Additional Resources:
Product Page
3D Model
PCB Footprint
date
08/05/2022
page 1 of 3
MODEL: CPE-223 | DESCRIPTION: PIEZO BUZZER INDICATOR
FEATURES
• through-hole pins
• 12 Vdc rating
• 3.3 kHz rated frequency
SPECIFICATIONS
parameter
conditions/description
min
rated voltage
max
12
operating voltage
current consumption
typ
3
at rated voltage
rated frequency
2,800
sound pressure level
at 30 cm, rated voltage
dimensions
Ø23.8 x 12.2
3,300
units
Vdc
Vdc
13
mA
3,800
81
Hz
dB
mm
weight
material
PBT+15% Glass
terminal
pin type (Sn plating)
3.5
g
operating temperature
-20
85
°C
storage temperature
-30
95
°C
max
units
380
°C
260
°C
RoHS
Notes:
yes
1. All specifications measured at 5~35°C, humidity at 45~85%, under 86~106kPa pressure, unless otherwise noted.
SOLDERABILITY
parameter
min
hand soldering
for maximum 5 seconds
330
wave soldering
see wave solder profile
5 Sec Max
260
Temperature (°C)
2000 °C/Sec
120
2~5 °C/Sec
2~5 °C/Sec
25
40 Sec
60 Sec
Preheating
1.5
Sec Max
Melting
Time (sec)
cuidevices.com
100 Sec
Cooling
typ
Product Page
3D Model
PCB Footprint
CUI DEVICES | MODEL: CPE-223 | DESCRIPTION: PIEZO BUZZER INDICATOR
MECHANICAL DRAWING
units: mm
tolerance: ±0.5 mm
PERFORMANCE CURVES
P: Voltage vs. Sound Pressure Level
I: Voltage vs. Current Consumption
cuidevices.com
date 08/05/2022 | page 2 of 3
Product Page
3D Model
PCB Footprint
date 08/05/2022 | page 3 of 3
REVISION HISTORY
rev.
description
date
1.0
initial release
11/12/2007
1.01
brand update
12/16/2019
logo, datasheet style update
08/05/2022
1.02
The revision history provided is for informational purposes only and is believed to be accurate.
CUI Devices offers a one (1) year limited warranty. Complete warranty information is listed on our website.
CUI Devices reserves the right to make changes to the product at any time without notice. Information provided by CUI Devices is believed to be accurate
and reliable. However, no responsibility is assumed by CUI Devices for its use, nor for any infringements of patents or other rights of third parties which may
result from its use.
CUI Devices products are not authorized or warranted for use as critical components in equipment that requires an extremely high level of reliability. A
critical component is any component of a life support device or system whose failure to perform can be reasonably expected to cause the failure of the life
support device or system, or to affect its safety or effectiveness.
cuidevices.com
很抱歉,暂时无法提供与“CPE-223”相匹配的价格&库存,您可以联系我们找货
