AS3649
2500mA High Current LED Flash Driver
1 General Description
2 Key Features
The AS3649 is an inductive high efficient DCDC step up converter
with two current sources. The DCDC step up converter operates at a
fixed frequency of 4MHz and includes soft startup to allow easy
integration into noise sensitive RF systems. The two current sources
can operate in flash / torch or video light modes.
High efficiency 4MHz fixed frequency DCDC Boost converter
The AS3649 includes flash timeout, overvoltage, overtemperature,
undervoltage and LED short/open circuit protection functions. A
TXMASK/TORCH function reduces the flash current in case of
parallel operation to the RF power amplifier and avoids a system
shutdown. Alternatively this pin can be used to directly operate the
torch light directly. If the TXMask function is not used, it can be used
as a hardware torch input (programmable).
Automatic current adjustment for low battery voltage
A hardware NTC pin can be used to measure the LED temperature
with the ADC and to automatically reduce the LED current if a
temperature threshold is exceeded.
2
The AS3649 is controlled by an I C interface and has a hardware
reset pin ON. Setting ON=0 resets the AS3649. Interface input
voltage levels are 1.8V compliant.
The AS3649 is available in a space-saving WL-CSP package
measuring only 2.06x2.02x0.6mm and operates over the -30ºC to
+85ºC temperature range.
with soft start allows small coils
- Stable even in coil current limit
LED current adjustable up to 2x1000mA(2x1250mA with current
boost) or 2000mA and automatic load balancing for two LEDs
PWM operation for lower output current for reliable light output
of the LED; can run at 31.5kHz to avoid audible noise
Protection functions:
Automatic Flash Timeout timer to protect the LED(s)
Overvoltage and undervoltage Protection
Overtemperature Protection
ADC to measure LED temperature
NTC to automatically reduce the flash current if the LED
temperature is too high (programmable level)
2
I
C Interface with hardware reset pin
Available in tiny WL-CSP Package, 16 balls 0.5mm pitch,
2.06x2.02x0.6mm package size
3 Applications
Flash/Torch for mobile phones
Figure 1. Typical Operating Circuit
www.ams.com/AS3649
(01$
AS3649
1.0-2
1 - 39
AS3649
Datasheet - P i n A s s i g n m e n t s
4 Pin Assignments
Figure 2. Pin Assignments (Top View)
AS3649
4.1 Pin Description
Table 1. Pin Description for AS3649
1
Pin Number
Pin Name
A1
PGND2
Power ground; make a short connection between all GND balls
A2
PGND1
A3
VIN
A4
ON
B1
SW2
DCDC converter switching node - make a short connection to SW1 / coil LDCDC
B2
SW1
DCDC converter switching node - make a short connection to SW2 / coil LDCDC
B3
NTC
LED temperature sensor input (NTC) for LED overtemperature protection
B4
TXMASK/TORCH
Description
Positive supply voltage input - connect to supply and make a short connection to input capacitor
CVIN and to coil LDCDC
Hardware reset input; an active low signal resets the registers of AS3649 and enters shutdown
2
(and I C lines SDA and SCL are in high-Z), active high allows to operate the device
Function 1: Connect to RF power amplifier enable signal - reduces currents during flash to avoid
a system shutdown due to parallel operation of the RF PA and the flash driver
2
Function 2: Operate torch current level without using the I C interface to operate the torch
2
without need to start a camera processor (if the I C is connected to the camera processor
C1
VOUT2
DCDC converter output capacitor - make a short connection to CVOUT / VOUT1
C2
VOUT1
DCDC converter output capacitor - make a short connection to CVOUT / VOUT2
www.ams.com/AS3649
1.0-2
2 - 39
AS3649
1
Pin Number
Pin Name
Description
C3
SCL
serial clock input for I C interface
C4
SDA
serial data input/output for I C interface (needs external pullup resistor)
D1
LED_OUT2
Flash LED current source
D2
LED_OUT1
D3
AGND
Analog ground; make a short connection between all GND balls
D4
STROBE
Digital input with pulldown to control strobe time for flash function
2
2
1. Final pinout subject to change - now only used to count number of pins
www.ams.com/AS3649
1.0-2
3 - 39
AS3649
Datasheet - A b s o l u t e M a x i m u m R a t i n g s
5 Absolute Maximum Ratings
Stresses beyond those listed in Table 2 may cause permanent damage to the device. These are stress ratings only, and functional operation of
the device at these or any other conditions beyond those indicated in Electrical Characteristics on page 5 is not implied. Exposure to absolute
maximum rating conditions for extended periods may affect device reliability.
Table 2. Absolute Maximum Ratings
Parameter
Min
Max
Units
VIN to GND
-0.3
+7.0
V
STROBE, TXMASK/TORCH, SCL, SDA, ON, NTC to
GND
-0.3
VIN + 0.3
V
SW1/2, VOUT1/2, LED_OUT1/2 to GND
-0.3
+7.0
V
VOUT1/2 to SW1/2
-0.3
voltage between AGND, PGND1/2 pins
0.0
Input Pin Current without causing latchup
-100
Comments
max. +7V
V
Note: Diode between VOUT1/2 and SW1/2
0.0
V
short connection required
+100
+IIN
mA
Norm: EIA/JESD78
Continuous power dissipation
1470
mW
PT at 70ºC
Continuous power dissipation derating factor
mW/ºC
PDERATE
ESD HBM
±2000
V
Norm: JEDEC JESD22-A114F
ESD CDM
±500
V
Norm: JEDEC JESD 22-C101E
Continuous Power Dissipation (TA = +70ºC)
1
2
Electrostatic Discharge
Temperature Ranges and Storage Conditions
Junction to ambient thermal resistance
50
ºC/W
For more information about thermal metrics, see
application note AN01 Thermal Characteristics
Junction Temperature
+150
ºC
Internally limited (overtemperature protection),
max. 20000s
3
Storage Temperature Range
-55
+125
ºC
Humidity
5
85
Non condensing
+260
ºC
according to IPC/JEDEC J-STD-020
Body Temperature during Soldering
Moisture Sensitivity Level (MSL)
MSL 1
Represents a max. floor life time of unlimited
1. Depending on actual PCB layout and PCB used measured on demoboard; for peak power dissipation during flashing see document
'AS3649 Thermal Measurements'
2. PDERATE derating factor changes the total continuous power dissipation (PT) if the ambient temperature is not 70ºC. Therefore for e.g.
TAMB=85ºC calculate PT at 85ºC = PT - PDERATE * (85ºC - 70ºC)
3. Measured on AS3649 demoboard.
www.ams.com/AS3649
1.0-2
4 - 39
AS3649
Datasheet - E l e c t r i c a l C h a r a c t e r i s t i c s
6 Electrical Characteristics
VVIN = +2.7V to +4.4V, TAMB = -30ºC to +85ºC, unless otherwise specified. Typical values are at VVIN = +3.7V, TAMB = +25ºC, unless otherwise
specified.
Table 3. Electrical Characteristics
Symbol
Parameter
Condition
Min
Typ
Max
Unit
3.7
4.4
V
General Operating Conditions
VVIN
Supply Voltage
Pin VIN
2.7
VVINREDUCED_
Supply Voltage
AS3649 functionally working, but not all parameters
fulfilled
2.5
2.7
4.4
5.5
ISHUTDOWN
Shutdown Current
TXMASK/TORCH=L, STROBE=L, ON=L, VVIN= CCh)
www.ams.com/AS3649
1.0-2
22 - 39
AS3649
Datasheet - D e t a i l e d D e s c r i p t i o n
Table 9. Current Set LED2 Register
Addr: 2
Bit
Bit Name
This register defines design versions
Default
Access
Description
Define the current on pin LED_OUT2;
torch mode uses bits 5:0 of this current setting (max. 1/4 of full current
setting)
indicator or low current pwm mode uses only 5:0 of this current setting
(max. 1/4 of full current setting)
Note: Always keep led_current1 >= led_current2
led_current2
7:0
9Ch
R/W
0h
0mA
1h
7.8mA
2h
11.7mA
3Fh
250mA (maximum current for torch light mode, indicator or low
current pwm mode,
mode_setting=01 or 10)
7Fh
500mA
9Ch
613.3mA - default setting
FEh
996mA (1245mA if current_boost=1)
FFh
1000mA (1250mA if current_boost=1)
1
1
1. Only use current_boost=1 for currents > 1000mA(code >= CCh)
Table 10. TXMask Register
TXMask Register
Addr: 3
Bit
Bit Name
This register defines the TXMask settings and coil peak current
Default
Access
Description
Defines operating mode for input pin TXMASK/TORCH
1:0
txmask_torch_mode
00
00
pin has no effect
01
txmask-mode; during flash if TXMASK/TORCH=1, the LED
current is set to flash_txmask_current - (see TXMASK on page
15)
10
external torch mode: if TXMASK/TORCH=1 and
mode_setting=00, the AS3649is set into external torch mode
1
(LED current is defined by the 6LSB bits of led_current1 and
led_current2)
11
don’t use
R/W
Defines the maximum coil current (parameter ILIMIT)
3:2
www.ams.com/AS3649
coil_peak
10
R/W
00
ILIMIT = 2.5A
01
ILIMIT = 2.9A
10
ILIMIT = 3.3A
11
ILIMIT = 3.7A
1.0-2
23 - 39
AS3649
Table 10. TXMask Register (Continued)
TXMask Register
Addr: 3
Bit
Bit Name
Default
Access
Description
Define the current on pin LED_OUT1 and LED_OUT2 (each current
source) in flash mode if txmask_torch_mode=01 and TXMASK/
TORCH=1
7:4
2
6h
R/W
0h
0mA
1h
31mA (39mA if current_boost=1)
2h
63mA (78mA if current_boost=1)
3h
94mA (118mA if current_boost=1)
4h
125mA (157mA if current_boost=1)
5h
157mA (196mA if current_boost=1)
6h
188mA (235mA if current_boost=1) - default
7h
220mA (275mA if current_boost=1)
8h
251mA (314mA if current_boost=1)
9h
282mA (353mA if current_boost=1)
Ah
314mA (392mA if current_boost=1)
Bh
345mA (431mA if current_boost=1)
Ch
376mA (471mA if current_boost=1)
Dh
408mA (510mA if current_boost=1)
Eh
439mA (549mA if current_boost=1)
Fh
471mA (588mA if current_boost=1)
1. The MSB bit of this register not used to protect the LED; therefore the maximum current = 1/4 the maximum flash current
2. If current_boost=1, the LED current is increased by 25%.
Table 11. Low Voltage / NTC Register
Addr: 4
Bit
Bit Name
This register defines the operating mode with low battery voltages
Default
Access
Description
Voltage level on VIN where current reduction triggers during operation
(see Current Reduction by VIN Measurements in Flash Mode and
Diagnostic Pulse on page 15) - only in flash mode; if VIN drops below
this voltage during current ramp up, the current ramp up is stopped;
during operation the current is decreased until the voltage on VIN rises
above this threshold - status_uvlo is set
2:0
www.ams.com/AS3649
vin_low_v
4h
R/W
0h
function is disabled
1h
3.0V
2h
3.07V
3h
3.14V
4h
3.22V - default
5h
3.3V
6h
3.38V
7h
3.47V
1.0-2
24 - 39
AS3649
Table 11. Low Voltage / NTC Register (Continued)
Addr: 4
Bit
Bit Name
Default
Access
Description
Enable overtemperature protection on pin NTC (internal comparator
comparing NTC to VNTC_TH)
3
ntc_on
R/W
disabled
1
enabled
Current through the NTC (INTC); it is enabled once the LED current
source (LED_OUT1/2) is operating and ntc_on=1 or the ADC measures
the LED temperature (see NTC - Flash LED Overtemperature Protection
on page 14)
7:4
www.ams.com/AS3649
ntc_current
8h
R/W
0h
off;
can be used to use an external
current to bias the NTC
1h
40µA
2h
80µA
3h
120µA
4h
160µA
5h
200µA
6h
240µA
7h
280µA
8h
320µA - default
9h
360µA
Ah
400µA
Bh
440µA
Ch
480µA
Dh
520µA
Eh
560µA
Fh
600µA
1.0-2
25 - 39
AS3649
Table 12. Flash Timer Register
Addr: 5
Bit
This register identifies the flash timer and timeout settings
Bit Name
Default
Access
Description
Define the duration of the flash timer and timeout timer
5:0
flash_timeout
1
26h
R/W
00h … 4ms
01h … 8ms
02h … 12ms
03h … 16ms
04h … 20ms
05h … 24ms
06h … 28ms
07h … 32ms
08h … 36ms
09h … 40ms
0Ah … 44ms
0Bh … 48ms
0Ch … 52ms
0Dh … 56ms
0Eh … 60ms
0Fh … 64ms
10h … 68ms
11h … 72ms
12h … 76ms
13h … 80ms
14h … 84ms
15h … 88ms
2Bh … 484ms
2Ch … 516ms
2Dh … 548ms
2Eh … 580ms
2Fh … 612ms
30h … 644ms
31h … 676ms
32h … 708ms
33h … 740ms
34h … 772ms
35h … 804ms
36h … 836ms
37h … 868ms
38h … 900ms
39h … 932ms
3Ah … 964ms
3Bh … 996ms
3Ch … 1028ms
3Dh … 1060ms
3Eh … 1092ms
3Fh … 1124ms
16h … 92ms
17h … 96ms
18h … 100ms
19h … 104ms
1Ah … 108ms
1Bh … 112ms
1Ch … 116ms
1Dh … 120ms
1Eh … 124ms
1Fh … 128ms
20h … 132ms
21h … 164ms
22h … 196ms
23h … 228ms
24h … 260ms
25h … 292ms
26h … 324ms
27h … 356ms
28h … 388ms
29h … 420ms
2Ah … 452ms
1. Internal calculation for codes above 20h: flash timeout [ms] = (flash_timeout-32) * 32 + 132 [ms]
Table 13. Control Register
Control Register
Addr: 6
Bit
Bit Name
This register identifies the operating mode and includes an all on/off bit
Default
Access
Description
Define the AS3649 operating mode - see Table 5, “Operating Mode and
Current Settings,” on page 14
standby/shutdown or external torch mode if
txmask_torch_mode (page 23)=10
00
indicator mode (or low current mode using PWM)
01
1:0
mode_setting
00
R/W
1
led_current2 pwm modulated defined by register inct_pwm
(31.5kHz: 1/16...4/16, 7.9kHz: 1/64...3/64)
torch light mode:
10
2
led_current2
flash mode:
LED current is defined by led_current1 and led_current2
(mode_setting is automatically cleared after a flash pulse)
11
www.ams.com/AS3649
1.0-2
26 - 39
AS3649
Table 13. Control Register (Continued)
Control Register
Addr: 6
Bit
Bit Name
Default
Access
Description
Increase min. on time of DCDC converter - use for diagnostic pulse, if
freq_switch_on=1.
If this register is not 00 and freq_switch_on=1, the DCDC converter will
use 4MHz operation forced PWM mode or pass-through mode but will
not switch to 1MHz operation
3:2
min_on_increase
00
R/W
00
100% - default min. on time
01
108%
10
131%
11
157%
Force DCDC operation even in pass-through mode - use for diagnostic
pulse, if freq_switch_on=1
4
force_dcdc_on
R/W
DCDC is only enabled when needed; default
1
DCDC is always enabled even when pass-though mode could be
used
Increase voltage compliance of current source for diagnostic pulses see Short Diagnostic Pulse on page 16
vcompl_adj
7:5
000b
R/W
000
default - 0mV
001
14mV (26mV if current_boost=1)
010
29mV (51mV if current_boost=1)
011
43mV (77mV if current_boost=1)
100
57mV (103mV if current_boost=1)
101
71mV (129mV if current_boost=1)
110
85mV (154mV if current_boost=1)
111
100mV (180mV if current_boost=1)
1. The two MSB bits of this register are not used to protect the LED; therefore the maximum indicator (or low current mode using PWM)
light current = 1/4 the maximum flash current multiplied by the duty cycle defined by inct_pwm
2. The two MSB bits of this register not used to protect the LED; therefore the maximum torch light current = 1/4 the maximum flash current
Table 14. Strobe Signalling / ADC Register
Addr: 7
Bit
Bit Name
This register defines the flash current reducing and mode for STROBE
Default
Access
Description
Select ADC channel for conversion
3:0
www.ams.com/AS3649
adc_channel
000b
R/W
000
NTC
001
TJUNC
010
VIN
1.0-2
27 - 39
AS3649
Table 14. Strobe Signalling / ADC Register (Continued)
Addr: 7
Bit
Bit Name
Default
Access
Description
Start ADC conversion
adc_convert
4
R/W
ADC conversion finished
1
Start ADC conversion - once finished the register bit is
automatically reset and the result is stored in adc_result
Allow pulseskip operation of DCDC - see Table 4 on page 12
5
dcdc_skip_enable
1
R/W
Disabled - force 4MHz (1MHz) operation
1
Enabled - can use pulseskip
1
Defines if the STROBE input is edge or level sensitive; see also bit
strobe_on (page 28)
strobe_type
6
1
R/W
STROBE input is edge sensitive
1
STROBE input is level sensitive
Enables the STROBE input
strobe_on
7
1
R/W
STROBE input disabled
1
STROBE input enabled
in flash mode
1. Exception depending on freq_switch_on (see page 29) - see Table 4 on page 12
Table 15. Fault Register
Fault Register
Addr: 8
Bit
2
3
Bit Name
status_uvlo
reserved
fault_ntc
fault_txmask
This register identifies all the different fault conditions and provide information about the
LED detection
Default
Access
R/sC
1
Description
an undervoltage event has happened - see Current Reduction by VIN
Measurements in Flash Mode and Diagnostic Pulse on page 15
No
1
Yes
R
R/sC
R/sC
reserved - don’t use
1
1
LED overtemperature detection hit - see NTC - Flash LED
Overtemperature Protection on page 14
No
1
Yes
TXMASK/TORCH event triggered during flash - see TXMASK event
occurred on page 13
No
1
Yes
see Flash Timeout on page 14
4
www.ams.com/AS3649
fault_timeout
R/sC
1
No fault
1
Flash timeout exceeded
1.0-2
28 - 39
AS3649
Table 15. Fault Register (Continued)
Fault Register
Addr: 8
Bit
LED detection
Bit Name
Default
Access
Description
see Overtemperature Protection on page 13
5
fault_overtemp
R/sC
1
No fault
1
Junction temperature limit has been exceeded
see Short Circuit Protection on page 13
6
fault_led_short
R/sC
1
No fault
1
A shorted LED is detected (pin LED_OUT1/2)
see Overvoltage Protection on page 13
fault_ovp
7
R/sC
1
No fault
1
An overvoltage condition is detected (pin VOUT)
1. R/sC = Read, self clear; after readout the register is automatically cleared
Table 16. PWM and Indicator Register
Addr: 9
Bit
This register defines the PWM mode (e.g. for indicator) and 4/1MHz mode switching
Bit Name
Default
Access
Description
Define the AS3649 PWM with 31.5kHz or 7.9kHz operation for indicator
or low current mode (mode_setting=01)
1
2:0
inct_pwm
00
R/W
000
1/16 duty cycle / 31.5kHz
001
2/16 duty cycle / 31.5kHz
010
3/16 duty cycle / 31.5kHz
011
4/16 duty cycle / 31.5kHz
100
1/64 duty cycle / 7.9kHz; needs const_v_mode=1 (additional
quiescent current)
101
2/64 duty cycle / 7.9kHz; needs const_v_mode=1
(additional quiescent current)
110
3/64 duty cycle / 7.9kHz; needs const_v_mode=1
111
(4/64 duty cycle / 7.9kHz) don’t use; use 000 setting instead
Exact frequency switching between 4MHz/1MHz for operation close to
maximum
pulsewidth - see Table 4 on page 12
3
freq_switch_on
www.ams.com/AS3649
R/W
Pulseskip operation is allowed depending on dcdc_skip_enable
(see page 28)
1
if led_current1>=40h or led_current2>=40h and current_boost=0,
the DCDC is running at 4MHz or 1MHz and pulseskip is disabled results in improved noise performance
1.0-2
29 - 39
AS3649
Table 16. PWM and Indicator Register (Continued)
Addr: 9
Bit
4
Bit Name
Default
load_balance_on
Access
R/W
Description
Balance the current sources (up to +/-15% of set current) to improve
application efficiency for unmatched LED forward voltages - see Load
Balancing on page 17
disabled
1
enabled
Enables Constant output voltage mode
5
const_v_mode
Normal operation defined by mode_setting
1
5V constant voltage mode on VOUT1/2;
LED current can be controlled by registers mode_setting,
led_current1 and led_current2 as in normal operating mode, but
the ramping up/down of the current sources is disabled
(instantaneous on/off of the LED current)
R/W
1. Using 31.5kHz modulation avoids audible noise on the output capacitor CVOUT
Table 17. ADC Result Register
ADC Result Register
Addr: Ah
This register reports the actual set LED current
Bit
Bit Name
Default
Access
Description
7:0
adc_result
NA
R
Result of ADC conversion for channel adc_channel
Table 18. ADC Result LSBs Register
Addr: Bh
Bit
Bit Name
Default
Access
Description
1:0
adc_result_lsbs
NA
R
Table 19. Minimum LED Current Register
Addr: Eh
Bit
7:0
This register reports the minimum LED current from the last operation cycle
Bit Name
led_current_min
Default
123
00h
Access
Description
R
Diagnostic Pulse (see page 15) and Figure 20 on page 16
1. Only the current through LED_OUT1 is reported.
2. As the internal change of this register is asynchronous to the readout, it is recommended to readout the register after the flash pulse.
The register will store the minimum current through the LED after e.g. a previous flash. This current can be used for a subsequent flash
pulse for a safe operating range.
3. This register is only set if an actual current reduction happens (status_uvlo (see page 28)=1) otherwise led_current_min=0.
www.ams.com/AS3649
1.0-2
30 - 39
AS3649
Table 20. Actual LED Current Register
Addr: Fh
Bit
7:0
Bit Name
led_current_actual
12
Default
Access
Description
00h
R
Actual set current through the current source (including all current
reductions as described in Flash Current Reductions (see page 15)
including LED current ramp up/down)
2. As the internal change of this register is asynchronous to the readout, it is recommended to readout the register twice and compare the
results.
Table 21. Unlock Register Register
Addr: 80h
Protection for register Current Boost
Bit
Bit Name
Default
Access
Description
7:0
unlock
NA
W
Write 55h into this register to enable access to register 81h
Table 22. Current Boost Register
Addr: 81h
Bit
Increase output current by 25%
Bit Name
Default
Access
Description
Boost all LED currents by 25%
current_boost
1
R/W
all LED current are as described in the tables
1
all LED current are increased by 25%
2
1. Write 55h into register unlock (0x80) to enable access to this register (unlocking is only valid for the next I C access) - required on any
write access to this register
www.ams.com/AS3649
1.0-2
31 - 39
AS3649
8.10 Register Map
Table 23. Register Map
Register Definition
1
Addr
Default
Name
Content
b7
b6
b5
b4
b3
ChipID
Cxh
Current Set LED1
1
9Ch
led_current1
Current Set LED2
2
9Ch
led_current2
TXMask
3
68h
Low Voltage / NTC
4
84h
ntc_current
Flash Timer
5
26h
Control
6
00h
Strobe Signalling /
ADC
7
E0h
dcdc_skip adc_conv
strobe_on strobe_ty
pe
_enable
ert
Fault
8
00h
fault_over fault_time fault_txm
fault_ovp fault_led_
short
temp
out
ask
PWM and Indicator
9
00h
const_v_ load_bala freq_switc
mode
nce_on
h_on
ADC Result
Ah
NA
ADC Result LSBs
Bh
NA
Minimum LED Current
Eh
00h
led_current_min
Actual LED Current
Fh
00h
led_current_actual
Unlock Register
80h
00h
unlock
Current Boost
81h
00h
b2
fixed_id
b1
b0
version
coil_peak
txmask_torch_mode
ntc_on
vin_low_v
flash_timeout
force_dcd
c_on
vcompl_adj
min_on_increase
mode_setting
adc_channel
fault_ntc
reserved status_uvl
o
inct_pwm
adc_result
adc_result_lsbs
current_b
oost
1. Always write’0’ to undefined register bits
www.ams.com/AS3649
1.0-2
32 - 39
AS3649
Datasheet - A p p l i c a t i o n I n f o r m a t i o n
9 Application Information
9.1 External Components
9.1.1
Input Capacitor CVIN
Low ESR input capacitors reduce input switching noise and reduce the peak current drawn from the battery. Ceramic capacitors are required for
input decoupling and should be located as close to the device as is practical.
Table 24. Recommended Input Capacitor
Part Number
C
TC Code
Rated
Voltage
Size
Manufacturer
GRM188R60J106ME47
10µ
>3µF@4.5V
>2µF@5.25V
X5R
6V3
0603
Murata
www.murata.com
LMK107BBJ106MA
10µ
>3µF@4.5V
X5R
6V3
0603
Taiyo Yuden
www.t-yuden.com
If a different input capacitor is chosen, ensure similar ESR value and at least 3µF capacitance at the maximum input supply voltage. Larger
capacitor values (C) may be used without limitations.
Add a smaller capacitor in parallel to the input pin VIN (e.g. Murata GRM155R61C104, >50nF @ 3V, 0402 size).
9.1.2
Output Capacitor CVOUT
Low ESR capacitors should be used to minimize VOUT ripple. Multi-layer ceramic capacitors are recommended since they have extremely low
ESR and are available in small footprints. The capacitor should be located as close to the device as is practical.
X5R dielectric material is recommended due to their ability to maintain capacitance over wide voltage and temperature range.
Table 25. Recommended Output Capacitor
Part Number
C
TC Code
Rated
Voltage
Size
GRM219R61A106ME47
10µF +/-10%
>4.2µF@5V
X5R
10V
0805 (2.0x1.25x0.85mm
max 1mm height)
22µF
>4.2µF@4.5V
X5R
6.3V
0805
(2.0x1.25x1.25mm
max. 1.4mm height)
10µF +/-20%
>4.2µF@4V
X5R
6.3V
0603
(1.6x0.8x0.85mm
max. 0.95mm height)
GRM21BR60J226M
1
GRM188R60J106ME84
2
Manufacturer
Murata
www.murata.com
1. Use only for VLED < 4.1V
2. Use only for VLED < 3.75V
If a different output capacitor is chosen, ensure similar ESR values and at least 4.2µF capacitance at 5V output voltage.
www.ams.com/AS3649
1.0-2
33 - 39
AS3649
9.1.3
Inductor LDCDC
The fast switching frequency (4MHz) of the AS3649 allows for the use of small SMDs for the external inductor. The saturation current
15
ISATURATION should be chosen to be above the maximum value of ILIMIT . The inductor should have very low DC resistance (DCR) to reduce
2
the I R power losses - high DCR values will reduce efficiency.
Table 26. Recommended Inductor
Part Number
L
DCR
ISATURATION
Size
Manufacturer
LQM32PN1R0MG0
1.0µH
>0.6µH @ 3.0A
60m
3.0A
3.2x2.5x0.9mm
max 1.0mm
height
Murata
www.murata.com
SPM4012T-1R0M
1.0µH +/-20%
38m
4.57A
4.4x4.1x1.2
mm
height is max
2
3.2x3x1.2
mm
height is max
4
3.2x2.5mm
max 1.0mm
height
4
3.2x2.5x0.9mm
max 1.0mm
height
3
2.4x2.4x1.2mm
(height is max.)
4
2.5x2.0x1.2mm
height is max
1
SPM3012T-1R0M
1.0µH +/-20%
57m
+/-10%
3.4A
CIG32W1R0MNE
1.0µH
>0.7µH @ 2.7A
>0.6µH @ 3.0A
60m
+/-25%
3.0A
CKP3225N1R0M
1.0µH
>0.6µH @ 3.0A
0.6µH @ 2.5A
77m
2.5A
MAMK2520T1R0M
1.0µH
>0.6µH @ 2.75A
45m
3.1A
TDK
www.tdk.com
Samsung Electro-Mechancs
www.sem.samsung.co.kr
Taiyo Yuden
www.t-yuden.com
1. Flash pattern: 200ms/3A, 200ms pause, 200ms/3A, 2s then repeat again (no limit on the number of total cycles)
Alternative pattern with 1000ms/1.6A, 200ms pause, 200ms/3A, 200ms pause, 200ms/3A, 2s then repeat again. (no limit on the number
of total cycles). Use only up to coil_peak=2.9A setting
2. Inductance changes by -30%, use only up to coil_peak=3.3A setting
3. Use only for coil_peak=2.5A setting.
4. Use only up to coil_peak=2.9A setting.
If a different inductor is chosen, ensure similar DCR values and at least0.6µH inductance at ILIMIT.
9.1.4
Thermistor (NTC)
The NTC is used to protect the LED against overheating (hardware protection inside the AS3649, which works without any software - see NTC Flash LED Overtemperature Protection on page 14).
The thermistor has to be thermally coupled to the LED (and therefore as close as possible to the LED) and it shall not share the same ground
connection as the LED return ground (if they share the same ground connection the high current through the LED will offset the measurement of
the NTC).
Table 27. Recommended Thermistors
Part Number
Resistance @ 25ºC
B-constant 25/50ºC
NCP03WL224E05RL
220k +/-3%
4485K +/-1%
NCP03WL104E05RL
100k +/-3%
4485K +/-1%
NCP15WF104F03RC
100k
NCP15WL683J03RC
68k
Size
Manufacturer
0201
Murata
www.murata.com
0402
It is recommended to use 220k resistance for a detection threshold of 125ºC, 100k for 110ºC and 68k for 80ºC LED temperature detection
threshold.
15.Can be adjusted in I2C mode with register coil_peak (see page 23)
www.ams.com/AS3649
1.0-2
34 - 39
AS3649
9.2 PCB Layout Guideline
The high speed operation requires proper layout for optimum performance. Route the power traces first and try to minimize the area and wire
length of the two high frequency/high current loops:
Loop1: CVIN/CVIN2 - LDCDC - pin SW1/2 - pin GND - CVIN/CVIN2
Loop2: CVIN/CVIN2 - LDCDC - pin SW1/2 - pin VOUT1/2 - CVOUT - pin GND - CVIN/CVIN2
At the pin GND a single via (or more vias, which are closely combined) connects to the common ground plane. This via(s) will isolate the DCDC
high frequency currents from the common ground (as most high frequency current will flow between Loop1 and Loop2 and will not pass the
ground plane) - see the ‘island’ in Figure 31.
Figure 31. Layout Recommendation
+,-./,-01
*4
* /2+1
5*
234
234,
Note: If component placement rules allow, move all components close to the AS3649 to reduce the area and length of Loop1 and Loop2.
It is recommended to use the main ground plane for the LED ground connections (improved thermal performance of the LEDs) - it is
recommend to use a separate ground line as shown Figure 31 for the ground connection of the NTC (this avoids errors for the temperature measurement of the LEDs due to the high LED current in the main ground plane).
Keep the LED path (from pin LED_OUT1/2 to the LED and the ground return path) below 10cm (represents an inductance of less than
100nH).
An additional 100nF (e.g. Murata GRM155R61C104, >50nF @ 3V, 0402 size) capacitor CVIN2 in parallel to CVIN is recommended to filter high
frequency noise for the power supply of AS3649. This capacitor should be as close as possible to the AGND/VIN pins of AS3649.
www.ams.com/AS3649
1.0-2
35 - 39
AS3649
9.3 5V Operating Mode
The AS3649 can be used to power a 5V system (e.g. audio amplifier). The operating mode is selected by setting register bit
const_v_mode (page 30)=1.
Note: There is always a diode between VIN and VOUT1/2 due to the internal circuit. Therefore VOUT1/2 cannot be completely switched off
Figure 32. 5V Operating Mode
AS3649
www.ams.com/AS3649
1.0-2
36 - 39
AS3649
Datasheet - P a c k a g e D r a w i n g s a n d M a r k i n g s
10 Package Drawings and Markings
Figure 33. WL-CSP16 Marking
Note:
Line 1:
Line 2:
Line 3:
ams AG logo
AS3649
Encoded Datecode (4 characters)
Figure 34. WL-CSP16 Package Dimensions
The coplanarity of the balls is 40µm.
www.ams.com/AS3649
1.0-2
37 - 39
AS3649
Datasheet - O r d e r i n g I n f o r m a t i o n
11 Ordering Information
The devices are available as the standard products shown in Table 28.
Table 28. Ordering Information
Ordering Code
AS3649-ZWLT
Description
Delivery Form
Package
Tape & Reel
16-pin WL-CSP
(2.06x2.02x0.6mm)
0.5mm pitch
RoHS compliant / Pb-Free / Green
Z Temperature Range: -30ºC - 85ºC
WL Package: Wafer Level Chip Scale Package (WL-CSP) 2.06x2.02x0.6mm
T Delivery Form: Tape & Reel
Note: All products are RoHS compliant and ams green.
Buy our products or get free samples online at www.ams.com/ICdirect
Technical Support is available at www.ams.com/Technical-Support
For further information and requests, email us at sales@ams.com
(or) find your local distributor at www.ams.com/distributor
www.ams.com/AS3649
1.0-2
38 - 39
AS3649
Copyrights
Copyright © 1997-2013, ams AG, Tobelbaderstrasse 30, 8141 Unterpremstaetten, Austria-Europe. Trademarks Registered ®. All rights
reserved. The material herein may not be reproduced, adapted, merged, translated, stored, or used without the prior written consent of the
copyright owner.
All products and companies mentioned are trademarks or registered trademarks of their respective companies.
Disclaimer
Devices sold by ams AG are covered by the warranty and patent indemnification provisions appearing in its Term of Sale. ams AG makes no
warranty, express, statutory, implied, or by description regarding the information set forth herein or regarding the freedom of the described
devices from patent infringement. ams AG reserves the right to change specifications and prices at any time and without notice. Therefore, prior
to designing this product into a system, it is necessary to check with ams AG for current information. This product is intended for use in normal
commercial applications. Applications requiring extended temperature range, unusual environmental requirements, or high reliability
applications, such as military, medical life-support or life-sustaining equipment are specifically not recommended without additional processing
by ams AG for each application. For shipments of less than 100 parts the manufacturing flow might show deviations from the standard
production flow, such as test flow or test location.
The information furnished here by ams AG is believed to be correct and accurate. However, ams AG shall not be liable to recipient or any third
party for any damages, including but not limited to personal injury, property damage, loss of profits, loss of use, interruption of business or
indirect, special, incidental or consequential damages, of any kind, in connection with or arising out of the furnishing, performance or use of the
technical data herein. No obligation or liability to recipient or any third party shall arise or flow out of ams AG rendering of technical or other
services.
Contact Information
Headquarters
ams AG
A-8141 Unterpremstaetten, Austria
Tel
Fax
: +43 (0) 3136 500 0
: +43 (0) 3136 525 01
For Sales Offices, Distributors and Representatives, please visit:
http://www.ams.com/contact
www.ams.com/AS3649
1.0-2
39 - 39
