DC Fan
92
San Ace 92
mm sq.
■ General Specifications
25mm thick (9GA type), 25mm thick (9S type)
25mm thick (9P type), 25mm thick (San Cooler) (9A type)
32mm thick (9G type), 38mm thick (9GA type)
38mm thick (9HV type), 38mm thick (9GV type)
38mm thick (9G type)
・Material …………………… Frame: Plastics (Flammability: UL94V-0),
Impeller: Plastics (Flammability: UL94V-1)
・Expected Life …………… Refer to specifications(L10:Survival rate:90% at 60℃ ,
rated voltage, and continuously run in a free air state)
Sensor yellow
・Storage Temperature …-30℃ to +70℃(Non-condensing)
・Lead Wire …………………⊕red ⊖black or blue
92×92×25mm
■ Specifications
9P type
〔Mass:150g〕
The following nos. have pulse sensors and ribs. For ribless, append "1" to the model no.
Rated Voltage Operating Voltage Range Rated Current Rated Input
Model No.
[V]
109P0912J401
109P0912W401
109P0912H401
109P0912F401
109P0912M401
109P0912L401
109P0924W401
109P0924H401
109P0924F401
109P0924M401
109P0924L401
109P0948H401
[W]
[min-1]
[m³/min]
[CFM]
6 to 13.8
6 to 16
0.56
0.21
0.21
0.14
0.1
0.07
0.12
0.12
0.08
0.06
0.05
0.06
6.72
2.52
2.52
1.68
1.2
0.84
2.88
2.88
1.92
1.44
1.2
2.88
4,300
2,850
2,850
2,450
2,100
1,700
2,850
2,850
2,450
2,100
1,700
2,850
2.03
1.45
1.45
1.24
1.04
0.8
1.45
1.45
1.24
1.04
0.8
1.45
71.6
51.2
51.2
43.8
36.7
28.3
51.2
51.2
43.8
36.7
28.3
51.2
10.2 to 13.8
12 to 30
48
Max. Airflow
[A]
12
24
Rated Speed
[V]
20.4 to 27.6
43 to 53
Max. Static Pressure
SPL
Operating Temperature Expected Life
[Pa] [inchH²O] [dB(A)]
92.2
45
45
32.3
23.5
16.6
45
45
32.3
23.5
16.6
45
0.37
0.181
0.181
0.130
0.094
0.067
0.181
0.181
0.130
0.094
0.067
0.181
47
33
33
30
27
23
33
33
30
27
23
33
[h]
-20 to +60
-20 to +70
40,000
-20 to +70
Some models can also be equipped without sensors as an option. Please refer to the index (pp. 417 to 437).
■Set Models
・The set models listed below can be ordered as a single order.
Set configuration items: Fan (without sensor), finger guard, screws (with flat washer and spring washer), hex nuts, operation manual
Fan Model
Sensor Specifications
9U-109P0912H402
109P0912H402 (performs the same as the 109P0912H401)
9U-109P0924H402
109P0924H402 (performs the same as the 109P0924H401)
■ Dimensions(unit : mm)(With ribs)
4-φ4.3±0.3
Mounting
取付用穴 Hole
109-099E
■ Options(unit : mm)
Finger Guards
25±0.5
(4)
Mounting Screws
M4 screws (40 mm) x 4,
Nuts x 4
Model:109-099C
(4)
Outlet side
+1
4.3±0.3 5 0
φ1.6
φ1.6 8
9.
φ3φ87
+1.5
120.5 ー0.5
+30
300 0
99
92±0.5
82.5±0.3
Lead
Wire
リード線
AWG24
UL1007
.6
16
φ1
(10)
Rotating
Direction
回転方向
Mass
質量:22g
Airflow
Direction
風吹出方向
■ Reference Dimension of
Model:109-099E
:109-099H
Mounting Holes and Vent Opening(unit : mm)
90.5
+1.5
82.5±0.3
10
φ
Color
Surface treatment :Nickel-chrome plating(silver)
:Cation electropainting(black)
Inlet side, Outlet side
4-φ4.5
8
3
82.5±0.3
90.5
82.5±0.3
4-φ4.5
10
φ
Outlet side
120.5 -0.5
Inlet side
82.5±0.3
Color
+1
5 0
4.3±0.3
φ1.6
φ1.6
7
φ8
91
92±0.5
82.5±0.3
Without sensor
Finger Guard Model
99
Model Number to Order
.6
16
φ1
131
90.5
90.5
質量:29g
Mass
Resin Filter Kits
Model:109-1001G
Model:109-1001F13(13PPI)
,109-1001F20(20PPI)
:109-1001F30(30PPI)
,109-1001F40(40PPI)
96.5±1
7±0.5
4-2±0.5
4-φ4.3±0.3
10.5±0.5
82.5±0.3
96.5±1
4-φ4.3±0.3
82.5±0.3
82.5±0.3
92±1
92±1
82.5±0.3
4-φ9.5±0.5
質量:12g
Mass
Mass
質量:25g
4-2±0.5
■ Airflow - Static Pressure Characteristics
(inch H2O) (Pa)
0.30
13.8V
12V
6V
0.5
1
1.5
2
0 10 20 30 40 50 60 70 80
風量
→ Airflow
60
0.20
50
10
H speed
(inch H2O)(Pa)
13.8V/27.6V
12V/24V
30
0.10
10.2V/20.4V
10
1.0
1.5
0.20
0.15
0.10
0.05
2.0 (m3/min)
25
0.08
10
0.02
5
48V
43V
30
1.0
(Pa)
(inch H2O)
24V
30
10
12V
0.5
1.5
1.0
1.5
2.0 (m3/min)
風量
Airflow
0.15
53V
40
30V
40
(CFM)
2.0 (m3/min)
(CFM)
109P0948H401
M speed
(CFM)
F speed
40
13.8V/27.6V
30
12V/24V
0.10
10.2V/20.4V
30
40
風量
Airflow
1.5 (m3/min)
50
(CFM)
109P0912F401
109P0924F401
L speed
0.10 25
13.8V/27.6V
12V/24V
10.2V/20.4V
15
0.04
50
(inch H2O)(Pa)
Airflow
風量
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
0.10
0.20
109P0924W401
109P0912H401
109P0924H401
30
2.0 (m3/min)
H speed
50
Airflow
風量
0.12
1.5
60
0 10 20 30 40 50 60 70 (CFM)
(inch H2O)(Pa)
1.0
風量
→ Airflow
0.25
40
0.5
60
0.15
Wide range
70
0.25
109P0912W401
50
0.15
6V
60
0.20
12V
30
0.10
90 (CFM)
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
0.25
0.30
16V
40
0.15
109P0912J401
(inch H2O)(Pa)
(inch H2O) (Pa)
70
0.25
2.5 (m3/min)
Wide range
→ Static
Pressure
→ 静圧
120
0.45 110
0.4 100
0.35 90
80
0.3
70
0.25 60
0.2
50
0.15 40
30
0.1
→ Static
Pressure
→ 静圧
→ Static
Pressure
→ 静圧
0.5
→ Static
Pressure
→ 静圧
J speed
(inch H2O)(Pa)
0.5
30
40
Airflow
風量
109P0912M401
109P0924M401
1.5 (m3/min)
50
(CFM)
0.08 20
0.06 15
0.04 10
0.02
5
13.8V/27.6V
12V/24V
10.2V/20.4V
0.2 0.4 0.6 0.8 1.0 1.2
0 5 10 15 20 25 30 35 40
Airflow
風量
(m3/min)
(CFM)
109P0912L401
109P0924L401
132
DC Fan 92mm
Resin Finger Guards
DC
很抱歉,暂时无法提供与“109P0912H4D01”相匹配的价格&库存,您可以联系我们找货
