GT16
GT13
GT5
Interface Connector
PO5G
GT10 Series
Features
Usable with existing 040 connectors.
Front retainer design prevents incomplete insertion.
GT9
GT8E
GT25
GT18W
GT10
GT7
GT3
GT32
GT17
GT11
GT36
GT26
GT21
GT15
Interface Connector
Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved.
GT19
— ECU Interface Connectors —
184
In cases where the application will demand a high level of reliability, such as automotive,
please contact a company representative for further information.
GT10 Series ● Interface Connector
GT5
F Connectors
GT13
Terminal
GT16
GT21
GT26
1.45
2.1
GT36
Part No.
GT10-2022SCF
GT10-2428SCF
HRS No.
760-0003-0
760-0009-6
Material
Plating
Copper palloy
Tin plating
Conductor Size (AWG)
20 to 22 AWG
24 to 28 AWG
Outer Diameter
φ1.1 to 1.3
φ0.8 to 1.1
A Dimension
Packaging
16.1
10,000 pcs/reel
15.1
RoHS
YES
GT11
GT17
Housing (with Retainer Provisionally Mounted)
BRetainer assembled.
GT32
Housing
GT3
Retainer
22
(21.65)
GT10
1.3
GT18W
14.5
11
19.15
P=2
19.15
HRS No.
RoHS
YES
GT9
Note: This product has the retainer provisionally mounted to the housing.
Note: To use, fully mount the retainer at the specified position after the
terminals have been inserted.
GT8E
Material/Plating or Color Packaging
Housing:PBT / Light Gray
GT10-16DS-HU 760-0002-7
1
Retainer:PBT / Dark Gray
Part No.
GT25
GT15
185
Interface Connector
GT7
GT19
A
21.1
PO5G
1.7
GT13
GT5
GT10S Series with cover case
Housing
19
BView with Cover Attached
GT16
34
13
25
22
(14)
11
GT21
GT26
Part No.
GT10S-16DS-HU
HRS No.
760-0007-0
Color
Light Gray
Material
PBT
Packaging
1
RoHS
YES
Note: This product should be used with the cover attached to the housing.
GT3
GT32
GT17
GT11
GT36
P=2
Cover
28
21
6
6
0.6
2.5
GT18W
GT25
186
0.3
0.3
GT10
25
25
GT7
28
21
.7
R3
.7
R3
GT8E
GT9
GT15
Interface Connector
GT19
22
PO5G
21
Cover A
Part No.
GT10S-16DS-CV
HRS No.
760-0008-3
Color
Black
Material
PC
Packaging
1
Cover B
RoHS
YES
Note 1 : This product can be used with cables having outside diameters of 4, 4.8, and 5.2 mm.
Note 1: Please use as a set in conjunction with clamp fittings and bushings that suit the cable.
Note 2 : This product is sold as a set with cover A, B, and screws.
GT5
Clamp Fittings
GT13
B
GT16
GT26
Bushings
GT36
GT11
GT17
15.8
GT32
HRS No.
Part No.
MQ138-BS (4.0) (01) 206-0890-4 01
MQ138-BS (4.8) (01) 206-0683-0 01
MQ138-BS (5.2) (01) 206-0662-0 01
Color
Material
Black
PCV
Outer diameter of the cable Packaging RoHS
φ4.0
1
YES
φ4.8
φ5.2
GT3
10.5
8.5
GT10
GT18W
GT25
GT8E
GT9
GT15
187
Interface Connector
GT7
Material A Dimension B Dimension Outer diameter of the cable Packaging RoHS
9
5.5
φ4.0
Brass
11.3
5.6
1
YES
φ4.8
12
5.6
φ5.2
GT21
HRS No
206-0891-7
206-0684-2
206-0664-5
GT19
Part No.
MQ138-CM (4.0)
MQ138-CM (4.8)
MQ138-CM (5.2)
PO5G
4.5
(A)
M Connectors
1.45
0.9
Terminal
2.1
0.64
23.35
6.5
GT21
GT26
HRS No.
760-0006-8
Material
Brass
Plating
Conductor Size (AWG) Outer Diameter
Tin plating 20 to 22 AWG
φ1.1 to 1.3
Packaging
10,000 pcs/reel
RoHS
YES
Housing
GT11
GT36
Part No.
GT10-2022PCF
12.6
13.6
GT17
24.6
GT32
P-2
15
GT3
GT7
GT10
GT10-16DP-R
Retainer
Packaging RoHS
GT10-16DP-R
YES
1
Retainer
Note: This product has a retainer provisionally attached to the housing.
At time of use, install the retainer all the way to the specified position after the terminal has been inserted.
Part No.
HRS No.
Color
GT10-16DP-HU 760-0004-2 Light Gray
Material
PBT
Retainer (Only for GT10-16DP-HU)
GT25
10
3
5
GT18W
24.4
1.7
GT9
GT8E
P=2
GT15
Interface Connector
GT19
28.35
PO5G
GT16
GT13
GT5
188
Part No.
GT10-16DP-R
HRS No.
Color
760-0005-5 Dark Gray
Material
PBT
Packaging RoHS
YES
1
GT5
Board Type
3
6.5
3.25
GT13
BRecommended PCB pattern
4.75
18
14
10
6
2
24.6
PO5G
29.2
16
-φ
1
35.6
29.2
GT16
3.5
2-φ
φ
2.
3
GT19
13.6
5
4
GT21
P=2
18
GT26
BMated condition
GT36
Part No.
HRS No.
GT10-16DP-DS(70)
760-0001-4 70
Terminal:Brass / Tin plating
Packaging
RoHS
1
YES
T=1.6
(22.45)
(6.65)
Note : Use class 4 JIS B 1115 and 1122 mounting screws and diameter 3. length 6
(for a board thickness of 1.6mm).
Board
3
Note
GT10-16DS-HU
GT11
GT17
B Crimping tools
GT32
User manuals are available. Please contact your Hirose Electric account representative.
Automatic Crimping Machine
Specifications
Picture reference only
Item
Specification
Remarks
Stroke Length
30mm
200spm (50Hz)
Weight
75kg
Motor
0.2kw
Crimping speed
2,000 to 4,000 pcs/hour
240spm (60Hz)
AC100V
GT10
Number of strokes
GT18W
GT25
Part No. CM-105C
Harness tool
Terminal HRS No.
760-0003-0
760-0006-8
765-0009-6
Tool Part No.
AP105-GT10-2022S
AP105-GT10-2022P
AP105-GT10-2428S
Tool HRS No.
901-5016-8
901-5049-7
901-5063-4
GT8E
Terminal Part No.
GT10-2022SCF
GT10-2022PCF
GT10-2428SCF
GT9
GT15
189
Interface Connector
1.5tons
GT7
Press capacity
GT3
15.8
很抱歉,暂时无法提供与“GT10-16DP-R”相匹配的价格&库存,您可以联系我们找货
