9CRB0412P5K001
9CRB0412P5K001
    SANYODENKI
    FAN40X56MM12VDCTACH,PWM
9CRB0412P5K001 数据手册
Counter Rotating Fan 40 San Ace 40 mm sq. ■ General Specifications ・Material …………………… Frame: Plastics (Flammability: UL94V-0), Impeller: Plastics (Flammability: UL94V-0) ・Expected Life …………… Refer to specifications(L10:Survival rate:90% at 60℃ , rated voltage, and continuously run in a free air state) ⊕red ⊖black Sensor yellow Control brown Outlet ⊕orange ⊖gray Sensor purple Control white ・Storage Temperature …-30℃ to +70℃(Non-condensing) ・Lead Wire ………………… Inlet 40×40×56mm ■ Specifications 〔Mass:100g〕 The following nos. have PWM controls and pulse sensors. Rated Voltage Operating Voltage Range Model No. 9CRB type [V] [ V] PWM duty Rated Current Rated Input [W] cycle※[%] [A] 9CRB0412P5S201 12 9CRB0412P5K001 10.8 to 13.2 9CRB0412P5J201 100 0 100 0 100 0 1.4 0.09 0.88 0.11 0.72 0.07 16.8 1.08 10.56 1.32 8.64 0.84 Rated Speed Max. Airflow [min-1] [m³/min] [CFM] Inlet Outlet 22,000 3,800 19,000 5,700 17,300 3,450 19,700 3,500 17,000 5,100 16,000 3,200 0.9 0.15 0.76 0.21 0.71 0.13 Max. Static Pressure SPL Operating Temperature Expected Life [Pa] [inchH²O] [dB(A)] 31.8 1,045 5.3 31 26.83 730 7.41 67 25.1 650 4.59 26 4.197 0.124 2.93 0.26 2.61 0.10 [℃] 68 26 62 33 61 24 [h] -20 to +70 40,000/60℃ ※PWM Frequency:25kHz ■ Dimensions(unit: mm) Inlet side Outlet side +30 320 0 4-φ3.5±0.3 Mounting 取付用穴Hole 56±0.5 (10) (5) (5) 40±0.3 32±0.3 4-φ3.5±0.3 Mounting 取付用穴 Hole 32±0.3 40±0.3 (10) +30 320 0 Lead Wire リード線 AWG28 UL1061 回転方向 Rotating Direction AWG28 UL1007 (Model no.: 9CRB0412P5S201 only) (型番: 9CRB0412P5S201 のみ) 風吹出方向 Airflow Direction ■ Reference Dimensions of Mounting Holes and Vent Opening(unit: mm) Inlet side, Outlet side 39 32±0.3 4-φ3.7 39 (18) 213 32±0.3 39 .5 (18) 回転方向 Rotating Direction ■ Options(unit: mm) Finger Guards DC Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Model:109-059 :109-059H Inlet side, Outlet side 3.5±0.3 Counter Rotating Fan 40mm +1 4  0 φ1.6 φ1 .6 .5 38.5 49 +1.5 ー0.5 9 φ2 φ 18 . 3 .3 5 φ4 質量:7g Mass ■ Airflow - Static Pressure Characteristics PWM Duty Cycle 0 (inch H2O)(Pa) DC 12V 100% 50% 0% 0.2 0.4 0.6 0.8 2.5 3.0 100% 700 600 2.0 500 1.5 400 50% 300 1.0 200 0.5 0% 100 0 1.0(m3/min) PWM Duty Cycle PWMデューティ 800 3.0 (inch H2O)(Pa) DC12V 900 3.5 PWMデューティ PWM Duty Cycle → Pressure 静圧 → Static 4.5 1,100 4.0 1,000 3.5 900 800 3.0 700 2.5 600 2.0 500 1.5 400 300 1.0 200 0.5 100 0 0 → Static →Pressure 静圧 → Static → Pressure 静圧 (inch H2O) (Pa) 0 5 10 15 20 25 30 35(CFM) 0.2 0 →Airflow 風量 → 9CRB0412P5S201 0.4 0.6 0.8 600 2.0 500 1.5 400 0.5 0 1.0(m3/min) 5 10 15 20 25 30 35 (CFM) →→ 風量 Airflow 9CRB0412P5K001 PWM Duty Cycle PWMデューティ 700 2.5 1.0 DC 12V 800 100% 300 50% 200 100 0% 0 0.2 0 5 10 15 20 25 30 35(CFM) 0.4 0.6 0.8 1.0(m3/min) →→ Airflow 風量 9CRB0412P5J201 Operating Voltage Range 0 (inch H2O)(Pa) PWM Duty Cycle 100% PWMデューティ100% 3.5 12V/13.2V 10.8V 0.2 0.4 0.6 0.8 3.0 2.5 800 13.2V 700 12V 500 1.5 400 0.5 10.8V 300 200 100 0 1.0(m3/min) 0 5 10 15 20 25 30 35 (CFM) 0.2 0 →Airflow 風量 → 9CRB0412P5S201 3.0 600 2.0 1.0 (inch H2O)(Pa) PWM Duty Cycle 100% PWMデューティ100% 900 → Static → Pressure 静圧 4.5 1,100 4.0 1,000 3.5 900 800 3.0 700 2.5 600 2.0 500 1.5 400 300 1.0 200 0.5 100 0 0 → Static → Pressure 静圧 → Static Pressure → 静圧 (inch H2O) (Pa) 0.4 0.6 0.8 1.0(m3/min) 800 600 2.0 500 1.5 400 0.5 0 5 10 15 20 25 30 35 (CFM) 風量 →→ Airflow 9CRB0412P5K001 12V/13.2V 700 2.5 1.0 PWM Duty Cycle 100% PWMデューティ100% 10.8V 300 200 100 0 0.2 0 5 10 15 20 25 30 35 (CFM) 0.4 0.6 0.8 1.0(m3/min) → 風量 → Airflow 9CRB0412P5J201 ■ PWM Duty - Speed Characteristics Example 20,000 (min-1) 20,000 22,000min-1 19,700min-1 Inlet 吸込側 15,000 3,800min-1 10,000 Outlet 吐出側 5,000 3,500min-1 0 100(%) PWM Duty Cycle PWM デューティサイクル 9CRB0412P5S201 :12V DC Voltage 電圧:DC12V PWM Frequency PWM周波数 :25kHz:25kHz 19,000min 17,000min-1 Inlet 吸込側 15,000 (min-1) 5,700min-1 Outlet 吐出側 10,000 5,000 0 20,000 -1 5,100min-1 100(%) PWM Duty Cycle PWM デューティサイクル 9CRB0412P5K001 → 回転速度 → Rotation Speed → 回転速度 → Rotation Speed 25,000 :12V DC Voltage 電圧:DC12V PWM Frequency:25kHz PWM周波数:25kHz → 回転速度 → Rotation Speed (min-1) 15,000 :12V DC Voltage 電圧:DC12V PWM Frequency PWM周波数 :25kHz:25kHz Inlet 吸込側 10,000 3,450min-1 5,000 0 17,300min-1 16,000min-1 Outlet 吐出側 3,200min-1 100(%) PWM Duty Cycle PWM デューティサイクル 9CRB0412P5J201 214
9CRB0412P5K001 价格&库存
很抱歉,暂时无法提供与“9CRB0412P5K001”相匹配的价格&库存,您可以联系我们找货
