ABOVE REF
PART NUMBER
BELOW REF
0.004 0.10
SEE NOTE 3
RASH10
NO
RASH10S
YES
RASH10P
NO
RASH10PS
YES
SEAL O-RING
NOT ALWAYS SUPPLIED
SEE TABLE & NOTE 1
NO
YES
HEX NUT
SEE NOTE 1
0.95 24.2
DETAIL A
0.125 3.18 MAXIMUM
PANEL THICKNESS
SCALE 6 : 1
SHUNT
TERMINAL
PCB LOCATING POST
NOT ALWAYS PRESENT
SEE TABLE
0.055 1.40
MOUNTING BUSHING
5/16-32 UNEF 2A
THREAD
0.47 11.9
0.08 [2.0mm]
CENTER PIN
FLAT WASHER
SEE NOTE 1
LOCATING
SEAL O-RING PCB POST
0.35 9.0
2X 0.180 4.57
0.03 0.6
CENTER PIN
TERMINAL
0.10 2.5
0.23 5.8
BUSHING I.D.
SLEEVE SPRING
TERMINAL
SLEEVE
TERMINAL
SLEEVE
TERMINAL
0.43 11.0
0.26 6.5
A
SHUNT TERMINAL
0.08 2.0
0.19 4.9
0.07 1.7
0.06 1.6
0.020 0.51
0.325 8.26
0.062 1.57
0.10 2.5
CENTER PIN
TERMINAL
0.008 0.20
0.07 1.7
0.19 4.8
0.10 2.5
RASH10PS SHOWN HERE
0.349 8.87
0.248 6.29
SHUNT
A
SLEEVE
0.290±0.002 7.37±0.05
SCHEMATIC
0.316±0.002 8.03±0.05
1. HEX NUT, WASHER, AND O-RING (IF REQUIRED) SUPPLIED UNASSEMBLED.
2. MATERIAL:
HOUSING, COVER: THERMOPLASTIC, BLACK
MOUNTING BUSHING, HEX NUT: COPPER ALLOY, NICKEL PLATED
CENTER PIN: COPPER ALLOY, NICKEL PLATED
PIN AND SHUNT TERMINALS: COPPER ALLOY, SILVER PLATED
SLEEVE SPRING TERMINAL: SPRING COPPER ALLOY, SILVER PLATED
FLAT WASHER: STEEL, NICKEL PLATED
O-RING: ELASTOMER, BLACK
4. THESE PRODUCTS ARE RoHS COMPLIANT.
0.04 1.1
CENTER PIN
NOTES:
3. HIGH POINT OR EDGE OF EACH OF THE THREE SOLDER TABS
SHALL BE WITHIN A ZONE DEFINED BY COPLANARITY OF 0.004 INCH.
SURFACE A SHALL BE 0.002 BELOW OR 0.010 ABOVE THE PLANE
ESTABLISHED BY THE THREE HIGH POINTS OR EDGES OF THE
THREE SOLDER TABS.
0.030 0.76
0.020 0.51
0.054 1.36
0.60 15.2
0.14 3.4 TYP
CUSTOMER DRAWING
RECOMMENDED PANEL CUT-OUT
THIS DRAWING DESCRIBES A DESIGN CONSIDERED PROPRIETARY IN NATURE, DEVELOPED AND MANUFACTURED
BY SWITCHCRAFT INC. AND IS RELEASED ON A CONFIDENTIAL BASIS FOR IDENTIFICATION PURPOSES ONLY.
UNLESS OTHERWISE SPECIFIED
1. ALL DIMENSIONS IN INCHES [mm]
SIZE
REV
27139
ECO NUMBER
04/29/13
DATE
REVISIONS
PC
BY
- TWO PLACE DECIMALS
0.02
[0.5]
- THREE PLACE DECIMALS
0.005 [0.13]
02/17/12
DO NOT SCALE DRAWING
SolidWorks CAD File
NAME
TEMPER
BY
SPEC No.
SCALE
3:1
CHKD
PNK
PNK
02/17/12
APVD
SRC
02/17/12
RA POWER JACKS, HYBRID
HIGH AMP, 0.08 [2.0mm] PIN, RoHS
B
LBS/M
MATERIAL
SPEC No.
FIRST USED ON
TJK
APVD
MULT
FINISH
DATE DRAWN
A
WIDTH
SHEET
PART No.
1
OF
RASH10 SERIES
2
REV
A
0.177 4.50
0.248 6.30
0.248 6.30
0.177 4.50
0.160 4.06
0.160 4.06
0.150 3.81
0.120 3.05
0.258 6.55
0.025 0.64
SLV
0.044 1.12
A
0.120 3.05
0.150 3.81
0.025 0.64
0.258 6.55
0.044 1.12
SLV
0.040 1.02
A
SLV
SHUNT
JACK MOUNTING SURFACE
0.050 1.27
0.130 3.30
PIN
0.189 4.80
PIN
SHUNT
0.120 3.05
0.070 [1.78] MIN FOR CLEARANCE FIT
0.067 [1.70] MAX FOR INTERFERENCE FIT
REQUIRED ONLY FOR JACKS WITH POST
0.265 6.73
0.130 3.30
0.050 1.27
SLV
SHUNT
0.030 0.76
PIN
SHUNT
PIN
0.130 3.30
0.189 4.80
0.030 0.76
0.265 6.73
0.130 3.30
0.120 3.05
0.157 3.99
0.157 3.99
2X 0.250 6.35
2X 0.250 6.35
0.349 8.87
0.478 12.14
0.349 8.86
ALTERNATE PCB LAYOUT
COMPONENT SIDE
0.478 12.14
RECOMMENDED PCB LAYOUT
COMPONENT SIDE
CUSTOMER DRAWING
SCALE
4:1
DATE DRAWN
12/03/19
DRAWN BY
SHEET
PART No.
OF
RASH10 SERIES
PC
SolidWorks CAD File
2
B
2
REV
A
很抱歉,暂时无法提供与“RASH10”相匹配的价格&库存,您可以联系我们找货
