74LVC1G14
Single Schmitt-trigger inverter
Rev. 14 — 2 December 2016
Product data sheet
1. General description
The 74LVC1G14 provides the inverting buffer function with Schmitt-trigger input. It is
capable of transforming slowly changing input signals into sharply defined, jitter-free
output signals.
The input can be driven from either 3.3 V or 5 V devices. This feature allows the use of
this device in a mixed 3.3 V and 5 V environment. Schmitt-trigger action at the input
makes the circuit tolerant for slower input rise and fall time.
This device is fully specified for partial power-down applications using IOFF. The IOFF
circuitry disables the output, preventing the damaging backflow current through the device
when it is powered down.
2. Features and benefits
Wide supply voltage range from 1.65 V to 5.5 V
High noise immunity
Complies with JEDEC standard:
JESD8-7 (1.65 V to 1.95 V)
JESD8-5 (2.3 V to 2.7 V)
JESD8-B/JESD36 (2.7 V to 3.6 V).
24 mA output drive (VCC = 3.0 V)
CMOS low power consumption
Latch-up performance exceeds 250 mA
Direct interface with TTL levels
Unlimited rise and fall times
Input accepts voltages up to 5 V
Multiple package options
ESD protection:
HBM JESD22-A114F exceeds 2000 V
MM JESD22-A115-A exceeds 200 V.
Specified from 40 C to +85 C and 40 C to +125 C.
3. Applications
Wave and pulse shaper
Astable multivibrator
Monostable multivibrator
74LVC1G14
Nexperia
4. Ordering information
Table 1.
Type number
Package
Temperature range
Name
Description
Version
74LVC1G14GW
40 C to +125 C
TSSOP5
plastic thin shrink small outline package; 5 leads;
body width 1.25 mm
SOT353-1
74LVC1G14GV
40 C to +125 C
SC-74A
plastic surface-mounted package; 5 leads
SOT753
74LVC1G14GM
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT886
6 terminals; body 1 1.45 0.5 mm
74LVC1G14GF
40 C to +125 C
XSON6
plastic extremely thin small outline package; no leads; SOT891
6 terminals; body 1 1 0.5 mm
74LVC1G14GN
40 C to +125 C
XSON6
6 terminals; body 0.9 1.0 0.35 mm
SOT1115
74LVC1G14GS
40 C to +125 C
XSON6
6 terminals; body 1.0 1.0 0.35 mm
SOT1202
74LVC1G14GX
40 C to +125 C
X2SON5
X2SON5: plastic thermal enhanced extremely thin
small outline package; no leads; 5 terminals;
body 0.8 0.8 0.35 mm
SOT1226
5. Marking
Table 2.
Marking
Type number
Marking code[1]
74LVC1G14GW
VF
74LVC1G14GV
V14
74LVC1G14GM
VF
74LVC1G14GF
VF
74LVC1G14GN
VF
74LVC1G14GS
VF
74LVC1G14GX
VF
[1]
The pin 1 indicator is located on the lower left corner of the device, below the marking code.
6. Functional diagram
PQD
Fig 1.
Logic symbol
74LVC1G14
Product data sheet
PQD
PQD
Fig 2.
IEC logic symbol
All information provided in this document is subject to legal disclaimers.
Fig 3.
Logic diagram
Nexperia B.V. 2017. All rights reserved
2 of 21
74LVC1G14
Nexperia
7. Pinning information
7.1 Pinning
/9&*
/9&*
QF
*1'
9&&
QF
9&&
QF
*1'
DDE
7UDQVSDUHQWWRSYLHZ
DDE
Fig 4.
Pin configuration SOT353-1 and SOT753
Fig 5.
Pin configuration SOT886
/9&*
/9&*
QF
QF
9&&
QF
*1'
9&&
*1'
DDH
DDD
7UDQVSDUHQWWRSYLHZ
7UDQVSDUHQWWRSYLHZ
Fig 6.
Pin configuration SOT891, SOT1115 and
SOT1202
Fig 7.
Pin configuration SOT1226 (X2SON5)
7.2 Pin description
Table 3.
Pin description
Symbol
Pin
Description
TSSOP5 and X2SON5
XSON6
n.c.
1
1
not connected
A
2
2
data input
GND
3
3
ground (0 V)
Y
4
4
data output
n.c.
5
not connected
VCC
5
6
supply voltage
74LVC1G14
Product data sheet
3 of 21
74LVC1G14
Nexperia
8. Functional description
Table 4.
Function table[1]
Input
Output
A
Y
L
H
H
L
[1]
H = HIGH voltage level; L = LOW voltage level
9. Limiting values
Table 5.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
Conditions
output voltage
VO
Max
Unit
0.5
+6.5
V
[1]
0.5
+6.5
V
Active mode
[1][2]
0.5
VCC + 0.5
V
Power-down mode
[1][2]
0.5
+6.5
V
50
mA
50
mA
input voltage
VI
Min
IIK
input clamping current
VI < 0 V
IOK
output clamping current
VO > VCC or VO < 0 V
IO
output current
VO = 0 V to VCC
50
mA
ICC
supply current
+100
mA
IGND
ground current
100
mA
Tstg
storage temperature
65
+150
C
250
mW
total power dissipation
Ptot
Tamb = 40 C to +125 C
[3]
[1]
The input and output voltage ratings may be exceeded if the input and output current ratings are observed.
[2]
When VCC = 0 V (Power-down mode), the output voltage can be 5.5 V in normal operation.
[3]
For TSSOP5 and SC-74A packages: above 87.5 C the value of Ptot derates linearly with 4.0 mW/K.
For XSON6 and X2SON5 package: above 118 C the value of Ptot derates linearly with 7.8 mW/K.
10. Recommended operating conditions
Table 6.
Symbol
Parameter
VCC
supply voltage
VI
input voltage
VO
output voltage
Tamb
ambient temperature
Conditions
Active mode
Power-down mode; VCC = 0 V
74LVC1G14
Product data sheet
Min
Typ
Max
Unit
1.65
5.5
V
V
VCC
V
V
40
+125
C
4 of 21
74LVC1G14
Nexperia
11. Static characteristics
Table 7.
At recommended operating conditions; voltages are referenced to GND (ground = 0 V).
Symbol
VOH
Parameter
HIGH-level
output voltage
LOW-level
output voltage
VOL
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
VCC 0.1
VCC 0.1
V
IO = 4 mA; VCC = 1.65 V
1.2
1.54
0.95
V
VI = VT+ or VT
IO = 100 A;
VCC = 1.65 V to 5.5 V
IO = 8 mA; VCC = 2.3 V
1.9
2.15
1.7
V
IO = 12 mA; VCC = 2.7 V
2.2
2.50
1.9
V
IO = 24 mA; VCC = 3.0 V
2.3
2.62
2.0
V
IO = 32 mA; VCC = 4.5 V
3.8
4.11
3.4
V
IO = 100 A;
0.10
0.10
V
0.07
0.45
0.70
V
0.12
0.30
0.45
V
0.17
0.40
0.60
V
0.33
0.55
0.80
V
0.39
0.55
0.80
V
VI = VT+ or VT
II
input leakage
current
VI = 5.5 V or GND;
VCC = 0 V to 5.5 V
0.1
1
1
A
IOFF
power-off
leakage
current
VI or VO = 5.5 V; VCC = 0 V
0.1
2
2
A
ICC
supply current
VI = 5.5 V or GND; IO = 0 A;
0.1
4
4
A
ICC
additional
supply current
VI = VCC 0.6 V; IO = 0 A;
VCC = 2.3 V to 5.5 V
5
500
500
A
CI
input
capacitance
VCC = 3.3 V; VI = GND to VCC
5.0
pF
[1]
All typical values are measured at maximum VCC and Tamb = 25 C.
Table 8.
Transfer characteristics
Voltages are referenced to GND (ground = 0 V); for load circuit see Figure 9.
Symbol Parameter
VT+
positive-going
threshold voltage
74LVC1G14
Product data sheet
40 C to +85 C
Conditions
40 C to +125 C
Unit
Min
Typ[1]
Max
Min
Max
VCC = 1.8 V
0.82
1.0
1.14
0.79
1.14
V
VCC = 2.3 V
1.03
1.2
1.40
1.00
1.40
V
VCC = 3.0 V
1.29
1.5
1.71
1.26
1.71
V
VCC = 4.5 V
1.84
2.1
2.36
1.81
2.36
V
VCC = 5.5 V
2.19
2.5
2.79
2.16
2.79
V
see Figure 10 and Figure 11
5 of 21
74LVC1G14
Nexperia
Table 8.
Transfer characteristics …continued
Symbol Parameter
VT
negative-going
threshold voltage
40 C to +125 C
Min
Typ[1]
Max
Min
Max
Unit
VCC = 1.8 V
0.46
0.6
0.75
0.46
0.78
V
VCC = 2.3 V
0.65
0.8
0.96
0.65
0.99
V
VCC = 3.0 V
0.88
1.0
1.24
0.88
1.27
V
VCC = 4.5 V
1.32
1.5
1.84
1.32
1.87
V
VCC = 5.5 V
1.58
1.8
2.24
1.58
2.27
V
VCC = 1.8 V
0.26
0.4
0.51
0.19
0.51
V
VCC = 2.3 V
0.28
0.4
0.57
0.22
0.57
V
VCC = 3.0 V
0.31
0.5
0.64
0.25
0.64
V
VCC = 4.5 V
0.40
0.6
0.77
0.34
0.77
V
VCC = 5.5 V
0.47
0.6
0.88
0.41
0.88
V
hysteresis voltage (VT+ VT); see Figure 10,
Figure 11 and Figure 12
VH
[1]
40 C to +85 C
Conditions
All typical values are measured at Tamb = 25 C
12. Dynamic characteristics
Table 9.
Symbol Parameter
propagation delay
tpd
40 C to +85 C
Conditions
A to Y; see Figure 8
[1]
Max
Min
Max
1.0
4.1
11.0
1.0
14.0
ns
VCC = 2.3 V to 2.7 V
0.7
2.8
6.5
0.7
8.5
ns
VCC = 2.7 V
0.7
3.2
6.5
0.7
8.5
ns
VCC = 3.0 V to 3.6 V
0.7
3.0
5.5
0.7
7.0
ns
0.7
2.2
5.0
0.7
6.5
ns
15.4
pF
VCC = 4.5 V to 5.5 V
power dissipation
capacitance
Typ[1]
[2]
VCC = 1.65 V to 1.95 V
CPD
40 C to +125 C Unit
Min
[3]
Typical values are measured at Tamb = 25 C and VCC = 1.8 V, 2.5 V, 2.7 V, 3.3 V and 5.0 V respectively.
[2]
tpd is the same as tPLH and tPHL.
[3]
CPD is used to determine the dynamic power dissipation (PD in W).
PD = CPD VCC2 fi + (CL VCC2 fo) where:
fi = input frequency in MHz;
fo = output frequency in MHz;
CL = output load capacitance in pF;
VCC = supply voltage in V.
74LVC1G14
Product data sheet
6 of 21
74LVC1G14
Nexperia
13. Waveforms
9,
90
$LQSXW
*1'
W 3+/
W 3/+
92+
90
很抱歉,暂时无法提供与“74LVC1G14GW,165”相匹配的价格&库存,您可以联系我们找货
