9WP0812G401
9WP0812G401
    SANYODENKI
    FAN80X25MM12VDCIP68TACH
9WP0812G401 数据手册
Splash Proof Fan 80×80×25 mm IP68 San Ace 80W 9WP type · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in indoor free air at 60°C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black Yellow Sensor · Mass………………………………………… 130 g · Ingress protection………………………… IP68 ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 9WP0812G401 12 9WP0812H401 9WP0824S401 9WP0824H401 9WP0848S401 Max. airflow [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] SPL Operating temperature [dB (A)] [˚C] 10.8 to 13.2 0.38 4.56 4500 1.5 53 80.4 0.323 40 10.2 to 13.8 0.13 1.56 2900 1.03 36.4 35.3 0.142 29 0.1 2.4 3400 1.2 42.4 48.0 0.193 34 0.07 1.68 2900 1.03 36.4 35.3 0.142 29 0.06 2.88 3400 1.2 42.4 48.0 0.193 34 24 20.4 to 27.6 48 40.8 to 55.2 Expected life [h] -20 to +60 -20 to +70 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) 40000/60˚C (70000/40˚C) 60000/60˚C (90000/40˚C) 40000/60˚C (70000/40˚C) Note: Sensor and control options are available for selection. Refer to the table on p. 639. ■ Airflow - Static Pressure Characteristics 9WP0812G401 9WP0812H401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 0.30 0.25 0.20 0.15 0.10 0.05 0 (inch H2O) (Pa) (inch H2O) (Pa) 13.2 V 12 V 10.8 V 0.2 0.4 0.6 0.8 1.0 1.2 1.4 1.6 1.8 (m3/min) 0 10 20 30 40 50 60 Airflow (CFM) 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 With pulse sensor Operating voltage range 50 70 0.25 40 13.8 V 12 V 10.2 V 30 Static pressure Static pressure 0.35 100 90 80 70 60 50 40 30 20 10 0 Static pressure 0.40 9WP0824S401 With pulse sensor 20 10 50 0.15 40 0.10 0.05 0 0.5 0 10 20 1.0 30 Airflow 40 1.5 (m3/min) 50 (CFM) 60 0.20 0 27.6 V 24 V 30 20.4 V 20 10 0 0.5 0 10 20 1.0 30 40 1.5 (m3/min) 50 (CFM) Airflow CATALOG No. C1111B002 '21.9.IT 289 Splash Proof Fan 80 mm sq. DC ■ General Specifications ■ Airflow - Static Pressure Characteristics 9WP0824H401 9WP0848S401 With pulse sensor Operating voltage range With pulse sensor Operating voltage range (inch H2O) (Pa) 0.30 50 0.25 40 27.6 V 24 V 20.4 V 30 Static pressure Static pressure 0.20 0.18 0.16 0.14 0.12 0.10 0.08 0.06 0.04 0.02 0 20 10 0 0.5 0.15 40 0.10 0 10 20 30 40 50 55.2 V 60 50 48 V 40.8 V 30 20 0 1.5 (m3/min) 1.0 70 0.20 0.05 10 0 0.5 0 (CFM) 10 Airflow ■ Dimensions (unit: mm) 1.5 (m3/min) 1.0 30 40 50 (CFM) (With ribs) 80±0.5 71.5±0.3 4-ø4.3±0.3 Mounting hole (3) 25±0.5 (3) +30 300 0 71.5±0.3 80±0.5 20 Airflow (10) Lead wire AWG24 UL 1007 Rotating direction Airflow direction ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) Inlet side, Outlet side 71.5±0.3 4-ø4.5 71.5±0.3 0 ø9 78.5 Splash Proof Fan 80 mm sq. DC (inch H2O) (Pa) 78.5 ■ Options Finger guards Model no.: 109-049E, 109-049H, 109-049C 290 CATALOG No. C1111B002 '21.9.IT page: p. 584 Resin finger guards Model no.: 109-1002G page: p. 591
9WP0812G401 价格&库存
很抱歉,暂时无法提供与“9WP0812G401”相匹配的价格&库存,您可以联系我们找货
