604-00030
604-00030
    PARALLAXINC.
    DIP8_300MIL
    IC FLOATING-POINT COPROC V2 8DIP
604-00030 数据手册
uM-FPU Floating Point Coprocessor V2 Datasheet Introduction The uM-FPU is a 32-bit floating point coprocessor that can be easily interfaced with microcontrollers to provide support for 32-bit IEEE 754 floating point operations and long integer operations. The uM-FPU is easy to connect using either an I2C or SPI compatible interface. uM-FPU Features           8-pin integrated circuit. I2C compatible interface up to 400 kHz SPI compatible interface up to 4 Mhz 32 byte instruction buffer Sixteen 32-bit general purpose registers for storing floating point or long integer values Five 32-bit temporary registers with support for nested calculations (i.e. parentheses) Floating Point Operations  Set, Add, Subtract, Multiply, Divide  Sqrt, Log, Log10, Exp, Exp10, Power, Root  Sin, Cos, Tan, Asin, Acos, Atan, Atan2  Floor, Ceil, Round, Min, Max, Fraction  Negate, Abs, Inverse  Convert Radians to Degrees, Convert Degrees to Radians  Read, Compare, Status Long Integer Operations  Set, Add, Subtract, Multiply, Divide, Unsigned Divide  Increment, Decrement, Negate, Abs  And, Or, Xor, Not, Shift  Read 8-bit, 16-bit, and 32-bit  Compare, Unsigned Compare, Status Conversion Functions  Convert 8-bit and 16-bit integers to floating point  Convert 8-bit and 16-bit integers to long integer  Convert long integer to floating point  Convert floating point to long integer  Convert floating point to formatted ASCII  Convert long integer to formatted ASCII  Convert ASCII to floating point  Convert ASCII to long integer User Defined Functions can be stored in Flash memory  Conditional execution  Table lookup  Nth order polynomials Micromega Corporation 1 Revised 2005-06-21 Pin Description and Connecting the uM-FPU Pin Diagram and Pin Description CS SOUT SCLK/SCL VSS 1 8 2 uM -FPU 7 V2 3 6 TSTIN TSTOUT 4 SIN/SDA 5 Pin 1 2 VDD 3 4 5 6 7 8 Name CS SOUT Type Input Output SCLK SCL VSS SIN SDA TSTOUT TSTIN VDD Input Power Input In/Out Output Input Power Description Chip Select SPI Output Busy/Ready SPI Clock I2C Clock Ground SPI Input I2C Data Test Output Test Input Supply Voltage Connecting the uM-FPU to the I2C compatible interface If the CS pin is a logic high at reset (e.g. tied to +5V), the uM-FPU will be configured as an I2C slave device. Using an I2C interface allows the uM-FPU to share the I2C bus with other peripheral chips. The connection diagram is shown below. 2 I C Connection Microcontroller Pins SDA Note: SDA and SCL must have pull-up resistors as required by the I2C bus. +5V 1 CS 2 SOUT 3 SCL +5V uM-FPU SCL 4 VSS VDD TS TIN TS TOUT SDA 8 7 6 5 I2C Slave Address The slave address is 7 bits long, followed by an 8th bit which specifies whether the master wishes to write to the slave (0), or read from the slave(1). The default slave address for the uM-FPU is 1100100x (binary).  expressed as a 7-bit value, the default slave address is 100 (decimal), or 0x64 (hex).  expressed as a left justified 8-bit value the default slave address is 200 (decimal) or 0xC8 (hex). The slave address can be changed using the built-in serial debug monitor and stored in nonvolatile flash memory. I2C Bus Speed The uM-FPU can handle I2C data speeds up to 400 kHz. Micromega Corporation 2 uM-FPU V2 Datasheet Resetting and Executing Instructions I2C Data Transfers The following diagrams show the write and read data transfers. A write transfer consists of a slave address, followed by a register address, followed by 0 to n data bytes. A read transfer is normally preceded by a write transfer to select the register to read from. I2C Write Data Transfer Slave Register Address Address Data Data S 1100100 0 A aaaaaaaa A dddddddd A dddddddd A P 0 to n data bytes S - Start Condition A - ACK/NAK P - Stop Condition I2C Read Data Transfer Slave Address Data Data S 1100100 1 A dddddddd A dddddddd N P S - Start Condition A - ACK N - NAK P - Stop Condition 1 to n data bytes I2C Registers Register Address 0 1 Write Data Reset Item I2C transfer speed Read Delay – normal operation Read Delay – debug enabled Read Data / Status Buffer Space Min Max Unit 50 100 400 90 180 kHz usec usec I2C Reset Operation The uM-FPU should be reset at the beginning of every program to ensure that the microcontroller and the uM-FPU are synchronized. The uM-FPU is reset by writing a zero byte to I2C register address 1. A delay of 8 milliseconds is recommended after the reset operation to ensure that the Reset is complete and the uM-FPU is ready to receive commands.. All uM-FPU registers are reset to the special value NaN (Not a Number), which is equal to hexadecimal value 0x7FC00000. I2C Reading and Writing Data uM-FPU instructions and data are written to I2 C register 0. Reading I2 C register 0 will return the next data byte, if data is waiting to be transferred. If no data is waiting to be transferred the Busy/Ready status is returned. A read operation is normally preceded by a write operation to select the I2C register to read from. Micromega Corporation 3 uM-FPU V2 Datasheet Resetting and Executing Instructions I2C Busy/Ready Status The Busy/Ready status must always be checked to confirm that the uM-FPU is Ready prior to any read operation. The Busy status is asserted as soon as a valid opcode is received. The Ready status is asserted when both the instruction buffer and trace buffer are empty. If the uM-FPU is Ready, a zero byte is returned. If the uM-FPU is Busy, either executing instructions, or because the debug monitor is active, a 0x80 byte is returned. If more than 32 bytes of data are sent between read operations, the Ready status must also be checked at least once every 32 bytes to ensure that the instruction buffer does not overflow. I2C Buffer Space Reading I2C register 1 will return the number of bytes of free space in the instruction buffer. This can be used by more advanced interface routines to ensure that the instruction buffer remains fully utilized. It is only used to determine if there is space to write data to the uM-FPU. The Busy/Ready status must still be used to confirm the Ready status prior to any read operation. Read Delay There is a minimum delay required from the end of a read instruction opcode until the first data byte is ready to be read. If debug tracing is active, this delay is longer (see table). With many microcontrollers the call overhead for the interface routines is long enough that no additional delay is required. On faster microcontrollers a suitable delay must be inserted after a read instruction to ensure that data is valid before the first byte is read. A 180 microsecond read delay will handle all circumstances (including the debug mode). Connecting the uM-FPU using the SPI compatible interface If the CS pin is a logic low at reset (e.g. tied to GND), the uM-FPU will be configured as a SPI slave device. The uM-FPU can be connected using either a 2-wire or 3-wire SPI interface depending on the capabilities of the microcontroller. The 3-wire SPI connection uses separate data input and data output pins on the microcontroller. The 2-wire SPI connection uses a single bidirectional pin for both data input and data output. If a 2-wire SPI interface is used, the SOUT and SIN pins should not be connected directly together, they must be connected through a 1K resistor. The microcontroller data pin is connected to the SIN pin. The connection diagrams are shown below. 2-wire SPI Connection Microcontroller Pins DATA 1K 1 2 3 4 CLK Micromega Corporation 4 +5V uM-FPU 8 CS VDD 7 SOUT TS TIN 6 SCLK TS TOUT 5 VSS SIN uM-FPU V2 Datasheet Resetting and Executing Instructions 3-wire SPI Connection Microcontroller Pins DATA OUT +5V uM-FPU 1 2 3 CS VDD SOUT TS TIN SCLK TS TOUT 4 VSS SIN DATA IN CLK 8 7 6 5 SPI Reset Operation The uM-FPU should be reset at the beginning of every program to ensure that the microcontroller and the uM-FPU are synchronized. To cause a Reset, the SIN line must be Low while the SCLK line is held High for a minimum of 500 microseconds. The reset operation will not occur until the SCLK line returns Low. A delay of 8 milliseconds is recommended after the Reset to ensure that the Reset is complete and the uM-FPU is ready to receive commands. All uM-FPU registers are reset to the special value NaN (Not a Number), which is equal to hexadecimal value 7FC00000. Reset Timing Diagram Reset Reset Delay SCLK SIN Item Reset - SCLK Output High Reset - SIN Output Low Reset Delay Min 500 100 3 Typical 8 Max Unit usec usec msec SPI Reading and Writing Data The uM-FPU is configured as a Serial Peripheral Interconnect (SPI) slave device. Data is transmitted and received with the most significant bit (MSB) first using SPI mode 0, summarized as follows: SCLK is active High (idle state is Low) Data latched on leading edge of SCLK Data changes on trailing edge of SCLK Data is transmitted most significant bit first The maximum SCLK frequency is 4 MHz, but there must be minimum data period between bytes. The minimum data period is measured from the rising edge of the first bit of one date byte to the rising edge of the first bit of the next data byte. The minimum data period must elapse before the Busy/Ready status is checked. Read Delay There is a minimum delay required from the end of a read instruction opcode until the first data byte is ready to be read. If debug tracing is active, this delay is longer (see table). With many microcontrollers the call overhead for the interface routines is long enough that no additional delay is required. On faster microcontrollers a suitable delay must be inserted after a read instruction to ensure that data is valid before the first byte is read. A 180 microsecond Micromega Corporation 5 uM-FPU V2 Datasheet Resetting and Executing Instructions read delay will handle all circumstances (including the debug mode). SPI Instruction Timing Diagram (Opcode) Minimum Data Period SCLK SIN SOUT Ready Busy Ready Instruction Timing Diagram (Opcode followed by an additional argument) Minimum Data Period Minimum Data Period Minimum Data Period SCLK SIN SOUT Ready Busy Ready SPI Instruction Timing Diagram (Opcode followed by return value) Read Setup Delay Read Byte Delay Minimum Data Period SCLK SIN SOUT Ready Micromega Corporation Busy 6 Ready uM-FPU V2 Datasheet Resetting and Executing Instructions Item Min SCLK Frequency SCLK Output Low (per bit) SCLK Output High (per bit) Minimum Data Period – normal operation Minimum Data Period – debug trace enabled Read Setup Delay – normal operation Read Setup Delay – debug trace enabled Read Byte Delay – normal operation Read Byte Delay – debug trace enabled 0.125 0.125 10 15 90 180 10 15 Max Unit 4 MHz usec usec usec usec usec usec usec usec 60 SPI Busy/Ready Status The busy/ready status must always be checked to confirm the Ready status prior to any read operation. The Busy status is asserted as soon as a valid opcode is received. The Ready status is asserted when both the instruction buffer and trace buffer are empty. If the uM-FPU is Ready the SOUT pin is held Low. If the uM-FPU is Busy, either executing instructions, or because the debug monitor is active, the SOUT pin is held High. The minimum data period must have elapsed since the last byte was transmitted before the SOUT status is checked. If more than 32 bytes of data are sent between read operations, the Ready status must also be checked at least once every 32 bytes to ensure that the instruction buffer does not overflow. Micromega Corporation 7 uM-FPU V2 Datasheet Debug Monitor Using the TSTIN and TSTOUT Pins The TSTIN and TSTOUT pins can be configured as an activity monitor or as a serial interface for the built-in debug monitor. The mode of operation is selected by the logic value of the TSTIN pin whenever the uM-FPU is reset. If the serial interface is not being used, the TSTIN pin should be tied to GND. Activity Monitor If the TSTIN pin is Low when the uM-FPU is reset, the TSTOUT pin is configured to generate an activity monitor signal. In this mode TSTOUT will be High when the uM-FPU is Busy, and will be Low when it is Ready. TSTOUT can be connected to an LED to provide a visual activity indicator, used as an input to an oscilloscope or logic analyzer during testing, or left unconnected. Activity Indicator Serial Interface for Debug Monitor If the TSTIN pin is High when the uM-FPU is reset, the TSTIN pin is configured as a serial input and the TSTOUT pin is configured as a serial output. The uM-FPU has a built-in debug monitor that is accessed through the TSTIN and TSTOUT serial connection. This enables the uM-FPU to be easily connected to a PC for debugging. The serial connection is configured as 57,600 baud, 8 bits, no parity, and one stop bit. There is no flow control. Note: The idle state of an RS-232 connection will assert a high level on the TSTIN pin, so provided the uM-FPU is connected to an active idle RS-232 port when the uM-FPU is reset, TSTIN and TSTOUT will be properly configured as a serial interface. Serial Interface Connection Micromega Corporation 8 uM-FPU V2 Datasheet Debug Monitor Debug Monitor The built-in debug monitor provides support for displaying the contents of uM-FPU registers, tracing the execution of uM-FPU instructions, setting breakpoints for debugging, and programming user functions. Whenever the uMFPU is reset and the serial interface is enabled the following message is displayed: {RESET} Commands are specified by typing an uppercase or lowercase character followed by a return key. The command is not processed (or echoed) until the return key is pressed. Once the return key is pressed, the command prompt and command are displayed, and the command is executed. If the command is not recognized, a question mark is displayed. Special commands are prefixed with a dollar sign. These commands are used to program the user functions and to check the contents of the uM-FPU. They are not generally used when debugging a running application. The $M and $P will reset the uM-FPU on completion. The commands are listed below: B G R T V / $C $D $M $P Break Go Register Trace Version Comment Checksum Display Mode Program stop execution after next opcode continue execution display registers toggle trace mode on/off display version information add comment to debug trace display checksum value display user function memory set mode parameters program user function memory Break – stop execution after next opcode The Break command is used to interrupt operation of the uM-FPU. The break will not occur until after the next opcode that is not a SELECTA or SELECTB is executed by the uM-FPU. The debug monitor displays the hex value of the last opcode executed and any additional data. Entering another Break command, or simply pressing the return key, will single step to the next opcode. Entering the Go command will continue execution. >B 53 {BREAK} (i.e. SET R3) > F6:0028 {BREAK} > (i.e. LOADWORD $0028) 80 {BREAK} (i.e. FMUL R0) > 02 51 {BREAK} (i.e. SELECT R2; SET R1) Go – continue execution The Go command is used to continue normal execution after a Break command. >G Micromega Corporation 9 uM-FPU V2 Datasheet Debug Monitor Registers – display registers The Register command displays the current contents of all uM-FPU registers. >R {A=R2, B=R0 R0:41200000 R1:3F16791A R2:3F16791A R3:40490FDB R4:41200000 R5:41A00000 R6:7FC00000 R7:7FC00000 R8:7FC00000 R9:7FC00000 R10:7FC00000 R11:7FC00000 R12:7FC00000 R13:7FC00000 R14:7FC00000 R15:7FC00000 T1:7FC00000 T2:7FC00000 T3:7FC00000 T4:7FC00000 T5:7FC00000} Trace – toggle trace mode on/off The Trace command toggles the trace mode. The current state of the trace mode is displayed. When trace mode is on, each opcode that is executed by the uM-FPU is displayed. >T {TRACE ON} 01 FA:55 F8" 1.00000" 53 F6:0002 80 95 E6 02 51 F6:000A 80 EA F2 50 42:0000000A 01 FA:55 F8" 0.95106" 53 F6:0004 80 95 E6 02 51 F6:000A 80 EA F2 50 42:00000008 01 FA:55 F8" 0.80902" 53 F6: 0006 80 95 E6 02 51 F6:000A 80 EA F2 50 42:00000006 01 FA:55 F8 " 0.58779" 53 F6:0008 80 95 E6 02 51 F6:000A 80 EA F2 50 42:000 00003 01 FA:55 F8" 0.30902" 53 F6:000A 80 95 E6 02 51 F6:000A 8 0 EA F2 50 42:00000000 01 FA:55 F8" 0.00000" 53 F6:000C 80 95 E 6 02 51 F6:000A 80 EA F2 50 42:FFFFFFFD 01 FA:55 F8"-0.30902" 5 3 F6:000E 80 95 E6 02 51 F6:000A 80 EA F2 50 42:FFFFFFFA 01 FA: 55 F8"-0.58778" 53 F6:0010 80 95 E6 02 51 F6:000A 80 EA F2 50 4 2:FFFFFFF8 01 FA:55 F8"-0.80902" 53 F6:0012 80 95 E6 02 51 F6:0 00A 80 EA F2 50 42:FFFFFFF6 01 FA:55 F8"-0.95106" 53 F6:0014 80 95 E6 02 51 F6:000A 80 EA F2 50 42:FFFFFFF6 01 FA:55 F8"-1.000 00" 53 F6:0016 80 95 E6 02 51 F6:000A 80 EA F2 50 42:FFFFFFF6 0 1 FA:55 F8"-0.95106" 53 F6:0018 80 95 E6 02 51 F6:000A 80 EA F2 50 42:FFFFFFF8 >T {TRACE OFF} Version – display version information The Version command displays the version string for the uM-FPU chip and the selected interface. If the selected interface is I2C the I2C address is also shown. >V uM-FPU V2.0 I2C C8 Comment – add comment to debug trace The comment command is used to insert short comment strings (up to six characters) in the debug session. This can be useful to provide some notations to refer to when analyzing debug results. >/test1 Checksum – display checksum value The Checksum command displays a checksum for the uM-FPU chip, excluding the stored function area. This can be used to confirm that the chip is valid. >$C:000EC52B Micromega Corporation 10 uM-FPU V2 Datasheet Debug Monitor Display – display user function memory The Display command displays the contents of the user function memory in Intel Hex format. This can be used to confirm the contents of the user function memory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ode – set mode parameters The Mode command is used to set the four interface mode parameter bytes that are stored in Flash memory. The factory setting of the parameter bytes is all zeros. The parameter bytes are read at reset to determine the mode of operation. The mode command displays the current parameter values and the user is prompted to enter new values. (The values are entered as hexadecimal values.) The new values are programmed into Flash memory and the uMFPU is Reset. >$M 00000000 :00CA0000 Two hexadecimal digits represent each parameter byte. The mode parameter bytes are interpreted as follows: Byte 0: BIT 7 6 5 4 3 2 1 0 B - T - - P MM Bit 7 Bit 5 Bit 2 Bits 1:0 Break on Reset (if debug mode is enabled) Trace on Reset (if debug mode is enabled) PIC mode enabled (see PICMODE instruction) Mode 00 – CS pin determines interface mode (default) 01 – I2C mode selected (CS pin ignored) 10 – SPI mode selected (CS pin ignored) 11 – SPI mode selected (CS pin is active as chip select for data transfers) Byte 1: I2C Address (if zero, the default address (0xC8) is used. The 7-bit address is entered as a left justified 8-bit value. The last bit is ignored. Byte 2: reserved Byte 3: reserved Micromega Corporation 11 uM-FPU V2 Datasheet Debug Monitor Program – program user function memory The Program command is used to program the user function memory. Once in program mode, the uM-FPU looks for valid Intel Hex format records. The records must have an address between 0x0000 and 0x03C0, start on a 64-byte boundary, and have a length of 1 to 64 bytes. The data is not echoed, but an acknowledge character is sent after each record. The acknowledge characters are as follows: + The record was programmed successfully. F A format error occurred. A An address error occurred. C A checksum error occurred. P A programming error occurred. The uM-FPU IDE program (or another PC based application program) would normally be used to send the required data for the program command. (See documentation for the uM-FPU IDE application program.) To exit the program mode, an escape character is sent. The program command will reset the uM-FPU on exit. >$P {*** PROGRAM MODE ***} +++ {RESET} Debug Opcodes There are several opcodes that are designed to work in conjunction with the debug monitor. If the serial debug monitor interface was not selected by the TSTIN pin at the last Reset, these commands are NOPs. The opcodes are as follows: BREAK When this opcode is encountered a Break occurs and the debug monitor is entered. Execution will only resume when a Go command is issued to the debug monitor. TRACEOFF Turns the debug trace mode off. TRACEON Turns the debug trace mode on. All opcodes will be traced on the debug terminal until the trace mode is turned off by a TRACEOFF opcode or is turned off using the debug monitor. TRACESTR Displays a trace string to the debug monitor output. This can be useful for keeping track of a debug session. Trace strings are always output; they are not affected by the trace mode. Micromega Corporation 12 uM-FPU V2 Datasheet Stored Functions Stored Functions There are 1024 bytes of flash memory reserved on the uM-FPU for storing user functions and the mode paramaters. Up to 64 user functions can be defined and saved by the user. Stored user functions have the advantage of conserving space on the microcontroller and greatly reducing the communications overhead between the microcontroller and the uM-FPU. In addition, certain instructions (e.g. IF_XXX, TABLE, POLY) are only valid in user defined functions. Opcodes FE00 through FE3F are used to execute the stored user functions 0 through 63. The Busy condition remains set while all of the opcodes in the stored function execute. User function memory is divided into two sections: the header section and the data section. The header section is located at program address 0x0000 and consists of 64 pairs of bytes that specify the offset to the data section and the length of the stored function. The offset is specified as the address divided by 4, therefore all stored functions must start on an even 4-byte boundary. The data section contains the opcodes and data for the instructions that make up the user defined function. User functions are programmed using the serial debug monitor. The uM-FPU IDE application supports the definition of user functions. (Refer to uM-FPU IDE documentation.) Micromega Corporation 13 uM-FPU V2 Datasheet Absolute Maximum Ratings Absolute Maximum Ratings Parameter Storage Temperature Ambient Temperature with Power Applied Supply Voltage on VDD relative to VSS DC Input Voltage VSS Maximum Current into any I/O Pin Recommended VDD Operating Range Supply Current Minimum -55 -40 -0.5 -0.5 -25 4.75 - Typical 7 Maximum +100 +70 +6.0 VDD+0.5 +50 5.25 - Units ° Celsius ° Celsius V V mA V mA Further Information Check the Micromega website at www.micromegacorp.com Micromega Corporation 14 uM-FPU V2 Datasheet Appendix A – Instruction Summary Appendix A uM-FPU V2 Instruction Summary Opcode Name Data Type Opcode SELECTA 0x SELECTB 1x Arguments B Reg Description Select A register x FWRITEA Float 2x yyyy zzzz FWRITEB Float 3x yyyy zzzz FREAD FSET/LSET FADD FSUB FMUL FDIV LADD LSUB LMUL Float Either Float Float Float Float Long Long Long 4x 5x 6x 7x 8x 9x Ax Bx Cx LDIV Long Dx SQRT LOG LOG10 EXP EXP10 SIN COS TAN FLOOR CEIL ROUND NEGATE ABS INVERSE Float Float Float Float Float Float Float Float Float Float Float Float Float Float E0 E1 E2 E3 E4 E5 E6 E7 E8 E9 EA EB EC ED DEGREES Float EE RADIANS Float EF SYNC Returns x yyyy zzzz x x x x x x x x F0 5C FLOAT Long F1 0 FIX Float F2 0 FCOMPARE Float F3 LOADBYTE Float F4 bb 0 LOADUBYTE Float F5 bb 0 LOADWORD Float F6 wwww 0 LOADUWORD Float F7 wwww 0 Micromega Corporation ss 15 Select B register Select A register, Write floating point value to A register Select B register, Write floating point value to B register Read register Select B register, A = B Select B register, A = A + B Select B register, A = A - B Select B register, A = A * B Select B register, A = A / B Select B register, A = A + B Select B register, A = A -B Select B register, A = A * B Select B register, A = A / B Remainder stored in register 0 A = sqrt(A) A = ln(A) A = log(A) A = e ** A A = 10 ** A A = sin(A) radians A = cos(A) radians A = tan(A) radians A = nearest integer = A A = nearest integer to A A = -A A = |A| A=1/A Convert radians to degrees A = A / (PI / 180) Convert degrees to radians A = A * (PI / 180) Synchronization Copy A to register 0 Convert long to float Copy A to register 0 Convert float to long Compare A and B (floating point) Write signed byte to register 0 Convert to float Write unsigned byte to register 0 Convert to float Write signed word to register 0 Convert to float Write unsigned word to register 0 Convert to float uM-FPU V2 Datasheet Appendix A – Instruction Summary READSTR F8 aa … 00 ATOF Float F9 aa … 00 FTOA Float FA ff ATOL Long FB aa … 00 LTOA Long FC ff FSTATUS Float FD XOP FE NOP FF FE0n FE1n FE2n FE3n FUNCTION 0 ss 0 IF_FSTATUSA Float FE80 ss IF_FSTATUSB Float FE81 ss IF_FCOMPARE Float FE82 ss IF_LSTATUSA Long FE83 ss IF_LSTATUSB Long FE84 ss IF_LCOMPARE Long FE85 ss IF_LUCOMPARE Long FE86 ss IF_LTST Long FE87 ss TABLE Either FE88 POLY Float FE89 READBYTE READWORD READLONG READFLOAT LINCA LINCB LDECA LDECB LAND LOR LXOR LNOT LTST LSHIFT LWRITEA LWRITEB LREAD Long Long Long Float Long Long Long Long Long Long Long Long Long Long Long Long Long FE90 FE91 FE92 FE93 FE94 FE95 FE96 FE97 FE98 FE99 FE9A FE9B FE9C FE9D FEAx FEBx FECx LUDIV Long FEDx POWER ROOT Float Float FEE0 FEE1 Micromega Corporation 0 bb wwww yyyy zzzz yyyy zzzz ss yyyy zzzz yyyy zzzz x yyyy zzzz x 16 Read zero terminated string from string buffer Convert ASCII to float Store in register 0 Convert float to ASCII Store in string buffer Convert ASCII to long Store in register 0 Convert long to ASCII Store in string buffer Get floating point status of A Extended opcode prefix (extended opcodes are listed below) No Operation User defined functions 0-15 User defined functions 16-31 User defined functions 32-47 User defined functions 48-63 Execute user function code if FSTATUSA conditions match Execute user function code if FSTATUSB conditions match Execute user function code if FCOMPARE conditions match Execute user function code if LSTATUSA conditions match Execute user function code if LSTATUSB conditions match Execute user function code if LCOMPARE conditions match Execute user function code if LUCOMPARE conditions match Execute user function code if LTST conditions match Table Lookup (user function) Calculate nth degree polynomial (user function) Get lower 8 bits of register A Get lower 16 bits of register A Get long integer value of register A Get floating point value of register A A=A+1 B=B+1 A=A-1 B=B-1 A = A AND B A = A OR B A = A XOR B A = NOT A Get the status of A AND B A = A shifted by B bit positions Write register and select A Write register and select B Read register Select B register, A = A / B (unsigned) Remainder stored in register 0 A = A raised to the power of B A = the Bth root of A uM-FPU V2 Datasheet Appendix A – Instruction Summary MIN MAX Float Float FEE2 FEE3 FRACTION Float FEE4 ASIN ACOS ATAN ATAN2 Float Float Float Float FEE5 FEE6 FEE7 FEE8 LCOMPARE Long FEE9 ss LUCOMPARE Long FEEA ss LSTATUS LNEGATE LABS LEFT RIGHT LOADZERO LOADONE LOADE LOADPI Long Long Long ss Float Float Float Float FEEB FEEC FEED FEEE FEEF FEF0 FEF1 FEF2 FEF3 LONGBYTE Long FEF4 bb 0 LONGUBYTE Long FEF5 bb 0 LONGWORD Long FEF6 wwww 0 LONGUWORD Long FEF7 wwww 0 IEEEMODE PICMODE CHECKSUM BREAK TRACEOFF TRACEON TRACESTR VERSION FEF8 FEF9 FEFA FEFB FEFC FEFD FEFE FEFF 0 0 0 0 0 0 0 aa … 00 A = minimum of A and B A = maximum of A and B Load Register 0 with the fractional part of A A = asin(A) radians A = acos(A) radians A = atan(A) radians A = atan(A/B) Compare A and B (signed long integer) Compare A and B (unsigned long integer) Get long status of A A = -A A = |A| Left parenthesis Right parenthesis Load Register 0 with Zero Load Register 0 with 1.0 Load Register 0 with e Load Register 0with pi Write signed byte to register 0 Convert to long Write unsigned byte to register 0 Convert to long Write signed word to register 0 Convert to long Write unsigned word to register 0 Convert to long Set IEEE mode (default) Set PIC mode Calculate checksum for uM-FPU code Debug breakpoint Turn debug trace off Turn debug trace on Send debug string to trace buffer Copy version string to string buffer Notes: Data Type Opcode Arguments Returns B Reg x n yyyy zzzz ss bb wwww aa … 00 Micromega Corporation data type required by opcode hexadecimal opcode value additional data required by opcode data returned by opcode value of B register after opcode executes register number (0-15) function number (0-63) most significant 16 bits of 32-bit value least significant 16 bits of 32-bit value status byte 8-bit value 16-bit value zero terminated ASCII string 17 uM-FPU V2 Datasheet
604-00030 价格&库存
很抱歉,暂时无法提供与“604-00030”相匹配的价格&库存,您可以联系我们找货
