74LVC1G06
Inverter with open-drain output
Rev. 11 — 28 November 2016
Product data sheet
1. General description
The 74LVC1G06 provides the inverting buffer.
Input can be driven from either 3.3 V or 5 V devices. These features allow the use of
these devices in a mixed 3.3 V and 5 V environment.
Schmitt-trigger action at all inputs makes the circuit tolerant for slower input rise and fall
time.
This device is fully specified for partial power-down applications using IOFF.
The IOFF circuitry disables the output, preventing the damaging backflow current through
the device when it is powered down.
The output of the device is an open drain and can be connected to other open-drain
outputs to implement active-LOW wired-OR or active-HIGH wired-AND functions.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8B/JESD36 (2.7 V to 3.6 V)
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Inputs accept voltages up to 5 V
Multiple package options
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V
Specified from 40 C to +125 C
74LVC1G06
Nexperia
3. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G06GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package;
5 leads; body width 1.25 mm
SOT353-1
74LVC1G06GV
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1G06GM
40 C to +125 C
XSON6
plastic extremely thin small outline package;
no leads; 6 terminals; body 1 1.45 0.5 mm
SOT886
74LVC1G06GF
40 C to +125 C
XSON6
no leads; 6 terminals; body 1 1 0.5 mm
SOT891
74LVC1G06GN
40 C to +125 C
XSON6
extremely thin small outline package; no leads; SOT1115
6 terminals; body 0.9 1.0 0.35 mm
74LVC1G06GS
40 C to +125 C
XSON6
extremely thin small outline package; no leads; SOT1202
6 terminals; body 1.0 1.0 0.35 mm
74LVC1G06GX
40 C to +125 C
X2SON5
X2SON5: plastic thermal enhanced extremely
thin small outline package; no leads; 5
terminals; body 0.8 0.8 0.35 mm
SOT1226
4. Marking
Table 2.
Marking codes
Type number
Marking[1]
74LVC1G06GW
VR
74LVC1G06GV
V06
74LVC1G06GM
VR
74LVC1G06GF
VR
74LVC1G06GN
VR
74LVC1G06GS
VR
74LVC1G06GX
VR
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
5. Functional diagram
*1'
PQD
PQD
Fig 1.
Logic symbol
74LVC1G06
Product data sheet
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
PQD
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 18
74LVC1G06
Nexperia
6. Pinning information
6.1 Pinning
/9&*
/9&*
QF
*1'
9&&
QF
9&&
QF
*1'
DDI
7UDQVSDUHQWWRSYLHZ
DDI
Fig 4.
Pin configuration SOT353-1 and SOT753
Fig 5.
Pin configuration SOT886
/9&*
/9&*
QF
QF
9&&
QF
*1'
9&&
*1'
DDI
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 6.
Pin configuration SOT891, SOT1115 and
SOT1202
Fig 7.
Pin configuration SOT1226 (X2SON5)
6.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
n.c.
1
1
not connected
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74LVC1G06
Product data sheet
3 of 18
74LVC1G06
Nexperia
7. Functional description
Table 4.
Function table[1]
Input
Output
A
Y
L
Z
H
L
[1]
H = HIGH voltage level; L = LOW voltage level.
8. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
output voltage
VO
Conditions
VI < 0 V
[1]
Min
Max
Unit
0.5
+6.5
V
50
0.5
+6.5
V
50
mA
0.5
+6.5
V
VO > VCC or VO < 0 V
Active mode and Power-down
mode
[1][2]
mA
50
mA
ICC
supply current
+100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
250
mW
IO(sink/source) output sink or source current
total power dissipation
Ptot
VO = 0 V to VCC
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
9. Recommended operating conditions
Table 6.
Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
t/V
input transition rise and fall rate
74LVC1G06
Product data sheet
Conditions
Min
Typ
Max
Unit
1.65
5.5
V
V
Active mode
V
Power-down mode; VCC = 0 V
V
40
+125
C
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 5.5 V
10
ns/V
4 of 18
74LVC1G06
Nexperia
10. Static characteristics
Table 7.
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol Parameter
40 C to +85 C
Conditions
Min
HIGH-level
input voltage
VIH
LOW-level
input voltage
VIL
VCC = 1.65 V to 1.95 V
40 C to +125 C
Max
Min
Unit
Max
0.65VCC
0.65VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
VCC = 2.7 V to 3.6 V
2.0
2.0
V
VCC = 4.5 V to 5.5 V
0.7VCC
0.7VCC
V
0.35VCC
0.35VCC
V
0.7
0.7
V
0.8
0.8
V
0.3VCC
0.3VCC
V
0.10
0.10
V
IO = 4 mA; VCC = 1.65 V
0.45
0.70
V
IO = 8 mA; VCC = 2.3 V
0.30
0.45
V
IO = 12 mA; VCC = 2.7 V
0.40
0.60
V
IO = 24 mA; VCC = 3.0 V
0.55
0.80
V
IO = 32 mA; VCC = 4.5 V
0.55
0.80
V
LOW-level
VI = VIH or VIL
output voltage
IO = 100 A;
VCC = 1.65 V to 5.5 V
VOL
Typ[1]
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1
1
A
IOZ
OFF-state
output current
VI = VIH or VIL;
VO = VCC or GND; VCC = 5.5
V
0.1
2
2
A
IOFF
power-off
leakage
current
VI or VO = 5.5 V; VCC = 0 V
0.1
2
2
A
ICC
supply current VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
A
ICC
additional
VI = VCC 0.6 V; IO = 0 A;
supply current VCC = 2.3 V to 5.5 V; per pin
5
500
500
A
CI
input
capacitance
5
pF
[1]
VCC = 3.3 V; VI = GND to VCC
All typical values are measured at VCC = 3.3 V and Tamb = 25 C.
74LVC1G06
Product data sheet
5 of 18
74LVC1G06
Nexperia
11. Dynamic characteristics
Table 8.
Voltages are referenced to GND (ground = 0 V); for load circuit see Figure 9.
Symbol
Parameter
40 C to +85 C
Conditions
Min
Max
Min
Max
1.0
3
6.5
1.0
8.5
ns
0.5
1.9
4
0.5
5.5
ns
VCC = 2.7 V
0.5
2.5
4.5
0.5
6
ns
[2]
propagation delay A to Y; see Figure 8
tpd
power dissipation
capacitance
CPD
40 C to +125 C Unit
Typ[1]
VCC = 3.0 V to 3.6 V
0.5
2.3
4
0.5
5.5
ns
0.5
1.7
3
0.5
4
ns
14
pF
VI = GND to VCC; VCC = 3.3 V
[3]
[1]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLZ and tPZL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi N + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V;
N = number of inputs switching;
(CL VCC2 fo) = sum of outputs.
12. Waveforms
9,
90
$LQSXW
*1'
W 3=/
W 3/=
9&&
很抱歉,暂时无法提供与“74LVC1G06GW,165”相匹配的价格&库存,您可以联系我们找货
