Data Sheet
AS3605
Multi-Standard Power Management Unit
1 General Description
The AS3605 is a highly-integrated CMOS power management
device designed specifically for portable devices such as mobile
phones, PDAs, CD players, digital cameras and other devices
powered by 1-cell Li-Ion battery. It can be used for any mobile phone
handset standards such as CDMA, WCDMA, GSM, GPRS, EDGE,
UTMS and other Japanese or American standards.
The device incorporates low dropout regulators (LDOs), a DC/DC
converter, a complete battery charger, and an audio power amplifier
on one die.
The linear analog LDOs feature extremely high performance
regarding:
- Noise – typ 30µ VRMS from 100Hz to 100kHz
- Line/Load Regulation – < 1mV static, < 10mV transient
- Power Supply Rejection – > 70dB @ 1kHz
The integrated Step Down DC/DC Converter does not require an
external Schottky diode yet provides very high efficiency (up to 95%)
throughout the whole operating range.
5 programmable current sources are included to control LED
brightness.
A low-distortion audio power amplifier (1 Watt @ 8Ω) supports
handsfree operation and HiFi ring-tones.
The device also features a battery charger including automatic trickle
charging, and programmable constant voltage and current charging.
The AS3605 is controlled via a serial interface and integrates all
necessary system specific functions such as Reset, Watchdog, and
Power-On Detection.
Output voltages and start-up timings can be programmed via the
internal OTP.
Battery Charger
Automatic Trickle Charging
Programmable Constant Current Charging
Programmable Constant Voltage Charging
Safety Functions (Low Battery Shutdown)
Over- and Under-Temperature Charge Disable
Operation without Battery
Can Regulate the Current Through the Battery or from the
Charger
- Charger Input Overvoltage Protection (6V)
- Shutdown even with Connected Charger
- Charger Resume Operation
- Charger Interrupts (Inserted, Removed, Overvoltage,
Resume)
- No-Battery Detection
Momentary Power Loss Detection
- Battery Supply Short-Interruption Detection ( 200 @ 0.8A
RSENSE
Current sense resistor
100mΩ ±1%, 125mW for ICHG < 1.5A
e.g. Vishay Dale WSL0805
CCHRG
Bypass capacitor on charger pin
10µ F ±20%, X5R or X7R dielectric
CBAT
Minimum total capacitance parallel to
battery
10µ F, X5R or X7R dielectric
www.austriamicrosystems.com
1.00
11 - 73
AS3605 1v2
Data Sheet - D e t a i l e d D e s c r i p t i o n
7.1.1
Charge Controller Operating Modes and Building Blocks
Charge Adapter Detection. The charge controller uses an integrated detection circuit to determine if an external charge adapter has been
applied to the VCHARGER pin. If the adapter voltage exceeds the battery voltage at pin VBAT by VCHDET the ChDet bit in the ChargerStatus
register will be set. The detection circuit will reset the charge controller (bit ChDet is cleared) as soon as the voltage at the VCHARGER pin
drops to only VCHMIN above the battery voltage. In case the AS3605 device is reset the charge controller will also be reset, even if a charge
adapter is applied to the VCHARGER pin.
Low Current (trickle) Charging. Trickle charge mode is started when an external charge adapter has been detected and the battery voltage
at pin VBAT is below the VUVLO threshold; bits ChAct and Trickle will be set in the ChargerStatus register. In this mode the charge current
will be limited to TrickleCurrent[1:0] (set in the ChargerControl1 register) to prevent undue stress on either the battery or any of the charger
components in case of deeply discharged batteries. Once VUVLO has been exceeded, the charger will change over to constant current charging
(Trickle is cleared) and switch on the device.
Constant Current Charging. Constant current charging is initiated by setting ChEn in the ChargerControl1 register. Note that ChEn is
set by default to enable operation of the device without a battery connected to the system. The ChAct bit is set when the charger has started,
and the charge current will be limited to ConstantCurrent[3:0] (set in the ChargerControl1 register) by the battery charge controller. When
the battery approaches full charge, its voltage will exceed the charge termination threshold VCHOFF. VCHOFF depends on the Li4v2 bit in the
ChargerControl2 register. The charging action will either be terminated (EOC bit will be set) or a top-off charge will be started (CVM will be
set).
Constant Voltage Charging. Constant voltage charge mode is initiated and the CVM bit will be set when the VCHOFF threshold has been
reached.
The charge current is monitored during constant voltage charging. It will be decreasing from its initial value during constant current charging and
eventually drop below the value set by TrickleCurrent[1:0] in the ChargerControl1 register. If the measured charge current is less than or
equal to TrickleCurrent[1:0], the charging cycle is terminated and EOC is set.
Battery Presence Indication and Operation Without Battery. After EOC state is reached a timer for NOBAT detection is started. If
there is no battery present, the voltage will drop to VNOBAT_REG. Depending on the load on VBAT and the capacitor on VBAT this might take
some mseconds to 1 second. If the RESUME mode is enabled (Bit resume_disable=0), the charger will restart charging (ConstantCurrent
charging) after 100msec.
The 100msec dead time is necessary to get a battery oscillation frequency of below 10Hz, if there is no battery present.
If the NOBAT detection timer is below 2 seconds after reaching EOC state, and this happens 2 times in serial, the NOBAT bit in ChargerStatus
register is set. If a battery is inserted, then the bit will be reset after the timer exceeds the 2 seconds.
Charger Overvoltage Protection. This blocks checks if the charger voltage is above 6.05V or 6.45V if ChOvH is 1. If the status bit ChOv
is 1 when ChOvEn is 1, the charger will shut down by clearing the ChEn bit and an interrupt will be generated.
Table 5. Charger Parameters
Symbol
VCHDET
VCHMIN
Parameter
Charger detection threshold
VCHOVH
VCHARGER overvoltage detection
VUVLO
Undervoltage lockout threshold
VCHOFF
Charge termination threshold
VNOBATREG
“No battery” regulation voltage
VRESUME_ON
Charger resume on threshold
Min
Typ
Max
50
75
105
6.2
6.45
6.71
5.81
6.05
6.29
3.1
4.20
mV
V
V
2.8
4.158
Unit
4.242
4.10
3.85
V
V
3.75
3.85
V
3.75
1.00
Notes
Hysteresis is > 40mV
ChOvH = 1
ChOvH = 0
VBAT rising
VBAT falling
Li+ Battery: Li4v2 = 1
Li+ Battery: Li4v2 = 0
Li4v2 = 1
Li4v2 = 0
12 - 73
AS3605 1v2
Symbol
Parameter
VRESUME_OFF
Charger resume off threshold
IGATE_OFF
Current into pin GATE, if charger
disabled
IGATE_ON
enabled and operation in low dropout
mode (low VCE)
3.5
7.1.2
Min
Typ
Max
Unit
4.02
V
3.92
0.4
5
Notes
Li4v2 = 1
Li4v2 = 0
µA
VCHARGER=5V
mA
VCHARGER=5V
Charger Registers
Table 6. Charger Register Summary
Name
Addr.
LDO_CHG
10h
ChargerControl1
14h
b7
b6
b5
b4
b3
b2
b1
b0
EOCCurrent[1:0]
ChOvEn
TrickleCurrent[1:0]
ChargerControl2
16h
ChOv
ChOvH
NA
Li4v2
resume_d
isable
ChargerStatus
35h
NA
NoBat
EOC
CVM
Trickle
Page
14
ChEn
13
14
NA
ChAct
ChDet
15
ChargerControl1 Register (Address 14h).
ChargerControl1
Addr: 14h
Bit
Bit Name
Default
Access
ChEn
1b
R/W
4:1
OTP
R/W
Bit Description
Disable charging
1
Enable charging
0mA + Trickle_current
1
50mA + Trickle_current
2
100mA + Trickle_current
3
150mA + Trickle_current
4
200mA + Trickle_current
5
250mA + Trickle_current
6
300mA + Trickle_current
7
350mA + Trickle_current
8
400mA + Trickle_current
9
450mA + Trickle_current
A
500mA + Trickle_current
B
550mA + Trickle_current
C
600mA + Trickle_current
D
650mA + Trickle_current
E
700mA + Trickle_current
F
750mA + Trickle_current
1.00
13 - 73
AS3605 1v2
ChargerControl1
Addr: 14h
Bit
6:5
7
Bit Name
Default
TrickleCurrent[1:0]
Access
OPT
ChOvEn
R/W
1
R/W
Bit Description
50mA
1
100mA
2
150mA
3
200 mA
Disable the Charger Overvoltage protection
1
Enable the Charger Overvoltage protection
LDO_CHG Register (Address 10h).
LDO_CHG
Addr: 10h
Bit
3:2
Adjusts EOC current of Charger.
Bit Name
EOCCurrent[1:0]
Default
Access
00
R/W
Bit Description
00
EOC Current = Trickle Current
01
EOC Current = Trickle Current + 18mA
10
do not use
11
EOC Current = Trickle Current + 33mA
ChargerControl2 Register (Address 16h).
ChargerControl2
Addr: 16h
Bit
Bit Name
Default
Access
2:0
NA
NA
3
resume_disable
R/W
4
Li4v2
1
R/W
5
NA
NA
6
7
ChOvH
ChOv
1
NA
Bit Description
Enable Resume in EOC state
1
Disable Resume in EOC state
VCHOFF = 4.1V for Li+ battery cells with coke anode
1
VCHOFF = 4.2V for Li+ battery cells with graphite anode
Sets low threshold for Over voltage protection
(typ. 6.05V)
1
Sets high threshold for Over voltage protection
(typ. 6.45V)
R/W
R
Indicates Charger overvoltage condition
1.00
14 - 73
AS3605 1v2
ChargerStatus Register (Address 35h).
ChargerStatus
Addr: 35h
Read only
Bit
Bit Name
Default
Access
ChDet
NA
R
Bit is set when external charge adapter has been detected
1
ChAct
NA
R
Bit is set when charger is operating
2
NA
3
Trickle
NA
R
Bit is set when charger is in trickle charge mode
4
CVM
NA
R
Bit is set when charger is in top-off charge mode
5
EOC
NA
R
Bit is set when charging has been terminated. Bit is cleared
automatically when ChEn is cleared.
6
NoBat
NA
R
Bit is set when battery detection circuit indicates that no battery is
connected to the system. Bit is cleared automatically when a battery is
connected or when ChEn is cleared.
7
NA
NA
Bit Description
1.00
15 - 73
AS3605 1v2
7.2 Step Down DC/DC Converter
The step-down converter is a high-efficiency fixed frequency current mode regulator. By using low resistance internal PMOS and NMOS
switches, efficiency up to 95% can be achieved. The fast switching frequency allows using small inductors, without increasing the current ripple.
The unique feedback and regulation circuit guarantees optimum load and line regulation over the whole output voltage range, up to an output
current of 500mA, with an output capacitor of only 10µ F. The implemented current limitation protects the DC/DC Converter and the coil during
overload condition.
Figure 5. Step Down DC/DC Converter Block Diagram
170mA
IMIN
buck_dis_curmin
2.2MHz
VBAT2
800mA
ILIMIT
ISENSP
C16
1µF
Overvoltage
Comparator
Ref + 8%
Skip
PSW
buck_dis_pon
LX
Ref - 4%
Logic
L2
2.2µH
100%
Duty Cycle
NSW
VOUT
C18
10µF
PWM
Comparator
GND_PAD
ISENSN
Zero
Comparator
Σ
VBUCK
AS3605
Ref = 0.6V
buck_v
Skip
Softstart
Slope
Compensation
1.00
16 - 73
AS3605 1v2
Table 7. Step Down DC/DC Converter Parameters
Symbol
Parameter
Min
Typ
Max
Unit
VIN
Input Voltage
VOUT
Regulated Output Voltage
VOUT_TOL
Output Voltage Tolerance
ILIMIT
Current Limit
3.0
5.5
V
Pin VBAT_2
0.6
3.4
V
Sense pin VBUCK
-50
50
mV
-3%
3%
RPSW
PSW On-Resistance
0.5
Ω
RNSW
NSW On-Resistance
0.5
Ω
ILOAD
Load Current
500
mA
fSW
Switching Frequency
2.2
MHz
COUT
Output Capacitor
10
µF
Lx
Inductor
2.2
µH
h
Efficiency
90
900
Current Consumption
100
Sense pin VBUCK; Output Voltage < 1.6V
Sense pin VBUCK; Output Voltage > 1.6V
mA
Supply current into PMOS transistor
Ceramic
ILOAD = 100mA, VOUT = 2.3V,
VBAT = 3V
Operating Current; No Load
250
IVDD_DCDC
Notes
µA
Quiescent Current; Low-Power Mode
Shutdown Current
0.1
tMIN_ON
Minimum ON Time
80
ns
tMIN_OFF
Minimum OFF Time
40
ns
To allow optimized performance in different applications, there are bit settings possible, to get the best compromise between high efficiency and
low input/output ripple.
7.2.1
Low-Ripple, Low-Noise Operation
Low-ripple, low-noise operation can be enabled by setting bit buck_dis_curmin = 1. In this mode there is no minimum coil current necessary
before switching OFF the PMOS. As result, the ON time of the PMOS will be reduced down to tMIN_ON at no or light load conditions, even if the
coil current is very small or the coil current is inverted. This results in a very low ripple and noise (but decreased efficiency) at light loads,
especially at low input-to-output voltage differences.
Note: Because of the inverted coil current in that case the regulator will not operate in pulse skip mode.
1.00
17 - 73
AS3605 1v2
Figure 6. Bit buck_dis_curmin = 1 Operation
LX Voltage
Coil Current (1mV=1mA)
VOUT
7.2.2
High-Efficiency Operation (Default Setting)
High-efficiency operation is enabled by setting bit buck_dis_curmin = 0. In this mode there is a minimum coil current necessary before
switching OFF the PMOS. As result there are less pulses at low output load necessary, and therefore the efficiency at low output load is
increased. This results in higher ripple, and noisy pulse skip operation up to a higher output current.
Figure 7. Bit buck_dis_curmin = 0 Operation
LX Voltage
VOUT
Note: It is possible to switch between these two modes during operation, i.e.:
Bit buck_dis_curmin = 0: System is in idle state. No audio or RF signal. Decreased supply current preferred. Increase ripple doesn't effect
system performance.
1.00
18 - 73
AS3605 1v2
Bit buck_dis_curmin = 1: System is operating. Audio signal on and/or RF signal used. Decreased ripple and noise preferred. Increased power
supply current can be tolerated.
7.2.3
100% PMOS ON Mode for Low Dropout Regulation
For low input-to-output voltage difference bit buck_dis_pon can be set to allow 100% duty cycle of the PMOS transistor, if the output voltage
drops by more than 4% below regulation.
7.2.4
Low Power Mode
Bit buck_lpo can be set all the time. This mode allows internal power down, of not used blocks during pulseskip mode, which results in a better
efficiency at light output loads.
7.2.5
Typical Performance Characteristics
Figure 8. DC/DC Step-Down Efficiency vs. Output Current (buck_dis_cfm = 0)
DCDC buck Efficiency @2MHz, 3.6V VBAT2
100
95
Efficiency [%]
90
85
80
Vbuck @ 1,2V
75
Vbuck @ 1,8V
Vbuck @ 2.5V
70
Vbuck @ 1.2V lpo = 1
Vbuck @ 1.8V lpo = 1
65
Vbuck @ 2.5V lpo = 1
60
1
10
100
1000
Output Current [mA]
7.2.6
Step Down DC/DC Converter Registers
The Step Down DC/DC Converter is controlled by the registers listed in Table 8.
Table 8. Step Down DC/DC Converter Register Summary
Name
Addr.
b7
b6
b5
b4
Step Down Voltage/Test
Modes
01h
Reg Power
09h
buck_on
ldo_sim_
on
Step Down Configuration
17h
buck_dis_ buck_
curmin
dis_pon
buck_lpo
b3
b2
b1
b0
buck_v
1.00
ldo_ana2_ ldo_ana1
on
_on
buck_
dis_n
Page
buck_
nsw_on
buck_
psw_on
AS3605 1v2
Step Down Voltage Register (Address 01h).
Step Down Voltage/Test Modes
Addr: 01h
Bit
Sets the output voltage of the Step Down DC/DC Converter.
Bit Name
Default
Access
Bit Description
Controls the voltage selection for the Step Down DC/DC Converter.
000000 0.6V
5:0
buck_v
Boot ROM
R/W
(LSB = 50mV)
111000- 3.4V
111111
7:6
NA
NA
Reg Power Register (Address 09h).
Reg Power
Addr: 09h
Enables/disables voltage regulators.
Bit
Bit Name
Default
Access
Bit Description
ldo_ana1_on
Boot ROM
RW
Refer to page 28
1
ldo_ana2_on
Boot ROM
RW
Refer to page 28
3:2
NA
NA
4
ldo_sim_on
Boot ROM
RW
Refer to page 28
Enables the Step Down DC/DC Converter.
5
buck_on
7:6
Boot ROM
R/W
NA
Step Down DC/DC Converter is OFF.
1
Step Down DC/DC Converter is ON.
NA
Step Down Configuration Register (Address 17h).
Addr: 17h
Bit
Configures the operation mode of the Step Down DC/DC Converter.
Bit Name
Default
Access
Bit Description
Activate PSW (0.5Ω PMOS) only if buck_on and buck_nsw_on = 0.
buck_psw_on
R/W
Default setting. P-Channel switching transistor is controlled by
the DC/DC Converter.
1
Turns on P-Channel switching transistor. Bits buck_on and
buck_nsw_on must both = 0.
Activates NSW (0.5Ω NMOS) only if buck_on = 0 and buck_psw_on = 0.
1
buck_nsw_on
R/W
2
buck_dis_n
R/W
3
RW
Default setting. N-Channel switching transistor is controlled by
1
Turns on N-Channel switching transistor. Bits buck_on and
buck_psw_on must both = 0.
Default setting. Normal operation of The synchronous rectifier.
1
The synchronous rectifier is disabled (NSW is always OFF).
1.00
20 - 73
AS3605 1v2
Addr: 17h
Bit
Bit Name
Default
Access
4
R/W
Bit Description
5
buck_lpo
R/W
Low-power mode disabled.
1
Low-power mode enabled.
Step down PON feature control.
6
buck_dis_pon
R/W
PON feature enabled. 100% duty cycle (PMOS always on) if
output voltage drops more than 4%. Increased output ripple in
that operation.
1
PON feature disabled. Maximum duty cycle = 1 - (tmin_off*fsw)
Step down current force mode
7
buck_dis_curmin
current force mode enabled. Inductor current regulated to min
170mA. Higher efficiency in low dropout and low output current
operation. Higher output ripple and noise.
1
current force mode disabled. Decreased efficiency in low
dropout mode and at low output current. Small output ripple and
noise.
R/W
1.00
21 - 73
AS3605 1v2
7.3 Low Dropout Regulators
The Low Dropout Regulators (LDOs) are linear high performance regulators with programmable output voltages. The LDOs can be controlled by
either software (voltage, ON/OFF) or hardware (ON/OFF) using highly configurable GPIO1 to GPIO3 pins.
The Low Dropout Regulators include the following:
RF and Analog Low Dropout Regulators – Described on page 22
Analog LDO Block Diagram – Described on page 22
SIMCard Low Dropout Regulator – Described on page 23
Low Power Low Dropout Regulator – Described on page 24
7.3.1
The RF LDOs (VRF_1 - VRF_4) and Analog LDOs (VANA_1 and VANA_2) are designed to supply power to sensitive analog circuits like LNAs,
Transceivers, VCOs and other critical RF components of cellular radios. Additionally, these LDOs are suitable for supplying power to audio
devices or as a reference for A/D and D/A converters.
The design is optimized to deliver the best compromise between quiescent current and regulator performance for battery powered devices.
Stability is guaranteed with ceramic output capacitors (see Figure ) of 1µ F ±20% (X5R) or 2.2µ F +100 / -50% (Z5U).
The low ESR of these capacitors ensures low output impedance at high frequencies. Regulation performance is excellent even under low
dropout conditions, when the power transistor has to operate in linear mode. Power supply rejection is high enough to suppress ripple on the
battery caused by the PA in TDMA systems. The low noise performance allows direct connection of noise sensitive circuits without additional
filtering networks. The low impedance of the power transistor enables the device to deliver up to 150mA even at nearly discharged batteries
without any decrease of performance.
The LDOs have a built-in discharge function when switched off.
Figure 9. Analog LDO Block Diagram
High-Gain
Low-Bandwidth
Amplifier
VREF1.8V Low-Noise
DC Reference
Low-Gain
Ultra High-Bandwidth
Amplifier
VBAT 3.0 to 5.5V
VOUT 1.8 to 3.35V
250/150mA Load
1µF X5R
(External)
GND
1.00
22 - 73
AS3605 1v2
Table 9. RF and Analog LDO Characteristics
VBAT = 3.6V; ILOAD = 150mA; TA = 25ºC; CLOAD = 2.2µ F (Ceramic); unless otherwise specified.
Symbol
Parameter
Min
VBAT
Supply Voltage Range
3
RON
On-Resistance
PSRR
Power Supply Rejection Ratio
IOFF
Shut Down Current
100
nA
IVDD_LDO
Supply Current
50
µA
Noise
Output Noise
50
µ Vrms
tSTART
Startup Time
200
µs
VOUT
Output Voltage
VOUT_TOL
VLINEREG
Line Regulation
VLOADREG
Load Regulation
ILIMIT
Current Limitation
7.3.2
Typ
Max
Unit
5.5
V
1
VANA_1, VANA_2
Ω
2
Notes
VRF_1, VRF_2, VRF_3, VRF_4
f = 1kHz
70
dB
40
30
1.8
2.85
1.8
3.35
-50
50
-1
1
-10
10
-1
1
-10
10
f = 100kHz
Without load
10Hz < f < 100kHz
VBAT > 3.0V
V
Full programmable range
mV
Static
mV
Transient; Slope: tr = 10µ s
Static
mV
250
400
mA
VANA_1, VANA_2
150
180
mA
The SIMCard LDO (VSIM) is optimized for SIMCard supply. It is designed to achieve the lowest possible power consumption and still provide
reasonable regulation characteristics. To ensure high PSRR and stability, a low-ESR ceramic capacitor of 100nF (min.) must be connected to the
output. The LDO has a built-in discharge function when switched off.
Table 10. LDO VSIM Characteristics
VBAT = 3.6V; ILOAD = 20mA; TA = 25ºC; CLOAD = 100nF (Ceramic); unless otherwise specified.
Symbol
Parameter
Min
VBAT
3
RON
On-Resistance
PSRR
IOFF
Shut Down Current
IVDD_SIMCARD
Supply Current
tSTART
Startup Time
VOUT
Output Voltage
VOUT_TOL
VLINEREG
Line Regulation
Typ
Max
Unit
5.5
V
50
Ω
Notes
f = 1kHz
40
dB
40
nA
µA
200
µs
1.8
3.0
V
-50
50
mV
-10
10
-100
100
1.00
f = 100kHz
VBAT > 3.2V
Static
mV
23 - 73
AS3605 1v2
Table 10. LDO VSIM Characteristics (Continued)
Symbol
Parameter
VLOADREG
7.3.3
Load Regulation
Min
Typ
Max
-10
10
-100
100
Unit
Notes
Static
mV
The low-power bootstrap LDO (V2_5) is needed to supply power to the core (analog and digital) of the AS3605. LDO V2_5 is designed to
achieve the lowest possible power consumption, and still provide reasonable regulation characteristics. LDO V2_5 has two supply inputs
selecting automatically the higher one. This gives the possibility to supply the AS3605 core either with the battery or with the Battery Charger,
depending on the conditions.
To ensure high PSRR and stability, a low-ESR ceramic capacitor of 1µ F (min.) must be connected to the output.
Note: Levelshifters in both directions (input and output) are placed between digital pins (VANA_1) and the digital core (V2_5) of the device,
because of the different power supplies.
Table 11. LDO V2_5 Characteristics
VBAT = 3.6V; CLOAD_EXT = 0; TA = 25ºC; CLOAD = 2.2µ F (Ceramic); unless otherwise specified.
Symbol
Parameter
Min
VBAT
Supply Voltage
Range
VCHARGER
External Charger
Adapter voltage
RON
On-Resistance
IOFF
Shut Down Current
100
nA
IVDD_LPLDO
Supply Current
3
µA
tSTART
Startup Time
200
µs
VOUT
Output Voltage
2.6
V
Typ
Max
Unit
2.8
5.5
V
4
15
V
Ω
50
2.4
2.5
1.00
Notes
Guaranteed per design
Guaranteed per design; consider
device internal load for measurement
24 - 73
AS3605 1v2
7.3.4
Figure 10. Load Regulation of LDOs VANA_1, VANA_2
Figure 11. Output Noise of LDOs VANA_1, VANA_2
5mV
VOUT = 2.8V, 10mV/Div
3mV
8mV
ILoad = 150mA
ILoad = 100mA
120mA, Slope: 10μs
1µ s
1mA
10mA
Spectral Distribution at 150mA Output Load
X-Axis: 40µ s/Div
Figure 12. Load Regulation of LDO V2_5
7mV
Figure 13. Line Regulation of LDO V2_5
VOUT = 5mV/
VOUT = 1mV/Div
ILOAD = 20mA
VBAT = 3.1V
ILOAD = 1mA
VBAT = 3.0V
X-Axis: 40µ s/Div
X-Axis: 25µ s/Div
10µ s
1.00
25 - 73
AS3605 1v2
7.3.5
LDO Registers
The Low Dropout Regulators are controlled by the registers listed in Table 12.
Table 12. Low Dropout Regulators Register Summary
Name
Addr.
b7
b6
b5
b4
b3
b2
b1
b0
Page
LDO_RF1 Voltage
02h
ldo_rf1_v
26
LDO_RF2 Voltage
03h
ldo_rf2_v
27
LDO_RF3 Voltage
04h
ldo_rf3_v
27
LDO_RF4 Voltage
05h
ldo_rf4_v
27
LDO_ANA2_Voltage
06h
ldo_ana2_v
27
LDO_ANA1_Voltage
07h
ldo_ana1_v
28
LDO_SIM_Voltage
08h
28
Reg Power
09h
LDO_GPIO Active
0Fh
LDO_CHG
10h
ldo_rf4
_on
ldo_rf3
_on
LDO_AD GPIOx
11h
LDO_RF GPIOx
12h
ldo_sim_v
ldo_ana2 ldo_ana1
_on
_on
28
ldo_rf4_g ldo_rf3_g ldo_rf2_g ldo_rf1_g ldo_ana2 ldo_buck
pio
pio
pio
pio
_gpio
_gpio
29
buck_on
ldo_sim_
on
ldo_rf2
_on
ldo_rf1
_on
ldo_rf4_gpio_sel
ldo_rf3_gpio_sel
EOCCurrent[1:0]
ana2_sw ana1_sw
29
ldo_ana2_gpio_sel
buck_gpio_sel
30
ldo_rf2_gpio_sel
ldo_rf1_gpio_sel
31
LDO_RF1 Voltage Register (Address 02h).
LDO_RF1 Voltage
Addr: 02h
Bit
Sets the voltage for LDO VRF_1.
Bit Name
Default
Access
Bit Description
00000
4:0
ldo_rf1_v
Boot ROM
R/W
11111
7:5
NA
1.8V
(LSB = 50mV)
3.35V
NA
1.00
26 - 73
AS3605 1v2
LDO_RF2 Voltage Register (Address 03h).
LDO_RF2 Voltage
Addr: 03h
Bit
Sets the voltage for LDO VRF_2.
Bit Name
Default
Access
Bit Description
00000
4:0
ldo_rf2_v
Boot ROM
R/W
11111
7:5
NA
1.8V
(LSB = 50mV)
3.35V
NA
LDO_RF3 Voltage Register (Address 04h).
LDO_RF3 Voltage
Addr: 04h
Bit
Sets the voltage for LDO VRF_3.
Bit Name
Default
Access
Bit Description
00000
4:0
ldo_rf3_v
Boot ROM
R/W
11111
7:5
NA
1.8V
(LSB = 50mV)
3.35V
NA
LDO_RF4 Voltage Register (Address 05h).
LDO_RF4 Voltage
Addr: 05h
Bit
Sets the voltage for LDO VRF_4.
Bit Name
Default
Access
Bit Description
00000
4:0
ldo_rf4_v
Boot ROM
R/W
11111
7:5
NA
1.8V
(LSB = 50mV)
3.35V
NA
LDO_ANA2_Voltage Register (Address 06h).
LDO_ANA2_Voltage
Addr: 06h
Bit
Sets the voltage for LDO VANA_2.
Bit Name
Default
Access
Bit Description
4:0
ldo_ana2_v
Boot ROM
R/W
00000
11111
7:5
NA
1.80V
(LSB = 50mV)
3.35V
NA
1.00
27 - 73
AS3605 1v2
LDO_ANA1_Voltage Register (Address 07h).
LDO_ANA1_Voltage
Addr: 07h
Bit
Sets the voltage for LDO VANA_1.
Bit Name
Default
Access
Bit Description
4:0
ldo_ana1_v
Boot ROM
00000
R/W
11111
7:5
NA
1.8V
(LSB = 50mV)
3.35V
NA
LDO_SIM_Voltage Register (Address 08h).
LDO_SIM_Voltage
Addr: 08h
Sets the voltage for Digital LDO VSIM.
Bit
Bit Name
Default
Access
5:0
NA
NA
Bit Description
Sets the voltage for LDO VSIM.
6
7
ldo_sim_v
Boot ROM
NA
R/W
1.8V
1
3.0V
NA
Reg Power
Addr:09h
Bit
Bit Name
Default
Access
Bit Description
Enables control of LDO VANA_1.
Note: Do not set this bit = 0 or serial interface access will be disabled.
ldo_ana1_on
Boot ROM
R/W
LDO VANA_1 is OFF.
1
LDO VANA_1 is ON.
Enables control of LDO VANA_2.
1
3:2
ldo_ana2_on
Boot ROM
NA
R/W
LDO VANA_2 is OFF.
1
LDO VANA_2 is ON.
NA
Enables control of LDO VSIM.
4
ldo_sim_on
Boot ROM
R/W
LDO VSIM is OFF.
1
LDO VSIM is ON.
5
7:6
buck_on
Boot ROM
NA
1
NA
1.00
28 - 73
AS3605 1v2
LDO_GPIO Active Register (Address 0Fh).
LDO_GPIO Active
Addr: 0Fh
Bit
Activates GPIO ON/OFF control for voltage regulators.
Bit Name
Default
buck_gpio
Boot
ROM
Access
Bit Description
Activates GPIO control of Step Down DC/DC Converter.
R/W
Controlled by software.
1
On when assigned GPIO pin = 1 and bit buck_on = 1.
Activates GPIO control for LDO VANA_2.
1
ldo_ana2_gpio
Boot
ROM
R/W
1
On when assigned GPIO pin = 1 and bit ldo_ana2_on = 1.
Activates GPIO control for LDO VRF_1.
2
ldo_rf1_gpio
Boot
ROM
R/W
1
On when assigned GPIO pin = 1 and bit ldo_rf1_on = 1.
Activates GPIO control for LDO VRF_2.
3
ldo_rf2_gpio
Boot
ROM
R/W
1
On when assigned GPIO pin = 1 and bit ldo_rf2_on = 1.
Activates GPIO control for LDO VRF_3.
4
ldo_rf3_gpio
Boot
ROM
R/W
1
On when assigned GPIO pin = 1 and bit ldo_rf3_on = 1.
Activates GPIO control for LDO VRF_4.
5
7:6
ldo_rf4_gpio
Boot
ROM
R/W
NA
1
LDO VRF_4 is on when assigned GPIO pin = 1 and bit ldo_rf4_on = 1.
NA
LDO_RF Switch Register (Address 10h).
LDO_CHG
Addr: 10h
Enables LDOs and high-side switches.
Bit
Bit Name
Default
Access
ana1_sw
R/W
1
ana2_sw
R/W
Bit Description
VANA_1 operates as LDO.
1
VANA_1 is operating as high-side switch (RON=1Ω);
valid if ldo_ana1_on = 0.
VANA_2 operates as LDO.
1
VANA_2 is operating as high-side switch (RON=1Ω);
valid if ldo_ana2_on = 0.
Enables control of LDO VRF_1.
4
ldo_rf1_on
R/W
LDO VRF_1 is OFF.
1
LDO VRF_1 is ON.
1.00
29 - 73
AS3605 1v2
LDO_CHG
Addr: 10h
Bit
Bit Name
Default
Access
Bit Description
Enables control of LDO VRF_2.
ldo_rf2_on
5
R/W
LDO VRF_2 is OFF.
1
LDO VRF_2 is ON.
Enables control of LDO VRF_3.
ldo_rf3_on
6
R/W
LDO VRF_3 is OFF.
1
LDO VRF_3 is ON.
Enables control of LDO VRF_4.
ldo_rf4_on
7
R/W
LDO VRF_4 is OFF.
1
LDO VRF_4 is ON.
ldo_anax_on*
anax_sw*
ANA LDO Function
OFF
Fully ON, RON = 1Ω
1
Linear Voltage Regulator
1
1
Not Allowed
* Where x = 1-4
LDO_AD GPIOx Register (Address 11h).
LDO_AD GPIOx
Addr: 11h
Bit
Selects GPIO pin for power ON/OFF control for DCDC and VANA_2.
Bit Name
Default
Access
Bit Description
Valid if GPIO activation bit buck_gpio = 1
1:0
buck_gpio_sel
00h
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
Do not use this setting
Valid if GPIO activation bit ldo_ana2_gpio = 1
3:2
7:4
ldo_ana2_gpio_sel
00h
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
NA
1.00
30 - 73
AS3605 1v2
LDO_RF GPIOx Register (Address 12h).
LDO_RF GPIOx
Addr: 12h
Bit
Selects GPIO pin for power ON/OFF control for RF LDOs VRF_1 - VRF_4.
Bit Name
Default
Access
Bit Description
Valid if ldo_rf1_gpio = 1
1:0
ldo_rf1_gpio_sel
Boot ROM
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
Valid if ldo_rf2_gpio = 1
3:2
ldo_rf2_gpio_sel
Boot ROM
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
Valid if ldo_rf3_gpio = 1
5:4
ldo_rf3_gpio_sel
Boot ROM
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
Valid if ldo_rf4_gpio = 1
7:6
ldo_rf4_gpio_sel
Boot ROM
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
1.00
31 - 73
AS3605 1v2
7.4 Charge Pump
The Charge Pump uses the external flying capacitor C2 (470nF) to generate output voltages higher than the battery voltage. There are two
different operating modes of the charge pump itself:
1:1 Bypass Mode
- Battery input and output are connected by a low-impedance switch
- Battery current = output current
1:2 Mode
- The output voltage is up to 2 times the battery voltage (without load), but is limited to VCPOUTmax all the time
- Battery current = 2 times output current
As the battery voltage decreases, the Charge Pump must be switched from 1:1 mode to 1:2 mode in order to provide enough supply for the
current sinks. Depending on the actual current, the mode with best overall efficiency can be automatically or manually selected:
The charge pump mode switching can be done manually or automatically with the following possible software settings:
Automatic
- Start with 1:1 mode
- Switch up automatically to 1:2 mode
Manual
- Set modes 1:1 and 1:2 by software
7.4.1
Charge Pump Mode Switching
If automatic mode switching is enabled (cp_mode_switching = 0) the charge pump monitors the current sinks, which are connected via a LED
to the output V5_6. To identify these current sources (sinks), the registers CP mode Switch (register bits curr1_on_cp …curr5_on_cp) should
be setup before starting the charge pump (cp_on =1). If any of the voltage on these current sources drops below the threshold (currlv_switch,
currhv_switch), the 1:2 mode is selected after the debounce time. The CP will not switch back to 1:1 mode.
If the currX_on_cp=0 and the according current sink is connected to the charge pump, the current sink will be functional, but there is no up
switching of the charge pump, if the voltage compliance is too low for the current sink to supply the specified current.
Figure 14. Automatic Mode Switching
1.00
32 - 73
AS3605 1v2
The Charge Pump requires the external components specified in Table 13.
Table 13. Charge Pump External Components
Symbol
Parameter
Min
CFLY (C2)
External Flying Capacitor
CSTORE (C3)
External Storage Capacitor
Typ
Max
Unit
470
1
4.7
Notes
nF
Ceramic low-ESR capacitor between pins
CAPP and CAPN (see page 2).
µF
V5_6 and VSS (see page 2).
Note: Connections to the two external capacitors should be kept as short as possible.
Table 14. Charge Pump Parameters
VBAT = 3.6V; TAMB = 25ºC; unless otherwise specified.
Symbol
Parameter
Min
ICPOUT
Output Current
VCPOUTmax
Output Voltage
RCP
Effective Charge Pump Output
Resistance
currlv_switch
if the current sink voltage drops
below this threshold it will
change from 1:1 to 1:2 mode
tdeb
start_up debounce time
ISHUTDOWN
Shutdown Current
7.4.2
Typ
Max
Unit
60
mA
5.6
V
including output ripple
8.8
Ω
VBAT = 3.0V, cp_mode[1:0] = 1:1
31
Ω
VBAT = 3.0V, cp_mode[1:0] = 1:2
mV
cp_mode_switching = automatic
200
240
µs
2000
0.1
Notes
cp_start_debounce = 0
cp_start_debounce = 1
µA
Charge Pump Registers
Table 15. Charge Pump Register Summary
Name
Addr.
b7
b6
b5
b4
b3
cp_freq
cp_mode
_switchin
g
b2
b1
b0
Page
cp_on
34
Charge Pump Control
Onkey Pulldown
18h
cp_auto_ cp_start_d onkey_pul
on
ebounce
ld_off
CP Mode Switch
36h
NA
curr5_on curr4_on curr3_on_ curr2_on_ curr1_on_
_cp
_cp
cp
cp
cp
35
Curr Low Voltage Status
37h
NA
curr5_low curr4_low curr3_low curr2_low curr1_low
_volt
_volt
_volt
_volt
_volt
35
1.00
cp_mode[1:0]
33 - 73
AS3605 1v2
Charge Pump Control Onkey Pulldown Register (Address 18h).
Addr: 18h
Sets the operation mode of the Charge Pump.
Bit
Bit Name
Default
Access
cp_on
0b
R/W
Bit Description
Set CP into 1:1 mode (OFF state) unless cp_auto_on is
set.
1
Enable manual mode switching
CP mode (in manual mode sets this mode, in automatic mode reports
the actual mode used)
00
2:1
cp_mode[1:0]
00b
R/W
01
10
11
1:1 mode
1:2 mode
Set the mode switching algorithm
3
cp_mode_switching
0b
R/W
Automatic mode switching
1
Manual mode switching; register cp_mode[1:0] defines the
actual CP mode used.
Clock frequency selection
4
cp_freq
0b
R/W
5
onkey_pulld_off
0b
R/W
6
cp_start_debounce
0b
R/W
7
cp_auto_on
1b
R/W
1 MHz
1
500 kHz
pull down on ON-key active
1
pull down on ON-key deactivated
Mode switching debounce timer is always 240µ s.
1
Upon startup (cp_on set to 1) the mode switching debounce
time is first started with 2ms then reduced to 240µ s.
The CP is swiched ON/OFF with cp_on
1
The CP is automatically switched on if a current sink, which
is connected to the CP (defined by registers CP Mode
Switch 1&2) is switched ON and detects a low voltage
condition.
1.00
34 - 73
AS3605 1v2
CP Mode Switch Register (Address 36h).
CP Mode Switch
Addr: 36h
Setup which current sinks are connected (via LEDs) to the CP; if set to 1 the corresponding current sink is
used for automatic mode selection of the CP.
Bit
Bit Name
Default
curr1_on_cp
0b
1
curr2_on_cp
0b
2
curr3_on_cp
0b
3
curr4_on_cp
0b
4
curr5_on_cp
0b
5:7
NA
Access
R/W
R/W
R/W
R/W
R/W
Bit Description
Current sink CURR1 is not connected to the CP
1
Current sink CURR1 is connected to the CP
Current sink CURR2 is not connected to the CP
1
Current sink CURR2 is connected to the CP
Current sink CURR3 is not connected to the CP
1
Current sink CURR3 is connected to the CP
Current sink CURR4 is not connected to the CP
1
Current sink CURR4 is connected to the CP
Current sink CURR5 is not connected to the CP
1
Current sink CURR5 is connected to the CP
NA
Curr Low Voltage Status Register (Address 37h).
Addr: 37h
Indicates the low voltage status of the current sinks. If the currX_low_v bit is set, the voltage on the current
sink is too low, to drive the selected output current.
Bit
Bit Name
Default
Access
curr1_low_v
NA
R
1
curr2_low_v
NA
R
2
curr3_low_v
NA
R
3
curr4_low_v
NA
R
4
curr5_low_v
NA
R
5:7
NA
NA
Bit Description
The voltage of current sink CURR1 > currlv_switch
1
The voltage of current sink CURR1 < currlv_switch
The voltage of current sink CURR2 > currlv_switch
1
The voltage of current sink CURR2 < currlv_switch
The voltage of current sink CURR3 > currlv_switch
1
The voltage of current sink CURR3 < currlv_switch
The voltage of current sink CURR4 > currlv_switch
1
The voltage of current sink CURR4 < currlv_switch
The voltage of current sink CURR5 > currlv_switch
1
The voltage of current sink CURR5 < currlv_switch
1.00
35 - 73
AS3605 1v2
7.5 General Purpose Input/Output
The general purpose input/output pins (GPIO1 - GPIO3) are highly configurable and independently controlled.
Table 16. DC Characteristics Input/Output Pin with Selectable Supply GPIO1:GPIO3
Symbol
Parameter
Min
Max
VIH
High-Level Input Voltage
0.7 x VANA_1
VIL
Low-Level Input Voltage
ILEAK
Input Leakage Current
(if not used as pulldown/pullup)
IPULLDOWN
Unit
Notes
V
0.3 x VANA_1
V
-5
5
µA
to VANA_1 and VSS
Pulldown Current
(if configured as pulldown)
5
50
µA
to VSS
IPULLUP
Pullup Current
(if configured as pullup)
-200
-20
µA
to V5_6 or VANA_1 as
configured
VOH
High-Level Output Voltage
Supply VANA_1
0.8 x VANA_1
V
at -2mA
VOL
Low-Level Output Voltage
0.2 x VANA_1
V
at 2mA
CLOAD
Capacitive Load
50
pF
GPIO1 - GPIO3 can be used to accommodate the following functionality:
Software controlled input and output
Input pin for the Watchdog
Signal input (GPIO1-GPIO3)
Interrupt output with configurable interrupt source
Configurable frequency and duty cycle output
External clock input for Step Up/Down DC/DC Converters and Charge Pump synchronization (GPIO1 only)
Active pullup or pulldown; can be combined with other I/O functions
Output open drain (push or pull type)
1.00
36 - 73
AS3605 1v2
Figure 15. General Purpose I/O Block Diagram
VANA_1
VANA_1
interface
Register
GPIO
Control
en_pup
en_pdwn
en_pmos
en_nmos
gpio_invert
gpio_out_src
gpio
Frequency
Generator
sysclk
Interrupt
f_out
MUX
GPIOx
int
Interrupt Sources
7.5.1
GPIO Registers
GPIO1 - GPIO3 are controlled by the registers listed in Table 17.
Table 17. GPIO Register Summary
Name
Addr.
b7
b6
b5
b4
b3
b2
b1
b0
Page
GPIO1 Control
1Ah
gpio1_out_src
gpio1_
invert
gpio1_pulls
gpio1_
low_curr
gpio1_mode
38
GPIO2 Control
1Bh
gpio2_out_src
gpio2_
invert
gpio2_pulls
gpio2_low
_curr
gpio2_mode
38
GPIO3 Control
1Ch
gpio3_out_src
gpio3_
invert
gpio3_pulls
gpio3_
low_curr
gpio3_mode
39
GPIO Signal
21h
GPIO Frequency Control
High Time
22h
gpio_h_time
41
Low Time
23h
gpio_l_time
41
Clock Generation
1Eh
Interrupt Enable
1Fh
chgov_in chgrmv_in resume_in
t_en
t_en
t_en
chdet_
int_en
onkey_
int_en
ovtmp_
int_en
Interrupt Status
20h
chgov_i
chdet_i
onkey_i
ovtmp_i
chgrmv_i
resume_i
gpio3
1.00
gpio2
gpio1
40
ext_clk
41
vchoff_
int_en
wdog
_int_en
42
vchoff_i
wdog_i
43
37 - 73
AS3605 1v2
GPIO1 Control Register (Address 1Ah).
GPIO1 Control
Addr: 1Ah
Bit
Configures pin GPIO1.
Bit Name
Default
Access
Bit Description
Sets the direction for pin GPIO1.
1:0
2
gpio1_mode
gpio1_low_curr
00
R/W
Input only
01
Output (push and pull)
10
Output (open drain, only push; only NMOS is active)
11
Output (open drain, only pull; only PMOS is active)
Fast output slew rate
1
Slow output slew rate
R/W
Sets pullup/pulldown to pin GPIO1 (independent of bit gpio1_mode
setting).
4:3
5
gpio1_pulls
gpio1_invert
00
R/W
None
01
Pulldown
10
Pullup
11
NA
Output signal is not inverted.
1
Inverts any output signal going to GPIO1. This is useful for
the Watchdog output source to make the output active high
or low.
R/W
Sets the source of pin GPIO1 output.
7:6
gpio1_out_src
00
R/W
x0
Bit gpio1 controlled through the serial interface.
01
Frequency generator defined by bits gpio_h_time and
gpio_l_time.
11
Interrupt signal (see Interrupt Function on page 42).
GPIO2 Control Register (Address 1Bh).
GPIO2 Control
Addr: 1Bh
Bit
Configures pin GPIO2.
Bit Name
Default
Access
Bit Description
Sets the direction for pin GPIO2.
1:0
2
gpio2_mode
gpio2_low_curr
00
R/W
R/W
00
Input only
01
10
11
1
1.00
38 - 73
AS3605 1v2
GPIO2 Control
Addr: 1Bh
Bit
Bit Name
Default
Access
Bit Description
Sets pullup/pulldown to pin GPIO2 (independent of bit gpio2_mode
setting).
4:3
5
gpio2_pulls
gpio2_invert
00
R/W
R/W
00
None
01
Pulldown
10
Pullup
11
NA
1
Inverts any output signal going to pin GPIO2. This is useful
for the Watchdog output source to make the output active
high or low.
Sets the source of pin GPIO2 output.
7:6
gpio2_out_src
00
R/W
x0
Bit gpio2 (controlled through the serial interface).
01
gpio_l_time.
11
GPIO3 Control Register (Address 1Ch).
GPIO3 Control
Addr: 1Ch
Bit
Configures pin GPIO3.
Bit Name
Default
Access
Bit Description
Sets the direction for pin GPIO3.
1:0
3:2
gpio3_mode
gpio3_low_curr
00
R/W
R/W
00
Input only.
01
Output (push and pull).
10
Output (open drain, only push; only NMOS is active).
11
Output (open drain, only pull; only PMOS is active).
1
1.00
39 - 73
AS3605 1v2
GPIO3 Control
Addr: 1Ch
Bit
Bit Name
Default
Access
Bit Description
Sets pullup/pulldown to pin GPIO3 (independent of bit gpio3_mode
setting).
4
5
gpio3_pulls
gpio3_invert
00
R/W
R/W
00
None
01
Pulldown
10
Pullup
11
NA
1
Inverts any output signal going to pin GPIO3. This is useful for
the Watchdog output source to make the output active high or
low.
Sets the source of pin GPIO3.
Bit gpio3 (controlled through the serial interface)
x0
7:6
gpio3_out_src
00
R/W
01
gpio_l_time.
11
GPIO Signal Register (Address 21h).
Table 18. GPIO Signal Register (Address 33)
GPIO Signal
Addr: 21h
Reads the logic signal of the GPIO pins, independently of any other GPIO bit setting.
Bit
Bit Name
Default
Access
gpio1
NA
R
Reads the logic signal from pin GPIO1. If gpio1_out_src = 00, this is
the output signal at pin GPIO1.
1
gpio2
NA
R
Reads the logic signal from pin GPIO2. If gpio2_out_src = 00, this is
the output signal at pin GPIO2.
2
gpio3
NA
R
Reads the logic signal from pin GPIO3. If gpio3_out_src = 00, this is
the output signal at pin GPIO3.
7:3
NA
NA
Bit Description
1.00
40 - 73
AS3605 1v2
7.5.2
Programmable Frequency Generator
The Programmable Frequency Generator is controlled by bits gpio_h_time and gpio_l_time. It generates a waveform with 0.9 microseconds
times gpio_h_time high-level and 0.9 microseconds times gpio_l_time low-level. The accuracy of these timings is ±10%.
The frequency of the Programmable Frequency Generator is:
f=1/(tCLK*gpio_h_time + tCLK*gpio_l_time)
(EQ 1)
Where:
tclk = 1/fCLK = 1/1.1MHz (typ) = 0.909µ s (typ)
The purpose of the Programmable Frequency Generator is to have a controlled sweepable frequency or duty cycle source for one of the
following:
General User-Defined Clock
8-Bit DAC (output should be filtered by an RC filter)
(High) Positive and Negative Voltage Generation (see Interrupt Function on page 42)
7.5.3
Programmable Frequency Generator Registers
Bit definition for programmable frequency generator registers are given below.
GPIO Frequency Control High Time Register (Address 22h).
Addr: 22h
Bit
Configures programmable frequency generator.
Bit Name
Default
Access
Bit Description
Defines the number of system clock cycles (typ 0.9µ s), that the
programmable frequency generator at the GPIO output(s) is high.
7:0
gpio_h_time
00h
R/W
00h
0.909µ s
FFh
232.7µ s
GPIO Frequency Control Low Time Register (Address 23h).
Addr: 23h
Bit
Bit Name
Default
Access
Bit Description
programmable frequency generator at the GPIO output(s) is low.
7:0
gpio_l_time
64h
R/W
00h
0.909µ s
FFh
232.7µ s
1.00
41 - 73
AS3605 1v2
7.5.4
Interrupt Function
Any of the GPIO pins (GPIO1 - GPIO3) can be configured as interrupt output pins. To enable this function, the corresponding GPIO control bits
must be set to 11b. See gpio1_out_src, gpio2_out_src, or gpio3_out_src.
Several signals can be configured as interrupt source using the Interrupt Enable (page 42). A rising edge of an enabled interrupt control signal
sets the selected GPIO interrupt output pin = 1.
The Interrupt Status (page 43) shows the currently active interrupt signals. Reading this register resets the Interrupt Status (page 43) bits and
sets the active GPIO pin (GPIO 1 - GPIO3) = 0.
7.5.5
Interrupt Registers
Bit definition for Interrupt registers are given below.
Interrupt Enable Register (Address 1Fh).
Interrupt Enable
Addr: 1Fh
Enables/disables interrupt sources.
Bit
Bit Name
Default
Access
wdog_int_en
R/W
1
vchoff_int_en
1
R/W
2
ovtmp_int_en
1
R/W
3
onkey_int_en
1
R/W
4
chdet_int_en
1
R/W
5
resume_int_en
1
R/W
6
chgrmv_int_en
1
R/W
7
chgov_int_en
1
R/W
Bit Description
Disables watchdog alarm as interrupt source signal.
1
Enables watchdog alarm as interrupt source signal.
Disables charge termination voltage as interrupt source signal.
1
Enables charge termination voltage as interrupt source signal.
Disables ov_temp_110 (device temperature alert at 110ºC).
1
Enables ov_temp_110 (device temperature alert at 110ºC).
Disables pin ON (active high).
1
Enables pin ON (active high).
Disables charger detection.
1
Enables charger detection.
Disables charger-resume interrupt.
1
Enables charger-resume interrupt.
Disables charger-removed interrupt.
1
Enables charger-removed interrupt.
Disables charger overvoltage interrupt.
1
Enables charger overvoltage interrupt.
1.00
42 - 73
AS3605 1v2
Interrupt Status Register (Address 20h).
Interrupt Status
Addr: 20h
Displays the status of the interrupt inputs.
Bit
Bit Name
Default
Access
wdog_i
R
1
vchoff_i
R
2
ovtmp_i
R
3
onkey_i
R
4
chdet_i
R
Charger detection interrupt, active if ChDet is falling.
5
resume_i
R
Active if VRESUME is reached (see Table 5).
6
chgrmv_i
R
7
chgov_i
R
Charger over voltage interrupt, active if ChOv is rising.
Bit Description
Software or hardware watchdog is OFF or has not rolled over.
1
Software or hardware watchdog is rollover.
Battery voltage is below VCHOFF (see page 12) threshold.
1
Battery voltage has reached VCHOFF threshold.
Device temperature is below 110ºC.
1
110ºC temperature threshold ov_temp_110 has been reached.
ON key has not been pressed.
1
ON key has been pressed (rising edge).
1.00
43 - 73
AS3605 1v2
7.6 Current Sinks
The AS3605 contains 5 general purpose current sinks intended to control backlights, buzzers, and vibrators. All current sinks have an integrated
protection (VPROTECT) against overvoltage and can therefore also drive inductive loads. The current sinks can also be used as switches to VSS
with configurable impedance as indicated in Table 19.
Table 19. Current Source Characteristics
Symbol
Parameter
Min
ICURRx
curr1_current = 01h - FFh
curr2_current = 01h - FFh
ICURRx
curr3_current = 01h - FFh
curr4_current = 01h - FFh
curr5_current = 01h - FFh
VPROTECT
Maximum voltage at pin CURRx to
protect driver transistor
Typ
Max
Unit
Notes
0.63
160
mA
resolution = 0.6275mA
0.16
40
mA
resolution = 0.1569mA
VBAT + 2.0V
V
ISINK ≥ 20mA, guaranteed by
design
Note: If a voltage higher than VPROTECT is applied to pins CURR1 - CURR5, a current of more than 20mA will flow into the AS3605. This
protects the device from voltage rises caused by inductive loads.
7.6.1
Current Sink Registers
The current sinks are controlled by the registers listed in Table 20.
Table 20. Current Sink Register Summary
Name
Addr.
b7
b6
b5
b4
b3
b2
b1
b0
Page
CURR5 Control GPIO Map
19h
CURR1 Value
24h
curr1_current
45
CURR2 Value
25h
curr2_current
45
CURR3 Value
26h
curr3_current
46
CURR4 Value
27h
curr4_current
46
CURR Control
28h
CURR5 Value
29h
CURR GPIO Map
2Ah
curr4_ctrl
curr5_gpio
curr3_ctrl
curr2_ctrl
curr5_ctrl
curr1_ctrl
curr5_current
curr4_gpio
curr3_gpio
curr2_gpio
45
46
47
curr1_gpio
47
Note: For all current sinks, the currx_on signal is controlled with the currx_ctrl bits.
1.00
44 - 73
AS3605 1v2
CURR5 Control GPIO Map Register (Address 19h).
Addr: 19h
Bit
1:0
Bit Name
curr5_ctrl
Default
00b
Access
R/W
Bit Description
00
Pin CURR5 is turned OFF
01
Pin CURR5 is active
1x
GPIO control; pin is active when curr5_gpio = 1
If the bits curr5_ctrl = 1x, the following pin is assigned for turning the
CURR5 pin ON and OFF.
3:2
7:4
curr5_gpio
00b
NA
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
NA
NA
CURR1 Value Register (Address 24h).
CURR1 Value
Addr: 24h
Bit
7:0
Sets the current / resistance of current source CURR1.
Bit Name
curr1_current
Default
00h
Access
R/W
Bit Description
00h
Power Down
01h
0.6275mA
FFh
160mA
CURR2 Value Register (Address 25h).
CURR2 Value
Addr: 25h
Bit
7:0
Sets the current / resistance of current source CURR2.
Bit Name
curr2_current
Default
00h
Access
R/W
Bit Description
00h
Power Down
01h
0.6275mA
FFh
1.00
160mA
45 - 73
AS3605 1v2
CURR3 Value Register (Address 26h).
CURR3 Value
Addr: 26h
Bit
7:0
Sets the current / resistance of current source CURR3.
Bit Name
curr3_current
Default
00h
Access
R/W
Bit Description
00h
Power Down
01h
0.1569mA
FFh
40mA
CURR4 Value Register (Address 27h).
CURR4 Value
Addr: 27h
Bit
7:0
Sets the current / resistance of current source CURR4.
Bit Name
curr4_current
Default
00h
Access
R/W
Bit Description
00h
Power Down
01h
0.1569mA
FFh
40mA
CURR Control Register (Address 28h).
CURR Control
Addr: 28h
Bit
1:0
3:2
5:4
7:6
Selects software/ hardware control of current sources.
Bit Name
curr1_ctrl
curr2_ctrl
curr3_ctrl
curr4_ctrl
Default
00b
00b
00b
00b
Access
R/W
R/W
R/W
R/W
Bit Description
00
Pin CURR1 is turned OFF.
01
Pin CURR1 is active.
1x
GPIO control; pin is active when curr1_gpio =1.
00
Pin CURR2 is turned OFF.
01
Pin CURR2 is active.
1x
GPIO control; pin is active when curr2_gpio =1.
00
Pin CURR3 is turned OFF.
01
Pin CURR3 is active.
1x
GPIO control; pin is active when curr3_gpio = 1.
00
Pin CURR4 is turned OFF.
01
Pin CURR4 is active.
1x
GPIO control; pin is active when curr4_gpio = 1.
1.00
46 - 73
AS3605 1v2
CURR5 Value Register (Address 29h).
CURR5 Value
Addr: 29h
Bit
7:0
Sets the current.
Bit Name
curr5_current
Default
00h
Access
R/W
Bit Description
00h
Power Down
01h
0.1569mA
FFh
40mA
CURR GPIO Map Register (Address 2Ah).
CURR GPIO Map
Addr: 2Ah
Bit
Selects GPIO pin to control current sources.
Bit Name
Default
Access
Bit Description
If bits curr1_ctrl = 1x, the following pin is assigned for turning the
CURR1 pin ON and OFF.
1:0
curr1_gpio
00
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
NA
If bits curr2_ctrl = 1x, the following pin is assigned for turning the
CURR2 pin ON and OFF.
3:2
curr2_gpio
00
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
NA
If bits curr3_ctrl = 1x, the following pin is assigned for turning the
CURR3 pin ON and OFF.
5:4
curr3_gpio
00
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
NA
If bits curr4_ctrl = 1x, the following pin is assigned for turning the
CURR4 pin ON and OFF.
7:6
curr4_gpio
00
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
NA
1.00
47 - 73
AS3605 1v2
7.7 Audio Amplifier
The integrated Audio Amplifier provides real CD-quality audio and can be used as a headphone amplifier for portable devices. It is designed to
meet the operational and power requirements of portable devices by delivering:
1WRMS continuous power into 8Ω differential at 5V supply
2 x 50mWRMS into 32Ω single-ended at 5V supply
The Audio Amplifier provides the following operational features:
Total harmonic distortion is less than 0.1% at 1kHz and the quiescent current does not exceed 8mA.
Power supply rejection is always better than 50dB and allows direct connection to noisy batteries, e.g. in TDMA systems.
The internal programmable gain can be used for volume and balance control.
Only a few external components are required for AC-coupling and reference bypass.
An internal smooth-rampup circuit ensures pop- and click-less startup without expensive and bulky external relays.
Device stability even with high capacitive loads of 1nF and does not require external snubber networks.
Inputs are high-impedance in power-down.
Figure 16. Audio Amplifier Block Diagram – Stereo Mode
330kΩ
AIN_L
Audio In Left
100nF
aud_gain
Startup, Biasing,
Control Logic
Gain Control
AOUT_L
≥100µF
≥4Ω
AGND
≥4Ω
100nF
aud_on
≥100µF
aud_lpo
AOUT_R
100nF
Audio In Right
AIN_R
330kΩ
Bit aud_stereo (see page 51) = 1
Note: The value of the audio output decoupling capacitors depends on the speaker impedance and the desired minimum output frequency:
C = 1/(2xPxfxR)
(EQ 2)
Where:
f = minimum output cutoff frequency, -3dB point.
R = speaker impedance in Ω.
C = decoupling capacitance in F.
1.00
48 - 73
AS3605 1v2
Figure 17. Audio Amplifier Block Diagram – Differential Mode
AIN_L
330kΩ
Audio In
100nF
aud_gain
Startup, Biasing,
Control Logic
Gain Control
AOUT_L
AGND
≥8Ω
100nF
aud_on
aud_lpo
AOUT_R
100nF
AIN_R
165kΩ
165kΩ
Bit aud_stereo (see page 51) = 0
Table 21. Audio Amplifier Characteristics
Symbol
Parameter
Min
Typ
VDDH
Supply Voltage Range (VBAT_3)
3
PSRR
Power Supply Rejection Ratio,
Differential
70
PSRR
Power Supply Rejection Ratio, SingleEnded
50
IOFF
Shut Down Current
Max
Unit
5.5
V
f = 1kHz
dB
50
40
100
Supply Current
(Differential Mode)
4
Supply Current
(Stereo Mode)
IVDDH
THD+N
Output Load
aud_lpo = 0 and aud_ib_red = 00
mA
aud_lpo = 1 and aud_ib_red = 11
8
3
8
mA
4
aud_lpo = 1 and aud_ib_red = 00
Ω
1.00
2.7
Differential mode
Stereo mode
0.1
POUT = 1W, RLOAD = 8Ω, f = 1kHz,
VBAT = 5.5V; Differential
0.5
POUT = 1W, RLOAD = 8Ω, f = 20kHz,
0.05
POUT = 50mW, RLOAD =32Ω, f = 1kHz,
VBAT = 4V; Single-Ended
0.2
POUT = 50mW, RLOAD =32Ω, f = 20kHz,
Total Harmonic Distortion
f = 20kHz
nA
1.7
RLOAD
f = 20kHz
f = 1kHz
dB
9
IVDDH
Notes
49 - 73
AS3605 1v2
Table 21. Audio Amplifier Characteristics (Continued)
Symbol
Parameter
Min
Typ
Max
Unit
Notes
dB
VBAT=3.7V, not tested, guaranteed per
design
dB
Programmable gain: AOUT/AIN
SNR
Signal to Noise Ratio
84
91
A0
Gain
-22
ΔAx
Programmable Gain Step-Size
lOV_ON
Overcurrent On_limit
591
650
744
mA
Current rising into PMOS driver; when
aud_lpo = 0 and aud_ib_red = 00, and
aud_overcur = 1.
lov_off
Overcurrent Off_limit
397
550
650
mA
Current decreasing in PMOS driver; when
aud_overcur is cleared.
lov_hyst
Overcurrent Hysteresis
7.7.1
dB
100
mA
Audio Amplifier Registers
Bit definition for Audio amplifier registers are given below.
Audio Control Register (Address 2Bh).
Audio Control
Addr: 2Bh
Bit
Configures the Audio Amplifier.
Bit Name
Default
Access
Bit Description
Activates the Audio Amplifier.
aud_on
R/W
Audio amplifier off; inputs AIN_L and AIN_R are highimpedance.
1
Audio amplifier on.
Select Low-Power Operation; reduced output power.
1
aud_lpo
R/W
Use for speakers < 32Ω (nominal impedance) in stereo
mode; < 64Ω differential.
1
Use for speakers ≥ 32Ω (nominal impedance) in stereo
mode; ≥ 64Ω differential.
Reduced bias current into Audio Amplifier circuit.
3:2
aud_ib_red
00b
R/W
00
Use for speakers < 8Ω (nominal impedance) in stereo
mode; < 16Ω differential.
01
NA
10
NA
11
Use for speakers ≥ 8Ω (nominal impedance) in stereo
mode; ≥ 16Ω differential.
Audio Amplifier gain adjust.
7:4
aud_gain
0000b
R/W
0000
Output off
1000
0dB
0001
-22dB
1001
+2dB
0010
-19dB
1010
+5dB
0011
-16dB
1011
+8dB
0100
-13dB
1100
+11dB
0101
-10dB
1101
+14dB
0110
-7dB
1110
+17dB
0111
-4dB
1111
+20dB
1.00
50 - 73
AS3605 1v2
Audio Control 2 Register (Address 41h).
Audio Control 2
Addr: 41h
Bit
Bit Name
Default
Access
Bit Description
Selects audio mode.
aud_stereo
aud_overcur
1
R/W
R
Differential mono mode (connect pin AIN_R to pin
AOUT_L)
1
Stereo mode.
Normal operation; audio output current below limit of
lOV_ON.
1
Audio output current exceeds limit (lOV_ON).
Audio amplifier output pulldown control; active if aud_on=0.
3:2
7:4
aud_pulldwn
00b
NA
R/W
00
30µ A
01
0.6mA
10
1.2mA
11
2.5mA
Na
1.00
51 - 73
AS3605 1v2
Data Sheet - S y s t e m S u p e r v i s o r y F u n c t i o n s
8 System Supervisory Functions
8.1 Reset
XRES is an active low bi-directional pin; an external pullup to LDO VANA_1 has to be added (see Digital Input/Output DC/AC Characteristics on
page 61). During each reset cycle the following states are controlled by the AS3605:
Pin XRES is Forced to GND
Programmable Power-off Function
Programmable Power-on Sequence and Regulator Voltages
Programmable Reset Timer
All Register bits Set to Default Values after Power-On (except the Audio Control 2 (page 51), the Interrupt Status (page 43).
Note: Programming is controlled by the internal OTP-ROM.
8.1.1
Reset Conditions
Reset can be activated from 7 different sources:
Power On (Battery or Charger Insertion)
Low Battery
Power Off Mode
Software Forced Reset
Externally Triggered through the XRES Pin
Overtemperature
Watchdog
Power On (Battery or Charger Insertion). There are two types of voltage dependent resets:
VPOR – Monitors the voltage on pin V2_5. LDO V2_5 uses the voltage VCHARGER or VBAT as its source.
VRESET – Monitors the voltage on VBAT pins. Pin XRES is only released if V2_5 > VPOR and VBAT > VRESETRISE.
Low Battery. A reset is automatically generated if VBAT drops below VRESETFALLING for a minimum period (VRESETMASk).
Table 22. Reset Levels
Symbol
Parameter
Min
Typ
Max
Unit
VPOR
Overall power on reset
1.5
2.0
2.3
V
Monitor voltage on pin V2_5; power on reset for all
internal functions.
Pin RESET stays low until V2_5 > VPOR
VRESETRISE
Reset level for VBAT rising
3.1
V
Monitor voltage on pin VBAT; rising level.
VRESETFALLING
Reset level for VBAT falling
2.8
V
Monitor voltage on pin VBAT; falling level.
VRESETMASK
Mask time for VRESETFALLING
40
µs
TPOWERLOSS
Interval for recovery of power loss
on VBAT
1
100
250
500
ms
Notes
Duration for VBAT < VRESETFALLING until a reset
2
cycle is started .
If the duration of a power loss on VBAT is below this
duration, the system will restart
1. VRESETFALLING is only accepted if the reset condition is longer than VRESETMASK. This guard time is used to avoid a complete reset
of the system in case of short drops of VBAT.
2. VRESET signal is debounced with the specified mask time for rising- and falling-slope of VBAT. The default time is 40µ s and it can be
programmed from 0µ s to 200µ s with the register reset-mask timer.
1.00
52 - 73
AS3605 1v2
Power Off. Setting bit power_off = 1 puts the AS3605 into ultra low-power mode. To start a complete reset cycle, the AS3605 waits until the
external pin ON is pulled high, the Battery Charger is inserted, or level VPOR is reached. Bit power_off is automatically cleared by this reset
cycle. During power off state, all circuits are turned off except LDO V2_5, thus the current consumption of the AS3605 is reduced to less than
10µ A. The digital part is supplied by LDO V2_5, all other circuits are turned off in this mode, including internal references and oscillator.
Note: All registers except the Reset Control on page 53 are set to their default value after power-on.
Software Forced Reset. Setting bit force_reset = 1 immediately initiates a reset cycle, and is automatically cleared during a reset.
External Triggered Reset. If the pin XRES is pulled from high to low by an external source (microprocessor or button) a reset cycle is
initiated.
Overtemperature Reset. The reset cycle can be started by overtemperature conditions (see page 55).
Watchdog Reset. If the Watchdog is armed (bit wtdg_on = 1 and bit wtdg_res_on = 1) and the timer expires, a reset is initiated. Refer to
page 57 for information about the Watchdog block.
8.1.2
Reset Registers
Bit definition for Reset registers are given below.
Reset Control Register (Address 3Ah).
Reset Control
Addr: 3Ah
Controls reset and power off.
Bit
Bit Name
Default
Access
force_reset
R/W
1
power_off
R/W
Bit Description
Normal operation.
1
Initiates a complete reset cycle.
Normal operation.
1
Initiates power-off mode where all LDOs are turned off except LDO
V2_5. The AS3605 waits for a rising edge on pin ON or until the
battery charger is detected.
Static indication of ON input pin.
2
on_input
R
ON input pin is low.
1
ON input pin is high (external ON key depressed).
Indicates to the software the reason for the most recent reset.
5:3
reset_reason
0h
R
6
tmp_ pwr_loss
R
7
NA
NA
000
VPOR was reached (initial battery or charger insertion)
001
VRESETFALLING was reached (VBAT < 2.75V)
010
Software forced by bit force_reset
011
Software forced by bit power_off and a Battery Charger detected
100
Software forced by bit power_off and ON was pulled high
101
Externally triggered through pin XRES
110
Reset caused by overtemperature T140
111
Reset caused by Watchdog
Normal startup.
1
A momentary power loss condition was detected.
1.00
53 - 73
AS3605 1v2
Reset Timer Register (Address 13h).
Reset Timer
Addr: 13h
Bit
Sets the RESET timer value.
Bit Name
Default
Access
Bit Description
Set RESTIME
2:0
res_timer
OTP
R/W
000
RESTIME = 0ms
001
RESTIME = 10ms
010
RESTIME = 20ms
011
RESTIME = 30ms
100
RESTIME = 40ms
101
RESTIME = 50ms
110
RESTIME = 60ms
111
RESTIME = 70ms
Set MASKTIME
5:3
7:6
8.1.3
reset_mask_timer
OTP
NA
R/W
000
MASKTIME = 0µ s
001
MASKTIME = 5µ s
010
MASKTIME = 10µ s
011
MASKTIME = 40µ s
100
MASKTIME = 80µ s
101
MASKTIME = 120µ s
110
MASKTIME = 160µ s
111
MASKTIME = 200µ s
NA
Reset Cycle
During a reset cycle, pin XRES is forced low for at least the time specified by bits res_timer and then all register bits are set to their default
values except bit ov_temp_140.
During the reset time, a normal startup is initiated (refer to Startup on page 55) and the reset is active until the reset timer (set by bits res_timer)
expires. The voltage on pin XRES is then pulled high by the external resistor and the whole system is leaving the reset state.
8.1.4
res_con: Reset Control
Reset is internally generated from a power on detection circuit (see page 52) and provided to the internal logic as well as externally through the
open-drain pin XRES. This pin can also be forced externally by pulling it low. Additionally Reset can be forced by software by setting bit
force_reset = 1.
1.00
54 - 73
AS3605 1v2
8.2 Startup
8.2.1
Normal Startup
During a normal reset cycle (see page 52), after V2_5 is above VPOR and VBAT is above VRESETRISE, a normal startup is initiated as follows:
1. The external capacitor on pin CREF is charged to 1.8V.
2. The DC/DC converters and LDOs are sequentially powered up according to the Boot OTP configuration.
3. Depending on the Boot OTP setting (Auto-Shutdown):
a) The AS3605 enters shutdown mode if no momentary power loss is detected (only valid through initial start-up, not during a reset
cycle).
-orb) The Reset-Timer is set by the Boot OTP and the reset is released when the Reset-Timer expires (pin XRES is pulled high).
8.2.2
Programmable Startup Sequences
The start-up sequnece is factory programmed. For more details please contact austriamicrosystems AG.
8.2.3
Startup from Battery Charger
If the voltage on pin VCHARGER is within VSTARTCHARGER, the Battery Charger is started in all cases, even with VBAT = 0V. This allows the
battery to be charged (even from deep discharge) and a normal startup to proceed.
Table 23. Battery Charger Startup Conditions
Symbol
Parameter
Min
Typ
Max
Unit
VSTARTCHARGER
Voltage on pin VCHARGER for the
AS3605 to start
4.35
5.0
15
V
Notes
On pin VCHARGER.
8.3 Protection Functions
The Step Down DC/DC Converter, and all LDOs have integrated overcurrent protection. Overtemperature protection of the AS3605 is also builtin and can be activated with the serial interface bit temp_pmc_on.
The AS3605 has two temperature indicators:
ov_temp_110 – Automatically reset if the overtemperature condition is removed.
ov_temp_140 – Must be reset via the serial interface with bit rst_ov_temp_140. If ov_temp_140 is set, an automatic reset of the
complete AS3605 is initiated. Bit ov_temp_140 is not cleared by this reset cycle to indicate the reason for this (unexpected) shutdown. It
must be cleared intentionally by bit rst_ov_temp_140. The cause of this reset is stored in the Reset Control (page 53). This allows a
detection of the reset cause, after the device has restarted.
8.3.1
TMP_SV: Temperature Supervision
The AS3605 includes an integrated temperature sensor, implemented to provide overtemperature protection of the device. It generates flags
linked to the two temperature thresholds:
T110 – 110º threshold. Sets ov_temp_110, signalling the 110º overtemperature condition. Thus software can react and shut down powerconsuming functions in order to decrease the device’s temperature.
T140 – 140º threshold. Reaching this temperature level generates a Reset, when temp_pmc_on is enabled. This sets all regulators into
power-down mode and stops battery charging.
1.00
55 - 73
AS3605 1v2
8.3.2
Overtemperature Detection
Table 24. Overtemperature Detection Parameters
8.3.3
Symbol
Parameter
T110
ov_temp_110 Rising Threshold
T140
ov_temp_140 Rising Threshold
Thyst
ov_temp_110 and ov_temp_140 Hysteresis
Min
Typ
Max
Unit
95
110
125
ºC
203
230
257
ºF
125
140
155
ºC
257
284
311
ºF
5
ºC
Overtemperature Detection Register
Overtemperature Control Register (Address 3Bh).
Addr: 3Bh
Bit
Device temperature supervision.
Bit Name
Default
Access
Bit Description
Activates/deactivates temperature supervision.
Default: Off - all other bits are only valid if set to 1.
temp_pmc_on
ov_temp_110
R/W
R
Temperature supervision is disabled. No reset will be
generated when the device temperature exceeds 140ºC.
1
Temperature supervision is enabled.
1
Warning flag indicating that the device temperature has
exceeded 110ºC.
1
Indicates that the device overtemperature has exceeded
140ºC. This bit is not cleared by the automatic reset
caused by this flag. It must be cleared using bit
rst_ov_temp_140.
2
ov_temp_140
R
3
rst_ov_temp_140
R/W
Used to clear bit ov_temp_140; first set this bit = 1 and then set it =0.
4
temp_test0
R/W
Only used for production; must always be set to 00.
5
temp_test1
R/W
6
tco_110_a
R
Only used for production – direct output of T110 comparator.
7
tco_140_a
R
Only used for production – direct output of T140 comparator.
www.austriamicrosystems.com
1.00
56 - 73
AS3605 1v2
8.4 Watchdog Block
The AS3605 includes a Watchdog block to detect a deadlock of the connected controller.
If the Watchdog block is active (wtdg_on = 1), it must get a continuous trigger signal within a programmable timer window. If there is no signal
for a certain time period from a defined GPIO pin or bit wtdg_sw_sig, the Watchdog block starts either a complete reset – bit wtdg_res_on
must be set to 1 – or sets interrupt flag wdog_i.
The Watchdog timer window is defined by bits:
wtdg_min_timer
wtdg_max_timer
The trigger signal can be configured using bits:
wtdg_trigger
wtdg_sw_sig – Watchdog is reset by software
wtdg_gpio_input – Watchdog is reset by hardware (GPIO)
Any of the general purpose input/outputs can be configured as inputs using bit wtdg_gpio_input, and outputs using bits gpio1_out_src,
gpio2_out_src, or gpio3_out_src = 11, for the Watchdog. While the GPIO input must be continuously re-triggered in order to avoid a
Watchdog interrupt, the GPIO output will generate in interrupt when the Watchdog runs over – wdog_int_en.
8.4.1
Watchdog Registers
The Watchdog is controlled by the registers listed in Table 25.
Table 25. Low Dropout Regulators Register Summary
Name
Addr
b7
b6
b5
b4
wtdg_
trigger
b3
Watchdog Control
2Eh
Watchdog_min Timer
2Fh
wtdg_min_timer
Watchdog_max Timer
30h
wtdg_max_timer
Watchdog Software Signal
31h
b2
wtdg_gpio_input
b1
b0
Page
wtdg_
res_on
wtdg_on
57
58
58
wtdg_
sw_sig
58
Watchdog Control Register (Address 2Eh).
Watchdog Control
Addr: 2Eh
Controls the Watchdog block.
Bit
Bit Name
Default
Access
wtdg_on
R/W
Bit Description
Disables the Watchdog block.
1
Enables the Watchdog block.
If the Watchdog expires and this bit = 1, a reset cycle will be started. Refer
to page 52 for information about reset cycles.
1
wtdg_res_on
1
R/W
A watchdog overflow does not generate a reset.
1
A watchdog overflow generates a reset.
1.00
57 - 73
AS3605 1v2
Watchdog Control
Addr: 2Eh
Bit
Bit Name
Default
Access
Bit Description
Specifies the input pin of the Watchdog if bit wtdg_trigger = 1.
3:2
wtdg_gpio_input
00
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
Do not use this setting.
Select type of trigger (software or hardware).
4
7:5
wtdg_trigger
NA
R/W
Use bit wtdg_sw_sig as trigger signal for the Watchdog.
1
Use the pin defined by bit wtdg_gpio_input as trigger
NA
Watchdog_min Timer Register (Address 2Fh).
Watchdog_min Timer
Addr: 2Fh
Bit
7:0
Sets the minimum Watchdog trigger time.
Bit Name
wtdg_min_timer
Default
00h
Access
R/W
Bit Description
00h
0s
01h
16ms
FFh
4.08s
Watchdog_max Timer Register (Address 30h).
Watchdog_max Timer
Addr: 30h
Bit
Sets the maximum Watchdog trigger time.
Bit Name
Default
Access
Bit Description
01h
7:0
wtdg_max_timer
FFh
R/W
16ms
FFh
4.08s
Caution: Do not set these bits = 00h
Watchdog Software Signal Register (Address 31h).
Addr: 31h
Bit
Resets the Watchdog block by software.
Bit Name
Default
Access
Bit Description
Trigger input by the serial interface if wtdg_trigger = 0
wtdg_sw_sig
NA
R/W
Force watchdog trigger = low (see Figure 18)
1
Force watchdog trigger = high (see Figure 18)
NA
1.00
58 - 73
AS3605 1v2
Figure 18. Watchdog Timing Diagram
tMAX
tMIN
wtdg_trigger
tMIN
tMAX
8.5 Internal Reference Circuits
The internal reference circuits (V, I, fCLK) require the external components listed in Table 26.
Table 26. Reference External Components
Symbol
CEXT
Parameter
External filter capacitor
Min
Typ
Max
Unit
Notes
-20%
100
+20%
nF
pins CREF and VSS
Table 27. References Characteristics
Symbol
Parameter
Min
Typ
Max
Unit
Notes
VCEXT
Reference voltage
-1%
1.8
+1%
V
Low noise trimmed voltage reference
- connected to pin CREF; do not load.
fCLK
Internal reference clock
1.0
1.1
1.2
MHz
Trimmed clock reference
To reduce the current consumption of the AS3605, internal references circuits can be set into a special low-power mode with bit
low_power_on.
1.00
59 - 73
AS3605 1v2
8.5.1
Internal Reference Registers
References Control Register (Address 2Dh).
References Control
Addr: 2Dh
Bit
Configures low-power mode.
Bit Name
low_power_on
Default
Access
Bit Description
Standard mode or controlled by GPIO, if
low_power_gpio_on = 1.
1
Low-power mode; all parameters except noise (see
LDO parameters, section 7.3) are still valid.
R/W
If set and low_power_on = 0 then the low-power mode is controlled
by a GPIO pin.
1
low_power_gpio_on
R/W
Low-power mode disabled for GPIO control.
1
Low-power mode is activated by GPIO pin
(low_power_gpio). low_power_on must be
enabled.
Specifies the pin to be used as GPIO control.
3:2
4
7:5
low_power_gpio
low_power_gpio_pol
00
NA
R/W
00
GPIO1
01
GPIO2
10
GPIO3
11
GPIO3
Low-power mode is activated. If the selected GPIO
input, bit low_power_gpio = 1.
1
input, bit low_power_gpio = 0.
R/W
NA
8.6 Low Power Mode
Bit low_power_on controls low-power mode. In low-power mode the integrated voltage reference and the temperature supervision
comparators operate in pulsed mode. This reduces the quiescent current of the AS3605 by 45µ A (typical). Because of the pulsed function, the
LDO output noise parameters do not meet the specification in low-power mode but the full functionality is still available.
Note: Low-power mode can be activated by hardware using one of the GPIO pins, or by software by setting bit low_power_on = 1.
1.00
60 - 73
AS3605 1v2
8.7 Serial Interface
8.7.1
VBAT_1 is used as supply voltage of the pins.
Table 28. DC Characteristics Input Pin SCK
Symbol
Parameter
Min
Max
Unit
VIH
1.5
VBAT
V
VIL
0.4
V
ILEAK
-5
5
µA
Max
Unit
Notes
to VBAT_1 and GND_PAD
Table 29. DC Characteristics Open Drain Pin SDA
Symbol
Parameter
Min
VIH
1.5
VIL
ILEAK
VOL
CLOAD
Notes
V
0.4
V
5
µA
0.2
V
at 4.0mA
Capacitive Load
50
pF
Max
Unit
-5
Table 30. DC Characteristics Input/Output Open Drain Pin XRES
Symbol
Parameter
Min
VIH
1.5
VIL
ILEAK
VOL
Notes
V
0.4
V
5
µA
to VANA_1 and GND_PAD
0.2
V
at 4mA
CLOAD
Capacitive Load
50
pF
RPULLUP
External Pullup Resistor
100k
Ω
-5
1.00
Connect to
