109P0824M7D01
109P0824M7D01
    SANYODENKI
    FAN80X15MM24VDCLOCK
109P0824M7D01 数据手册
80×80×15 mm San Ace 80 9P type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Yellow Sensor · Mass………………………………………… 68 g ■ Specifications The models listed below have ribs and pulse sensors. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 109P0812H701 12 109P0812M701 109P0824H701 7 to 13.8 24 109P0824M701 14 to 27.6 Max. airflow [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] SPL Operating temperature [dB (A)] [˚C] [h] -20 to +70 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) 0.2 2.4 3100 0.91 32.1 29.4 0.118 31 0.09 1.08 2000 0.57 20.1 12.6 0.051 21 0.1 2.4 3100 0.91 32.1 29.4 0.118 31 0.05 1.2 2000 0.57 20.1 12.6 0.051 21 Expected life Note 1: Sensor and control options are available for selection. Refer to the table on p. 622. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics 109P0812H701 109P0812M701 With pulse sensor Operating voltage range 0.12 12 V 20 7V 0.06 0.04 0.06 13.8 V 30 0.10 0.08 10 0 0.2 0.4 0.6 0.8 1.0 1.2 (m3/min) 0 10 20 30 40 Airflow 96 0.05 CATALOG No. C1111B002 '21.9.IT (CFM) 0.16 16 12 V 12 0.03 0.02 0 7V 8 40 0.14 13.2 V 0.04 0.01 0.02 0 (inch H2O) (Pa) Static pressure 0.07 0.14 With pulse sensor Operating voltage range (inch H2O) (Pa) 40 Static pressure 0.16 109P0824H701 With pulse sensor Operating voltage range (inch H2O) (Pa) Static pressure DC DC Fan 80 mm sq. DC Fan 4 0.12 27.6 V 30 24 V 0.10 0.08 20 14 V 0.06 0.04 10 0.02 0 0.2 0 5 0.4 10 15 0.6 20 Airflow 0.8 (m3/min) 25 30 (CFM) 0 0 0.2 0.4 0.6 0.8 1.0 1.2 (m3/min) 0 10 20 30 Airflow 40 (CFM) 109P0824M701 DC ■ Airflow - Static Pressure Characteristics DC Fan 80 mm sq. With pulse sensor Operating voltage range (inch H2O) (Pa) 0.07 Static pressure 0.06 0.05 16 27.6 V 24 V 12 0.04 0.03 0.02 0.01 0 14 V 8 4 0 0.2 0 5 0.4 10 0.6 15 20 0.8 (m3/min) 25 30 (CFM) Airflow ■ Dimensions (unit: mm) +1 15 0 4-ø4.3±0.3 Mounting hole (3.5) (3.5) Lead wire AWG24 UL 1007 +30 300 0 71.5±0.3 80±0.5 80±0.5 71.5±0.3 (10) Airflow direction Rotating direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side Outlet side 71.5±0.3 4-ø4.5 5 9. 4 ø8 78 71.5±0.3 ø8 78 4-ø4.5 78 71.5±0.3 71.5±0.3 78 ■ Options Finger guards page: p. 584 Model no.: 109-049E, 109-049H, 109-049C Resin filter kits Resin finger guards page: p. 591 Model no.: 109-1002G page: p. 592 Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI), 109-1002F30 (30PPI), 109-1002F40 (40PPI) CATALOG No. C1111B002 '21.9.IT 97
109P0824M7D01 价格&库存
很抱歉,暂时无法提供与“109P0824M7D01”相匹配的价格&库存,您可以联系我们找货
