QR/P15-8S-C(50)
QR/P15-8S-C(50)
    HRS(广濑)
    CONNSOCKETHOUSING8POS
QR/P15-8S-C(50) 数据手册
Ultra-small Rack/Panel Crimp Connectors QR/P15 Series Separate connection to panel-mounted connectors Crimp terminated wires Connector 1 A 7 Panel Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Receptacle Plug Panel 1 A 7 Connector Crimp terminated wires Fig.1 Overview Expansion of the proven QR/P Series with a separate panel-mounted plugs / receptacles connecting with detachable crimp terminated connectors. Plugs / receptacles can be mounted on the panels and the terminated connectors may be inserted at later time, allowing wire crimp termination to be done away from the equipment. Available in 8 or 24 pos (with 4 positions for power contacts) and 40 pos. Features 1. Two piece part structure The main connector body is not directly terminated with individual or discrete wires, but allows for cabled, sub-assembly connector groups to be plugged and unplugged to it. This separate structure of a main connector body and sub-assemblies allows harnesses to be preassembled, and simplifies the installation of both the sub-assenblies and rack and panel mounting. 2. Sequential contact mating structure Sequential contact mating is featured on the 40-position version, with two contacts on each side of the connector. This provides better grounding and improved safety. 3. Accepts power supply connections (24-position only) The 24-position connectors incorporate power supply contacts. The power supply connections use an MDF6 Series 4-position connector (3.5mm pitch, UL and CSA recognized, and can handle 6A a current using 16 AWG conductors. Wire termination can also be accomplished with an automatic crimping machine. 4. Reliable connections Two-point contacts assure highly reliable electrical and mechanical connection. In cases where the application will demand a high level of reliability, such as automotive, please contact a company representative for further information. 2021.2e 1 QR/P15 Series●Ultra-small Rack/Panel Crimp Connectors Product Specifications Ratings Signal : 1 A Power : 6 A 30V AC/ DC Current rating Voltage rating Item 1. Insulation resistance 2. Withstanding voltage 3. Contact resistance Specification 1,000Mø min. No flashover or insulation breakdown 50mø max. 8 pos. 0.8 N min. 8 N max. 24 pos. 2.8 N min. 28 N max. 40 pos. 4.0 N min. 40 N max. 4. Mating/ Unmating forces Conditions 500V DC 500V AC / 1minute 100mA Measured when mated with corresponding connector 1,000 cycles No damage, cracks or parts dislocation. Frequency : 10 to 55 Hz, single amplitude of 0.75mm, No electrical discontinuity of 10µs or longer 3 directions for 2 hours No damage, cracks or parts dislocation. 2 Acceleration of 490m/s , 11ms duration, No electrical discontinuity of 10µs or longer sine half-wave, 3 cycles in each of the 3 axis No damage, cracks or parts dislocation. No damage, cracks or parts dislocation. Contact resistance : 60mø max. Temperature : -55 → +5 to 35 → +85 → +5 to 35ç Insulation resistance : 1,000Mø min. Time : 30 → 5 → 30 → 5 min. 5 cycles Contact resistance : 60mø max. No damage, cracks or parts dislocation. Insulation resistance : 1,000Mø min. 96 hours at 40ç, R.H. 90% to 95% Contact resistance : 60mø max. 96 hours at a concentration of 3 ppm 5. Durability Contact resistance : 60mø max. 6. Vibration Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. Operating temperature range : -10°C to +60°C 7. Shock 8. Temperature cycle 9. Humidity (Steady state) 10. Hydrogen sulfide Materials Plug Part Insulator Contacts Pin socket Shoulder Screw Material PBT Phosphor bronze Polyamide Steel Finish Color: Black Selective gold plated Color: Black, white (Natural)* Nickel plated Remarks UL94V-0 --------------UL94V-0 --------------- Material PBT Phosphor bronze Polyamide Finish Color: Black Selective gold plated Color: Black, white (Natural)* Remarks UL94V-0 --------------UL94V-0 Receptacle Part Insulator Contacts Pin socket *Insulator bodies for the MDF6 connectors in the 24-position power supply connector will be white. Product Number Structure QR / P15 - 24 (4) P - C (50) q w e t q Series name : QR/P15 w Number of contacts : 8, 24, 40 e Number of power contacts r Connector type t Series number y Specification number 2 r y : 4 (24 position connector only) P : Plug S : Receptacle QR/P15 Series●Ultra-small Rack/Panel Crimp Connectors Connector Mating Charts and Wiring Termination Tables P side (Plug) 8-pos. S side (Receptacle) 1 7 7 1 7 1 A A 7 1 DF11 crimp termination connector DF11 crimp termination connector QR/P15-8P-C Part No. No. of contacts HRS No. DF11-8DS-2C 543-0503-0 8 pos. Signal (DF11 connector) P side 1 3 5 7 2 4 6 8 S side 7 5 3 1 8 6 4 2 Remarks RoHS 8 Yes Wire connection in applicable connectors P side (Plug) 24-pos. S side (Receptacle) DF11 crimp termination connector DF11 crimp termination connectorv 1 1 9 19 1 A 9 9 1 1 A 19 1 9 2 4 MDF6 crimp termination connector MDF6 crimp termination connector QR/P15-24(4)P-C QR/P15-24(4)S-C 20 pos. Signal (DF11 connector) Part No. No. of RoHS contacts HRS No. DF11-20DS-2C 543-0509-7 20 MDF6-4DS-3.5C 543-0074-1 4 Remarks 4 pos.Power (MDF6 connector) Yes Wire connection in applicable connectors P side (Plug) 40-pos. P side 1 3 5 ~ 15 17 19 2 4 6 ~ 16 18 20 S side 19 17 15 ~ 5 3 1 20 18 16 ~ 6 4 2 P side 1 2 3 4 S side 3 4 1 2 S side (Receptacle) 2 2 9 1 0 1 1 A 18 1 8 17 9 1 0 1 2 9 1 2 2 2 0 1 A 1 2 2 1 7 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. QR/P15-8S-C 21 22 DF11 crimp termination connector DF11 crimp termination connector QR/P15-40P Part No. HRS No. No. of RoHS contacts DF11-18DS-2C 543-0508-4 18 DF11-22DS-2C 543-0510-6 22 Yes QR/P15-40S 18 pos. Signal (DF11 connector) Remarks Wire connection in applicable connectors P side 1 3 5 ~ 13 15 17 2 4 6 ~ 14 16 18 S side 2 4 6 ~ 14 16 18 1 3 5 ~ 13 15 17 22 pos. Signal (DF11 connector) P side 1 3 5 ~ 17 19 21 2 4 6 ~ 18 20 22 S side 2 4 6 ~ 18 20 22 1 3 5 ~ 17 19 21 Note : Refer to the Nylon Connector Catalog for details about the wire terminations used in DF11 and MDF6 connectors. 3 QR/P15 Series●Ultra-small Rack/Panel Crimp Connectors Plugs 8 pos. 34 10.7 3 17.1 12 1.9 26.6 M3∞0.5 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8.1 Screw (Supplied not-attached) (0.5mm float) Part No. QR/P15-8P-C(50) HRS No. 221-0247-0 50 RoHS Yes QR/P15-8P-C 12.6 24 pos. 59 23.7 3 17.1 10.7 12 2.4 51.6 M3∞0.5 HRS No. RoHS QR/P15-24(4)P-C(70) 221-0249-6 70 Yes 10.5 8.1 Part No. Screw (Supplied not-attached) (0.5mm float) QR/P15-24(4)P-C 18.5 22.25 40 pos. 69.4 10.7 3 17.1 12 2.4 62 Part No. QR/P15-40P(50) HRS No. 221-0252-0 50 RoHS Yes 8.1 M3∞0.5 Screw (Supplied not-attached) (0.5mm float) QR/P15-40P 48 4 QR/P15 Series●Ultra-small Rack/Panel Crimp Connectors Receptacles 8 pos. 34 2- Ø3 26.6 HRS No. 221-0248-3 50 8.1 Part No. QR/P15-8P-C(50) RoHS Yes QR/P15-8S-C 12.6 24 pos. 59 2- Ø3 51.6 0.5 23.8 3 17.4 8 10.5 12 2.4 .2 10.5 HRS No. 221-0250-5 70 RoHS Yes 8.1 Part No. QR/P15-24(4)S-C(70) QR/P15-24(4)S-C 18.5 40 pos. 22.25 69.4 2- Ø3 62 12 2.4 .2 HRS No. 221-0253-3 50 RoHS Yes 0.5 8.1 Part No. QR/P15-40S(50) 3 8 10.5 Sequence terminal 17.4 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 0.5 3 17.4 8 10.5 12 1.9 1.9 .2 QR/P15-40S 48 5 QR/P15 Series●Ultra-small Rack/Panel Crimp Connectors Applicable panel thickness : 1.5mm to 3.0mm Panel cutouts Mating side Mating side Front panel Rear panel Q R / P15-8P-C (50) Q R /P 1 5 - 8 S - C ( 5 0 ) Front panel Front panel 26.6 26.6 .7 12.8 3.1 .5 M3∞0.5 .5 2.7 1.9 3.1 R0 R3 .3 .5 R0 16 R0 M3∞0.5 3.1 1.9 12.7 1.9 3.1 18.6 R R3 .5 .7 R0 11.6 R3 11.3 3. 25 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. 8 pos 16 11.6 17.8 12.6 Rear panel Rear panel 26.6 R2 1.9 .1 26.6 15.1 8.8 M3∞0.5 R0 .5 1.9 1.9 2.3 M3∞0.5 .5 R0 R2 .5 1.9 9.6 2.3 14.1 15.9 13.3 24 pos QR/ P15-24(4)P-C (50) Q R /P 1 5 - 2 4 ( 4 ) S - C ( 5 0 ) Front panel Front panel 51.6 42.8 Rear panel Rear panel 51.6 51.6 6 .5 R0 18.85 8.8 12.7 4.75 2.4 13.5 2.4 2.4 9.6 M3∞0.5 4.3 M3∞0.5 2.4 41.7 42.5 19.25 5 0. R 3.1 2.4 .3 R3 41 25.2 M3∞0.5 .25 R3 12.7 3.1 .5 R0 41 25.3 .5 R0 2.4 3.1 13.5 . R3 3.1 2.4 2.4 7 7 2.7 23.7 43.6 R3. 51.6 M3∞0.5 24.1 QR/P15 Series●Ultra-small Rack/Panel Crimp Connectors QR/P15-40P(50) QR/P 1 5 -4 0 S (5 0 ) Front panel Front panel 62 05 R2. 8.45 .7 R2 48.2 2.4 2.4 9.75 2.3 2.4 25.85 2.3 R3 .45 62 2.4 2.4 2.4 12.65 3.1 3.15 2.4 Rear panel M3∞0.5 3.1 2.5 R0 R3. 75 .3 R0 25.7 53 62 26.5 3 0. R Rear panel 49.5 R0 .5 30.55 .5 30.35 M3∞0.5 28.95 R0 29.45 .3 R0 .5 13.65 3.1 2.4 5 .9 Mated condition (Shown for reference) Note : The distance between the plug and receptacle when fully mated must be 1.5mm max. as shown below. Plug 1.5mm MAX Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. .5 R0 54 R3 M3∞0.5 62 M3∞0.5 29.45 R3 .45 40 pos. Receptacle Float – Plug (Shown for reference) Note : Floating distance for shoulder screw is ± 0.5mm. Float: ± 0.5 mm Panel 7 Dec.1.2022 Copyright 2022 HIROSE ELECTRIC CO., LTD. All Rights Reserved. QR/P15 Series●Ultra-small Rack/Panel Crimp Connectors USA: HIROSE ELECTRIC (U.S.A.), INC. HEADQUARTERS CHICAGO OFFICE 2300 Warrenville Road, Suite 150, Downers Grove, IL 60515 Phone : +1-630-282-6700 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. SAN JOSE OFFICE 2841 Junction Ave, Suite 200 San Jose, CA. 95134 Phone : +1-408-253-9640 Fax : +1-408-253-9641 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. DETROIT OFFICE (AUTOMOTIVE) 17197 N. Laurel Park Drive, Suite 253, Livonia, MI 48152 Phone : +1-734-542-9963 Fax : +1-734-542-9964 http://www.hirose.com/us/ USA: HIROSE ELECTRIC (U.S.A.), INC. BOSTON OFFICE 300 Brickstone Square Suite 201, Andover, MA 01810 Phone : +1-978-662-5255 THE NETHERLANDS: HIROSE ELECTRIC EUROPE B.V. Hogehillweg #8 1101 CC Amsterdam Z-O Phone : +31-20-6557460 Fax : +31-20-6557469 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. GERMAN BRANCH Schoenbergstr. 20, 73760 ostfildern Phone : +49-711-456002-1 Fax : +49-711-456002-299 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. NUREMBERG OFFICE Neumeyerstrasse 22-26, 90411 Nurnberg Phone : +49-911 32 68 89 63 Fax : +49-911 32 68 89 69 http://www.hirose.com/eu/ GERMANY: HIROSE ELECTRIC EUROPE B.V. HANOVER OFFICE Bayernstr. 3, Haus C 30855 Langenhagen, Germany Phone : +49-511 97 82 61 30 Fax : +49-511 97 82 61 35 http://www.hirose.com/eu/ FRANCE: HIROSE ELECTRIC EUROPE B.V. PARIS OFFICE 130 Avenue Joseph Kessel, Bat E, 78960 Voisins le Bretonneux, France Phone : +33-1-85764886 Fax : +33-1-85764823 http://www.hirose.com/eu/ UNITED KINGDOM: HIROSE ELECTRIC EUROPE BV (UK BRANCH) 4 Newton Court, Kelvin Drive, Knowlhill, Milton Keynes, MK5 8NH Phone : +44-1908 202050 Fax : +44-1908 202058 http://www.hirose.com/eu/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. (SHANGHAI, HEADQUARTERS) 18, Enterprise Center Tower 2, 209# Gong He Road, Jing’an District, Shanghai, CHINA 200070 Phone : +86-21-6391-3355 Fax : +86-21-6391-3335 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO.,LTD. BEIJING BRANCH A1001, Ocean International Center, Building 56# East 4th Ring Middle Road, ChaoYang District, Beijing, 100025 Phone : +86-10-5165-9332 Fax : +86-10-5908-1381 http://www.hirose.com/cn/ CHINA: HIROSE ELECTRIC (CHINA) CO., LTD. SHENZHEN BRANCH Room 09-13, 19/F, Office Tower Shun Hing Square, Di Wang Commercial Centre, 5002 Shen Nan Dong Road, Shenzhen City, Guangdong Province, 518008 Phone : +86-755-8207-0851 Fax : +86-755-8207-0873 http://www.hirose.com/cn/ HONG KONG: HIROSE ELECTRIC HONGKONG TRADING CO., LTD. Room 1001, West Wing, Tsim Sha Tsui Centre, 66 Mody Road, Tsim Sha Tsui East, Kowloon, Hong Kong Phone : +852-2803-5338 Fax : +852-2591-6560 http://www.hirose.com/hk/ TAIWAN: HIROSE ELECTRIC TAIWAN CO., LTD. 103 8F, No.87, Zhengzhou Rd., Taipei Phone : +886-2-2555-7377 Fax : +886-2-2555-7355 http://www.hirose.com/tw/ KOREA: HIROSE KOREA CO.,LTD. 143, Gongdan 1-daero, Siheung-si, Gyeonggi-do, 15084, Korea Phone : +82-31-496-7000 Fax : +82-31-496-7100 http://www.hirose.co.kr/ SINGAPORE: INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. DELHI LIAISON OFFICE HIROSE ELECTRIC SINGAPORE PTE. LTD. 03, Anson Road, #20-01, Springleaf Tower, Office NO.552, Regus-Green Boulevard, Level5, Tower C, Sec62, Plot B-9A, Block B, Noida, 201301, Uttar Pradesh, India Singapore 079909 Phone : +91-12-660-8018 Phone : +65-6324-6113 Fax : +91-120-4804949 Fax : +65-6324-6123 http://www.hirose.com/sg/ http://www.hirose.com/sg/ INDIA: HIROSE ELECTRIC SINGAPORE PTE. LTD. BANGALORE LIAISON OFFICE Unit No-403, 4th Floor, No-84, Barton Centre, Mahatma Gandhi (MG) Road, Bangalore 560 001, Karnataka, India Phone : +91-80-4120 1907 Fax : +91-80-4120 9908 http://www.hirose.com/sg/ MALAYSIA: THAILAND: PENANG REPRESENTATIVE OFFICE BANGKOK OFFICE (REPRESENTATIVE OFFICE) 73-3-1, Ideal@The One, Jalan Mahsuri, Bayan Unit 4703, 47th FL., 1 Empire Tower, South Sathorn Road, Yannawa, Sathorn, Bangkok 10120 Thailand Lepas Penang, 11950, Malaysia Phone : +66-2-686-1255 Phone : +604-648-5536 Fax : +66-2-686-3433 http://www.hirose.com/sg/ http://www.hirose.com/sg/ ® 8 2-6-3,Nakagawa Chuoh,Tsuzuki-Ku,Yokohama-Shi 224-8540,JAPAN TEL: +81-45-620-3526 Fax: +81-45-591-3726 http://www.hirose.com http://www.hirose-connectors.com The characteristics and the specifications contained herein are for reference purpose. Please refer to the latest customer drawings prior to use. The contents of this catalog are current as of date of 02/2021. Contents are subject to change without notice for the purpose of improvements.
QR/P15-8S-C(50) 价格&库存
很抱歉,暂时无法提供与“QR/P15-8S-C(50)”相匹配的价格&库存,您可以联系我们找货
