60×60×25 mm
San Cooler 60 9A type
■ General Specifications
· Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0)
· Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage)
Expected life at 40°C is for reference only.
· Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 599.
· Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
· Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
· Sound pressure level (SPL)……………… At 1 m away from the air inlet
· Storage temperature……………………… -30 to +70˚C (Non-condensing)
· Lead wire……………………………………
Red
Black or Blue
Sensor
Yellow
· Mass………………………………………… 80 g
■ Specifications
The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers.
Model no.
Rated voltage
Operating voltage range
Rated current
Rated input
Rated speed
[V]
[V]
[A]
[W]
[min-1]
6 to 13.2
9A0612G401
9A0612S401
9A0612H401
9A0612F401
9A0612M401
12
6 to 13.8
7 to 13.8
9A0624G401
9A0624S401
9A0624H401
9A0624F401
9A0624M401
24
12 to 27.6
14 to 27.6
Max. airflow
[m3/min]
[CFM]
Max. static pressure
[Pa]
[inchH2O]
SPL
Operating temperature
[dB (A)]
[˚C]
Expected life
[h]
0.24
2.88
5600
0.78
27.6
87.3
0.351
39
-20 to +60
30000/60˚C
(53000/40˚C)
0.17
0.11
0.09
0.06
2.04
1.32
1.08
0.72
4600
3800
3200
2600
0.65
0.53
0.44
0.36
23.0
18.7
15.5
12.7
56.8
40.2
29.4
19.6
0.228
0.161
0.118
0.079
33
28
24
-20 to +70
40000/60˚C
(70000/40˚C)
0.13
3.12
5600
0.78
27.6
87.3
0.351
39
-20 to +60
30000/60˚C
(53000/40˚C)
0.08
0.06
0.05
0.04
1.92
1.44
1.2
0.96
4600
3800
3200
2600
0.65
0.53
0.44
0.36
23.0
18.7
15.5
12.7
56.8
40.2
29.4
19.6
0.228
0.161
0.118
0.079
33
28
24
-20 to +70
40000/60˚C
(70000/40˚C)
Note 1: Sensor and control options are available for selection. Refer to the table on pp. 623 to 624.
Note 2: The
mark indicates Short Lead Time Service applicable models. See p. 654 for details.
■ Airflow - Static Pressure Characteristics
9A0612S401
With pulse sensor
(inch H2O) (Pa)
(inch H2O) (Pa)
110
100
90
80
70
60
50
40
30
0.40
0.35
0.30
0.25
0.20
0.15
0.10
0.05
13.2 V
12 V
6V
5
10 15 20 25 30
Airflow
CATALOG No. C1111B002 '21.9.IT
0.25
0.15
40
0.10
(CFM)
0.25
13.8 V
0.20
60
50
With pulse sensor
(inch H2O) (Pa)
70
0.20
0.05
0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min)
Static pressure
0.45
9A0612H401
With pulse sensor
Static pressure
9A0612G401
Static pressure
DC
DC Fan 60 mm sq.
DC Fan
12 V
6V
30
0.10
0.2
0.6
0.8
1.0 (m3/min)
5 10 15 20 25 30 35
Airflow
(CFM)
13.8 V
50
40
12 V
30
6V
10
0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min)
10
15
Airflow
25 (CFM)
9A0612M401
With pulse sensor
(inch H2O) (Pa)
40
13.8 V
30
0.10
0.08
12 V
0.04
10
6V
0.02
0.10
25
0.08
15
0.04
10
0.02
5
0.1 0.2 0.3 0.4 0.5 0.6 (m3/min)
10
15
(inch H2O) (Pa)
13.8 V
12 V
7V
0.1
(CFM)
Airflow
9A0624S401
9A0624H401
With pulse sensor
Static pressure
Static pressure
0.15
0.05
27.6 V
60
40
0.10
0.25
70
50
0.5
15
(m3/min)
24 V
12 V
30
0.10
0.2
0.6
0.05
0.8
1.0 (m3/min)
5 10 15 20 25 30 35
24 V
12 V
9A0624F401
With pulse sensor
5
10 15 20 25 30
(CFM)
With pulse sensor
(inch H2O) (Pa)
0.16
60
27.6 V
50
40
40
0.14
24 V
30
12 V
10
0.12
27.6 V
30
0.10
0.08
24 V
0.04
10
12 V
0.02
(CFM)
Airflow
9A0624M401
27.6 V
Airflow
0.15
0.10
0.05
110
100
90
80
70
60
50
40
30
20 (CFM)
(inch H2O) (Pa)
80
0.20
0.4
(inch H2O) (Pa)
0.25
0.3
10
0.45
0.40
0.35
0.30
0.25
Airflow
0.30
0.2
5
Static pressure
0.12
Static pressure
Static pressure
0.14
0.12
With pulse sensor
Static pressure
(inch H2O) (Pa)
0.16
9A0624G401
With pulse sensor
DC Fan 60 mm sq.
9A0612F401
DC
5
10
15
25 (CFM)
Airflow
10
15
(CFM)
Airflow
With pulse sensor
Static pressure
(inch H2O) (Pa)
0.12
30
0.10
25
0.08
15
0.04
10
0.02
5
27.6 V
24 V
14 V
0.1
5
0.3
0.4
10
0.5
15
(m3/min)
20 (CFM)
Airflow
■ Dimensions (unit: mm)
(With ribs)
+1
60 0
25±0.5
4-ø4.3±0.3
Mounting hole
(3)
(3)
Lead wire
AWG24
UL 1007
+50
300 0
50±0.3
+1
60 0
50±0.3
(10)
Rotating direction
Airflow direction
81
Inlet side, Outlet side
DC Fan 60 mm sq.
59
4-ø4.5
50±0.3
59
29.7
62
.7
29.7
50±0.3
DC
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
■ Options
Finger guards
page: p. 584
Model no.: 109-139E, 109-139H
Resin filter kits
Model no.: 109-1003G
page: p. 592
Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI),
109-1003F30 (30PPI), 109-1003F40 (40PPI)
82
Resin finger guards
page: p. 591
很抱歉,暂时无法提供与“9A0624H402”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+131.18317
- 5+128.42350
- 10+126.10122
