Additional Resources:
Product Page
date
08/05/2022
page 1 of 3
MODEL: PJ-076 | DESCRIPTION: DC POWER JACK
ED
FEATURES
U
• low profile
• shielded
• internal switch
N
RoHS
SPECIFICATIONS
conditions/description
rated input voltage
rated input current
at 500 Vdc
at 50/60Hz for 1 minute
insertion/withdrawal force
terminal strength
units
Vdc
2.5
A
50
30
mΩ
mΩ
500
Vac
3
kg
500
g
MΩ
0.3
-25
85
5,000
O
RoHS
°C
cycles
UL94V-0
yes
1. When measured at a current of less than 100 mA / 1 kHz
IS
C
Notes:
24
any direction for 10 seconds
operating temperature
max
100
N
insulation resistance
voltage withstand
flammability rating
typ
between terminal and mating plug
between terminal in a closed circuit
contact resistance1
life
min
TI
parameter
SOLDERABILITY
min
typ
max
units
wave soldering
dipped in solder pot for 5 ±0.5 seconds at
255
260
265
°C
D
parameter
cuidevices.com
Product Page
CUI DEVICES | MODEL: PJ-076 | DESCRIPTION: DC POWER JACK
date 08/05/2022 | page 2 of 3
MECHANICAL DRAWING
units: mm[inches]
terminal 1
terminal 2
terminal 3
terminal 4
shield
plastic
10.0 0.394
6.20 0.244
11.5 0.453
1.65 0.065
7.2 0.283
3.50 0.138
TI
3.00 0.118
1.80 0.071
(2 PLCS)
10.3 0.406
(3 PLCS)
3
5.2 0.205
tin
copper alloy
tin
brass
nickel
PBT
2.5 0.098
(6 PLCS)
3.1 0.122
3.4 0.134
5.2 0.205
3.7 0.146
6.1 0.240
4.00 0.157
4
1
1.60x1.60
3
2.30X1.00
(2 PLCS)
IS
C
D
11.3 0.445
tin
brass
11.3 0.445
3.4 0.134
4
3.0 0.118
(2 PLCS)
copper alloy
10.3 0.406
(3 PLCS)
O
1
3.7 0.146
tin
3.1 0.122
2
6.1 0.240
3.0 0.118
(2 PLCS)
1.50 0.059
(4 PLCS)
N
2.00X1.00
(4 PLCS)
4.00 0.157
nickel
brass
N
6.00 0.236
2.4 0.094
+0.1
-0.0
copper
U
10.9 0.429
PLATING
ED
center pin
TOLERANCE:
X.X ±0.2mm
X.XX ±0.1mm
X.XXX ±0.05mm
MATERIAL
2
PCB LAYOUT
TOP VIEW
1
4
3
2
Schematic
MATING PLUG
Jack Insertion Depth: 8.2mm
cuidevices.com
Model
Center Pin
PJ-076
Ø1.65 mm
Product Page
date 08/05/2022 | page 3 of 3
REVISION HISTORY
description
date
02/06/2013
1.0
initial release
1.01
increased voltage rating
1.02
brand update
1.03
logo, datasheet style update
ED
rev.
05/18/2016
10/25/2019
08/05/2022
D
IS
C
O
N
TI
N
U
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“PJ-076”相匹配的价格&库存,您可以联系我们找货
