109L0912H401
109L0912H401
    SANYODENKI
    FAN92X25MM12VDCRBLSTACH
109L0912H401 数据手册
Long Life Fan 92 San Ace 92L 25mm thick mm sq. ■ General Specifications ・Material …………………… Frame: Aluminum, Impeller: Plastics (Flammability: UL94V-1) ・Expected Life …………… Refer to specifications (L10:Survival rate: 90% at 60℃ , rated voltage, and continuously run in a free air state) ・Lead Wire ………………… 䊝red 䊞black or blue Sensor yellow ・Storage Temperature …−30℃ to +70℃(Non-condensing) 92×92×25mm ■ Specifications Model No. Model no. 109L0948C401 is not certified. 〔Mass:170g〕 The following nos. have pulse sensors. Rated Voltage Operating Voltage Range Rated Current Rated Input [V] 109L0912S401 109L0912H401 109L0912F401 109L0912M401 109L0912L401 109L0924H401 109L0924F401 109L0924M401 109L0924L401 109L0948C401 109L0948H401 12 [V] 20.4 to 27.6 48 43 to 53 40.8 to 55.2 Max. Air Flow Max. Static Pressure [W] [min-1] [m³/min] [CFM] 0.32 0.21 0.14 0.11 0.08 0.12 0.08 0.06 0.05 0.1 0.06 3.84 2.52 1.68 1.32 0.96 2.88 1.92 1.44 1.2 4.8 2.88 3,500 2,850 2,450 2,100 1,700 2,850 2,450 2,100 1,700 3,400 2,850 1.69 1.38 1.18 1.01 0.80 1.38 1.18 1.01 0.80 1.65 1.38 59.7 48.7 41.7 35.7 28.2 48.7 41.7 35.7 28.2 58.3 48.7 10.2 to 13.8 24 Rated Speed [A] SPL [Pa] [inchH²O] [dB(A)] 66.6 45.1 32.3 23.5 16.7 45.1 32.3 23.5 16.7 64.2 45.1 0.267 0.181 0.130 0.094 0.067 0.181 0.130 0.094 0.067 0.258 0.181 39 33 30 27 23 33 30 27 23 38 33 ・Available options: ⇒ Without Sensor ・Please inquire as the availability of these functions depend on the model. ⇒ Lock Sensor Low speed Sensor ■ Dimensions(Unit : mm) 8-φ4.3±0.3 Mounting Hole 取付用穴 25±0.5 3.5±0.3 3.5±0.3 Lead Wire リード線 AWG24 UL1007 82.5±0.3 92±0.5 92±0.5 82.5±0.3 +30 300 0 (10) Rotating Direction 回転方向 Air Flow Direction 風吹出方向 ■ Reference dimension of mounting holes and vent opening(Unit : mm) Inlet side Outlet side 4-φ4.5 2 0 90 293 10 φ 90 10 82.5±0.3 90 φ 4-φ4.5 82.5±0.3 90 82.5±0.3 82.5±0.3 Operating Temperature Expected Life [℃] [h] 100,000 − 20 to + 70 80,000 100,000 ■ Options(Unit : mm) Finger guards Resin Finger guards Model:109-099C Model:109-1001G Color Surface treatment :Nickel-chrome plating(silver) 92±1 Outlet side 92±1 4-φ4.3±0.3 4-2±0.5 82.5±0.3 99 +1.5 120.5 ー0.5 4.3±0.3 φ1.6 φ1.6 9.8 φ3φ87 7±0.5 82.5±0.3 5+10 .6 16 φ1 Resin filter kits Model:109-1001F13(13PPI) ,109-1001F20(20PPI) :109-1001F30(30PPI) ,109-1001F40(40PPI) Inlet side, Outlet side 96.5±1 5 4.3±0.3 φ1.6 φ1.6 10.5±0.5 82.5±0.3 +1  0 Long Life Fan 92mm Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Model:109-099E :109-099H 4-φ4.3±0.3 96.5±1 82.5±0.3 91 99 +1.5 120.5 −0.5 7 φ8 .6 16 φ1 4-φ9.5±0.5 4-2±0.5 ■ Air Flow - Static Pressure Characteristics S speed (inch H2O)(Pa) 0.40 60 0.20 50 0.15 40 12V 10.2V 30 20 0.05 10 0 0 70 0.5 0 1.0 20 1.5 40 2.0 60 0.25 50 0.15 40 0.10 53V 60 0.20 48V 43V 30 20 0.05 0 (m3/min) 80 70 10 0 0.5 F speed → Static Pressure → 静圧 → Static Pressure → 静圧 13.8V/27.6V 12V/24V 10.2V/20.4V 20 10 0.5 0 10 20 10.2V/20.4V/40.8V 30 0.10 20 0.05 10 0 0 0.5 0.12 30 1.0 30 1.5 50 → Air → Flow 風量 109L0912F401 109L0924F401 0 (m3/min) 60(CFM) 12V/24V 20 10.2V/20.4V 10 0 0.5 0 2.0 (m3/min) L speed 13.8V/27.6V 0.06 0.04 1.5 (inch H2O)(Pa) 0.10 0.08 1.0 109L0912H401 109L0924H401 109L0948H401 0.02 0 0.15 0 10 20 30 50 60 70 (CFM) 0.14 0.10 12V/24V/48V 40 M speed 50 40 50 → Air → Flow 風量 (inch H2O)(Pa) 30 0 2.0 (m3/min) 13.8V/27.6V/55.2V 0.20 109L0948C401 (inch H2O)(Pa) 0.05 1.5 60 → Air → Flow 風量 109L0912S401 0.15 1.0 0.25 0 10 20 30 50 60 70 (CFM) (CFM) → Air → Flow 風量 0.20 → Static Pressure → 静圧 13.8V 70 H speed 0.30 80 0.30 80 0.25 0.10 (inch H2O)(Pa) → Static Pressure → 静圧 0.30 90 → Static Pressure → 静圧 → Static Pressure → 静圧 0.35 C speed (inch H2O)(Pa) 10 20 1.0 30 40 1.5 (m3/min) 50 → Air → Flow 風量 109L0912M401 109L0924M401 (CFM) 0.10 25 0.08 20 0.06 15 0.04 10 0.02 5 0 0 13.8V/27.6V 12V/24V 10.2V/20.4V 0.2 0.4 0.6 0.8 1.0 1.2 (m3/min) 0 10 20 30 40 (CFM) → Air → Flow 風量 109L0912L401 109L0924L401 294
109L0912H401 价格&库存
很抱歉,暂时无法提供与“109L0912H401”相匹配的价格&库存,您可以联系我们找货
