.27DS(71) 631-0205-0 71 40 33.65 31.45 24.13 HIF6A-050PA-1.27DS(71) 631-0206-3 71 50 40.00 37.80 30.48 HIF6A-052PA-1.27DS(71) 631-0207-6 71 52 41.27 39.07 31.75 HIF6A-060PA-1.27DS(71) 631-0208-9 71 60 46.35 44.15 36.83 HIF6A-068PA-1.27DS(71) 631-0209-1 71 68 51.43 49.23 41.91 HIF6A-080PA-1.27DS(71) 631-0210-0 71 80 59.05 56.85 49.53 HIF6A-100PA-1.27DS(71) 631-0211-3 71 100 71.75 69.55 62.23 RoHS YES Number of Contacts 2 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Pin Header Straight Type with Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= BPCB mounting pattern Number of Contacts 2 (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side (26, 34, 50 contacts) BApplication Pattern (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side Mounting hole center line (26, 34, 50 contacts) Unit : mm No. of Contacts A B C D E HIF6B-020PA-1.27DSA(71) 631-0351-2 71 20 30.95 26.67 20.95 11.43 18.75 HIF6B-026PA-1.27DSA(71) 631-0352-5 71 26 34.76 30.48 24.76 15.24 22.56 HIF6B-032PA-1.27DSA(71) 631-0353-8 71 32 38.57 34.29 28.57 19.05 26.37 HIF6B-034PA-1.27DSA(71) 631-0354-0 71 34 39.84 35.56 29.84 20.32 27.64 HIF6B-040PA-1.27DSA(71) 631-0355-3 71 40 43.65 39.37 33.65 24.13 31.45 HIF6B-050PA-1.27DSA(71) 631-0356-6 71 50 50.00 45.72 40.00 30.48 37.80 HIF6B-052PA-1.27DSA(71) 631-0357-9 71 52 51.27 46.99 41.27 31.75 39.07 HIF6B-060PA-1.27DSA(71) 631-0358-1 71 60 56.35 52.07 46.35 36.83 44.15 HIF6B-068PA-1.27DSA(71) 631-0359-4 71 68 61.43 57.15 51.43 41.91 49.23 HIF6B-080PA-1.27DSA(71) 631-0360-3 71 80 69.05 64.77 59.05 49.53 56.85 HIF6B-100PA-1.27DSA(71) 631-0361-6 71 100 81.75 77.47 71.75 62.23 69.55 Part No. *Lock pin type is also available. HRS No. RoHS YES B81 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■Pin Header Straight Type Without Mounting hole Unit : mm Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. n= BPCB mounting pattern (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side (26, 34, 50 contacts) BApplication Pattern (20, 32, 40, 52, 60, 68, 80, 100 contacts) Guide Key Side (26, 34, 50 contacts) Unit : mm Part No. B82 No. of Contacts A B C HIF6A-020PA-1.27DSA(71) 631-0301-4 71 HRS No. 20 20.95 11.43 18.75 HIF6A-026PA-1.27DSA(71) 631-0302-7 71 26 24.76 15.24 22.56 HIF6A-032PA-1.27DSA(71) 631-0303-0 71 32 28.57 19.05 26.37 HIF6A-034PA-1.27DSA(71) 631-0304-2 71 34 29.84 20.32 27.64 HIF6A-040PA-1.27DSA(71) 631-0305-5 71 40 33.65 24.13 31.45 HIF6A-050PA-1.27DSA(71) 631-0306-8 71 50 40.00 30.48 37.80 HIF6A-052PA-1.27DSA(71) 631-0307-0 71 52 41.27 31.75 39.07 HIF6A-060PA-1.27DSA(71) 631-0308-3 71 60 46.35 36.83 44.15 HIF6A-068PA-1.27DSA(71) 631-0309-6 71 68 51.43 41.91 49.23 HIF6A-080PA-1.27DSA(71) 631-0310-5 71 80 59.05 49.53 56.85 HIF6A-100PA-1.27DSA(71) 631-0311-8 71 100 71.75 62.23 69.55 RoHS YES Number of Contacts 2 HIF6 Series●1.27mm Pitch Two-Piece Connectors BConnection Circuit (20, 32, 40, 52, 60, 68, 80, 100 contacts) n= Connection of Cable 1 A1 2 B2 bn 1 ······ 1 bn ······ B1 ······ an an ······ A2 Number of Contacts Connection of Cable 2 An a1 Bn b1 Type A, A A1 b1 B1 a1 A2 b2 B2 a2 ······ ······ Connection of Cable 2 ······ Connection of Cable 1 ······ Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Type A, B An bn Bn an B83 HIF6 Series●1.27mm Pitch Two-Piece Connectors BConnection Circuit (26, 40, 50 contacts) n= Connection of Cable 1 A1 1 B2 bn 1 An a1 Bn b1 Type A, A Connection of Cable 1 B84 bn ······ B1 ······ an an ······ A2 Connection of Cable 2 ······ Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Type A, B Connection of Cable 2 A2 b2 B2 a2 ······ a1 ······ B1 ······ b1 ······ A1 An bn Bn an Number of Contacts 2 HIF6 Series●1.27mm Pitch Two-Piece Connectors BConnection Jig Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. ●Guide Plate ●Hi-Flex Connection Press Hi-Flex Connection Press HHP502 550 - 0082 - 2 HIF 6 - GPA 550 - 0165 - 8 *Pressing Block Part No. HRS No. Pressing Block A-01 550-0133-1 ●Cable Cutter ●Instruction Manual for HIF6 Connection Service Method HIF6 Cable Cutter-FC601 14 Pages 550 - 0166 - 0 B85 HIF6 Series●1.27mm Pitch Two-Piece Connectors ■HIF6 Series: Connection Type Coupled Connector HIF3B Series (MIL-C-83503) ●Compliant with the MIL standard ●The VA idea is reflected on both pin header and socket. ●Products with pull-out tab are available. ●Countermeasures are taken against noises in combination with the applicable cover case. ●The type aligned in single-row, low profile type, is available for pin header locking Oct.1.2018 Copyright 2018 HIROSE ELECTRIC CO., LTD. All Rights Reserved. system, in addition to standard products. Number of contacts: 6, 10, 14, 16, 20, 26, 30, 34, 40, 50, 60, 64 HIF2 Series (Board direct mount type) 12-row parallel type (HIF2E) Number of contacts: 10, 14, 16, 20, 26, 30, 34, 40, 50, 60 2.54mm grid alignment facilitates to the design pattern. 24-row staggered type (HIF2C) Number of contacts: 10, 14, 16, 20, 26, 30, 34, 40, 50, 60 Mounting height is 4.9mm low profile type. 1 HIF5 Series (Card edge ribbon type) ●Three types of full hole, semi-hole and no mount area are provided for the unit mount area. ●Connectors are connected in the bus line system. ●Cables can be returned within the connector mold width. Number of contacts: 20, 26, 34, 40, 50, 60 FD Series (D sub-ribbon connector) ●The standard pitch 1.27mm ribbon cable can be insulated and displaced by replacing a jig, in addition to the same pitch 1.38mm as for the D sub connector. ●The space saving type allows to reduce the thickness on the connection side according to set miniaturization. ●Connectors can be installed from both front and rear sides of the chassis or panel. Number of contacts: 9, 15, 25, 37 B86 Powered by TCPDF (www.tcpdf.org) 2
HIF6-50D-1.27R(02) 价格&库存
很抱歉,暂时无法提供与“HIF6-50D-1.27R(02)”相匹配的价格&库存,您可以联系我们找货
