DC Fan
80×80×25 mm
San Ace 80 9GV type
■ General Specifications
・ Material ………………………………………… Frame: Plastic (Flammability: UL 94V-0), Impeller: Plastic (Flammability: UL 94V-1)
・ Expected life …………………………………… See the table below. (L10 life: 90% survival rate for continuous operation in free air at 60˚C,
rated voltage)
・ Motor protection function ………………… Locked rotor burnout protection, Reverse polarity protection
For details, please refer to p. 547.
・ Dielectric strength …………………………… 50/60 Hz, 500 VAC, for 1 minute (between lead wire conductors and frame)
・ Insulation resistance………………………… 10 MΩ or more with a 500 VDC megger (between lead wire conductors and frame)
・ Sound pressure level (SPL) ……………… At 1 m away from the air inlet
・ Storage temperature ……………………… -30 to +70˚C (Non-condensing)
・ Lead wire ………………………………………
Red
Black
Sensor
Yellow
Brown
Control
・ Mass ……………………………………………… 125 g
■ Specifications
The models listed below have ribs and pulse sensors with PWM control function. For models without ribs, append "1" to the end of model numbers.
Rated voltage Operating voltage range
Model no.
[V]
[V]
9GV0812P4K03
12
10.2 to 13.8
9GV0824P4K01
24
20.4 to 27.6
9GV0848P4K03
48
43 to 53
9GV0812P4J03
PWM duty
cycle* [%]
100
Rated current Rated input Rated speed
Max. airflow
Max. static pressure
[A]
[W]
[min-1]
[m³/min]
[CFM]
[Pa]
0.87
0.1
0.47
0.07
0.44
0.06
0.22
0.04
10.4
1.2
5.6
0.8
10.56
1.44
10.56
1.92
5600
1400
4500
1200
5600
1400
5600
1500
2.12
0.5
1.72
0.45
2.12
0.53
2.12
0.57
74.8
18.7
60.7
16.2
74.8
18.7
74.8
20.1
173.0
10.3
110.0
7.5
173.0
10.8
173.0
12.4
[inchH²O]
0.69
0.04
0.44
0.03
0.69
0.04
0.69
0.05
SPL
Operating temperature
Expected life
[dB (A)]
[˚C]
[h]
52
18
46
14
52
18
52
19
-20 to +70
40000/60˚C
* PWM frequency: 25 kHz
The following sensor and control options are available for selection.
Differs according to the model. Refer to the table on p. 574. Without sensor
Pulse sensor
Lock sensor
■ Airflow - Static Pressure Characteristics / PWM Duty - Speed Characteristics Example
With pulse sensor with PWM control function
(inch
H2O)
(inch
H2O)(Pa)
(Pa)
12
VDCV V
DC12
DC12
静圧
Static静圧
pressure
0.80.8 200
200
0.60.6 150
150
PWMデューティ
PWM
duty cycle
PWMデューティ
100%
100%
0.40.4 100
100
0.20.2 5050
50%
50%
0%
0%
00
00
3 3
(m(m
/min)
/min)
0.50.5 1.01.0 1.51.5 2.02.0 2.52.5
0 0 2020 4040 6060 8080 (CFM)
(CFM)
風量
Airflow
風量
112
(inch
H2O)
(Pa)
(inch
H2O)
(Pa)
1.01.0250
250
0.80.8200
200
0.60.6150
150
0.40.4100
100
PWM duty - Speed characteristics example
00
00
6000
1212V V
10.2
10.2V V
3 3
(m(m
/min)
/min)
風量
Airflow
風量
5600 min-1
4000
3000
2000
1000
2020 4040 6060 8080
Voltage:
12 VDC
電圧:DC12
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
5000
13.8
13.8V V
0.20.2 5050
00
(min-1)
PWMデューティ100%
PWMデューティ100%
PWM
duty cycle 100%
回転速度
Fan
speed
PWM duty cycle
静圧
Static静圧
pressure
9GV0812P4K03
(CFM)
(CFM)
1400 min-1
100 (%)
PWM
デューティサイクル
PWM
duty cycle
(inch
H2O)
(Pa)
(inch
H2O)
(Pa)
00
6060
4040
2020
00
50%
50%
0%
0%
2020
4040
風量
Airflow
風量
9GV0824P4K01
6060
100
0.2
50
10.2
10.2V V
6060
4040
00 00
3 3
/min)
(m(m
/min)
00
2020
4040
風量
Airflow
風量
6060
(inch H2O) (Pa)
24
VDC
DC24
V
0.8
PWM duty cycle
PWMデューティ
100%
50%
9GV0848P4K03
1.0
40
1.5
2.0
0.6
60
80
Airflow
風量
0.2
50
6000
27.6 V
5000
24 V
4000
150
100
(min-1)
20.4 V
Static静圧
pressure
0.4
100
0.2
0.5
1.0
40
2.0
60
風量
Airflow
(inch H2O) (Pa)
48
VDC
DC48
V
0.8
PWMデューティ
PWM duty cycle
100%
50%
50
1400 min-1
100 (%)
PWM
duty cycle
PWM
デューティサイクル
(CFM)
PWM
duty cycle 100%
PWMデューティ100%
200
0.6
150
0.4
100
(min-1)
48 V
50
4000
3000
2000
1000
1.0
40
1.5
60
風量
Airflow
2.0
2.5 (m3/min)
80
(CFM)
40
1.5
60
Airflow
風量
5600 min-1
5000
53 V
43 V
0.2
Voltage:
48 VDC
電圧:DC48
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
6000
0%
2.5 (m3/min)
80
5600 min-1
3000
1000
200
150
(CFM)
Voltage:
24 VDC
電圧:DC24
V
PWM
frequency: kHz
25 kHz
PWM周波数:25
(inch H2O) (Pa)
0.6
100 (%)
PWM
duty cycle 100%
PWMデューティ100%
200
0.4
2.5 (m3/min)
PWM duty cycle
0.8
2000
回転速度
Fan
speed
0.5
Static静圧
pressure
PWM
デューティサイクル
PWM
duty cycle
(CFM)
(CFM)
0%
4500 min-1
4000
-1
1000 1200 min
0.10.1
2020
Static静圧
pressure
Static静圧
pressure
0.4
8080
200
150
1212V V
(inch H2O) (Pa)
0.6
0.20.2
(CFM)
(CFM)
PWM duty cycle
0.8
0.30.3
Voltage:
12 VDC
電圧:DC12
V
PWM
frequency:kHz
25 kHz
PWM周波数:25
5000
13.8
13.8V V
0.40.4100
100
3 3
/min)
(m(m
/min)
00
6000
回転速度
Fan
speed
0.10.1
8080
静圧
Static静圧
pressure
静圧
Static静圧
pressure
0.20.2
PWMデューティ
PWMデューティ
PWM
duty cycle
100%
100%
(min-1)
PWM
duty cycle 100%
PWMデューティ100%
PWMデューティ100%
140
140
0.50.5120
120
0.40.4 100
100
0.30.3
(inch
H2O)
(Pa)
(inch
H2O)
(Pa)
12
VDC
DC12
V V
DC12
120
120
回転速度
Fan
speed
PWM duty cycle
2.0
2.5 (m3/min)
80
(CFM)
1500 min-1
100 (%)
PWM
デューティサイクル
PWM
duty cycle
113
DC Fan 80 mm sq.
9GV0812P4J03
DC
■ Dimensions (unit: mm)
(With ribs)
4-ø4.5±0.3
Mounting
取付用穴hole
+30
300 0
71.5±0.3
80±0.5
Lead wire
リード線
AWG26
UL 1007
(10)
(4)
71.5±0.3
(4)
25.2±0.5
80±0.5
Rotating
direction
回転方向
Airflow
direction
風吹出方向
■ Reference Dimensions of Mounting Holes and Vent Opening (unit: mm)
Inlet side, Outlet side
71.5±0.3
4-ø4.5
78.5
71.5±0.3
ø9
78.5
■ Options
Finger guards
page: p. 532
Model no.: 109-049E, 109-049H, 109-049C
Resin filter kits
Model no.: 109-1002G
page: p. 540
Model no.: 109-1002F13 (13PPI), 109-1002F20 (20PPI),
109-1002F30 (30PPI), 109-1002F40 (40PPI)
114
Resin finger guards
page: p. 539
很抱歉,暂时无法提供与“9GV0824P4K01”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格
- 1+158.79707
- 10+154.15234
- 25+148.63125
