9CR0612S001
9CR0612S001
    SANYODENKI
    FAN60X76MM12VDCDUALTACH
9CR0612S001 数据手册
Counter Rotating Fan 60 San Ace 60 51mm thick (CR type), 76mm thick (CRA type) 76mm thick (CR type) mm sq. ■ General Specifications With a pulse sensor Specifications for pulse sensors Refer to Page 309 ・Material …………………… Frame: Plastics (Flammability: UL94V-0), Impeller:Plastics (Flammability: UL94V-1) ・Expected Life …………… Varies for each model(L10:Survival rate:90% at 60℃ , rated voltage, and continuously run in a free air state) 䊝red 䊞black Sensor yellow Outlet 䊝orange 䊞gray Sensor purple ・Storage Temperature …−30℃ to +70℃(Non-condensing) ・Lead Wire ………………… Inlet 60×60×76mm 〔Mass:230g〕 CR type ■ Specifications Model No. Rated Voltage Operating Voltage Range Rated Current Rated Input [V] [V] [A] Rated Speed [min-1] [W] Inlet 9CR0612S001 9CR0612H001 Without Sensor 12 3.2 2.7 10.8 to 13.2 Available upon request for all the Pulse Sensor models above. Max. Air Flow [m³/min] [CFM] 2.26 1.98 80 70 Lock Sensor SPL Operating Temperature Expected Life [℃] [h] −10 to +60 40,000 Outlet 11,500 7,000 10,300 6,500 38.4 32.4 Max. Static Pressure [Pa] [inchH²O] [dB(A)] 550 450 2.21 1.81 66 64 Please inquire as the availability of these functions depend PWM Control on the model. ■ Dimensions(Unit : mm) Inlet side Outlet side 76±0.5 (4) 60±0.5 (4) 50±0.3 (10) 50±0.3 (10) +50 300 0 Lead Wire リード線 AWG24 UL1007 UL1007 AWG24 Rotating Direction 回転方向 Air Flow Direction 風吹出方向 ■ Reference dimension of mounting holes and vent opening(Unit : mm) Inlet side, Outlet side 59 50 ± 0.3 191 59 50 ± 0.3 4-φ4.5 29.7 62 .7 29.7 4-φ4.3±0.3 Mounting Hole 取付用穴 Rotating Direction 回転方向 60±0.5 +50 300 0 4-φ4.3±0.3 Mounting Hole 取付用穴 ■ Options(Unit : mm) Finger guards Resin finger guards Model:109-139E :109-139H Model:109-1003G Color Surface treatment :Nickel-chrome plating(silver) :Cation electropainting(black) Inlet side, Outlet side +1 4 0 4.3±0.3 60.5±1 6.5±0.5 50±0.3 4-2±0.5 4-φ4.3±0.3 Counter Rotating Fan 60mm 62 50±0.3 +1.5 75 ー0.5 60.5±1 φ1.6 φ1.6 φ53 φ70.7 Resin filter kits Model:109-1003F13(13PPI) ,109-1003F20(20PPI) :109-1003F30(30PPI) ,109-1003F40(40PPI) 9.5±0.5 64±1 4-φ4.3±0.3 50±0.3 64±1 50±0.3 4-φ10±0.5 4-2±0.5 ■ Air Flow - Static Pressure Characteristics S speed (inch H2O)(Pa) H speed (inch H2O)(Pa) 2.5 700 600 → Static Pressure → 静圧 → Static Pressure → 静圧 2.5 12V 2.0 1.5 500 10.8V 400 300 1.0 200 0.5 100 0 0 600 13.2V 0.5 1.0 1.5 2.0 2.5 3.0 (m3/min) 0 20 40 60 80 100 →→ Air風量 Flow 9CR0612S001 (CFM) 2.0 13.2V 500 12V 1.5 400 10.8V 300 1.0 200 0.5 0 100 0 0.5 1.0 1.5 2.0 2.5 (m3/min) 0 10 20 30 40 50 60 70 80 90(CFM) →→ Air風量 Flow 9CR0612H001 60mm 3.0 192
9CR0612S001 价格&库存
很抱歉,暂时无法提供与“9CR0612S001”相匹配的价格&库存,您可以联系我们找货
