74LVC157A-Q100
Quad 2-input multiplexer
Rev. 3 — 19 March 2020
Product data sheet
1. General description
The 74LVC157A-Q100 is a quad 2-input multiplexer which select four bits of data from two sources
under the control of a common select input (S). The four outputs present the selected data in the
true (non-inverted) form. The enable input (E) is active LOW. When pin E is HIGH, all of the outputs
(1Y to 4Y) are forced LOW regardless of all the other input conditions. Moving the data from two
groups of registers to four common output buses is a common use of the 74LVC157A-Q100. The
state of the common data select input (S) determines the particular register from which the data
comes. It can also be used as function generator.
It is useful for implementing highly irregular logic by generating any 4 of the 16 different functions of
two variables with one variable common.
The device is the logic implementation of a 4-pole, 2-position switch, where the position of the
switch is determined by the logic levels applied to pin S.
Inputs can be driven from either 3.3 V or 5 V devices. This feature allows the use of these devices
as translators in mixed 3.3 V and 5 V applications.
This product has been qualified to the Automotive Electronics Council (AEC) standard Q100
(Grade 1) and is suitable for use in automotive applications.
2. Features and benefits
Automotive product qualification in accordance with AEC-Q100 (Grade 1)
• Specified from -40 °C to +85 °C and -40 °C to +125 °C
5 V tolerant inputs for interfacing with 5 V logic
Wide supply voltage range from 1.2 V to 3.6 V
CMOS low power consumption
Direct interface with TTL levels
Complies with JEDEC standard:
• JESD8-7A (1.65 V to 1.95 V)
• JESD8-5A (2.3 V to 2.7 V)
• JESD8-C/JESD36 (2.7 V to 3.6 V)
ESD protection:
• MIL-STD-883, method 3015 exceeds 2000 V
• HBM JESD22-A114F exceeds 2000 V
• MM JESD22-A115-B exceeds 200 V (C = 200 pF, R = 0 Ω)
DHVQFN package with Side-Wettable Flanks enabling Automatic Optical Inspection (AOI) of
solder joints
74LVC157A-Q100
Nexperia
3. Ordering information
Table 1. Ordering information
Type number
Package
Temperature range Name
Description
Version
74LVC157AD-Q100
-40 °C to +125 °C
SO16
plastic small outline package; 16 leads;
body width 3.9 mm
SOT109-1
74LVC157APW-Q100
-40 °C to +125 °C
TSSOP16
plastic thin shrink small outline package; 16 leads; SOT403-1
body width 4.4 mm
74LVC157ABQ-Q100
-40 °C to +125 °C
DHVQFN16 plastic dual in-line compatible thermal
enhanced very thin quad flat package; no leads;
16 terminals; body 2.5 × 3.5 × 0.85 mm
SOT763-1
4. Functional diagram
1
15
2
2
3
5
6
11
10
14
3
13
5
1I0 1I1 2I0 2I1 3I0 3I1 4I0 4I1
1
S
15
E
G1
EN
1
7
6
9
10
4
2Y
7
3Y
4Y
9
14
12
mna482
Logic symbol
Fig. 2.
2
1I0
3
1I1
5
2I0
6
2I1
11
3I0
10
3I1
14
4I0
13
4I1
12
13
mna481
Fig. 3.
4
11
1Y
Fig. 1.
MUX
1
SELECTOR
IEC logic symbol
MULTIPLEXER
OUTPUTS
1Y
4
2Y
7
3Y
9
4Y 12
S
E
1
15
mna483
Functional diagram
74LVC157A_Q100
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2020. All rights reserved
2 / 15
74LVC157A-Q100
Nexperia
S
E
1I1
1Y
1I0
2I1
2Y
2I0
3I1
3Y
3I0
4I1
4Y
4I0
Fig. 4.
mna484
Logic diagram
5. Pinning information
5.1. Pinning
1
S
terminal 1
index area
1I0
2
15 E
1I1
3
14 4I0
S
1
16 VCC
1Y
4
13 4I1
1I0
2
15 E
2I0
5
12 4Y
1I1
3
14 4I0
2I1
6
2Y
7
2I1
6
11 3I0
2Y
7
10 3I1
GND
8
9
12 4Y
Product data sheet
11 3I0
10 3I1
001aac931
Transparent top view
(1) This is not a supply pin. There is no electrical or
mechanical requirement to solder the pad. In case
soldered, the solder land should remain floating or
connected to GND.
3Y
Pin configuration for SO16 and TSSOP16
74LVC157A_Q100
9
5
3Y
2I0
74LVC157A
13 4I1
8
4
GND(1)
GND
1Y
001aac930
Fig. 5.
16 VCC
74LVC157A
Fig. 6.
Pin configuration for DHVQFN16
3 / 15
74LVC157A-Q100
Nexperia
5.2. Pin description
Table 2. Pin description
Symbol
Pin
Description
S
1
1I0
2
data input from source 0
1I1
3
data input from source 1
1Y
4
multiplexer output
2I0
5
2I1
6
2Y
7
multiplexer output
GND
8
ground (0 V)
3Y
9
multiplexer output
3I1
10
3I0
11
4Y
12
multiplexer output
4I1
13
4I0
14
E
15
enable input (active LOW)
VCC
16
supply voltage
6. Functional description
Table 3. Function table
H = HIGH voltage level; L = LOW voltage level; X = don’t care
Output
Input
E
S
nI0
nI1
nY
H
X
X
X
L
L
L
L
X
L
L
L
H
X
H
L
H
X
L
L
L
H
X
H
H
74LVC157A_Q100
Product data sheet
4 / 15
74LVC157A-Q100
Nexperia
7. Limiting values
Table 4. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134). Voltages are referenced to GND (ground = 0 V).
Symbol
Parameter
VCC
supply voltage
IIK
input clamping current
VI
input voltage
IOK
output clamping current
VO
output voltage
IO
output current
ICC
Min
Max
Unit
-0.5
+6.5
V
-50
-0.5
+6.5
V
±50
mA
-0.5
VCC + 0.5
±50
mA
supply current
100
mA
IGND
ground current
-100
mA
Tstg
storage temperature
-65
+150
°C
Ptot
total power dissipation
500
mW
[1]
[2]
[3]
Conditions
VI < 0
[1]
VO > VCC or VO < 0
[2]
VO = 0 V to VCC
Tamb = -40 °C to +125 °C
[3]
mA
V
The minimum input voltage ratings may be exceeded if the input current ratings are observed.
The output voltage ratings may be exceeded if the output current ratings are observed.
For SOT109-1 (SO16) package: Ptot derates linearly with 12.4 mW/K above 110 °C.
For SOT403-1 (TSSOP16) package: Ptot derates linearly with 8.5 mW/K above 91 °C.
For SOT763-1 (DHVQFN16) package: Ptot derates linearly with 11.2 mW/K above 106 °C.
8. Recommended operating conditions
Table 5. Recommended operating conditions
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VCC
1.65
3.6
V
1.2
V
supply voltage
functional
VI
input voltage
V
VO
output voltage
VCC
V
Tamb
ambient temperature
°C
Δt/ΔV
input transition rise and fall
rate
74LVC157A_Q100
Product data sheet
-40
+125
VCC = 1.65 V to 2.7 V
ns/V
VCC = 2.7 V to 3.6 V
ns/V
5 / 15
74LVC157A-Q100
Nexperia
9. Static characteristics
Table 6. Static characteristics
At recommended operating conditions. Voltages are referenced to GND (ground = 0 V).
Symbol
VIH
Parameter
HIGH-level
input voltage
VIL
LOW-level
input voltage
VOH
Conditions
-40 °C to +85 °C
VCC = 1.2 V
VCC = 1.65 V to 1.95 V
Unit
Min
Typ[1]
Max
Min
Max
1.08
1.08
V
0.65 x VCC
0.65 x VCC
V
VCC = 2.3 V to 2.7 V
1.7
1.7
V
2.0
2.0
V
VCC = 1.2 V
0.12
0.12
V
0.35 x VCC
0.7
0.7
V
0.8
0.8
V
VCC - 0.2
VCC - 0.3
V
IO = -4 mA; VCC = 1.65 V
1.2
1.05
V
IO = -8 mA; VCC = 2.3 V
1.8
1.65
V
IO = -12 mA; VCC = 2.7 V
2.2
2.05
V
IO = -18 mA; VCC = 3.0 V
2.4
2.25
V
IO = -24 mA; VCC = 3.0 V
2.2
2.0
V
0.2
0.3
V
IO = 4 mA; VCC = 1.65 V
0.45
0.65
V
IO = 8 mA; VCC = 2.3 V
0.6
0.8
V
IO = 12 mA; VCC = 2.7 V
0.4
0.6
V
IO = 24 mA; VCC = 3.0 V
0.55
0.8
V
VI = VIH or VIL
HIGH-level
output voltage
IO = -100 μA;
VCC = 1.65 V to 3.6 V
VI = VIH or VIL
LOW-level
output voltage
IO = 100 μA;
VOL
-40 °C to +125 °C
0.35 x VCC V
II
input leakage VCC = 3.6 V; VI = 5.5 V or GND
current
±0.1
±5
±20
μA
ICC
supply current VCC = 3.6 V; VI = VCC or GND;
IO = 0 A
0.1
10
40
μA
ΔICC
additional
per input pin; VI = VCC - 0.6 V;
supply current VCC = 2.7 V to 3.6 V; IO = 0 A
5
500
5000
μA
CI
input
capacitance
5.0
pF
[1]
VCC = 0 V to 3.6 V;
VI = GND to VCC
All typical values are measured at VCC = 3.3 V (unless stated otherwise) and Tamb = 25 °C.
74LVC157A_Q100
Product data sheet
6 / 15
74LVC157A-Q100
Nexperia
10. Dynamic characteristics
Table 7. Dynamic characteristics
Voltages are referenced to GND (ground = 0 V). For test circuit see Fig. 9.
Symbol
Parameter
Conditions
-40 °C to +85 °C
Min
tpd
propagation delay
nI0, nI1 to nY; see Fig. 7
Max
Min
Max
[2]
VCC = 1.2 V
16
ns
1.0
4.8
10.2
1.0
11.8
ns
1.5
2.8
5.8
1.5
6.7
ns
VCC = 2.7 V
1.0
2.9
5.9
1.0
7.5
ns
VCC = 3.0 V to 3.6 V
1.0
2.5
5.2
1.0
6.5
ns
17
ns
0.5
4.8
12.8
0.5
14.7
ns
1.5
2.8
7.2
1.5
8.3
ns
VCC = 2.7 V
1.0
2.9
7.8
1.0
10.0
ns
1.0
2.6
6.5
1.0
8.5
ns
16
ns
1.0
5.1
12.4
1.0
14.3
ns
1.5
3.0
7.0
1.5
8.1
ns
VCC = 2.7 V
1.0
3.1
7.3
1.0
9.5
ns
1.0
2.7
6.3
1.0
8.0
ns
1.0
1.5
ns
9.4
pF
12.8
pF
15.9
pF
E to nY; see Fig. 8
[2]
VCC = 1.2 V
S to nY; see Fig. 7
[2]
VCC = 1.2 V
tsk(o)
output skew time
[3]
CPD
power dissipation
capacitance
per input; VI = GND to VCC
[4]
[1]
[2]
[3]
[4]
Typ[1]
-40 °C to +125 °C Unit
Typical values are measured at Tamb = 25 °C and VCC = 1.2 V, 1.8 V, 2.5 V, 2.7 V, and 3.3 V respectively.
tpd is the same as tPLH and tPHL.
Skew between any two outputs of the same package switching in the same direction. This parameter is guaranteed by design.
CPD is used to determine the dynamic power dissipation (PD in μW).
2
2
PD = CPD × VCC x fi x N + ∑(CL x VCC x fo) where:
fi = input frequency in MHz; fo = output frequency in MHz
CL = output load capacitance in pF
VCC = supply voltage in V
N = number of inputs switching
2
∑(CL x VCC x fo) = sum of outputs
74LVC157A_Q100
Product data sheet
7 / 15
74LVC157A-Q100
Nexperia
10.1. Waveforms and test circuit
VI
nI0, nI1, S
VM
input
GND
t PHL
t PLH
VOH
VM
nY output
mna486
VOL
VM = 1.5 V at VCC ≥ 2.7 V; VM = 0.5 x VCC at VCC < 2.7 V.
VOL and VOH are typical output voltage levels that occur with the output load.
Fig. 7.
Data inputs (nI0, nI1) and common data select input (S) to output (nY) propagation delays
VCC
VM
E input
GND
t PHL
t PLH
VOH
VM
nY output
mna485
VOL
Fig. 8.
Enable input (E) to output (nY) propagation delays
74LVC157A_Q100
Product data sheet
8 / 15
74LVC157A-Q100
Nexperia
VI
negative
pulse
tW
90 %
VM
0V
VI
positive
pulse
0V
VM
10 %
tf
tr
tr
tf
90 %
VM
VM
10 %
tW
VCC
PULSE
GENERATOR
VI
VO
DUT
RT
CL
RL
001aaf615
Test data is given in Table 8. Definitions for test circuit:
RL = Load resistance.
CL = Load capacitance including jig and probe capacitance.
RT = Termination resistance should be equal to output impedance Zo of the pulse generator.
Fig. 9.
Test circuit for measuring switching times
Table 8. Test data
Supply voltage
Input
Load
VI
tr, tf
CL
RL
1.2 V
VCC
≤ 2 ns
30 pF
1 kΩ
1.65 V to 1.95 V
VCC
≤ 2 ns
30 pF
1 kΩ
2.3 V to 2.7 V
VCC
≤ 2 ns
30 pF
500 Ω
2.7 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
3.0 V to 3.6 V
2.7 V
≤ 2.5 ns
50 pF
500 Ω
74LVC157A_Q100
Product data sheet
9 / 15
74LVC157A-Q100
Nexperia
11. Package outline
SO16: plastic small outline package; 16 leads; body width 3.9 mm
SOT109-1
D
E
A
X
c
y
HE
v M A
Z
16
9
Q
A2
A
(A 3)
A1
pin 1 index
θ
Lp
1
L
8
e
w M
bp
detail X
5 mm
scale
DIMENSIONS (inch dimensions are derived from the original mm dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (1)
e
HE
L
Lp
Q
v
w
y
Z (1)
mm
1.75
0.25
0.10
1.45
1.25
0.25
0.49
0.36
0.25
0.19
10.0
9.8
4.0
3.8
1.27
6.2
5.8
1.05
1.0
0.4
0.7
0.6
0.25
0.25
0.1
0.7
0.3
inches
0.069
0.010 0.057
0.004 0.049
0.01
0.019 0.0100 0.39
0.014 0.0075 0.38
0.16
0.15
0.05
0.039
0.016
0.028
0.020
0.01
0.01
0.004
0.028
0.012
0.244
0.041
0.228
θ
o
8
o
Note
1. Plastic or metal protrusions of 0.15 mm (0.006 inch) maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
SOT109-1
076E07
MS-012
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-19
Fig. 10. Package outline SOT109-1 (SO16)
74LVC157A_Q100
Product data sheet
10 / 15
74LVC157A-Q100
Nexperia
TSSOP16: plastic thin shrink small outline package; 16 leads; body width 4.4 mm
D
SOT403-1
E
A
X
c
y
HE
v M A
Z
9
16
Q
A2
pin 1 index
(A 3 )
A1
A
θ
Lp
1
L
8
detail X
w M
bp
e
5 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
max.
A1
A2
A3
bp
c
D (1)
E (2)
e
HE
L
Lp
Q
v
w
y
Z (1)
θ
mm
1.1
0.15
0.05
0.95
0.80
0.25
0.30
0.19
0.2
0.1
5.1
4.9
4.5
4.3
0.65
6.6
6.2
1
0.75
0.50
0.4
0.3
0.2
0.13
0.1
0.40
0.06
8o
0o
Notes
1. Plastic or metal protrusions of 0.15 mm maximum per side are not included.
2. Plastic interlead protrusions of 0.25 mm maximum per side are not included.
OUTLINE
VERSION
SOT403-1
REFERENCES
IEC
JEDEC
JEITA
EUROPEAN
PROJECTION
ISSUE DATE
99-12-27
03-02-18
MO-153
Fig. 11. Package outline SOT403-1 (TSSOP16)
74LVC157A_Q100
Product data sheet
11 / 15
74LVC157A-Q100
Nexperia
DHVQFN16: plastic dual in-line compatible thermal enhanced very thin quad flat package; no leads;
SOT763-1
16 terminals; body 2.5 x 3.5 x 0.85 mm
B
D
A
A
E
A1
c
detail X
terminal 1
index area
terminal 1
index area
C
e1
e
b
2
7
y
y1 C
v M C A B
w M C
L
1
8
Eh
e
16
9
15
10
Dh
X
5 mm
scale
UNIT
A(1)
max.
A1
b
c
D (1)
Dh
E (1)
Eh
e
e1
L
v
w
y
y1
mm
1
0.05
0.00
0.30
0.18
0.2
3.6
3.4
2.15
1.85
2.6
2.4
1.15
0.85
0.5
2.5
0.5
0.3
0.1
0.05
0.05
0.1
Note
1. Plastic or metal protrusions of 0.075 mm maximum per side are not included.
REFERENCES
OUTLINE
VERSION
IEC
JEDEC
JEITA
SOT763-1
MO-241
EUROPEAN
PROJECTION
ISSUE DATE
02-10-17
03-01-27
Fig. 12. Package outline SOT763-1 (DHVQFN16)
74LVC157A_Q100
Product data sheet
12 / 15
74LVC157A-Q100
Nexperia
12. Abbreviations
Table 9. Abbreviations
Acronym
Description
CDM
Charged Device Model
CMOS
Complementary Metal-Oxide Semiconductor
DUT
Device Under Test
ESD
ElectroStatic Discharge
HBM
Human Body Model
MM
Machine Model
TTL
Transistor-Transistor Logic
13. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
74LVC157A_Q100 v.3
20200319
Product data sheet
74LVC157A_Q100 v.2
Modifications:
74LVC157A_Q100 v.2
20130502
Modifications:
74LVC157A_Q100 v.1
20120807
74LVC157A_Q100
Product data sheet
Table 4: Derating values for Ptot total power dissipation updated.
Type number 74LVC157ADB-Q100 removed.
Product data sheet
74LVC157A_Q100 v.1
74LVC157ADB-Q100 added.Product data sheet
13 / 15
74LVC157A-Q100
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
14. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
74LVC157A_Q100
Product data sheet
14 / 15
74LVC157A-Q100
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Ordering information....................................................2
4. Functional diagram.......................................................2
5. Pinning information......................................................3
5.1. Pinning.........................................................................3
5.2. Pin description............................................................. 4
6. Functional description................................................. 4
7. Limiting values............................................................. 5
8. Recommended operating conditions..........................5
9. Static characteristics....................................................6
10. Dynamic characteristics............................................ 7
10.1. Waveforms and test circuit........................................ 8
11. Package outline........................................................ 10
12. Abbreviations............................................................ 13
13. Revision history........................................................13
14. Legal information......................................................14
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 19 March 2020
74LVC157A_Q100
Product data sheet
15 / 15
