Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 4
MODEL: CMT-6635C-030 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
FEATURES
• externally driven
• wave solderable
• rated frequency of 3000 Hz
SPECIFICATIONS
parameter
rated voltage
conditions/description
Vo-p
min
2.0
0V
at rated voltage, 3,000 Hz square wave, ½ duty
rated frequency
sound pressure level
at 10 cm (A-weight), rated voltage, 3,000 Hz square wave,
½ duty
coil resistance
dimensions
max
3.0
operating voltage
current consumption
typ
units
Vo-p
5.0
Vo-p
80
mA
3,000
Hz
75
80
dBA
13
16
19
Ø6.6 x 3.5
Ω
mm
weight
0.4
material
PPO
terminal
pin type (Au plating)
g
operating temperature
-20
60
°C
storage temperature
-30
70
°C
max
units
250
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106 kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
wave soldering
see recommended wave soldering profile
min
Wave Solder Profile
3 Sec Max
250
2~5 °C/Sec
Temperature (°C)
130 °C/Sec
2~5 °C/Sec
110
25
40 Sec
60 Sec
Preheating
1.5
Sec Max
Melting
Time (sec)
cuidevices.com
100 Sec
Cooling
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CMT-6635C-030 | DESCRIPTION: MAGNETIC BUZZER TRANSDUCER
date 08/05/2022 | page 2 of 4
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
6RXQG+ROH
01 1 1
WEEK
01
02
FREQUENCY RESPONSE CURVE
MEASUREMENT METHOD
+VDC
+2.5V
180Ω
TR:
2SC1741AS
cuidevices.com
YEAR
10--2010
11--2011
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 4
PACKAGING
units: mm
Tray Size: 170 x 170 x 5 mm
Carton Size: 440 x 400 x 310 mm
Tray QTY: 225 pcs per tray
Carton QTY: 13,500 pcs per carton
PE Foam
Lot No.
XXXXXXXXXX
Model No. XXXXXXXXXX
Quantity.
XXXX
Pcs
3&63()RDP
Date:
DD MM YY
G
MADE IN CHINA
&DUWRQ%R[
3&62XW%R[
CUI Inc
PP
The label is placed on the inner
boxes and outer carton.
PP
cuidevices.com
PP
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 4 of 4
REVISION HISTORY
rev.
description
date
1.0
initial release
03/29/2016
1.01
brand update
11/22/2019
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CMT-6635C-030”相匹配的价格&库存,您可以联系我们找货
