EuroMag Series PCB Mount Pluggable Terminal Blocks
Terminal Blocks:
Single Row
Series EM3593
EuroMag Terminal Blocks
Header (Mates with EM3553, EM3543, and EM3583
Series); 3.81 Centers
EM359312HC
EM359308VC
EuroMag Series
Plug & Header
SPECIFICATIONS
Ratings: 10A, 300V
Center Spacing: 0.15" (3.81mm)
Housing Material: UL rated 94V0 Thermoplastic
Contact Material: Brass, Tin-Plated
Operating Temperature: 105°C (221°F) max., –40°C (–40°F) min.
Recommended PCB Hole Diameters: 0.51" (1.30mm)
Construction: Mold-to-length.
Agency Information:
File E62622; CE Certified
Dimensions - mm (in)
L (mm)
Poles
L (mm)
HORIZONTAL
02
03
04
05
06
07
8.23
12.04
15.85
19.66
23.47
27.28
Edge Connectors,
One-Sided Boards
Poles
08
09
10
11
12
31.09
34.90
38.71
42.52
46.33
L
9.20
(0.062)
6.90
(0.272)
3.00
(0.100)
* Dimensions in inches. To convert to millimeters, multiply by 25.4.
1.21
(0.062)
2.21
(0.087)
3.81
(0.150)
Ø1.30
(Ø 0.051)
1.20
(0.047)
9.20
(0.062)
PCB Hole Layout
3.81
(0.150)
VERTICAL
3.60
(0.198)
2.93
(0.110)
Part Numbering System
En
Mn
3n
5n
9n
3
n
Series
nn
# of Positions
02 to 12
L
9.20
(0.062)
6.90
(0.272)
2.2
(0.087)
3.81
(0.150)
Inches (Millimeters)
n
Orientation
H - Horizontal
V - Vertical
C
n
Side Base
C - Closed
Mating Plugs: EM3553 pg. 78
EM3543 pg. 79
EM3583 pg. 80
For additional product information, visit www.eaton.com/connectors
81
Compliance
References
1.80
(0.031)
很抱歉,暂时无法提供与“EM359303HC”相匹配的价格&库存,您可以联系我们找货
