Description:
Desco’s Statfree® Cushion Grade Static Dissipative Foam is a non-abrasive,
closed-cell cross-linked Polyethylene Foam Compounded for Permanent ESD
Control Properties. The ESD protective properties will not degrade; the foam is
designed not to flake, slough, or contaminate products. The foam will electrically
couple to a grounded ESD worksurface when placed on the worksurface. There is
no need for a separate ground cord for the foam when used in this fashion. The 1.9
lb/ft density provides cushioning protecting products from shock physical damage
Specifications:
Standard Document
Meets Requirements of:
ANSI/ESD S541 (ANSI/ESD S20.20) ESD Protective Packaging
Property
Cushion Grade, Black
Test Method
Density
Results
1.9 lb/ft3
Surface Resistance
1 x 105 to < 1 x 109 ohms
ANSI/ESD S4.1
Corrosivity
Pass
TS 1021BA (UK MOD)
ASTM D3575-91
Water Extract
Pass
TS 1021BA (UK MOD)
RoHS 3, REACH, and Conflict Minerals Statement
See the Desco Industries RoHS 3, REACH, and Conflict
Minerals Statement:
http://www.descoindustries.com/ROHS.aspx
Total Chlorine
Pass
TS 1021BA (UK MOD)
Recommended Operating
Temperature Range
+200°F to -95°F
Internal
See the Desco Limited Warranty:
http://desco.descoindustries.com/Limited-Warranty.aspx
Tear Strength
14 lbf/in
ASTM D3575-91
Tensile Strength
44 psi
ASTM D2575-91
See the Desco Disclaimer:
http://desco.descoindustries.com/Disclaimer.aspx
Consistent with ANSI/ESD S541 section A.3 “Dissipative Material for
Intimate Contact, To avoid rapid discharge to sensitive items, dissipative
materials should be used as the layer of packaging that contacts the item.”
ESD Handbook ESD TR20.20 section 5.3.1.7 Electrical Considerations
“[RTG is] The most important functional consideration for worksurfaces.
This establishes the resistance of the primary path to ground for items,
placed on the surface. When worksurface materials are being selected,
consideration should be given to possible Charged Device Model (CDM)
damage to ESD sensitive products. If CDM damage is a concern then
setting a lower resistance limit for the worksurface should be considered.
Typically, the lower limit for these types of worksurfaces is 1 x 106 ohms.
Item
Thickness
Size (in.)
12665
1/8
40 x 75
12666
1/4
40 x 75
12667
3/8
40 x 75
12668
1/2
40 x 75
Dimensions are nominal; thickness is ± 1/16".
Unless otherwise noted, tolerance is ±10%
Specifications and procedures subject to change without notice.
Statfree® Black Cushion Grade Static Dissipative Foam
DESCO WEST: 3651 WALNUT AVE., CHINO, CA 91710 WEB SITE: Desco.com
PHONE (909) 627-8178 FAX (909) 627-7449
DESCO EAST: ONE COLGATE WAY, CANTON, MA 02021-1407
PHONE (781) 821-8370 FAX (781) 575-0172
© 2020 DESCO INDUSTRIES INC.
Employee Owned
Made in the
United States of America
DRAWING NUMBER
12665
DATE:
August
2020
很抱歉,暂时无法提供与“12665”相匹配的价格&库存,您可以联系我们找货
