9A0612G4D01
9A0612G4D01
    SANYODENKI
    FAN60X25MM12VDCLOCK
9A0612G4D01 数据手册
60×60×25 mm San Cooler 60 9A type ■ General Specifications · Material……………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-0) · Expected life………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C, rated voltage) Expected life at 40°C is for reference only. · Motor protection function………………… Locked rotor burnout protection, Reverse polarity protection For details, please refer to p. 599. · Dielectric strength………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame) · Insulation resistance……………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame) · Sound pressure level (SPL)……………… At 1 m away from the air inlet · Storage temperature……………………… -30 to +70˚C (Non-condensing) · Lead wire…………………………………… Red Black or Blue Sensor Yellow · Mass………………………………………… 80 g ■ Specifications The models listed below have ribs and pulse sensors. For models without ribs, append "1" to the end of model numbers. Model no. Rated voltage Operating voltage range Rated current Rated input Rated speed [V] [V] [A] [W] [min-1] 6 to 13.2 9A0612G401 9A0612S401 9A0612H401 9A0612F401 9A0612M401 12 6 to 13.8 7 to 13.8 9A0624G401 9A0624S401 9A0624H401 9A0624F401 9A0624M401 24 12 to 27.6 14 to 27.6 Max. airflow [m3/min] [CFM] Max. static pressure [Pa] [inchH2O] SPL Operating temperature [dB (A)] [˚C] Expected life [h] 0.24 2.88 5600 0.78 27.6 87.3 0.351 39 -20 to +60 30000/60˚C (53000/40˚C) 0.17 0.11 0.09 0.06 2.04 1.32 1.08 0.72 4600 3800 3200 2600 0.65 0.53 0.44 0.36 23.0 18.7 15.5 12.7 56.8 40.2 29.4 19.6 0.228 0.161 0.118 0.079 33 28 24 20 -20 to +70 40000/60˚C (70000/40˚C) 0.13 3.12 5600 0.78 27.6 87.3 0.351 39 -20 to +60 30000/60˚C (53000/40˚C) 0.08 0.06 0.05 0.04 1.92 1.44 1.2 0.96 4600 3800 3200 2600 0.65 0.53 0.44 0.36 23.0 18.7 15.5 12.7 56.8 40.2 29.4 19.6 0.228 0.161 0.118 0.079 33 28 24 20 -20 to +70 40000/60˚C (70000/40˚C) Note 1: Sensor and control options are available for selection. Refer to the table on pp. 623 to 624. Note 2: The mark indicates Short Lead Time Service applicable models. See p. 654 for details. ■ Airflow - Static Pressure Characteristics 9A0612S401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) (inch H2O) (Pa) 110 100 90 80 70 60 50 40 30 20 10 0 80 0.40 0.35 0.30 0.25 0.20 0.15 0.10 0.05 0 0.30 13.2 V 12 V 6V 5 10 15 20 25 30 Airflow CATALOG No. C1111B002 '21.9.IT 0.25 0.15 40 0.10 (CFM) 0 Operating voltage range 0.25 13.8 V 0.20 60 50 With pulse sensor (inch H2O) (Pa) 70 0.20 0.05 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) 0 80 Static pressure 0.45 9A0612H401 With pulse sensor Static pressure 9A0612G401 Static pressure DC DC Fan 60 mm sq. DC Fan 12 V 6V 30 20 0.15 0.10 0.2 0 0.4 0.6 0.8 1.0 (m3/min) 5 10 15 20 25 30 35 Airflow (CFM) 13.8 V 50 40 12 V 30 6V 20 0.05 10 0 60 0 10 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 0 5 10 15 Airflow 20 25 (CFM) 9A0612M401 With pulse sensor Operating voltage range Operating voltage range (inch H2O) (Pa) 40 13.8 V 30 0.10 0.08 12 V 20 0.06 0.04 10 6V 0.02 0 0 30 0.10 25 0.08 20 0.06 15 0.04 10 0.02 5 0 0 0.1 0.2 0.3 0.4 0.5 0.6 (m3/min) 0 5 10 15 20 (inch H2O) (Pa) 13.8 V 12 V 7V 0.1 0 (CFM) Airflow 9A0624S401 9A0624H401 With pulse sensor 0 0.20 Static pressure Static pressure 0.15 0.05 27.6 V 60 40 0.10 0.25 70 50 0.5 15 (m3/min) 24 V 12 V 30 20 0.15 0.10 0.2 0 0.4 0.6 0.05 0.8 0 1.0 (m3/min) 5 10 15 20 25 30 35 24 V 12 V 0.1 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 (m3/min) 0 9A0624F401 With pulse sensor 5 10 15 20 25 30 (CFM) With pulse sensor Operating voltage range (inch H2O) (Pa) 0.16 60 27.6 V 50 40 40 0.14 24 V 30 12 V 10 0.12 27.6 V 30 0.10 0.08 24 V 20 0.06 0.04 10 12 V 0.02 0 0.1 0.2 0.3 0.4 0.5 0.6 0.7 (m3/min) 0 (CFM) Airflow 9A0624M401 27.6 V Airflow 20 10 0 0.20 0.15 0.10 0.05 0 120 110 100 90 80 70 60 50 40 30 20 10 0 20 (CFM) (inch H2O) (Pa) 80 0.20 0.4 Operating voltage range (inch H2O) (Pa) 0.25 0.3 10 0.45 0.40 0.35 0.30 0.25 Airflow Operating voltage range 0.30 0.2 5 Static pressure 0.12 Static pressure Static pressure 0.14 0.12 With pulse sensor Operating voltage range Static pressure (inch H2O) (Pa) 0.16 9A0624G401 With pulse sensor DC Fan 60 mm sq. 9A0612F401 DC ■ Airflow - Static Pressure Characteristics 5 10 15 20 25 (CFM) Airflow 0 0 0.1 0.2 0.3 0.4 0.5 0.6 (m3/min) 0 5 10 15 20 (CFM) Airflow With pulse sensor Operating voltage range Static pressure (inch H2O) (Pa) 0.12 30 0.10 25 0.08 20 0.06 15 0.04 10 0.02 5 0 0 27.6 V 24 V 14 V 0.1 0 0.2 5 0.3 0.4 10 0.5 15 (m3/min) 20 (CFM) Airflow ■ Dimensions (unit: mm) (With ribs) +1 60 0 25±0.5 4-ø4.3±0.3 Mounting hole (3) (3) Lead wire AWG24 UL 1007 +50 300 0 50±0.3 +1 60 0 50±0.3 (10) Rotating direction Airflow direction CATALOG No. C1111B002 '21.9.IT 81 Inlet side, Outlet side DC Fan 60 mm sq. 59 4-ø4.5 50±0.3 59 29.7 62 .7 29.7 50±0.3 DC ■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm) ■ Options Finger guards page: p. 584 Model no.: 109-139E, 109-139H Resin filter kits Model no.: 109-1003G page: p. 592 Model no.: 109-1003F13 (13PPI), 109-1003F20 (20PPI), 109-1003F30 (30PPI), 109-1003F40 (40PPI) 82 CATALOG No. C1111B002 '21.9.IT Resin finger guards page: p. 591
9A0612G4D01 价格&库存
很抱歉,暂时无法提供与“9A0612G4D01”相匹配的价格&库存,您可以联系我们找货
