Data Sheet
AS3560
Class-G Stereo Headphone Amplifier
1 General Description
2 Key Features
G-Class amplifier with integrated DCDC buck converter
The AS3560 is a Class-G stereo headphone amplifier optimized for
usage within portable devices. The Class-G supply rail adaptation is
implemented by an integrated DCDC buck converter that takes its
input directly from the battery. The continuous adaption of supply
rails is done according to the input signal swing and load conditions.
This architecture implements significant power savings compared to
traditional Class-AB amplifiers.
- 2x30mW, 0.02% THD @16Ω
- >100dB SNR @1Vrms
Charge pump for true ground output without coupling capacitors
Direct battery connection with wide supply range: 2.3V to 5.5V
Low power consumption optimized for battery operation
An I2C control interface is implemented for a 32-step volume control.
- 1 mA quiescent current with both channels enabled
很抱歉,暂时无法提供与“AS3560-BWLT”相匹配的价格&库存,您可以联系我们找货
